PDA
View Full Version : Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 [214] 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230
  1. Bolt on turbo kits?
  2. 15psi G-trim combo
  3. Raymer, BudH and Mighty Mouse make 2004 Boosted List
  4. Couple Blown LS1 questions
  5. ATI or RADIX
  6. More Pics of my custom 76 setup
  7. What is INTMD8's secret?????
  8. Headers and supercharger installation specials
  9. Tuned the car last night!!!
  10. Intake Manifold worth getting for blown car?
  11. Has anyone ran a FAST intake with boost yet?
  12. egt guage question
  13. Well tranny swwap is done and so is the engine
  14. Turbo guys, your going to LOVE this....
  15. F-body with roots/twin-screw??
  16. Good mods
  17. Another Emergeny
  18. New Message Board for All High Horsepower Vehicles
  19. Headers on SC ls1
  20. Scope the map
  21. FI before Heads
  22. Qustion for Rob Raymer
  23. Got in the Steel ATI bracket
  24. Is there a such thing as a cheap DIY supercharger kit?
  25. can a elec. bypass whipple be converted to mech. ?
  26. Need help deciding.
  27. WB/AFR/Methanol injection tuning questions
  28. C5 Dyno (408ci, Twin T66, AEM EMS)
  29. how much is acceptable pressure drop?
  30. Do I need FMU, inline fuel pump (vortech)
  31. waiting waiting waiting waiting waiting
  32. A few pics of my turbo project for you hardcore guys
  33. Explain this part "X" Explained! It's Running GOOD!!
  34. I know you get this all the time
  35. Forced Induction Videos, Dyno Graphs, and Timeslips...POST 'EM UP!
  36. G.T.O S/C kit=badA$$
  37. New pics of my T76 setup
  38. Want to get new heads
  39. New Pics Up...New Motor, Turbo, LSX Intake, etc.
  40. steel bracket # again I lost it
  41. Help, need input on O-rings
  42. Best blower cam?
  43. Stage I Incon - What is Max Boost?
  44. which valve springs for my QMP turbo (easy question)
  45. Incon installers....help
  46. Head gaskets/O-ringed heads
  47. Clutch for F/I
  48. Almost done, but its running!
  49. Turbo Technologies T-76 Questions
  50. alternate oil system...
  51. got the car back thurs. raced today.
  52. okay to trim the mount?
  53. Anyone else had to do this with there ATI?
  54. Finally got dyno and track #'s
  55. Interesting observation on non intercooled ATI
  56. Digital Boost Gauge..Who Has One?
  57. NE1 got pics of a CAS TT setup?
  58. Whats with magical #15 = psi?
  59. Home Built D1 System (pics)
  60. Take a Look at this $30 Turbo!
  61. QMP Logo Design Help Needed
  62. anybody supercharged and running slp headers
  63. Turbo at the backwheel?...
  64. I need emergency help
  65. cold air tuning MAF
  66. Anyone have pics of installed D-1SC's
  67. supercharger problems
  68. Flywheel!!!!!
  69. Corvette Magna-Charger on F-body?
  70. Precision PT63 turbo
  71. I blew a head gasket!!!
  72. Is it safe to say my MAF is maxed out?
  73. Morgon Motorsports ATI Crank Pulley FS
  74. ANY NEW PRO-M INFO? Need a MAF solution...
  75. Cam choice for S/C
  76. Want to make your own remote mount turbo kit?
  77. Turbo Systems
  78. Turbo Cam for 408 Iron block 6.0L
  79. PSJ intercooler mounting tabs.
  80. Fuel pressure
  81. thinking bout turbo....
  82. Newly installed ATI P1SC, only getting 2 psi
  83. Putting together parts list.
  84. a lil convo at school
  85. 8 rib conversion P1SC
  86. how about a stealth 2 cam?
  87. P-1SC at 7 psi and the stock A4....
  88. Video's Now Up of the QMP Turbo Formula
  89. I need an ATI pulley
  90. what size turbo's on LPE's TT427 package?
  91. What's a good compression for a blower?
  92. Cog dyno/boost results.........
  93. Vortech guys-come inside.
  94. WTB: Is it ok to buy used blower ?
  95. What are my Incon stage 1 Turbos worth ?
  96. News on ASP Cog Setup
  97. STS Turbo info?
  98. Who Dials In Whipples In S.ca.
  99. Beware of supercharged Mustang GTs!
  100. Incon TT kits...
  101. Best headers for a Vortech blower
  102. Has anyone swapped out the ATI bypass and seen a boost increase?
  103. Injector size input for blown set-up
  104. I'm gonna get blown!
  105. Underdrive pulley/ATI question
  106. Alchohol, propane, water, and other types of injection - Rules of thumb?
  107. Does a Rocker Ratio of 1.8, change the Cams LSA?
  108. Cam install question...dot to dot..is #1 on exhaust or compression
  109. Will this set up be a safe set up for my LS1?
  110. Need input on boost motor
  111. Would a fuel system for a turbo setup be good for others???
  112. ATI with spring loaded tensioner and boost referenced regulator install pics
  113. Procharger Question (filter location)
  114. D1SC Pro-Charger.... which heads cam and intake?
  115. Power, reliabilty, driveablity how?
  116. Boost Question
  117. Wiring a hi/low boost circuit?
  118. procharger finally installed
  119. 2002 powerdyne on a 1998
  120. Difference of SC to Turbo for HP per boost?
  121. Anyone with pics of an F1R on an LS1?
  122. I'm Thinking about buying a Supercharger...
  123. Track Times for QMP Turbo Formula!!!!!
  124. question if you installed your incon
  125. how much rwhp....
