View Full Version : Forced Induction
- 1995 camaro lt1 vortech supercharger runs lean
- wastegate ?
- Why wouldn't this work for the truck mani guys? Keep A/C
- gaskets?
- Golden Eagle Vacuum Manifold
- charge pipe sizes
- Any downside to knockoff wastegates? (examples inside)
- Is this turbo for real?
- ball bearing turbos....justify the cost
- Typically, how muh to make your own turbo kit?
- Is anyone interested in an Incon kit?
- flipped Mac mid lenghts?
- search is broken...what radiator?
- test runs in Nova
- Final FMIC install pics.
- Cutout
- new ideas
- Questoin About two bar?
- FI help
- New 10 Rib 'Vette Blower Mt. From ECS
- Anyone Want To Swap 96's For 83's??
- Are Precision On-center Turbine Housings Same Size As Turbonetics??
- wtf is up w/this...
- hey i need 2 V-band clamps
- Procharged guys, what exact plug are you running...
- Extra injectors or Methanol-
- New Friend for the camaro is here.....
- So 15lbs of boost isnt 15lbs of boost?
- ATI Cooling Improvement (Pics)
- No power
- How Much Airflow Am I Actually Taking In?? Experts??
- F1/F2 Procharger system...
- meth or nitrous?
- Gmr
- STS oil return into oil level sensor?
- Kenne Bell BAP-will a 40 amp be okay for a single pump?
- FMIC Pressure loss question
- Hi-Flo Update 6-7-2006
- Loss of a/c questions
- Scaling IFR to get negative LTFTrims for 60lb injectors-26%!!! FI application
- to MAF or not to MAf that is my question
- Power differance between mid frame and large frame turbos???
- Pulleys, Meth, And Boost Amount ?s
- 35 fi
- impression of my 1st CAS TT ride
- Maiden Voyage-Twin T67's-Short Video
- help! intermittent misfire
- high rpm closed throttle with SC
- F2 in a WS6....anyone done it?
- LS7 build up
- Can I tilt my radiator forward with the condenser still attatched?
- PCV Options HELP!!!!!!!
- Synergy All in One product line....
- what can you do to move oem radiator forward some
- Oil to Rear Mount Turbo
- Radiator Size
- wow crazy 99 pcv (not) valve
- plug gap for 20+PSI
- crank case pressure problem ???
- Turbo question
- Boost reference (fuel regulator) for STS...good setup?
- Who sells Procharger headunits?
- Whats the RWHP record with a F1R?
- blown Z06 fuel problem...??
- Quick Truck Question
- cutting radiator support?
- how to move radiator forward
- 90 mm throttle body for ls6
- phamspeed FMIC PICS
- flx-220
- to big for a 4.3L?
- Did some WOT Logs-I think I have a fuel issue-help?
- Why do you get more HP with a turbo set up?
- New Supercharger! now 1 question
- Need help with procharger noise/pulley issue *pics*
- bleeding off boost with this cam
- rear mount build up questions
- Few Q's
- GLM Tuned 382/Vortech (719hp 757tq)
- STS troubleshooting help
- 346/D-1SC@16psi=717rwhp@5200rpm Whats next?
- oil return question
- New 2 step and much much more just released by Synergy
- GMR Speed Twin Turbo
- Fmic??
- What's my compressor wheel trim?
- Kaos Released II ...w/pics
- Help me find this flange
- Some C5R pics
- MTI Procharged C6, Stock Block, Cam, and Heads - 711 rwhp!
- STS guys come inside
- Motor is once again ready to rumble!!!
- What exact sparkplugs for DART 225 heads on D1SC blower 9:5 LS6 motor?
- Explain A/R !!!
- Where To Buy V Band Clamps
- WTF Texas speed....????
- Turbo C4 dyno vids and initial numbers
- 700 rwhp with procharger possible ??
- menthal? alchol? gas pump fuel
- The new set up is up and running just working out a few bugs
- Roofer Dave's car ... 7.87 @ 179
- Vortech 38lb injectors rated at what pressure?
- turbo to big for the 4.3L?
- Tuning straight methanol, gots a question for the meth freaks..
- 25 to Blow
- Supercharging an LS1
- Water, Alky, Meth wtf is the difference?
- I was wondering????.............
- Hairspray??
- A/F Meter
- Timing Q
- Kenny Bell LS1??
- 408 iron and d1sc procharger
- bob @ EPP
- Another Hot Turbo Car?
- my FI PCV/Crank VAC system.
- turbo question here!!
- Oil pressure changes?
- The 9 Second STS build...
- coolant over flow tank?
- most rwhp out of sts turbo?
- Mounting of DevilsOwn pump?
- So what's the latest greatest clutch for FI?
- Can't make more than 13 psi
- The car runs!!!
