View Full Version : Forced Induction
- Does Boost Change??
- D1 with stock fuel system?
- GAINS WITH SWAPPING OUT MY CURRENT CAM??
- Turbo LS1 Update (pics)
- Good place to get silicone 90deg elbows
- Can't fill my gas tank... Whahappen??? *DELETED*
- most boost on stock motor? handle?
- Pics of turbo manifolds/headers
- What happens when you max out your turbos?
- Holla if you are running a FAST system...
- MMS Pulley update....
- Vortech w/ 50 shot
- Fuel system help with a solid roller D1 car please!
- Any Procharger guys installed ATI Super Damper?
- Incon TT Kit
- my by pass valve is broken
- 8.9:1 too low?
- Thank god I got an ATI Product!
- 1000 HP Billet Aluminum Flywheel Ripped Apart
- Incon Turbo
- Mike Brown firms up on second place (10.04 video and stills)
- Just installed Fuel Pressure Gauge - Observed the following.
- ARP Header Studs
- New Dyno #'s!! - 533/567
- Cost of ATI p-1sc?
- Wideband Monitor GP
- Check out my custom fan setup.
- Paging Brady, that twin turbo terror on the power tour
- who uses lucas oil?
- Wrong Pulley????
- Good set up fot twin turbo...
- What can 50#'s do???
- It is a SAD SAD DAY....My car is for SALE.......
- Which supercharger for a 4wd 5.3 Tahoe?
- How much boost will this make
- Need some tips???
- turbo specs
- What can i do with 14k on a camaro?
- Trying to contact ROB RAYMER
- questions about Procharging my 5.3L?
- 135 - 145 MPH folks, what timing and gas are you running?
- Static vs Dynamic Compression???
- Finally got the first part of my QMP kit
- Cheapest way to constant 500RWHP, FI
- Supercharged LS1, 63 Corvette, Will it fit?
- Timing adjustment for F.I
- Normal Temps for ATI kit??? HELP
- MACs __> Kooks
- SMC alky injection...
- Failure power points. Have you blown an engine?
- New dyno numbers at 10~12 PSI
- 8/29/03 - Final Pics of mounted Griffin intercooler setup
- belt slippage no prob!!!!!
- Max Boost with ATI on Stock Engine.
- New GRIFFIN S-TRIM intercooler
- Need help on heads for SC.
- Whos got Vids of supercharged LS1's
- Safety
- Started new project today.. 67 Camaro LS1 turbo w/ FAST
- Prices for Griffin YS-TRIM intercooler
- C5 Turbo Kits
- lets use iron heads
- QUestion about larger dispacement engine for FI
- Paging Rob Raymer
- ati pro charger
- ATI Supercharger
- 100 octane vs. 93....with my setup...
- Crank bolt won't stay put. Had to drop timing...
- Paging Rob Raymer
- oil lines for a turbo set up
- turbo for under $2000 does it exist
- Fuel system for 550-600 rwhp Magnacharger?
- Powerdyne Hits 450 rwhp!
- Turbo vs. Supercharger...
- How to building LT1 for procharger
- 42.5 injectors, 600rwhp not enough?
- ANy downside to having the PCV system under boost?
- playing with turbo calculator, whats a good guess on VE?
- intercooler eficency question and a cool intercooler site.
- Turbo not get enough air?
- Spraying Methanol problems
- Are you guys using X-pipes with your F.I. setups
- Plumbing boost gauge into where?
- What oil do you all run in your forged internals boost motor
- ATI parts 4 sale
- t4?
- Anyone see or hear of a 668rwhp ati TA from youngstown Oh
- paging rob raymer
- DynoJet numbers for my car....
- MMS Camshaft?
- Intake air temp guage
- What is the fastest F-body turbo six speed time?
- Does this make any sense to anyone?
- Beware Cerra Racing!!!
- Videos from T/A Nationals this morning (#2 and #4 car)
- New Best ET Today
- Dual walbro pumps 510L/Hr For Sale
- Incon Actuator Question...
- Proper Exhaust Bias for FI Heads?
- 57rwhp and 45rwtq from a cam swap?
- Magna Charger installed, need help
- Anyone add e-fans to their intercooler?
- is everybody runnin a bov?
- What are the QMP T-63 turbo specs
- bigger guage wire for intank pump??
- Superchargers on a 5.3 in a 03 Avalanche
- ball bearings on turbos?
- twins questions?
- paging PSJ
- MMS and big Dyno number?
- FINALLY up and running, CHECK OUT THE CHANGES!!
- what is Q trim?
- Innovate Wideband tool
- Bigger K&N cone filter for ATI procharger kits??????
- Free Ram Air Mod
- any manufactured turbo kits, not fabricated?
- Knock Sensor Question
- wife bought me a Vortech for my Birthday
- forced induction vs. Cam, heads, etc
- How many fast FI cars that do not post here..?
- Puttin my stock motor back in with TurboTech kit, Few ?'s
- Need answer on 2 inch headers/ need help
- Car still forsale
- Griffin Intercooler pics on another 4th gen
- Paging Black LS1 T/A: Your fuel system
- Video of the Moser TQ Arm Breakage
- A Testament To Incon's Intercooler Setup
- Need FI best techs in here, ATI related....