  126. Formula for RPM speed ATI ???
  127. QMP Formula Ready for the Track....
  128. Just got 101 lb injectors
  129. Y2KHawk any update on your car?
  130. Ati Procharger Tuning ?
  131. Head build up
  132. Cometic v. MLS
  133. Mild Steel vs. 304 SS
  134. turbos for 2002 ss camaro
  135. Reverse rotation question P1
  136. ATI/Procharger reccomendation & questions
  137. Using a BIG motor cam with turbos???
  138. Best cam for blower
  139. Ok how about Incon TT pics on or off car?
  140. How to build boost at the line?????
  141. cheapest place to buy ATI oil ???
  142. Which sponsor carries
  143. PSI Question
  144. BOV/Surge Valve for ATI
  145. what's going to break first?
  146. Belt issues
  147. Any pics of the Turbolocity Total Perf. Twin kit?
  148. Gauging Interest...
  149. Incon T/c
  150. What is the most popular S/C?
  151. Filter Question for the Turbo guys...
  152. Turbo shopping
  153. Turbo or SC
  154. Non sc procharger
  155. Opinions on Break In
  156. Magnacharger
  157. Few pics of the tt Camaro at shootout
  158. Who had S/C ENTER?
  159. TR230/224 with a D1
  160. Who all is using the QMP Kit (except RR of course)
  161. Where to buy piping for headers ?
  162. Anyone using the N-tercooler system?
  163. ATI F- series SC's
  164. Powerdyne for my 99 WS6??
  165. SLP 1.85 rockers.
  166. 12psi on 5.3ltr, head ?
  167. Not an LS1, but I need guidance...
  168. propane injection
  169. Anyone need some 50# injectors?
  170. Any news on the Pro M Maff solutions ?
  171. turbo question. correct me if im wrong.
  172. Designing a fuel system for Future FI
  173. ati pulley help
  174. C5 and Truck Magnuson superchargers on sale!
  175. Vortech Question
  176. Anyone with experience on the TT Street Kit?
  177. Did my heads lift or just a gasket?
  178. oil for turbo?
  179. Not sure which route to take on the engine?
  180. What should I expect?
  181. ATI P-1SC question...
  182. L-19 head stud GP
  183. if I have wastegates do I need a Blow off valve
  184. 11 PSI and Detination + stock bottom end not good
  185. can someone please pm me the link....
  186. Spark plug gap for blower
  187. L19 head studs, who wants them???
  188. How to keep heads down?
  189. Turbo or supercharge... which road to follow?
  190. QMP Formula Meets Its' End Tonight.....
  191. what is a vortech balancer worth?
  192. any got a pic of an ss hood cut for a vortech
  193. What Will i get for HP out These Parts
  194. Turbo Cam? For LT1, single turbo? Help!
  195. Another Newbie Question
  196. Need crank pinning tool help
  197. Stock displacement or stroker for turbocharger?
  198. ATI intercooler with Vortech Supercharger
  199. Ati Cog Setup Is Here Part 2
  200. turbo cam?
  201. Turbo Tech Kit questions?
  202. Who could help me out here.......
  203. ac and what else?
  204. I need HELP, BAD!!!!!
  205. FI tech questions....
  206. Turbotech Kit for sale
  207. does sikora sell bracket braces?
  208. rob raymer
  209. Coating internal engine parts....
  210. Need ideas on cam specs, H/C LS1 to swap into a v6 car
  211. Boosted Cars are not very Quick!!!!
  212. My brain hurts...
  213. ATI P-1SC-1 w/ stock engine/rearend?
  214. how is your pcv set up?
  215. Oil line and the pan issues
  216. Forced induction and ported heads?
  217. Upgraded my turbo before I got the car running
  218. Things are gettin ugly
  219. Several Turbo questions.
  220. how long did it take to get your procharger
  221. How Much Boost
  222. Turbo Question
  223. Newbie looking to build 800+ HP engine needs help
  224. STS updates?
  225. S/C car blown tranny
  226. Happy birthday Kurt Urban
  227. Sale On All Superchargers
  228. Turbos Roller barring or not That is the question
  229. Anyone need a good turbo cam?
  230. supercharger cam
  231. LS1 Hotcam and S/C will it help or hurt me?
  232. Need to make an injector decision for my fuel setup.....opinions please....
  233. Fast intake and Forced Induction
  234. VE vs Psi
  235. Turbo Tech Street kit vs. ATI Procharger vs Others ??? Opinions wanted on street car.
  236. Where can I get a 4.5 inch muffler
  237. Turbo feed and return lines
  238. Efficiency of the FI setups out there II (Final Results)
  239. Need advice with new combo
  240. TurboTech Race KIT Final Results
  241. Were schould I look for a good twin turbo kits?
  242. Twin SC?????
  243. Who is running low impedance injectors & converter box with stock PCM?
  244. first 6 pulls on ttech race system
  245. why do ls1 heads need porting so much compared to 5.0 based cars?
  246. Help!!!!!!
  247. Critique my FI plan :)
  248. ProCharger PSC-1 Fbody kit up for sale
  249. Oddball crank pinning question
  250. twin turbo tuning question
