View Full Version : Forced Induction
- Aussie Hornet Twin 366 on 5.3 Rearmount
- Best Block, head, cam, etc... combination for boost info source
- Oil less turbos
- Possible using OE manifolds on Silverado
- Bottom end rebuild questions
- ON3 Install...STS based Rear mount to N20 to ON3 Front Mount
- Oil pressure/turbo feed
- Looking for good interlocking 3" Vbands.... What brand/Where?
- Passing NY emissions inspection with Holley efi
- Torque app vs gauges
- JE pistons and boost ?
- Magnafuel 4303 750 blowing fuses
- 2006 TBSS TVS2300 Project
- 02 WS6 Vortech Supercharger NEED HELP!
- Holley dual solenoid boost control without C02
- in-line PCV valve
- Knock sensors on dominator?
- Procharger BOV vacuum
- brake 12 volt wire
- Just switched to e85 setup.. now Erratic fuel pressure
- Oil level sensor hole used as drain ?
- 1968 Camaro with mild LS1, Terminator X and turbo log.
- Does anyone use Kemso Fuel Pumps?
- Need Turbo Spec help?
- Twin turbo drain pipe ideas
- Windshield washer bottle w/front mount
- Whats everyones winter upgrades? Loving this stock block stuff
- LSA 408 Marine Build: HP Guestimates
- Water pump recomendations
- Will this cam/gear make 28psi w/85mm+spray?
- Rear end ratio for boost
- Huron Speed v1 truck manifold highest hp
- Cubic inches and Boost Correlation
- 5364 heads, inconel exhaust valves, or what for supercharged engine.
- Up forward facing headers
- Relocation mount for mini alternator
- Twin sizing for built 6.0L
- F1A folks come on in
- Gen 4 5.3 flat top pistons and boost ?’s
- SLP Loudmouth with CME and supercharger.
- 5.3l 7875 turbo build ** wastegate questions**
- tsp turbo stage 3 cam
- Throttle body options?
- Precision Turbo....PT8884.....T5 flange......anyone use it yet?
- 5.3 twin turbo BMW
- Gear ratios for FI
- Converter for boost....billet lockup or no?
- terminator x tune setup
- Air filter sizing
- What head gaskets for 1/2 head studded 4 bolt block?
- No intercooler spool times
- Boost Juice???
- Which TT kit to buy
- 10% off plus FREE Shipping on all PRECISION Turbo items at Huron Speed
- Huron Speed 19'-20' Group Purchase ~ BIGGEST SALE OF THE YEAR! ~
- T4 or T6 flange
- What intake now? For boost
- To good not to share...zl1 in the 8’s
- Fuel pumps
- Oil Check Valve
- Headgasket Choices? (boost)
- Rear mount turbo efficiency
- Help with 6.0 turbo lq4 build before black Friday
- Need help with supercharger pulley to fit alternator belt
- LQ4, LQ9, 5.3, What to build for turbo setup???
- Got it running!
- Post turbo flex pipe?
- TVS2300 Or TVS2650 In A Ws6? Cathedral Port Heads
- Adding LSA Super to 09' Colorado V8 E67
- P1SC question
- Turbo bottom end
- Huron twink kit plug issue
- Exhaust port size
- steel mesh screen instead of filter .
- Procharger - Stiff throttle pedal under acceleration
- Exciting new supercharger hits the market
- Whipple 2.9L intercooler fittings
- Squash Still In Business?
- LSA swap questions to people who have done it.
- More power and reliability
- Turbo, how much air should be moving thru the charge pipe?
- Who´s running dual in tank 525´s on E85.
- Can't decide which route to go engine wise...
- Blueprint LS3 style heads for boost. PS8015
- After 16 years of hibernation.
- At last....AT LAST!! (Track vid)
- Single downpipe into dual pipe advice please
- Recommendations on good floor shifter for 4l80
- Hot side pipe size
- T4 Flange to SCH10 2in
- Huron Speed 6th Annual Turbo Kit GROUP PURCHASE Announced! ~11/29~ Black Friday
- Torqstorm Pontiac G8 Gt/GXP PPV Supercharger kit
- Vacuum/boost lines - tee, splitter, manifold?
- Need help with turbo/ wastegate placement
- air flow sensor distance
- Does Procharger dual intercooled system affect AC?
- E85 winter preparation
- 5.3 S369sxe w/Tial 1.02 AR housing Spool?
- Procharger twin 4.5s or FMIC
- Let's Build Another Turbo Engine!
- Capizzi goes 4.50@155 SBE
- 5.3 twin turbo m6 a.r
- Best aftermarket ecu for turbo 2011 Ls 6.0
- Valve size for Magnuson 2300?
- SBE 6.2 goes 7.90@172
- Bosch 210 injector with adapters ( help)
- Camshaft theory question with D1SC
- 4th Gen Roots?
- SBE 6.0 Race Gas + meth boost limits
- Flipped manifolds and plug wires
- What do I need to complete my swap
- Procharger Head Unit Impeller slack/play (Solved)
- Boost controller recommendations
- low profile turbo air filter
- Check Valve for Catch Can Clean Side
- Quick turbo 5.3 sbe question
- Sizing Log Style Header
- Turbo guys running Terminator X
- Where to get budget rings n bearings 6.0
- Drive belt damage
- 4.8 twin turbo, any advice?
- Ebay Turbo setup recipe
- 7875 vs gen 2 7875 size difference?
- Holley or ms3 gold box??
- need some advice and help
- .96AR ve 1.25AR?
