View Full Version : Forced Induction
- PROJECT RED ROCKET TUNING HAS STARTED! AES390, Twin turbo, 4l80e. PG21, Post 408! :)
- will be going s480... but what one?!?!
- Turbo setup 317's VS LS3's
- Forged 380" LS3 6 speed and twins sizing!
- GT35 T3 .63 ar turbine housing
- Turbocharged cam!
- Katech tensioner with relocated alternator
- BOV Operation?
- Switching from D1SC to F1R, need pulley help!
- Build thread: 5.3/twin 66mm/megasquirt3
- Anybody running Speeds TU2, turbo 5.3?
- Leaving power on the table with current cam?
- Which plug to start with" help"
- New engine and have service light on need help
- any need for a flew joint in dp?
- Purchased the new MS3PRO for my turbo 5.3!
- ***LMR 9 second CTS-V***
- **My WS6 vs. 2 UGR Lambo's,F1A C6, TT C6Z, 80mm/nitrous Supra**
- Car Craft LS cam test
- holley High ram or victor with elbow?
- procharger helical gear set
- LQ9 408 ci twin turbo in aus
- does anyone sell a 4inch IC core?
- gt4294 too small for 408???
- Best intake for square port heads???
- 4.8 or 5.3 for Budget GT45, 4L80e, MegaSquirt3 Build?
- LMR Slayer package 2013 GT500 makes 708rwhp
- 745-rwhp/729-rwtq '13 CTS-V Sedan | VR Heads+Cam/Pulleys/Nitrous!
- Boost and steam vents, 799 heads what to do
- ebay gt45 turbos?
- So will the OBX 1 3/4 up and forward headers fit?
- Blow off valve
- Finally got my Air intake lid on!!!!
- 370 10.1-10.5 cr
- replacement STS pump
- procharger bov help plz
- 4" Cutout Availability, might have to go 3.5"
- Keep destroying low cooling fan
- aquamist injection?
- NEW ATI 1GT313-SCI 10-12 Camaro Stage 11 Intercooled System with i-1
- What would cause failure
- 90 degree turn prior to TB, does it matter?
- Race season sale at Burkhart
- Adding boost gauge to brake booster hose
- Front Mount Ls1 Third Gen w/ Truck Mani Kit
- Need advice in engine choice
- Look for pt88/GT91 T4 .96a/r turbine housing
- 4.8 + 7675= 723whp
- HURON SPEED A/C TURBO KIT. Spring special
- Cylinder wall to valve clearance for turbo app
- questions about which boost controller and alky kit for tta
- For those of you going from Procharger to Turbo
- TT SN95 365 with a 6spd
- Leaking oil where the snout mates to the case. What do I reseal it with?
- Should I keep my turbo? Gt4202 or buy S480
- JGS Fire Ring
- Running Vac Lines Mike Norris CC & Maggie 112
- p600b on a gen3 motor
- eBay, ptk clone turbo kit?
- Does anyone make a S400/GT47 frame single kit w/ AC for Camaro/Firebirds?
- 760hp/745tq Stock Bottom LS1 (TC78 to PT7675)
- Maf problems
- Water cooled comp turbo.
- what heads to run with my maggie
- Huron Speed T6 LSx Fox Body Custom Turbo Kit
- WTB aster bracket or SDCE set up
- on3 70mm exhaust housing
- Anyone using an aluminum cell as their meth tank?
- Project Land Whale (Silverado Turbo Build)
- Intercooler questions
- procharged carbed SBC to turbo 5.3 nova (building right now GT45, MS3pro)
- Tick stage one or two turbo cam's
- Lets play guess the numbers!
- 99 Camaro SS 370-PT88 ***14 psi-10.21 at 144 1.8 60' with video***
- scavenging pump mounting
- ls9 or ls3 cam??
- Rearmount turbo question
- compression check
- Check out my Curves! vids and pics
- 2bar map wiring???
