View Full Version : Forced Induction
- Compression ratio ?
- Vortech Super Sale - beat the price increase!
- Methanal Injection
- FI cam FS cheap
- Which gear to run with my new Twin Turbo setup??
- i think ive finalized my turbo setup
- No more spray for me;mod list
- pics
- How much will 4lbs raise my compression?
- CAS owners chime in
- advise on gears???
- Where to go from here?
- Turbo or Supercharger
- What size injectors with blower?
- So the season is done for me, Goal of 10s wasn't accomplished.
- Looking For..... Jz 97 Ss 1500
- New STS kit
- Z06 Cam
- How much meth do you use???
- Black oil before and after my vortech?
- STS turbo on LT1
- STS turbo boost What compression???
- Turbo sputter
- Wastegate V-band or flange?
- looking for a turbo or supercharger
- Where to get good priced air/liquid coolers?
- Few races then Waste Gate falls off? WTF
- Need help with intercooler piping!
- Not getting the boost I should be getting.
- Just got my kit today... have a few questions on injectors, plugs and pump.
- 38mm Tial BOV for sale Brand New
- Boost and a stock Mass Air
- fmic what size piping?
- Anybody want to sell there CAS Intercooler?
- PSJ- New info on the Eaton SC for F'ers???
- Anyone Using The Carb Manifold With EFI and Turbo/SC?
- Anyone moved tha AC to the driver side of the engine?
- STS Kit and My H/C LS1
- intake selection
- does altitude affect times with a turbo inducted car?
- go with cometic or felpro 1074
- Clog or 8 rib
- ATI Superdampner Unerdrive or not?
- Cams and Turbos
- Turbo or no?
- Need some advice??
- wastegate and BOV size
- Rear mount oiling...advice requested
- vortech G-trim supercharger
- Still trying to decide Custom Turbo VS nitrous...
- What size of turbo for 408 LS1?
- 02 C5 with Magnuson - Before / After With LG Motorsports G5X-B cam
- 02 C5 with Magnuson/G5X-B - before and after with QTP Headers
- What boost control should I go with for under $400???
- vortech supercharger oilfeed
- What needs to be modified to fit XX trim Vortech
- Any prob running a TurboXS BOV with a D1SC
- How many you turbo guys running these parts?...
- SpeedInc VortechYSI Eliminator kit & cam 4 sale $4300
- Procharger Idler Pulley
- Aussies are taking over ls1's? :p
- $7000 a good price for Vortech installed?
- Ordering Blower tommorow
- Turbo with carburetor - info needed
- Incon Turbo cam ?
- 96' vette LT1
- What's the best Turbo setup for the money
- Twin turbo setup: oil feed/return for turbos, where and how?
- Props to Vortech from a ATI Guy
- C6 Teaser
- Who all has removed EVAP?
- Road Race with FI setup?
- Ford 8-rib Idlers?
- OBX on TTI Street Kit ?
- Anyone doing the LS2 mani swap yet?
- Looking to up the boost in my JGP
- 4.3 - 4.5" Ultra-grip pulley
- Any pic for a STS intercooled?
- G-trim supercharger 4sale
- Need recommendation for Titanium?
- 8 rib PS pullies
- TT LS6 sandrail
- 7 sec rumor! Its true!!!!!!!!!
- FI videos...
- What kind of blower speed are you guys seeing...
- Took a ride in an STS car
- Good N/A engines with FI?
- Where can I get parts to assemble...
- Does anyone have any STS Turbo track results?
- Twin high flow intercooler worth the upgrade?
- Vid of my custom turbo setup...
- 90mm lsx worthwhile over 78mm LSX on turbo car?
- D1SC on the way ...
- anyone interested in twin T-44's?
- Vortech maintenance? Can u email me a manual?
- Intercooler question
- what's a good cam
- cam question
- ATI steel J-bracket
- eldelbrock heads
- 26 Mpg!!!
- Nasty performance Turbo manifolds?
- ATI SDCE 3.7 8 rib s/c pulley f/s $70
- FS: GT45, OBX intercooler, Turbo blanket, Misc.
- 80mm Pro-M on a 408 with 18psi?
- anyone had thier vortech head apart?
- STS under glass
- has anyone seen this before????
- Question for SDConcept users?
- Speed Inc. Shop Car 427ci, GT88 preliminary dyno results
- FI on a C5......
- Light The Afterburner With An STS Turbo (poster)!
- Pics of my fuel system supporting the Vortech YSi setup
- Worried about getting a STS kit because of Water?
- which one of these turbo setups are enough to support power to a built 408?
- Boost referenced regulators
- ATI + 370 + Synergy Motorsports =
- STS stock injectors maxed out at 5500 rpm?
- STS on pump gas?
- Can someone explain to me why headers are no good for STS kits? (STS Dealers!)
- compression ratio
- Fmu?
- BOV vs Surge Valve.
- Fuel system for ATI?
- Upper radiator support?
