PDA
View Full Version : Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 [181] 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230
  1. leaning toward turbo
  2. Procharger Possibly For Sale
  3. Vortech YSi Help?
  4. supercharger choice
  5. supercharger choice
  6. BAP, which one? MDS or KB?
  7. Charge cooling (Magnacharger) where to start
  8. GMHTP Feb cover car
  9. Help with piping
  10. What if an LS7 met with...
  11. Belt size for 3.6" pulley D1-SC,
  12. downpipe ?s
  13. Procharger
  14. Enough BS,lets see dyno #s for ebay intercooled cars
  15. What is going on in this pic
  16. How much noise does a cogged belt add?
  17. More dyno #'s ,, 14.5 psi
  18. Problems with turbo kit STS need help
  19. Cam Suggestions Please
  20. Getting My T-trim Rebuilt
  21. Behind Pass. Seat Intercoolers
  22. 11.30 1/4 mile at 142mph - Our twin turbo C5 Z06
  23. D1SC vs T-Trim
  24. time for the next step. i need help picking out a turbo/turbos for 1600+fwhp
  25. what happened to HI-Flo?
  26. Sts Question
  27. BOV placement
  28. My new turbo is in the shop
  29. STS Question
  30. cleaned maf = running rich??
  31. How many are running a cooler Stat like 160/180 degree
  32. procharger guys with twin intercoolers/small IC fans
  33. my 3rd gen TT build
  34. anyone in ca to fab twin turbo headers
  35. c6 kit to c5
  36. Post up dyno numbers with stock motor and turbos.
  37. Help choosing new turbo...
  38. welding to the oil pan
  39. best bang for the buck for S.C.
  40. Any problems spraying meth through the MAF?
  41. Motor is finally done! Bling Bling pics...
  42. Temperature in headers VS crossover pipe
  43. STS turbocharged Heat Shield???
  44. T3 vs T4 (Turbine)
  45. new sts turbo kit
  46. SMIC possibility on trans am?
  47. caterham / super7 idea - few simple ls1 questions
  48. Need help...
  49. D1SC Belt problem too small?
  50. Wastegate or Pullies???
  51. What size injectors do i need for 8-13 psi???
  52. What is a safe amount of boost
  53. Silicone Vacuum Hose Diameter
  54. Turbo Oil Feed?
  55. How much Boost Before Belt Slip Occurs?
  56. another sts question regarding the exhaust
  57. need help w/sts kit (ls1)
  58. check out my shirt!
  59. surge valve for p1sc
  60. Engine test fit
  61. guys w/ alternator relocation.....
  62. Need pics of single turbo builds....
  63. Turboooooo
  64. Milling LQ9 heads?
  65. Parts for procharger
  66. STS Spool time
  67. Building my OWN Procharger KIT
  68. Which plugs to use and at what gap?
  69. Few questions on a D1SC..please help
  70. Cool turbo SS build-up at Icon Autosports..
  71. Hey, what do you guys think?
  72. All in one gauge you FI might be interested in
  73. Quick turbo selection question
  74. Ordering fans for powerdyne tmrw..couple questions
  75. Electric Fans HELP
  76. Supercharger maintenance?
  77. Phamspeed install after 8 months of waiting
  78. Turbonetics Suggestions...
  79. looking for turbo kits for c5
  80. upgrading fuel system
  81. Roots Type Blower
  82. Which first? H/C or SC
  83. Apexi avc-r boost controller help...
  84. Happy New Years To Fi
  85. PT 2, My truck manifold turbo set up is done and running!
  86. Injector size for turbo?
  87. Powerdyne belt slip, Help Again!!!!!
  88. Which Boost Controller To Buy for STS
  89. GMR or GroundZero kit?
  90. GMR SPEED TT pics inside
  91. CAR WONT IDLE! wtf ! Help PLZ!
  92. sts turbo what plugs to use?
  93. STS Turbos: Cat or no cat
  94. where to get threaded air temp sensor??
  95. question revisited...15psi doubles the N/A hp, right?
  96. Turbo Screens...who else runs one?
  97. 5.3 truck with custom GT42 results
  98. Air temp sensor on turbo
  99. Cheapest turbo kit
  100. quick tapping question
  101. 994rwhp 863rwtq
  102. What's better for FI LS1, Hi CC Low DCR or Low CC Hi DCR?
  103. Pros and cons of 2.5" crossover vs 3"
  104. Is anyone running aftermarket Fuel Rails with there FI setup?
  105. for the experienced sts lovers
  106. where do you buy rubber elbows?
  107. D1SC is it TOO much
  108. I love my LT1
  109. Which head( 241, 243, 035) for stock bottom end and 8-9 lb P1SC
  110. Which Procharger
  111. turbo oil line size?? dumb question?
  112. Who fabricates turbo manifolds?
  113. what to get
  114. Can I tap my oil pan here or not really?
  115. bs3 boost controller - any information?
  116. Twin Turbo LS1... What injectors?
  117. What AFR Target for FI + Nitrous?
  118. Boost Gauage Directions
  119. Any DIY'ers lookin for a turbo?
  120. The Lux-0-Barge from Down under
  121. Supercharger...Should I go with 2.5" or 3" TD's?
  122. Get rid of the PCV or not??
  123. can I reuse my Cometic gaskets?