- Champion motors tvs 2300 dyno
- turbo kit on no tune..
- Spec me a cam please..
- Any Blow Through guys in here?
- Finally hit the dyno, but had issues
- Not quite forced injection but a little forced ejection
- New to this. Need help.
- Which Stall Converter are you guys in the 9's Using with your F/I setup?
- Lonnie's double pumper E85 max limit?
- just finished procharger build and only 3lb of boost
- How to cut silicone so it looks nice?
- Procharger support bracket
- Oil pressure warning.
- What is your alternator mounting setup? need help
- Featured on Dragzine and LSX TV
- Need to tame my turbo exhaust
- Featured on LSXTV: Lsx, 4L80, GT55-94: Street car WS6
- carb style intake fuel rail brackets
- using bov instead of wastegate
- New Turbo and hotside installed. Issues and resolving them...
- for use with any flip drive type system
- Bracing a heavy T6 turbo without solid motor mounts?
- LS6 and Nitrous
- FBody Twin Turbo Kits?!
- Ms4 with boost
- tail q bov flutter.
- Hands down...best coils on the market for 1,200+ RWHP........WHICH ONES..???
- BorgWarner Turbo.... *Sexiness Warning* (PG13)
- Anyone know where to get 1/2" NPT tap?
- XER lobes under boost? I want it to be stable...
- cam and lifters
- turbo 4.8 which heads??
- building a ls1 bottom end for boost, what to get
- Is Borg Warner s475 good for ls2
- Drivability of a F1A
- My turbo dream!
- Slight oil smoke (?) at idle... working the bugs out..
- stock 5.3 flexplate and th400 jw bellhousing ?
- ls1 single turbo kit
- v-banded truck manifolds on f-body to clear alt?
- What oil are you guys running in your turbo cars??
- 1986 Camaro - Caged, Forged 408, PRC237cc, Strange 9" 3.25, TH400, S475, MS2, MSD6010
- 2007-2011 l92 Supercharger interchangability
- Sloppy mechanics how to: broken exhaust manifold bolt removal *update 8/1/16
- Adjusting sdce tensioner ???
- 2000 degree coating on turbo hotside etc in here.
- anyone build a heavier car/truck (~5,000lbs)
- Better ET when you went to an auto?
- cxracing turbo kit ?
- Stock Bottom End LQ4 F1a
- New IRS 5th Gen Record... 8.47@168
- Twin turbo, do I need to run flex pipes on my downpipes(full exhuast)
- Will this work for an intercooler?
- ***LMR 427Lsx/F1X 2010 camaro makes 1165 through an auto!***
- TSP 233/239 R2 112 vs 224/226 114 cam for front mount.
- Fresh Turbo Blowing Oil Out of Exhaust
- About to start my head and cam swap.
- ***LMR 2013 GT500 makes 1106rwhp!!!***
- How Much Boost Will It Take?
- 68 c10 stock lq9 4l80
- Megasquirt 3 from EFI source engine dyno testing
- t70 vs t76
- Rear mount and headers ?
- Anybody use the newer LH6 5.3 with boost?
- VTC3 out the fender exhaust idle clip
- Anyone run 18psi on 93 octane stock shortblock?
- 374 LSX with blower 7.80 @ 181
- meth vs e85 cost wise?? for stock bottom end
- boosting an lq9 with stock bottom end
- Head studs
- 1985 6.0 turbo truck
- Not enough compression?
- TU1 cam for this setup? If not then what?
- '84 Cutlass 5.3L/4L80e LS9 Cammed Procharged Pro-Tourer
- 5.3 turbo need advice
- ***LMR CTS-VR1 on nitrous***
- How much boost/hp can a stock LS1 bottom end take?
- excessive oil leak?
- laggy tc78
- ATI Super Damper for High HP turbo ls1's??
- Full 3" turbo exhaust?
- Build me a budget motor!
