View Full Version : Forced Induction
- TurboD Lt1
- Anybody mind taking a look at my Idle Airflow table?
- results from modifying and re-tuning my rear mount
- Manual boost controller (sponsors?)
- Single Plane or Stock intake on LT1?
- APS allternate mass air pipe?
- Octane Booster
- thread size on sts checkvalve?
- best place to purchase a set of stainless header flanges and any primary size sugest?
- Video walk around lsx 434 tt
- Realistic price for my motor/blower setup?
- can 5.3L heads be used?
- how interchangeable are meth kits?
- Solve a dispute between me and a buddy
- Procharger BPV problem?
- My 370 buildup (for F1 procharger) WARNING: long post & lots of pics!
- Wide band bung?
- help..tt intercooler on single t70
- turbo oil return on front timing cover?
- Fuel drops 5 psi
- E85 and meth injection
- Want to replace Procharger 16" Fan
- Twin Charged, Compound boost with BW S475 Turbo and TVS 1900 Blower On A Truck
- Over heating with a verticle griffin. Anyone else??
- What gears to run with T76
- Already bought two turbos, now I think I want to go bigger
- Help with turbo oil connections?
- STS / cam question
- More power needed !
- Found a boost leak...
- anyone have video of their atmosphere WG?
- Turbo question
- Got my car tuned...questions...
- Another option for the puller fans
- Vortech T-trim Upgrade
- Switching exhaust setup for FI
- Need to quiet the car down, a LOT! My idea in here
- throwing belts
- POWER from a D1
- New to F1 section need injector help
- LS1 92 Z28 swap... which turbo?tc78? BW s475?Ideas?
- Just curious as to how much weight a Procharger setup adds?
- Can't go WOT
- Eating map sensors
- duramax diesel turbo on my ls1?
- Could my cam Really be Hurting me?
- How much hp can a stock ls1 handle safely on 93 octane?
- Feels like throttle slams shut.
- Help me figure out what is holding me back.
- what would good heads be for FI
- Guys with FI cars!
- Drilling holes in MLS head gaskets ?
- Cats to catless throw off tune???
- New alternator bracket
- D1SC Question
- How to determine What Size Turbo I have?
- Procharger Question
- NINETRES in NHRA??? 144mph??? Oh yes.
- High Comp & Boost
- Need some help please!!!
- The new 2010 FORD SHO
- looseing boost
- Piston Talk
- Started my turbo build! PICS!!
- FI + spray
- Good crank for supercharged application?
- Big Red Race Valve Placement?
- Stupid Question
- Wanting to go S/C. Looking for some input.
- Anyone running Precision 6262's??
- Radiator question
- Which cam for sts turbo
- Confusing O2 readings, need expert opinion
- LMR Twin Turbo Corvette Dyno Vid!!
- roots vs twin screw
- Twin MC76 turbonetics turbos for sale!!!!!
- Is my wg 2 small?
- Who's best to get a Custom Intercooler from?
- Opinion on custom 76mm Turbo set up for my 2010 Camaro
- FMIC on Vortech instead of Aftercooler
- 5.3L Boost questions?
- WG Dump Question
- Gforce Engineering's GTO Turbo build
- Burkhart's Dog Days of Summer Sale
- 347
- Project NIGHTMARE for LSX Shootout!
- Head gaskets
- Vid 1st crank 434 LSX TT
- Turbo with a 6 Speed?
- no Boost
- If I hit the rev limiter under boost will it blow?
- Who runs with no intercooler?
- Wiseco GFX rings good?
- Can anyone give me an idea what some parts are worth (parting car)?
- turbo guys in here need help
- EPP Front Mount F1A Air Inlet
- 98 f-body 2bar conversion wiring pigtail?
- Powerdyne supercharger??
- Belt for P1SC
- New APS Upgraded Turbos
- Fastest 60 Turbo F-body
- Speed Inc TT LS Typhoon 1/4 mile video
- 317 heads or 243s
- want to see what material you all are using for your turbo setup
- How much boost can I run and how is this cam?
- f1r procharger questions?
