View Full Version : Forced Induction
- Intercooler pipe diameters
- Paging Brian Tooley (TEA)
- Ati Install
- Calling All Bluffs....QMP Turbo Kits For Sale
- Road Racing Drive System
- Posting My Progress...or not.
- Fuel sytems?
- Migrating over to truck coil setup for Red Dogg
- Incon users...questions
- BOV question?
- LS1, bad forced induction motor?
- PIc of ATI F1?
- Efficiency of the FI setups out there
- Anybody going to 1BadLS1 Racing grand opening Saturday?
- QMP T-63 turbo
- Best place to buy a belt?
- What Size twin turbos for Big Ci motors
- What makes a turbo car lope?
- Another Incon stg 1 kit 4 sale
- Anyone ever here of Matt Antonelli
- Update on Red Dogg
- Can the MAF be placed After the throttle body?
- 768rwhp QMP Formula...LOTS of Info, Methanol vs No Methanol Dyno Results
- Need FI help/advice!!
- Water/Alky Injection ... Got Questions
- Rob Raymers hi temp coating by????
- Incon TT Owners. Please help:(
- Technical Whipple question -MAF
- T88 system pics.
- Anyone had a reichart 3" ATI pulley they arent using.
- Supercharger Newbie Question
- D1SC or F1?
- wastegate to it's own muffler
- Alternator: What's required to move it up top?
- which ATI kit to choose.
- Correction factor different for turbo?
- 2-step instructions??
- Come join us at superchargerhelp.com
- Step inside to get your ATI 8 rib supercharger!
- What kind of dyno numbers?
- C5/Z06 ATI superchargers are now available with programming!
- ATI F1 for sale
- Best Place to buy T76
- Vortech superchargers available for the 2004 5.3L light truck and SUV
- Quick Procharger Question
- QMP order time?
- How did QMP get stock MAF to work with 750-800 rwhp & ls1edit???
- Working on homemade single t76 on my 408", will stock 6.0l work and n20 cam??
- Got my SC today!!
- Stainless or mild steel for headers...
- want to see if this is right(turbo question)
- water/alky injection ???
- Ever wish you could finance a S/C kit?
- 387 ALL Bore or Blown/Forged 347 ?
- talked to turbonetics about oil restrictors.
- procharger question
- Will Cartek H cam work in a SC application
- Crankcase breater question?
- Blown 427
- February Vortech supercharger sale!!!
- 2003 Z06 - Vortech/Superchips programming question
- can i use the heads i have...
- Can turbo log manifolds be built from mild steel?
- What EGT's should i look for in a boosted application??
- boost gauge help
- where to find a good tt ls1 set up
- ATI ProCharger on 427 10.5:1 compression
- MAF lb/min vs turbo efficency
- How much boost on this shortblock?
- MIke (blackls1ta) Steel ATI bracket,
- MAX Turbo BOOST with 93 Octane
- Have the "old" issues with FI been solved....?
- how much power will nos pick up on blower
- 7.85 MMS pulley and 3.85 ATI pulley FS, 160.00 shipped
- Rob Raymer
- Pro stock john...
- Best single turbo kit for ls1?
- AP-engineering is now.....
- 620/684 12psi, 91 octane, Stock Motor + 918's
- Best Price on Procharger Kit
- Installing P1se what do you edit?
- SMC alky w/ magnusson.. thoughts?
- Valve springs?
- How Will Floating Valves Affect Power?
- IDEA! ATI Twin Intercooler question need advice....
- SD-Concepts 8 rib spring tensioner setup. Kickin bootay so far.
- PSJ Which head gaskets?
- Adding LT headers and gutting the cats?
- good lord!
- Calibrating 42, 50 and bigger injectors...
- supercharger vs Turbo how much boost
- so everybody's seen this right?
- D-1SC better than nitrous?
- what is the hp limit for the stock fuel rails?
- A question about injectors for my set up...opinions please
- Are lunati pistons and rings any good?
- Cam reccomendations from Comp Cams for supercharged cars
- Need a wastegate?
- Turbo XS Type H BOV F/S
- Griffin Intercooler GP in the works!
- What clutch are u guys running?
- Has anybody stuffed a ATI d2r into a 4th gen. ...
- First Installment Of The AP-Engineering Camaro
- Has anyone built a home turbo kit?
- New head units from Procharger!
- is THIS the worlds quickest FI ls1 f body?
- Powerdine
- Rob R. what was the DIms on your intercooler for the Z
- ATI D1 replacement cone filter
- ATI boost question
- XE 268-14 cam, vortech s/c results
- Quench Area...need help determining Head Gasket Thickness
- So what are the FI records?
- what do you guys think of this intercooler
- How much fuel
- Oil for the turbo
- K-member Question for Incon Owners
- how crazy is the refridgerator intercooler idea
- GM Hotcam and ATI?
- Good Twin Turbo Kit for LS1????
- PSJ...Let's see those dyno sheets!
- anyone have a 3.2" ATI pulley laying around?
