View Full Version : Forced Induction
- spark plug choice for boost
- S13 LQ4 S400 Glide Holley HP EFI
- supercharged 408 ci ws6
- Got a stock 2000 ls1 short block, now comes the fun part
- ls3 valves with boost?
- what stall should i use??????
- Can anyone ID this pulley?
- Sorry in advance Mods, Need a couple replacement rods! Lunati LTE1
- Water/Meth before MAF
- turbo guys.. what kind of oil you running???
- 1.85 rockers on a ZO6 cam?
- Front mount turbo kit
- 98 Camaro Z28 Twin Turbo 427 ERL LS2 Pics
- My new build....stock bottom end with a s480
- TSP 2.5 heads and 30 PSI
- does anybody have a comparison dyno graph on switching a/r housings
- Head studs?
- my log manifold for lsx sonoma.
- Vacuum ??????
- New custom TT setup - Power?
- Need gauge placement help!!
- procharger bracket questions
- how many run ngk 2668
- blowthrough 10:1 5.3 on alky
- What turbos/intercoolers???? (What are you guys running)
- 142mph on junkyard 5.3 .....
- Hi newbie here with questions.
- fbody maggie kit?????
- PT88 too big for a 5.3?
- help on turbo setup
- Precision Turbo's Car of the Month -- MINE!!
- F1R Procharger Kit Pro's & Con's, Tips with installation???
- Is 383 kit or 383 stroker better
- Help finding the right 5"+ v-band clamp
- need help deciding after dyno
- Oil pressure sender placement
- LSX Block Power Limit
- Opportunity to buy a used D1SC Procharger
- whatcha guys think? silverado build
- Need a opinion on the setup
- LS3 heads?
- how to package a turbo/supercharger for safe shipping
- FI with ss3600 stall
- Ps1c, heads and cam help
- Help from pro charger guys
- ebay/ptk vband gaskets
- 19lbs boost, looks like I popped the motor
- for a basic turbo setup..
- Cam for Procharger
- LS1 manifold vs LS6 with boost
- Which head gaskets??
- my kytp turbo build
- Best DYNAMIC compression ratio for boosted street car?
- best gears for a turbo m6?
- Which turbo-s
- Water cooled turbo guys, how to run lines/hoses??
- Anyone know if Forced Inductions made it through the storms ok?
- SC, LT & off Ypipe, stock pipes to Magnafow
- Another plug question (Little wordy)..up in the air on this combo
- Ebay Turbo Kits... Your Thoughts????
- What boost is more fun to drive?
- Few ?? about ls3/lsa heads and fi cam choice.
- A/W intercooler
- New intercooler
- Precision Turbo Size Comparison Pics.
- Help car not making power?
- Advice from high hp sts owners
- What kind of bolts to get for t4 turbo and tial wastegate
- cam/timing chain installation turbo related
- Thoughts of a well flowing exhaust for TT78 setup?
- Good or Bad.Which turbo company to go with???
- Tourquer V2 cam and boost? EPP? Brute Speed?
- Safe 93 octane effective compression ratio for 10.7:1 LSX w/procharger?
- PT88 turbo LS6 wont pull past 5k, w/dyno graph
- droping boost procharger
- vortech v9g ??
- L92 cam choice with turbo
- 422 LSX w/ Twin PT76's on KYTP kit
- question regarding boost and juice
- LME 408 looking for a turbo kit or ideas for a 91mm...
- ls1 intake vs ls6 intake in boosted application
- BOV & WG Suggestions for 410 & 101mm turbo
- Physical Size and Turbine Wheels: 7675, PT80, PT88
- dragonforce (and no not the band)
- Water/Meth on intercooled Magnacharger?
- CBR F2 System First Install
- Your best e.t. guess, 71Nova, LS2, F1A
- Precision Turbos new website!
- HPS TBSS Procharged 402 VIDEO!!!
- C6 Z06 3 go pro views 1 run
- Anyone running the LSX-LS7 Heads with boost?
- Boost/Vacuum source for multiple feeds.
- Turbo headers (start your build the right way)
- Any one use a condensor from another car?
- Apex Bov on Procharger? Any ideas?
- can i use this cam
- P1SC Belt noise, etc...
- Switched to SDCE, which blower pulley now?
- Crank Pulley Pinning Question
- Ok to drive car with turbo mounted and cold side unhooked?
- Magnusen SC from a 2000 burb, can it be made to work with an Fbody?
- I love my car
- low comp turbo build
- 2000+hp fuel system with Bosh 044 & MP-4703.. pic's
- need opinion on 6.0 block with misssing alternator holes/procharger
- **Any pics of vertical stock radiator**
- finally started working on my d1 ws6
- Experienced FI guys, please choose 3 guages for my F1-A setup..
- Supercharged set up
- 2 1/4" turbo crossover
- Pushrod length recommendation
- 5.3l turbo cam
- Whats a good TB for a Twin Screw
- 92 Z28 Turbo Build and keeping all comforts..and then some
- Piston options for my LQ4
- Using motor mount for ground
- 6.0 / t6 ?
- Pro charger parts list
- My BUDGET single front mount build thread.
- Procharger boost gauge, why so inexpensive?
- Project: yeloGoat (picture heavy)
- BOV question
- Anyone ditch hood latch for hood pins
- MS4 cam, good for boost?
