View Full Version : Forced Induction
- Holley efi fpr regulator question.
- 5.3 sbe pulled head found something I wasn't expecting
- 300zx Turbo 5.3 550-600rwhp
- Heavily debating turbo for my stock LS1 drag car
- Turbo question Precision 6870 verse Turbonetics 7575
- Mild 4.8 turbo build
- turbo cam
- 6.0 LQ9 with FItech EFI , wanting to add turbo....
- Why have a 90° bend on front bumper exit exhuast
- LQ4 turbo build
- 3" or 3.5" outlet on twin turbo FMC?
- LS IRS 8.47 @ 170.23 Toronto Motorsports Park
- My 2002 Twin Turbo Hoe
- boosted ls cylinder head questions....
- Does turbo mounting location make a difference?
- 6.0 aluminum block strength - 3.622 or 4.00 crank?
- Ultra4 Offroad Race Car - Turbo Help?
- pair of 58-61mm turbo discussion
- 99 Ford ranger 4wd with 5.3 and 4l60e turbo questions
- Boosting and changing map questions
- bent rods again
- Masterpower turbine housing fit on3 turbo?
- Low boost
- What turbo will fit where my PT76/75 .96ar is??
- Lq4 + th400 + s478 in 1994 Camaro - fuel system (need help)
- which turbo/s for jet boat engine build
- twin turbo collant lines help
- pcv question?? for you forced induction guys
- 4.8L versus 5.3L long block for turbo
- Speed density guys, how much does fueling change with weather?
- Building for turbo?
- Dont Miss SBF at ALL!
- Small mufflers
- 5.3 iron block turbo best budget pistons and rods?
- Lost my motor last night, so whats the recipe?
- SBC Intake Porting
- Want more boost
- LS3 Turbo/Cam Build
- Treadstone TRTT9: Can it fit 4th gen Camaro?
- What camshaft for supercharged LS2
- turbo drain
- ebay 88mm turbo
- F1-A supercharger & 402
- what injector for 1200hp
- Loose converter?
- GET IT WHILE ITS HERE! Huron Speed V1 T4 truck manifold kit
- Ls1 turbo build
- Questions on Turbocharging my 98 LS1
- Cam
- Fuel delivery ideas/thoughts
- 3 vs 4inch downpipe?
- Twin 366's with .91 AR too big for 6.0?
- swaped turbo silverado to e85 today. love it.
- ON3 76 5.3 sbe track results
- 77/83 from VS racing?
- PVC clearance
- Turbo tunes, how different can they be?
- Best stroker kit with strength and power
- Twin Turbo 69 Camaro Build
- PA racing crossmember. who uses on with turbo setup.
- Dump or keep
- 9.24 @ 150 sbe lq4, s480, th400
- SBE 5.3 with stock rod bolts
- Cathedral Shape Pipe
- D1sc procharger standard rotation (head unit only) for sale
- Bone stock 6.0 LQ4. - twin turbo size?
- Twin Turbo Manual Boost Control
- Which W/P and balancer?
- Is this a good boost cam?
- Pulling trigger on turbo/turbos today need advise
- Existing cam suitability for a TVS1900
- Hot side close to cooling fan
- who is running PTC 9.5"
- Sad day for my turbo TA!!
- Turbonetics 76mm any good?
- Physical size difference between PT76GTS, On3 7875, VS Racing 88/83
- New Build- 99 Formula/TA-LQ4-88/83-T56
- Volvo Wagon V2 First Dyno runs
- 98 Formula "Phoenix" Mp76, Sbe 6.0/t56
- 2.5 intercooler pipe
- Ebay head/main stud torq #'s
- Stock can + boost, pushrods?
- rear mount turbo
- Comp Cam lobes
- Aem 380lph
- rings for forced induction
- Supercharger with my setup?
- Choosing turbo for L92
- Skinnies / Fr8train / Red Dragon / Dat Maro...
- turbo, cam, head selection for 370, t400
- Double pinning....Procharger DI
- High Altitude Boosters Please Help
- 8 sec. 4.8l turbo lsx notch
- Oil feed/return setups
- Head Lifting or torched HG
- another cam question
- Alternator mounting
- 370 billet 85mm 8.87@150 on Pumpgas Upgrading to 25.3 going for 7s
- New charge piping setup
- 98 Camaro Z28 Turbo Build
- 5.3 Nova Best to date
- ? for people with Holley Hi rams
- Turbonetics turbos?
- Fresh boosted build first start!
- 383+s480+e85=962whp
- Turbo suggestion for twins
- Anyone have any experience with Thompson motorsports?
- turbo drain?
- Help diagnios Cylinder #4
- First turbo project - Am I dumb for wanting to do twin turbos?
- S475 question.
- Forged ls7 and boost questions
- Theory Question, Comp Wheel Flow
- on3 twin turbo 5.3 exhaust housing ??
- Fuel lines
- Whats the highest dyno number you have seen from a S475?
- Do i need to run dual BOV's?
- Opinions on twins for 410?
- ARP harmonic balancer bolt part# for F-body Procharger kit with 6 rib pulley
- swapping to turbo need some help
- S475 92 to 83 turbine size
- 5.3 ls turbo
- S480 Fox
- The Cannon!, 07 Canyon, L33, 88/83, th400 on Propane!
- How important is cam selection on this build?
- Gen IV 4.8 / Huron Speed Turbo Build!