- On center T-76
- Looking for a D1SC 4.1-4.2" pulley
- Water to Air Intercoolers
- VORTECH owners can you tell me something?
- couple of questions for twin turbo guys
- I see that the QMP kit works wonders on a stock engine but what about a 414ci LS6?
- question about psi and hp
- Vortech V9 More info, still the same problem..
- What lowZ injector should I run?
- any negatives to running a 4" crank?
- anyone want to sell thier powerdyne setup?
- Procharge or Vortech or Twin Turbo
- F/I Newbie Question
- new TT kit builder
- how could i mount this intercooler?
- Supercharger Flow Maps
- Chicago based 900 rwhp F1 car??? who is this?
- How much is too much?
- Is there a relationship between IAT, EGT and detonation?
- rob raymer
- QMP Turbo Formula - 750rwhp / 830rwtq STOCK ENGINE
- help with maxed MAF!!
- Vortech YS/Spearco intercooler forsale
- problems with turbo set up
- Pro-M MAF discussion
- Anyone have a 3.4 inch pulley for a D1SC for sale?
- How much boost on 8.5:1 compression
- talking about pushing the stock motor till it dies, what else will you hurt?
- Quick head stud comparo
- 3.3L whipple vs D1sc for GTO
- ?s on low impedance box
- Difference between TO4E and TO4S housing?
- Incon & CAS kit for sale
- ATI head units (D1 in particular) - universal fit?
- Forced Induction T-shirt (LS1TECH)
- Anyone Running a TR224-114 with ATI Blower?
- Lunati 382 & vortech S/C
- Anyone know the step-up of ATI And Vortech blower?
- Anyone have contact info for Dave White in California?
- Anyone got a 4" or larger ATI pulley and/or an ATI head unit for sale?
- D1sc 630 Rwhp
- QMP Wants Your Advice on Race Prepping the Formula
- ATI steel 8 rib idler
- High boost low compression guys.. answer this survey
- turbotech parts
- Here we go....FI Short block for sale
- Pistons for Boost
- Looking to borrow/rent a crank pin kit
- Turbo Log Qustion
- Quick question regarding the ATI D1 and P1 kits
- Should I?
- Considering a blower ATI vs Vortech?
- RPM's on Blower Motor?
- Anybody running a crank trigger on a FAST
- Question about bottom end.
- 774/774 dyno sheet
- Is a BOV a necessity?
- rob raymer
- on a d-1sc kit will the intercoolers flow...
- Need help deciding on method for reducing CR
- 8 rib ATI kits - quick update
- Vortech Racing Bypass...
- My new engine combo
- anyone interested in my PT-88?
- Custom Blower/Turbo Setup help!
- Anyone want to take a guess on what my new motor's going to get?
- Anyone in need of 8 rib pulleys?
- What Air Box Lid Are You Guys Using...
- To blow or not to blow, that is the question....
- Chris@Diamond is now Chris@AP-Engineering
- How much HP will 60-1 hifi support?
- Harlan, Pro M 90 MM MAF?
- John Ryan - Please check your pm's
- PSJ I'm coming for you (on they dyno that is)
- PCV to Checkvalve
- Thank you Vortech!!!!!!!!!!!!
- Help with new fuel system.
- Survey says (dyno session #4)... 719.5rwhp!!!!!!
- High compression and boost
- Max Gasket Thickness for "O" Ringed Heads??
- Pre-Blower #'s
- 90mm LSX+Supercharger
- MIGHTYMOUSE 2004 Preview vid!
- Turbo 400 users - Inside Please!
- Low compression cam ?
- Blowby Fix?
- whats the max hp for 50# injectors????
- Tell me how much power I can make out of this.
- I Need HELP
- Survey says... 705rwhp!!!!!!!!!!!!!!!!!!!!!!!!!
- Venting ATI
- What do you guys think about my new project?
- Oil Question?
- F1R install
- ATI Surge Valve Question
- 224/224 581 on 112 LSA with 1.8:1 rockers with FI
- blow off valve question
- rob raymer
- Ported Heads with FI?
- Intercooler cores cheap
- Looking for actuators (sp?) for incon kit
- More info on the Vortech V9 that I can't get to work right
- Speed Inc and Pro Stock John, Im comin for you!!!
- Are there any quiet FI systems out there
- Volumetric Efficiency (VE), How do we calculate it???
- D1SC Cam?
- What exhaust are you running with your Turbo
- F/S ACCEL 48lb Injectors
- Got a quick question....
- Modified G-trim progress->
- Who here has the SMC Water/Alky Kit?
- Head gaskets for boost and 4.030 bore?
- Race gas question
- Heads
- Superchargers for sale?
- Identify these wastegates....
- Anyone been lifting heads?
- questions to ask when shopping for an intercooler???
- FI people please help me
- saying thanks
- dynoed tonight
- Help with T-76 specs
- Evaluate the MTI Stealth cams on their suitability for a TT car:
- blower bracket bolts
- 800 FlyWHP
- 1200 RWHP boosted LS6 motor...............
- Modifying a Turbo Tech kit?
- Please comment on some details of my Twin turbo LS-1.