- Intercooler/Turbo Tubing
- Header material choices...experts inside
- Intake for IF
- STS GTO and SS Camaro at the proving grounds, SEMA
- Twin C5 setup from Pro Turbo Kits
- STS BASIC vs ATI P1SC?
- What kind of boost gauge are you running?
- What is a 76mm Turbo head unit worth barly used
- Don't these intercoolers sound small??
- Twin Screw blower on the way for the LS1
- SC vs Turbo at ½ throttle daily driving
- ATI D-1SC Prereqs?
- Talk to me about STS Turbos
- Where to buy individual parts for procharger
- F/S: ATI Crank Pin Kit
- Whos running Inconel exhaust valves instead of stainless?
- Most Power Made With Unported 317 Heads W/turbo?
- Truck manifolds backwards?
- Water/alky?
- can i run an FMIC with an underdash A/W???
- ATI install Dallas & South Texas?
- Belt Length, D1SC, 3.4" Pulley
- New motor, STS kit on and running...
- Vortech Question
- F1 Header Query
- turbo selection
- Orange Spark plugs
- CAS Twin Turbo Stg 2 or T76 Tuner kit???
- Help me out
- Update on the ATI 8 rib setup.
- Why is this car running such high duty cycles?
- Pics of LS1 F-Body with roots style blower mounted
- Vortech and cold starts
- Anyone know gains from a ported TB on a blower car?
- Blowing out the fire at high RPMs?
- Silicone adapter hose
- Why don't turbos make boost when they aren't under load?
- 7 Second Response!
- ASP 8-rib setup...?
- Supercharger pulley size question..
- sts turbo dyno #'s
- Electronics guys, switch question
- Mileage
- Which intake with Vortech?
- Now that Ive decided on ATI.. which one?
- so what heads are you running?
- ATI Twin IC's on an STS setup.
- What superchargers are equal to a 88/98 hybrid turbo?
- Does Any Body Have Flow #'s On A 90mm Lsx Intake
- Converter for my YS Trim LT1?
- Paging SD Concepts: Are they a member?
- S/C question
- Anyone thinking about building a single t88 system to KEEP a/c?
- Cost of intercooler piping
- Another D1-SC,FMIC VID
- Pic of LS1 + Vortech YSi + Strut Bar Brace
- Kenne Bell Vette
- 6.0L heads vs. stock...
- What to gain goign form 1 3/4 to 1 7/8 headers, anyone back to back?
- Plenum Volume?
- Superchargers: Chain Drive
- charger for VN?
- How much HP can you make W/ TTi T76?
- SC tune?
- Hey MightyMouse, what....
- Superchargers + belt slippage
- PUSHED 15PSI through ATI twins
- FMIC People...
- ATI D1 or STS?
- 5# Procharger Track Results
- what size oil line??
- pics of my build up
- What would Harlans car run if it.....
- Has anyone Magnacharged a 4thGen LS1 F-Body?
- What if STS re-designed the rear turbo to look like a cat-back?
- Who is running a F1 blower with over 15psi ?
- Slowly but Surely
- Cartek Twin Turbo 346 ran 9.90 today
- Aluminum or Iron what's better for boost?
- Help ... I'm losing hope with this SC stuff
- Replacement Belt for D1SC from a local store?
- Seven Second LS1 Rumor
- what is a vortech s-trim blower head unit worth?
- Vortech Polished 9lb kit w/aftercooler never installed! For Sale!
- Anyone have a stock tensioner? (D1SC)
- ATI setup, how does this sound?
- How much for STS?
- Cheapest place to get turbo manifolds?
- FS: Autometer Lunar Fuel & Boost Guage...
- Sts
- Few Qs about ATI setups...
- Any STS Dealers In Houston?
- Where DEM LSones
- SDCE 8 rib guys w/3.4" pulley step in.....
- Anybody using a set of AFR's yet?
- thought roots blowers didnt fit f bodies?
- FI heads for sale. TEA Judson port. 74cc
- Happy B-Day LS1TECH!
- Need some help
- What radiator are people like Harland running?
- Crank pinning kit to borrow?
- injectors?
- Eagle Rods in a turbo setup?
- 6.0 boost motor!??
- Where to get whipple pullies?
- Supercharged 03 Viper Video
- Possible to have over the axle true duals with turbo manifolds?
- We're now carrying STS Turbos!
- STS Vs D1 10psi
- New Dyno Graph
- How much power with this setup
- Bigbos
- Where is the best place to purchase a bigboy at t88 and up
- FI with a 408
- CP size on the new 8 rib ATI setup?
- Building a custom header for a FI application - what type of tubing?
- Who sells TT headers?
- Auto exhaust cutout... kinda cool
- A little tip for Procharger FMIC guys...
- The Ideal motor for a 101mm
- Blown valvetrain & rods?
- The car is finally fixed! Dyno #'s inside!
- Unfortunately CAS setup for sale :(
- need QMP phone number (not actually trying to get a hold of rob