- Procharger guys
- Air to water heat exchanger Question!
- 454 inches of turbocharged badness
- Opinions on this turbo for my 5.3...BW S372
- This thing desreves it's own thread..... Billet Mozez Intake and Valve Covers
- 317 heads ?
- buy procharger oil?
- Getting rid of my Precision 76gts... Looking at a GT91!
- 3 bar & meth
- turbo recommendation for daily driver.
- Steel vs. Aluminum piping/intercoolers
- alternator bracket on the driver side
- 98-02 Formula dual-FMIC placement
- sts kit build thoughts
- Question about downpipe...
- What power are you making with your 5.3, and how much boost did it take?
- Magnafuel pump suporting 2000hp.. wich one?
- Victor Jn vs Plo-Flo XP
- Bet you have never seen this before : CNG Powered Callaway SS Bi-Fuel!!
- help with worn cam bearings, going to be turbo'd
- Help With Belt Drive Fuel Pump & Balancer
- Is it better to part out a car or sell it whole?
- 1998 Formula turbo/ supercharger?
- Stock Waterpump Limits?
- Think I hurt a bearing again
- Video of 7.89@180 run C6 Z06 Corvette at Atlanta LSX series
- Good fitting Turbo Blanket for Precision T76GTS? ...tight clearance.
- Pusher or Puller Fans???
- which supercharger to get....
- What victor jr. Should i buy?
- .96 or 1.15 a/r housing behind 355 LT1?
- Boost controller
- Exhaust sounds terrible.....
- 65 gmc panel truck twin turbo pics
- ATI Damper for only 225? Blem*** Pics Added!***
- Car Wont Rev Past 6000
- Going SD...what is needed???
- Stock LS3 Heads\Cubes, AUTO, Procharger D1, NO METH = 888rwhp 827tq
- AES 390 Boosted Heads??
- Radiator moved forward with ac guys, which fans??
- How much boost are you guys with big brass ones running on the stock block?
- Quieting the Whine
- Smoke coming out valve cover breathers
- Which blower cam?
- FI catch can, which is best?
- Link to a lil video of my turbo trans am.....
- turbo timing
- Forcedinduction
- LME Motor dynoed and shipped
- 5.3 in an 86 IROC
- 19201805 valve material (lsx L92)
- Custom $1000 rearmount
- Conversion from LS3 to LS9 help needed!!
- How much timing are you using to spool larger turbos
- 6.0L coils vs 5.7L coils
- What boost level do I have?
- pro charger super damper
- how must boost can i run?
- new pb 9.12@148
- GTO fans in replacement of ls1?
- What kinda power without an ic or meth
- Need to decide today.ls1,or lq9.forged 18psi
- a lil help plz
- Stock block DD reliability- Take a guess how long it will last
- Lets see some exhaust setups! (front mount turbo)
- School me a little on Superchargers...
- Stock ls2 block reliability??
- New IRS Record 7.89
- wastegate question/concern
- Got my FTI Poweglide installed
- Trap speed with 9-10 psi
- Wastegate mounting?
- Autometer cable help?
- Alternator Relocation Bracket
- LS9 Cam
- Ford TB TPS
- blower cam choice!
- procharger pulley questions
- STS TURBO too LOUD...BEST MUFFLER TO KEEP FLOW.
- venting wastegate to atmosphere or to downpipe?
- 4.040 x4.00 piston
- 10.5:1 compression 408 with s91 turbo
- Gauge Question?
- Eboost in TA air vent
- Spal 12" puller fan question for turbo car..
- Why is this kit do cheap? Is this Garbage?
- Just bought a d1sc kit..... Parts needed for install
- Looking for P1sc head unit
- ls9 cam stock heads 4.8 pushrod length
- Is this blower cam ok?
- timing chain
- turbo and oil pressure ?
- I need YOUR advice!
- For those who are running a veritcal Griffin
- Exhaust smells like sulfur after WOT pull?
- Cooling setup for procharger
- 5.3L Turbo Motor with 6.0L heads...Gasket Suggestions???
- Anyone ever ran an F1A on an AES boost motor?
- FMIC on a LT1 Trans Am
- Our TT kit is FINALLY done.....
- Pro charger install
- Maggie Questions
- What pistons and cam?
- what rings to go with
- meth tank placement
- LT1 boost cam for 76mm?
- How would you do it? 408 w/STS C5
- Is partial boost possible at part throttle with a Procharger?
- Intercooler size
- Procharger belt size
- going boost...do i keep my wiper fluid reservoir?
- How reliable is the P1sc-1 procharger?
- APS turbo upgrade
- LS1 Bogging with Procharger
- ati crank pin
- **Another 700+rwhp ZR1 Corvette from Late Model Racecraft**
- P1sc install. Coolant pipe conflict with Procharger pipe conflict
- problem with procharger breaking belt
- 69 Camaro single turbo I'm working on.
- Oil drip from rear exhaust.
- Ebay/PTK Kit Owners What Size V-Band clamp on Driver Side Oil Pan Pipe Connection?
- PCV - Valley pan options
- car smoking a little... what do you guys think?
- 370 + F1c @ 900-1000hp.... double pin crank? Key?
- Piecing together procharger set up. Any help appreciated
- Turbo Sizing for Rear Mount
