View Full Version : Forced Induction
- can i move my MAF to after the blower?
- 737.7rwhp/669.5rwtq from 427 LS6 + GWP supercharger?
- Need Help ASAP: I have a few ?? on Vortech SuperCharger Install.
- Anyone want to buy my boost a pump?
- Making my car faster
- Tuned a Forced Induction car today (500rwhp)
- June GP of the Month - Vortech superchargers
- HELP!! my truck is slow
- How long did it take you to Install your Vortech SuperCharger with after cooler??
- some tuning tips for those with my setup
- Think I can
- Anyone with Stage 3 gwp kit
- inline pump install ?'s
- lt1 TT kit FS
- Paging Harlan...
- Need Cam Ideas for Incon TT
- first atap runs with new motor
- QTP has a good deal on arp bolts
- FS: Powerdyne 6# Supercharger kit 6# LS1
- Word is Incon is closed
- ATI or Vortech?
- link to pump voltage booster?
- Narrowed it down to 2 head gaskets..help
- Iron or aluminium?
- ATI LS1 Pulley Sizes and Advertised Boost?
- Motor is finally "right!!"
- ok to port maf with ati charger?
- White smoke coming out of exhaust
- Re-Clocking Incon Tilton Pump
- Very lean Idle with ATI SC
- whats a cam worth?
- exhaust question/opinions
- fuel pump voltage loss after long distance driving
- aluminum intake manifold?
- Propane injection kit has arrived...
- Time for a BIG blower (ATI F1 inside)
- rebuilding your pump.101
- Water/Alky Dyno Results
- pics of the Turbo Beast
- Alternatives to Vortech Programmer
- Need help selling my turbos
- How long will motor last with procharger?
- do your engine temps go up under boost?
- Also not in my kitchen, but the actuators showed up!
- could valve float cause loss of boost??
- Tuning Gurus step inside...
- Turbo / Supercharger Avatar?
- Not in my kitchen but even better
- Procharger Surge Problem HELP!!!
- Lt1 twin turbo kit FS
- Procharger questions
- What actuators work with an Incon kit
- Turbo manifolds...
- turbonetics and questions on a good turbo system for a 99z
- can i get rid of my extra injectors?
- This will only hurt a little bit
- ok, who has the .
- scavenge pump for sale
- Appearance mod for Supcharged cars, custom head plate>>
- GWP stage 2 1/4 mile times????
- Vortech smog questions?
- Fuel System ? IE Turbo kits
- Twin Turbo VS Supercharger
- Vortech Questions
- Do I need a puller to change the pulley on...
- Some FI questions
- INCON Stage 1 TWIN TURBO kit FOR SALE.
- Walbro 255lph inline question
- i blew out my dipstick ???
- gear ratios and turbo
- Y-pipe on Turbo
- So look what i got in my kitchen
- Curious on boost levels...
- k&n filtercharger or a lid with k&N
- Another link in the FI 422 Stroker chain
- vortech supercharger
- ? for Harlan or others who have custom tuned turbos @7 psi, 94 octane
- YES or NO?
- what would you pay for this ?
- T-76 Streetable
- 72lb injectors for sale
- Inline fuel pump?
- Turbo with Headers
- Check out the Group Purchase section for AUTOTAP deal!!
- Anyone run Heads Cam and Forced Induction?
- need a 1to1 fp regulator and a inline fuel pump
- injectors/fuel pump?
- low impedance injector converter
- Requirements for T-76 Turbo
- ? for all you turboed auto stalled cars
- FI and tuning questions
- cam & blower
- belt part # for t60 kit
- need help with alternator bracket
- need help pls. hp/tq with FI question
- ok, whats the best blower head gasket?
- Anyone using Turbo Tech T-76 Kit?
- How much Octane is TOO much?
- I want to upgrade my fuel system before I spray. Shopping list?
- incon, why isn't anyone answering
- water/alky tuning complete
- Isn't this sweet,
- ATI Questions
- ATI p1-SC
- 11.40 @ 120.23 MPH on 8 PSI (smaller Flash file)
- ATI 1/4 mile times.....
- alcohol/water injection
- SC with H/C car?
- help, to cam or not to cam
- where does all this vacuum tubing go??
- Stock fuel pump.. Whats it worth? How much can it flow and support.
- Powerdyne install: what to do with power steering cooler?
- Anyone using a Boost Reference Fuel Regulator ?
- Vent Tube
- Moderator Marker??
- Another pulley question... swap, etc
- Low boost question... pulley size to boost calc
- Where to hook boost gauge up at on 98 z28
- Adding FI to my 422
- Supercharger or Single Turbo:
- LS1 Motorsports Single Turbo TRACK RESULTS within....
- Turbo....?
- Black LS1 T/A? Custom Restrictor in intake that limited boost?
- 3" or 3.5" for 475rwhp blower car
- Lunati 382 rolling assembly. Is this good for forced induction?
- supercharging a zz4
- Vortech and ATI sale...
- Lets talk about a reliable mid 11 sec FI setup on DR's..
