View Full Version : Forced Induction
- after examining plugs......
- FI question
- Venting wastegate to atmosphere?
- Help me decide pleass...N20 v. FI
- Oh boy
- Fmic
- What displacement with twin T-61's
- Using 2 stock GN turbos...
- turbo sizing question for an LS1 street car
- Building a motor for FI
- Lt1 STS turbo kit questions?
- Some new pics of my Twin Turbo chevelle!!
- Using a AIR pump to help relieve crankcase pressure?
- Help with Turbo and Intercooler Sizing on 370ci
- boost on stock injectors?
- tti street kit crossover
- My STS Setup tuning results and STS review
- 12 Rib Pulley Question: Procharger
- Which 6.0 manifolds
- Thinking FI
- What kind of horsepower/torque should I expect??
- supercharger or turbo
- OK so ive got this miss..........
- '04 GTO automatic with ATI ProCharger
- i need some help
- turbo kit what do i want help me please
- simple question
- in case anyone is interested in Speed inc fuel rails...pics etc
- Can I remove this?
- boost.... how much???
- How many people running low 10's/high 9's on M6?
- twin turbo boost levels
- Some dyno numbers from GroundZero's turbo kit
- need help on turbo sizing
- More progress, 9.1 @151
- anybody tried a blanket on there STS turbo?
- oil pan pics
- Any info on Flat mount FMIC?
- My Twin Turbo Terror goes deeper into 8s
- Two WG springs which to use??
- intercooler ?
- Who is running STS
- Sizing a BOV and WG
- Any updates from Hi-Flo??
- Supercharger Talk?!?!?!?!
- Forced induction for road racing
- turbo kits?
- cost of fi setup?
- Yet another blower cam query.
- Turbo size / cubic inch?
- Building custom STS turbo system
- *engine pics*...when you play with fire...
- STS Turbo Car up on ebay
- Turbo guys- Your cams overlap?
- good spark plugs for fi?
- To gasket or not? What do you guys think about exhaust gaskets on turbo setups?
- planning FI...... recommendations?
- Supercharging a v6
- What next, FI or 402 stroker? Help me weigh my options please
- Anyone looking for an alternato relocation bracket...
- Those of you using the 8 rib setup.
- Anyone tried to fit an alternator with truck manifolds?
- Procharger Pulley Specs?
- Another STS in the 11's
- OBX intercoolers
- GTO twin turbo system pic - C6 twin turbo system in the pipe line
- What is the limit of the stock PCM?
- what size engine and turbo?
- Single Gt42 Truck Manifold Build...(pics)
- When is the aluminum block
- I know this has been discussed a lot but what is the best PCV method?
- Car breaking up on top end
- 16 Spal or LT1 Radiator?
- 600 RWHP with a magnacharger possible
- DIY turbo kits(whos doing them?)
- TTI Kit oil return problem?????
- exhaust charge pipe and outlet size.
- 8:1 procharger high boost cam specs?
- Are you happy with your Turbo/Supercharged setup?
- procharger seals
- a few quick pics
- Finally put all up pics up in a gallery
- Finally went 9's with vid
- Latest Track Times for TTi T-76
- how much boost and power will my 6.0 hold ?
- Turbo or not??
- i am positive i wil be chewed out for such a dumb question
- 408 compression
- STS dyno @8.8psi, 100 octane, 140,000 stock motor
- custom turbo kit
- Reroute of STS thru K-member
- Boost control INSTALL???????
- My Twins are finally up and running!!
- Innovate Wide Band With Gauge --- $249!!!!!
- Bigger piping on a STS
- How much boost can the 6.0
- need some advice
- Twin Turbo Z28 runs 6.9 in 1/8th at 117mph
- Magnacharger vs Whipple
- Racegate installation?
- T04R Question
- My C5 Twin Turbo kit for sale!!
- Need expert opinion on twin turbo LT1 plans!
- Ready, Set, Ignition
- where can I find out more about trims
- Procharger question for 120k mile ls1
- MAF (+ piping) rubbing pulleys/rad. fan.. any suggestion?
- TTI Kit. Lots of smoke out the exhaust HELP
- Procharger fitment
- Redline Motorsports Turbo
- Which Bottom End for Boost?
- Spending lots of $$$ on turbo, Some advice would be GREAT
- just placed an order for PTK hot parts.
- Intercooling question for TA's
- Vortech pulley change
- Powerdyne on a 408??
- procharger radiator support
- Do you have to cut the hood for a Vortech aftercooled S/C??
- Who has the biggest Twin Turbos?
- 11.2:1 too much compression for boost?
- Supercharger differences
- what size twins for 370?