- New Dyno numbers and 1/4 mile times
- Boost upgrade questions
- Cam too big for a blower motor???
- What brand of Supercharger to buy?
- I randomly lose TCS after working with fuel system.
- Blower cam's intake centerline
- P101 MAF Performance after D1SC installation
- Began my project today...
- how did you plum for oil?
- where do the vacume lines go.........
- 8/15/03 - Pics of Griffin Race intercooler out of the box
- Fuel Ratio Question ?
- Video of QMP Turbo Z 9.86 @ 136.79 is Up!
- P1SC to D1SC....
- Whats stopping me from leaning out the car more?
- 6.0 l heads, EGT temps
- Mightymouse Help - speed ink fuel rails
- Vortech V9 with Ram air Hood??
- Incon For sale
- Gapless rings with boost?
- How to pin a forged crank, with it still in the car?
- Ported MAF or Stocker?
- If you tune with EGT (Turbo guys).......
- supercharged cams?
- How to use a SFMU as a 1:1 regulator?
- Are there any Bolt on simple Low PSI Blowers???
- New Ls1 turbo kit
- Cog setup???
- Should I have keyed the crank?
- Computer System?
- Anybody else trying to make horsepower?
- MTI C2 cam ok for a supercharger?
- LS1 Motorsports/ QMP Turbo kit f/s in classifieds
- Pulley suggestions for a 414 LS1?
- Supercharger or Heads/Cam Package
- Lower PSI??? Lower $$$
- Quick ATI S/C pulley install question
- Looking For A Cog Setup my YS-trim is Slipping
- HELP ATI Tensioner bolt.......
- Which blower would be best for me?
- Oil Pressure seems to be low on hot days after ATI Install
- Procharger pullies
- ATI FMU Vacum line question for (LS1 Camaro)
- whos engine is this?
- Assist with ATI D1SC installation requirements please...
- LS1 Motorsports/ QMP Turbo Z28 goes 9.86 tonight!!!!!
- Base tune for my turbo setup.
- Low Impedance Driver Box
- 7# Pulley How safe???
- qmp turbo kit
- I need opinions on a turbo idea.
- 9 Second Pass in the LS1 Motorsports/QMP Turbo Z28 Tonight ?
- I've decided on a D1SC.. Now where to buy from?
- Limited Enginering (INCON TT)
- what is better 4 street use vortech or turbo??
- Vortech's Aftercooler vs ATI's Intercooler
- Need some help with a sticky throttle.
- Intercooled kit for Vette
- LS1 Motorsports / QMP Turbo Z28 Update: Stock Cubes, 700RWHP
- what do you Guys Think
- ati instructions
- Crank Pulley?
- Is anybody running the new Mezziere Pump with a Blower?
- ?s for guys running Water Alky injection
- I want a LOUD FI setup (blower whine/turbo whistle)
- V9 ... upgrades, sugestions?
- Any HP gains from 6.0 Heads?
- Thanks to Thunderracing! C5R set up dynoed!!
- Tips on installing D1SC?
- R1 Cam, 9:1 CR, and 15 psi
- MTI Forged 9:1 Motor, plz comment on Dish, C/R Calc
- Blower Cam Decision, cam options listed
- Blower time!
- Bigger Injectors?
- What should I get?
- need vortech parts
- Vortech Aftercooler Help
- Has anyone blown up a Forged Piston or Ringland under Boost?
- ATI Trouble
- Pistons
- Stop the Flames...
- What compression............
- Incon Stage II
- What should I do?
- turbo sizing?
- What do I need to safely run 8# ATI on stock LS1?
- QMP Turbo Kit - New Dyno Sheets Posted
- Charged Air Twin Turbo Kit
- ATI people please post ET's
- Weight savings: Remove Fuel Pump!
- Here is the list of new mods to get me in the 9's,
- No low end power?
- Does anyone have plumbing pics of Incons TT?
- ls1 and 03 cobra blower??
- My New Toys
- What type of belts do you blower guys use?
- Build my own turbo system?
- need the correct size belt for MMS Crank pulley
- Woud 5.3 Heads and 229 Cam be to much 4 Blower
- Were do I find turbo kits?
- QMP Turbo Kit - NEW Dyno Results !!!
- Starting Problem - Fuel Percolating??
- Is this part from a blower kit?
- Where to find Goodyear and Gates belts online?
- Got P0327 & P0332 Codes - Won't Go Away, HELP!
- How much faster did you go with blower/turbo?
- BENCHED, NO MORE!
- Question for richieg?!!
- What is a mock-up supercharger?
- Boosted List Updated
- boost related fuling issues?
- ATI owners
- Boost Controller Advice
- 4 inch Pulley on D1-SC? How much Boost?
- YS-Trim + 408 CID
- Injector Options for larger injectors
- Is the MMS pulley an 8 Rib ?
- Blower cam for a 408
- Tables for Delphi 55# Injectors
- don't know if am running rich or lean
- Which wastegate to use for 88mm turbo?