- ATI & Check Valve
- MAF location on ATI Setup... Can/Should you move it??
- 98 blown mustang gt.......white smoke out exaust, help me
- HELP! will this a/f gauge work???
- 5 PSI porcharger What eles do i need to go with it?
- Think I need to add another fuel pump
- boost, timing, octane?
- Anyone experience a fuel PSI drop while under boost from 70 to 55 PSI??
- Fuel PSI drops on boost??
- Keyway..
- Compression choice with a Vortech H/C.
- Sound Byte on a....
- Question about boost
- is there a way to calculate injector size?
- Building a supercharged motor from scratch.
- Need rubber connectors
- Supercharger for v6 camaro
- GWP Strokers puttin' out!
- Calling all Powerdyners. Need your help
- Single Turbo 404 CI LS1
- Interest in a Working Scavenge pump GP?
- SLP Engineering OE airbox lid for all f-cars
- For anyone with a turbo
- New! and Need help!!
- how did you hook up your fuel prese gauge?
- how much octane for how much boost?
- 9:1 and 12psi or 9.5:1 and 10psi?
- Instant Horsepower, just add water ;-)
- anyone with ati over 500hp on a dyno
- anyone use a fuel presure gauge as boost gauge?
- Should I even think of Supercharging?
- LS1 Vortech kit for sale
- LS1 Motorsports Single Turbo - 534rwhp / 687rwtq !
- need to find Turbo Tech website or number
- Supercharger question
- Speed Inc. is building a supercharged shop car
- Paging any 6# Powerdyner's with headers
- Okay guys, Please tell me what you think of the 6# Powerdyne kit. I need to know ASAP
- ATAP from night of 10.98 @ 126 MPH run
- HELP! how to tune a/f with fmu on wideband dyno?
- knock retard and timing question
- Good Lord.. you guys seen this?
- Stock Motor'd Vortech 9 lb dynos 500rwhp at Speed Inc!
- Which option is best....???
- Front Mounted Intercooler
- Walbro 340 In-Tank, what is new Fuel Pressure?
- best way to get better gas?
- BIG problems with GWP's service (not a flame just facts)
- Ok, I think it's been long enough..
- BEWARE ATI WITH FMU! ATI CUST service blows!
- Oil Blow By
- PLEASE help! fmu not working? no increase on fuel press.
- fabbing an intercooler setup...
- fuel system for 600 rwhp?
- boost question
- Magna charger
- Swapping head gasket (weeping a little)
- Kind of a Roll Call!!!
- Question on best Daily Diver, Bolt on,Turbo, or SC
- wtb: blower for a 98 ls1
- TT Lt1 motor and tranny in a 98 trans am.
- Most boost I can safely run with a stock engine??
- My h20/alky system, a few pics
- What cam for single turbo car?
- ATI problems...not LS1 but I need all the help I can get.
- Supercharger or TT?
- HIgh or Low sig. on PCM??
- Walbro 340 In-Tank for C5.. Requirements?
- HP & TQ peaks with ATI???
- just injectors/or will it flood car?
- FS- Turbo Tech Stage I...almost brand new:)
- How Difficult to Do My Own Pistons/Rods Swap??
- Stroked 427 ways... a jingle for ya!
- H/C Supercharged or Turbo Cars..
- How safe are these with FI?
- Paging Harlan
- Procharger life expectancy?
- Anyone using Alky inj ?
- need to win my friend over
- I had to let her go...
- SHE ALIVE
- need help with ATI install
- help! wb dyno run $150/ does scanmaster tell a/f ratio?
- LS1 Motorsports Single Turbo Initial Dyno Results !
- Rob Raymer Called me, initial Single Turbo Results!
- To drill, or not to drill
- Supercharger guys help me out
- Y2Khawk
- Harlan, I need your help.........
- Leaking connector on oil line
- Odd observation.. see inside.
- AFD Racing
- What do you blower guys use for plugs and wires?
- Info on ATI 4psi system and moving up to the 7 psi system, what is needed inside>>>
- question for anybody who has cut a key way in thier crank.
- does location affect boost reading??
- Walbro 340 pump noisy??
- A good A/F Ratio meter for my ATI
- cracked ringlands (pics)
- Guage install pics, instructions???
- Charged Air twin turbo kit?
- please move me on up to the #2 spot
- Help with autometer gauges!
- Twin turbo charger pics needed
- procharger purchase
- Please tell m the difference between Intercooled and Aftercooled
- Where does the water go?
- Too much compression???
- Anyone want to comment on 11psi with 4.10" ATI Pulley?
- T-Trim?
- what do heads and cam do for a FI motor?
- 222/232 Nice Blower Cam?
- ATI Airbox
- Single Turbo LS1's......
- 425 hp heads and cam -vs- 425 hp FI SOTP
- Cutting airbox & removing ram air baffle??
- where to get 6L block?
- Best pistons to get to 9:1?
- Vortech Warranty Transferrable?
- broke motor on boost
- Detonation?