- Help picking a turbo
- Has anyone ran more then 30 lbs of boost?
- How much boost?
- help me pick another cam
- A & A or SDCE Which one is better?
- FFHP T76 single turbo Corvette kit
- Help finding Coupler
- How to do FMIC mounting of firebirds??
- updated pics of my twinturbo build
- Anyone have an ATI 16" shroud?
- Should the coating on my pistons be burning off???
- Received my sheetmetal intake
- Meziere & SDCE
- compcams suggested this cam for turbo...doesnt seem right?
- FI safe tune
- Z06 cam with 6lb boost??
- over boost
- ATTENTION: Hurricane Rita & LS1TECH
- BOB at Exotic Performance Plus
- help/info on ATI 8-rib LS1 setup need instructions or PIC's
- Wideband O2 sensor placement on STS turbo car
- Speed Inc. shop car video
- Supercharger vs Stall
- My STS install pics so far....
- SDCE and Shims
- A/F problem with F.I
- 6.0 block for FI applications
- I didn't even know how to search for this one!
- Guys running Carb intake or plan on running
- A2W guys, what size thank, what kind of pump, and what kind of heat exchanger
- Alternative to Thunder Shootout --- Need Input
- edlebrock shorty's
- Sweet, made the cover of High Performance Pontiac
- 370 or 408
- Methanol Injection with a supercharger
- Finally started my project!
- Possible or not??
- STS Turbo on Camaro SS being installed at Exotic Performance Plus
- Where to get AN Lines?
- g-body supercharger help
- 408 and twin T04's ?
- What block for supercharger?
- What does "forged" mean?
- pusher fan help?
- Questions about possible STS setup..
- STS kit questions
- ATI Damper and belts
- Hi-Flo Turbo Strip Killer Progress Pics
- Opinions on painting intercooler.
- 8 rib belts
- New best last night, 9.78 @ 137.6
- magnacharger/nitrous
- STS guys with FMIC HELP
- NEW COMPLETE STS kits found.. Too good to be true??
- Dual Exhaust STS
- Pic: GM's TT Vortec 4200 I-6
- Check out these Vortech T trim numbers
- STS dyno on my stock 140,000 motor yesterday
- fresh short block or no
- hotparts done, ready to install
- Would these headers work/last with a big single (shortie headers -vs- cast manifolds)
- who all has made their own alky/meth kits?
- Meth/alcohol idea
- Did i smoke a ring or something else???
- D1SC on C6 8 pounds of boost
- Header Materials for Turbos
- Build up advice for STS TURBO
- Vacuum line question
- 10's Finally!
- Question About STS set-up
- New goodies go on next month
- Need advice on engine build up for lt1 -sts kit
- Stenod car won X/M at MIR LS1Tech race?
- Sts Turbo Instal Pics
- Got it running good then.......
- D1 cam
- biggest cam with d1 procharger
- Help me choose a cam
- Update on PTK kit
- Another ATI Super Damper question
- PTK, how stable are they?
- Flushing a FMIC
- New worst times today, yay!! not
- mbc
- Bore Vs. Stroke?
- Finished the PTK install
- Bypass Q
- T04r Hp?
- Everything for FI
- Retain Power steering with flipped truck manifolds?
- Turbo 6 Domestics allowed in Nopi......
- Vortech WHAT
- ATI, Vortech and Magnuson Supercharger Specials!
- Maybe someone will make a single GTO kit?
- lt1 turbo
- ATI damper question
- how about a PUBLIC vote, me in Extreme Mod
- Good cam for S/C
- Anybody up for some grudge matches at the EFI Nats?
- Alcohol pro's con's?????
- Why did my A/F spike?
- Hi Flo Turbo system becomes Precision Turbo dealer
- Low compression STS 408 with 10lbs with a problem
- o2 and maf confusion
- What compression
- car not making boost ??
- LS2 valve springs under boost?
- Meth Reservoir... where?
- 4.8L Kenny Bell supercharger
- Breaking in my engine...info please
- how critical is honing w/torque plates on FI engines? vs stock block machining?
- PVC and FI
- Turbo news 9/15
- Picture of GroundZero Motorsports new turbo kits
- supercharger or turbo?
- Today's September 15th...
- Harrop M112 supercharger kit testing results.
- sts guys exhaust setup?
- Turbo Timers
- who carries aluminum piping for fab work?
- What size pulley?
- Which turbo are you guys using?
- Gt42-76 Turbo Came
- Which single turbo for 650HP?
- STS Owners who have Dynoed ====>
- 6.0 heads
- critique my set up
- Part number for 1/2'' Ls1 headstuds