  124. Low boost in lower gears
  125. STS rear turbo kit & Catback ???
  126. Need intercooler pics
  127. Is installing the Procharger also a good time to install a pulley?
  128. (Plugs for STS kit)
  129. install instructions for Incon twin turbo kit...
  130. Question about setting up oil lines for custom rear mount single turbo.
  131. Another FI head question
  132. procharger boys running FMIC
  133. A&A vortech kit + 02 Z06?
  134. Turbo Header Fabrication
  135. Pros and Cons of these superchargers?
  136. Question regarding setup
  137. Has anyone made there own custom turbo setup ?
  138. 3.3 Whipple
  139. 851 rwhp mustang dyno vid
  140. what rear on a turbo car
  141. Turbo charger
  142. ~ 2006 Boosted List ~
  143. Turbo charger
  144. radiator? for a turbo car
  145. 6.0 manfold stud removal and bolt replacement
  146. Where to get turbine parts??
  147. What Fuel Filter with a Supercharger?
  148. What type oil are you using?
  149. heads 4 FI
  150. sts kit (rust on the turbo)
  151. Good idea or bad, coating turbo from sts
  152. Anyone having trouble with their methanol pumps?
  153. Oil feed line restrictor
  154. how long should a open dp be?
  155. Please give me your opinion on this turbo...
  156. 9 second and faster turbo a3/a3 cars...
  157. soon to be FI LS1 owner
  158. Custom truck manifold hot parts for sale
  159. Looking for an oiling system for a custom rear mount set up, please help!!
  160. Would I see more rwhp - Gear change
  161. need help with 2 bar hardware
  162. Who has the advantage?
  163. What head gasket to go with for HIGH boost???
  164. Help me pick a mild blower cam
  165. Different Air Filter Set-Up for Vortech?
  166. Superchargers
  167. what comes with procharger kit
  168. homemade turbo system
  169. Lets say I wanted to push 12+ psi on my P-1....
  170. Just bought STS
  171. How to deal with oil coming out of driverside breather filter
  172. Piston compression height
  173. Part # For Procharger K&N Filter...
  174. guaging interest ATI P1sc stage 2 kit *NEW*
  175. LT1 Turbo Question
  176. merry christmas
  177. Pulleys for F1R
  178. How many guys running 396-398 CID?
  179. I Got Turbos For Christmas!!!!
  180. Max boost on a stock 5.3...
  181. 98 firebird v6 supercharger
  182. SLP flow pac (help a new member out)
  183. CAS bin file
  184. whats the max hp on a build but not exotic motor combo
  185. Compression height
  186. Heat shields
  187. STS issue! Please help!
  188. Higher ratio rockers w/ FI setup?
  189. Hot cam with turbocharger??
  190. What heads and cam on a Z06 with a blower
  191. Poweryne belt slipping, HELP!!
  192. Collector test fit pics
  193. First runs on the 408 /T88 combo
  194. Blower?
  195. What Blow off Valve is everyone using
  196. KAOS' Custom truck manifold turbo setup, pic inside
  197. Corvette vs. Truck manifolds...
  198. Big problems with Pro charger setup!
  199. ls6 pcv conver. and AMW can????????
  200. To all you motor heads!
  201. mechanical or electrical boost guage
  202. (STS Kit) Best Blow off valve for LS1
  203. Custom intercooler
  204. Headers
  205. Collectors are finished
  206. Rear Gearing for a turbo app.
  207. opinion on ls1 powerdyne 6psi system??
  208. Final pics
  209. POLL: TT kit for the F-Body
  210. where to find a 500 cubic inch small block ls2?
  211. turbo gauges
  212. alum intake elbows
  213. Boosting questions
  214. Requesting some help. How to shape oil dipstick tube around turbo?
  215. Procharger P1 on a stroker #'s????
  216. What Crank Pulley are you running with Procharger...
  217. Who makes a good single turbo kit?(non STS)
  218. D1SC and passing emissions?
  219. f13 112 and P1SC kit
  220. Now boosted!
  221. Is this for real?
  222. Vortech SC sound clip?
  223. Intake Question about new GMHT Mag.
  224. daily driver
  225. Looking for Pics!
  226. Where can I get a T6 turbo flange?
  227. All business...That's all I can say!!
  228. Super or Turbo?
  229. 398 iron block + turbos at 8.5 PSI + M6 = fun
  230. highest comp. for FI and 105 octane
  231. Leaky Vortech aftercooler
  232. What FMU should I use?
  233. Procharger, intercooled, 8 psi on STOCK A4 FBody : RWHP????
  234. My FI setup!
  235. STS Kit In Finally (need help)
  236. what changes would i need to make? STS
  237. Copying the Incon TT kit
  238. Truck Manifolds And Stock K Member?
  239. Can ANYONE Get Me An Incon Part #
  240. gas mileage with supercharger?
  241. I love Pic's like this.....
  242. bought shortblock instead of building myself
  243. C5 turbo manifolds??
  244. LS1 Kenne Belle ETA?
  245. Anybody make intake plate adapters for Superchargers?
  246. Installation of a EGT A/F Guage XD-1 Kit...
  247. Boosted M6 guys.
  248. Twin Scew on an F-body?
  249. twin kit ?s
  250. Phamspeed Install