- Video Of My 14 Psi, 751 Rwhp 93 Octane Dyno!
- should i run this
- Procharger Clutch setup...Help
- FI for California guys!
- Methanol More Boost???
- STS style turbo kit !------- and some general turbo questions
- What do you think I will spend????
- blue smoke at startup?
- Happy Birthday Kyle (NA$TY-TA)!
- Turbo Kit done, with Forward headers!!!
- First E85 LSx setup? Anyone doing this?
- What's the max with this setup?
- Thoughts on this cam for turbo????
- Safe amount of boost on a stock bottom end?
- Cut out after turbo yes or no
- Tuning?
- what is the difference in 98 knock sensors vs 99-02
- Initial Startup/Dyno of My Twin T-67's
- Video of my Nova idling
- Cost to rebuild 60-1 Turbonetics turbos????
- Laminova intercoolers?
- 6.0 heads n/a?
- W2W "SUPER" nova
- Reichard Racing 3.600 DIA Pulley...Boost?
- I hate fuel injection, but i love Forced induction (thinking out of box)
- anyone run boost w/o 2 bar pcm upgrade?
- My thoughts about meth injection
- From nitrous to turbo-----------!!!!!!!!------
- Oil Feed line question with Pic.
- turbo question
- Whats it good for?
- bov?
- STS owners, oil return?
- how much for procharger installed
- Should VE and MAF be calibrated for 9psi?
- leak checks
- DCR, 92 octane, F-1 or YSi trim , and me...
- At 10#`s of boost what would be the hp difference
- Need Vortech Instructions
- Couple shakedown passes *video*
- MP T70s mounted
- Downpipe flex pipe?
- How Much Boost?
- What upgrades could I do with a P1SC Procharger, to get the most out of it?
- Any before/after results of going LSX78 to 90/90 on 346-348 LS1 turbo car
- FMIC Installed (w/pics) Boost control Q too.
- i have a 8 rib ATI kit, what do i upgrade for the SDCE?
- Looking for a Turbo tune in Norfolk, Va area.
- How many larger turbo (80+mm) street cars?
- Paging Intmd8, how is your staged fuel injection working out?
- Big single turbo peepz, what muffler are you running?
- Caveman, did you sell your T-Trim car?
- A realistic HP guess?
- Jose Line One Jose Line One
- how much rwhp per 1 lb of boost???
- F-1 Growl
- Frustrated... Procharger guys... PLEASE HELP!!!
- Strange boost problem
- I bought a Procharger today!!!
- GT42 guys inside...
- Hp/Tq #'s From Truck Mani Setups??
- procharger cam ?
- Timing question...
- What shortblock "upgrades" should i look into for my build?
- Trick to Sealing V-Band clamps?
- pvc question
- need a drain flange...help me out please
- boost + ls1
- 1500 Rwhp.
- Trims?
- Tell me about your ATI 8-Rib experience
- Checklist
- map tune or maf for sc
- z06 Cam after FI
- u guys still using TR6 plugs for 750rwhp?
- cam good for a supercharger
- What do i need to use a MAP sensor instead of MAF?
- 751 RWHP on 93 Octane
- very disappointed in CAS kit...i need some serious help please!!
- What is the rail to rail width on 4'th gen camaros?
- ??? on turbos
- Procharger?
- hi-flo website?
- overboost?
- What heads should i run with supercharger
- pulley size
- Strongest shelf forged piston for turbo 402"?
- Need Advise on Firebird FMIC
- IC or METH ?
- IC Spray
- tial WG & BOV
- Finally gonna be boosted!!!
- TR5, TR6 or which plug for Powerdyne blower.
- blow off valve to the atmo or tie back in
- what did you do to get to 650 or more HP?
- What DCR for 6# Supercharged?
- Supercharger!
- breaking up
- difficulty level of supercharger install?
- 600 Rwhp....
- Where to get 5 inc pipe from????
- car is almost done! not FI tho.
- turbo m6's, what gear do you run??
- MAF Output Choppy
- turbo and stock block..??
- Rear Turbo Pics
- best buy single turbo kit not remote mount?
- Motor Build
- Mufflex + twin turbo
- What TH400 torque converter with your turbo set up??
- Dyno results for twin T70 GTO
- Tuning
- About Cats and Forced Induction
- Which bearing for forced induction?
- 35 rwhp gain with mac midlengths over stock manifolds
- fuse box relocation bracket
- Oil ?
- Holdener F/I power calculation formula
- GMMG + twin turbo ?
- Less cubes > More cubes??? With a procharger at least?
- Muffler for high hp (>800 rwhp)
- guys running stock heads... what times/power?
- ATI belt pully change in vette (Godbless)
- Pics of the Bell IC mounted for the Incons.
- Forward headers done!!!!!!!!!!!!!!!