- Whats a fair price?
- 05lq4+01 camaro computer and harness?
- Legit Lambo Hunting HAHA
- how much hp is left
- Old school fast 78 worth porting for F1C?
- F3 135 procharger too big?
- Comp oil less turbo
- sts turbo system 4th gen
- Turbo Selection Help
- power gain with 243 heads over 706
- Which radiator for standup and 16'' fan?
- Pro Comp Ebay Head Studs -- Warning
- Vengeance Racing | 611-rwhp/601-rwtq '11 CTS-V | VR Camshaft/Pulleys/Bolt-ons
- fuel line sizes
- Turbowerx pump issue
- cam advice
- Questions about 5.3 build
- Injecting water only?
- Magna Charger noise at idle
- looking for D1SC procharger kit for 2001 formula
- Blew up my Turbo 6.0
- Help Needed! power leveling off >:D
- PT88 370ci back pressure?
- wastegate sizing and placement?
- Waste gate and DP???
- what header bolts does everyone use
- Blown LS1 w/TFS215's what to do next?
- oil feed and oil pressure sources.
- JY 5.3 turbo build question
- Oil pump/Timing chain question
- How much boost can ls6 springs handle?
- 4.0 whipple
- Fun spin around the neighborhood with a quick blast in second.
- Msd 6010 box with high boost?
- L33 Alum 5.3 users
- LSA heads and 4 digit horsepower #'s
- 5.3 with MP112
- Boost needed for 500whp on stock LQ4
- How much boost can i run at 9.8:1 without meth injection on 93?
- 1075rwhp TT "Sleeper " Package from RPM
- Twin Turbo System for 1998-02 LS1 Camaros & Firebirds
- Methanol pre-blower in a TVS setup?
- How much boost with my mods to get 500-525rwhp?
- ***LMR GT500 makes 1000+HP on third pull of initial tuning session!***
- Turbo Clearances
- Turbo Firebird Wheelie HD Video
- F body, motor plate, stainless works headers
- turbo shaft play question?
- Intercooler pump flow testing results
- 5.3/317 heads/ls6springs/soon to be boosted Cam question
- what meth injection kit are you using
- turbo and turbo cam suggestions
- Billet S480 track results... Round 2. We cracked the 4.90's.
- s400 big hp?
- Shell URT 105 unleaded race gas
- E-85 vs 92 and meth am I leaving much on the table?
- Physical size of PT7675
- Trying to decide on a f1-a, f1-c, f1-r and fuel system
- Water/meth injection questions
- G8- Twins or Single Build
- Huron Speed Truck Manifold Turbo Kit PACKAGE SPECIAL! Turbo, WG, BOV, Oil Lines
- Finishing up new hotside install...
- twin gt45s 5.3 build
- Best intercooler setup for DD?
- 4.8 turbo combination?
- LQ9 Gt4202 whp estimate?
- Cog setup vs. Callies Crank.
- Procharger guys 8 rib pulley question
- 2001 Trans Am Procharger heating up at idle
- Another how much boost can my stock ls6 handle
- DIY ceramic coating
- ** Official Ninetres TT Camaro Airstrip Attack Video **
- '99 5.3 whp estimate?
- holley 12-1800 fuel pumps for FI
- 5.3 jeep comanche, on3 76mm
- using coolant temp sensor to pull timing
- 408 4l80 car ProCharger guys what gears and radiator are you using
- Standalone oil system
- s400 turbo question??
- borg warner s372 on gm 4.8 capabilities?
- PCV System w/ Boost and MAF Sensor?
- Has anybody used these
- Going Procharger, but wich one D1SC or F1A?
- pretty happy with my $600 5.3
- Looking for a 3 bar map for LS7 intake
- Turbo Size 398 - 1200rwhp & Stock PCM vs Holley Dominator
- Anyone know this '07 vette w/ KB sc?
- Ls6 intake dyno past 7500