- holley dominator startup issues on turbo lq4
- 10.5:1 and boost, street driven flex fuel LM7
- How much will it hold?
- what cam for this turbo setup
- Truck acc problems
- S475 or PT7675
- Building twin turbo on stock LQ4. Tips
- ARP Bolts and TCI Flexplate backing out
- On3 fbody non ac kit
- SBE Record falls
- thread of some weird wacky and wonderful Turbo LS cars i have tuned lately
- 2003 Cobra - 5.3, th400, s476 5.71@123
- New PB - 9.54 @ 147 - A few questions inside
- Procharger price increase coming 10-26-15
- 814 RWHP ECS 1500 kit and Jam cam 113 on 2015 1LE
- Picked up a Huron Speed V2 Twin Kit
- new build needing fuel system ideas.
- Winter build for the Buick
- 6.2 F1C build
- Lq4 lasted 3 days
- Gen IV 4.8/5.3 Still Boost Friendly?
- Seeking recommendations for rearmount camshaft
- ProCharger Corvette Direct Drive
- Monster Turbo Engine Porn
- what to expect s10 6.0 s400
- Optimising the Completed Build
- Need Expert input on boosted build
- Turbo choice and exhaust sizing help LS Datsun 240z
- Opinion on this setup
- 408 turbo size question
- 317 cnc heads
- GT4202 on LQ4? 1.15 or 1.25?
- 990hp,s484 dyno video!
- SBE LS3 S480 C5Z 5.6@125 1/8 mile
- [VR] Camaro ZL1 - Nitrous Outlet fed VR Stage V Package - Pics/Video/Results
- 6061 gasket question on 91mm 408
- Does anyone let their radiator fan(s) run 24/7
- Procharger for ls powered g body
- horizontally mounted intercooler?
- Have a few unanswered APS TT questions
- Novi 2200 sl
- Sidemount whipple supercharger
- Enough Vacuum???
- Looking MaggieTVS2300 Peak effieciency, pulley size
- Oil everywhere under WOT
- E85 injector size for LS3 TT 800rwhp
- Tom Nelson Shout out to Denmah
- Procharger impellers
- On3 alternator relocation kit
- 370ci, twin 61s, T56 dyno/track results
- Adding Supercharger - Remove Adj Fuel Pressure Regulator?
- aftermarket rods for 4.8 with big pin
- Ported Polished 806 heads w/ turbo?
- Too many mile for an A&A??
- Procharger vs Turbo impeller size
- Rear Mount Setup, Lots of advice / clarification needed
- LS2 with LS3 Heads LSA supercharger
- Feeler on bringing back the Huron Speed V1 Truck Manifold Turbo Kit
- future build with ideas
- Good source for copper head gaskets?
- Track update
- Why should I purchase a Heartbeat?
- Transplant bracketed for D1
- Exhaust Manifold Bolts for Truck Manifold Turbo Setup
- Crank question
- Turbo build from "spare" parts
- School me on meth injection
- Intake to TB seal? (pics)
- the "gt45 ebay turbo"??
- What cam PT88/4.8?
- Iron l33,twin Holset hx35s,800whp???
- katech 243's or 317s for boost
- Question about half mile and mile racing - with forced induction lol
- Volvo 242 - The frog
- 05 cts v turbo possibilities?
- Anyone ever swap BOV springs?
- Wtb; Procharger Lsx swap kit
- Need detailed info on fbody STS rear turbo
- Meth Injection Without Tune Gains
- $400 China “S366”
- S480 408 turbo question
- 8.29@163 sbe 4.8 f.i. billet 76mm notch
- 2000 ws6 370" billet s480 th400 9in e85 build
- ProCharger 1GU204-SCI CORVETTE C7 Z06 TUNER KIT P-1SC-1/F-2
- single or dual cutout for turbo setup
- How's my set up look so far? TT C5Z
- Use my converter from my bbc 454 on my LS turbo or trash it?
- Gain in swapping to headers for my application.
- Who knows innovate widebands? Can somebody guide me thru a problem with it?
- Supercharger and valve job
- Check Valve For PCV?
- What's better for small boost app 6.0 or 6.2
- Disappointing dyno numbers...were my expectations too high?
- Bosch 160 high Z
- Low Boost Issue
- Need the turbo cam gurus!
- Fast 92 or 102 for boost?
- bunch of turbo questions for build
- Procharged trans am front mount with stock fog light location possible?
- GT4094R twins?
- 370 + S484 + RPM T56 Build Thread
- Hotrod package 2.9L Whipple vs Magnuson TVS2300
- 81 Regal 5.3 PT7675 build-9.94@138.5mph
- Tiny Single Turbo?
- I hate it when......
- Where to buy old STS "PCV Solenoid Challupa"
- Boost leash?
- Boost spike, now noise/oil pressure problems).
- Boost LS1 Ford Crown Victoria
- installation pictures of mighty mouse catch can wanted.
- Fully stock + Turbo. want some input for springs and studs
- Turbo upgrade! TC70 to 6766 to small?
- went to the track and did'nt get shut down.
- 4l80e guys
- 71 Nova TT 6.0
- Huron Speed WEEKLY 98-02 Kit Bundle Specials
- Internal wastegate adapter?
- hotside close to hood?
- Twin turbo Chevelle - Forward and down truck manifolds with all accessories?
- Aisin Amr500 supercharger on a 5.3
- Bolt in MAF mount
- LS2 Turbo questions.
- Diamond 11510 pistons?
- LS3 max bore ???