- Porting of the Turbo?
- LSA Build on LQ4/LS3
- 63 Chev Truck I tune
- What heads?
- Turbo LS forward facing manifolds with A/C
- Twin turbo 5.3 SBE suggestions
- Cylinder Head Help
- Waste Gate Measurement and size?
- After torrential rain, wont run & AFR maxed at 35.6
- Limits of 241 heads, ls6 intake, and stock throttle body
- Which direction does a crossover pipe expand?
- SBE 5.3 Goes 8.02 @ 169
- 76mm vs 88mm
- Spoke with tuner
- 88mm s400 install
- Which turbo GTX5518r or twin S364.5 built 5.3?
- Twin 7875c .81 hot side a/r on 5.3 ?
- Safe boost for stock lower end ls1
- Torqamp Electric Supercharger
- Metal in the oil follow up
- dyno number seem right?
- 5.3 Turbo w/glide rear gears
- First Boosted Build
- Recommended reading for turbo knowledge
- Turbo Spool Time Increase
- Help me get on track?
- Turbo 5.3 full exhaust too quiet?!
- 7875 spool up on 6.0
- Twin s372
- Racecraft k member fitment
- LS1 Built for boost
- vsr 80mm vs 85mm for 5.3
- Turbo Ws6. 8 year saga 😂
- What's holding me back?????
- Few Huron Speed Kits available w/ VSRacing components
- Tips on keeping my 4 bolt trickflow heads down at 1200rwhp?
- stock 5.7 aps twin cam upgrade
- Boosting Stuff Discussion
- Anyone know the size of the Magnuson 2300 ports?
- Destroke 6.0 8000rpm for twin turbo setup
- Info on 408 turbo sizing
- Cam Choice
- Turbo 5.3
- LS1 max compression for 91 octane and 8lbs of boost?
- HP Tuner Horsepower PID Help
- Turbine wheel sizing
- How I turbo'd my 1973 Camaro 6.0L
- High compression and boost?
- Huron Speed Fox body T4 turbo kit fire sale *big savings, check this out!*
- Holley Smart coils
- Dynamic Compression Questions
- Little Bit Of Tuning Help Needed :(
- Sloppy stage 2 and stock intake
- 1200whp Tick vs btr cam? on Twin 76 LQ4
- Scavenge Pump Mount Location - Huronspeed V3 Kit - 99 T/A
- Switching from pull through to blow through effect tune
- Cut-off point when aftermarket blocks become necessary
- Huron Speed *New* APS Style Twin Kit Group Purchase Intro Sale!
- Aster bracket tensioner
- Swap my manifold?
- Meth Kit bad distribution on truck manifold
- *NEW Kit from Huron Speed* APS Style Twin Kit retains all creature comforts!
- Methanol injection
- Buy LS2 Turbo Headers?
- For the sbe warriors
- Pieced together kit
- Varex muffler?
- Opinions on 418 capability
- Help me pick new rear gears
- Haters bring on the hate....
- Holley Terminator X and running motor on alky/methanol/M1 ?
- Fastest spooling turbo for sub 4000rpm use
- China boosted 102 Dbw TB
- Help with rear-mount turbo sizing
- Build the 5.3 or go ls3?
- Intake tubing?
- Ceramic coat, wrap or both?
- Dragy times
- What's The Smallest Pulley You Have Run With an ATI 6 Rib?
- So Many "STAGE 2" cams...Help me pick one..
- Which turbo
- 98 ls1 turbo in 1971 camaro
- Can I turn the boost up?
- Edelbrock Supercharger
- T4 S480 on a on3 hot side .yes it fits! with a normal fbody radiator !
- 383 LS1 T56 S480 Rear Gearing
- Ran wrong valve seals and developed metal shavings
- My F.I. People in Florida
- How to download Sloppy Mechanics file from tune cabinet?
- Borg S480SXE vs S488SXE on a T56 346ci street car
- Sniper race version on turbo 5.3
- Moderator For This Sub Forum?
- 2 step timing advance /retard boost building Holley terminator x
- 9.56 135mph with JY 4.8 with cast 74mm
- Thoughts on Straub/Yates headgaskets?
- Holley system and emissions?
- Complete LSA Motor Swap into Escalade?
- Battling high IAT's after 10% overdrive pulley added
- Pd blower ice tank?
- Holley Digital Dash Mount Prototype
- Turbo build question
- Magnuson TVS 2650 vs Edlebrock 2650 vs LT5 2650 vs Whipple 2.9L Compared in One Place
- Maxing our map sensor
- LQ4 Turbo C3 Corvette Build
- '12 yukon denali, dart 427, Rossler 4l80/AWD, S48X, E85
- 6.0 gen2 7875 hotside
- What size pulley to reach ~15 psi on D1?
- Can I get 480-500ish rwhp on 92 oct pump gas?
- 2.3L Whipple
- Cutting out under WOT in boost areas
- 388 s400-91 Build (lifter and rocker question)
- paralyzed and Stock Block 5.3 still making progress...more fun than my x275 car was
- Belt tension specification LSA?
- VS 8375+stock cam 4.8?
- GenIV FFV: External FRP for under 10PSI?
- Turbo headers
- I think my intercooler pump is bad.
- IAT k type thermocouple how far inside the charge pipe?
- ASI 3 Row Radiator
- Griptech
- Ls3 boost and fast or stock intake
- Sebring Silver Build
- My first build thread turbo Holden Ute down under 76/82 E85 manual
- S197 5.3 TH400 turbo build