- blower got crazy loud
- alittle different turbo question
- smallest procharger 8 rib pulley?
- will it fit?
- cam help!!!
- What would you do?
- FI question
- 8-Rib Gates Belt
- Vid-1st crank of LSX 434TT
- Wastegate(s) question
- Which turbo(s) would work best for me?
- wtf do i do for a turbo exhaust?
- What size pushrod to buy for boosted 427 with TFS245 heads
- HP limits of 317 heads
- boost with procharger
- Main bearing wear with a supercharger
- t88 seized t4
- Forged 347 + Meth + D1SC.
- Blow-Off, Pop-off, Wastegate on a SC Engine
- Wideband questions,opinions..observations..
- stock LS1 psi?
- Thinking about getting heads what CR should I got for
- HELP: changing a2w too a2a need help to kinda understand it and do it
- Turbo Newbie!!
- need help with fuel system/boost referenced regulator
- interchangability between GTO/Fbody Prochargers?
- eboost2 install tips and tricks and pics???
- Rule 3700 pump part 2.
- Eagle or Callies crank for FI?
- Vic Jr or LS6?
- Intercooler piping
- LT1 vs LS1 Procharger kits
- We're getting ready to hit the track with an F-1C on the EPP Camaro
- The Trickflow 245 heads what the intake runner height and width
- Anyone running one of these?
- Anyone have results after adding methanol w/NO tuning?
- which heads should i go with?
- Backyard turbo
- Meth color?
- Should i trying a EFI super victor or victor jr with new motor ? whats needed to run
- Aps guys who are running front sway with spacers come on in!
- Is my Impeller Screwed Up?
- Which head gaskets for a 427, LS7 or LS9?.(
- Budget Minded 500whp (LT1)
- Please help design a F1r pro charged ls3
- Wideband Placement?
- building turbo kit with truck manifolds need help
- I have almost all of my turbo stuff .......
- Is 4.5" downpipe enough for 1000Hp (TC78)?
- UPDATE ON MY JUNK! aka my first LS1
- Forged 347 Build + D1SC Procharger
- How are the new FAST92 for boost
- Virginia Speed Turbo LS2
- What turbos for a 427 Thinking of a mid mount ?
- Turbo project finally done... Pictures
- Spark plug gap
- What trans mount are you FI guys running?
- Custom High Mount LT1 F1A Procharger
- Need to get some parts
- f2 in an fbody
- IC / DP Sizing Question
- Living on the Edge. Why?
- best head for FI
- Question about supercharger pulley.
- Roller Rockers or stick with stockers?
- Turbo guys, what clutch are you running?
- Which turbo will put me in the 800rwhp range???
- best valvetrain / head choice for this single turbo set-up........
- LT1 MAF - How much boost?
- MAF question
- 3 bar map sensor instalation help
- boost?
- Vids of the 9sec RearMount LMR build!
- Vortech V-9 Gtrim W/Aftercooler and RedTop
- About time i posted my build (APS Build)
- Boost on a Stock T/A
- 408 with ls1 heads would lq9 317 head help?
- Turbocharged LT1 Spark plug boots burning - help needed!!
- how much can i expect to see?
- anyone used a synapse engineering 50mm gate?
- Redo After piston burn
- Angle of hot pipe into turbine housing?
- what vortech head units work
- D1SC Kits + Vote on motor build
- when to go with an aftermarket balancer
- 408ci 9.2:1+Z06+magnacharger= will it work?
- where can i get a Hobbs switch ASAP! no one has one in stock
- 3.8L Supercharger
- Not a LS, but boosted E85 dyno time!
- Speed Inc. LS2 GTO/APS results
- turbo cam.....?
- 30psi with a trubo come in
- QUESTION! Are Vortech and procharger pullies interchangable?
- Turbo Motor swap into a monte SS...Questions
- "v" bands
- Boost & power increase going from 3.5" twins to the bigger 4.5" twins?
- What Gauge Would You Go With?
- T-bolt V Band coupling question
- oil in cold side tubing
- new to FI... first mods..
- How much weight does Turbo add?
- TC78 and 408cui build
- Any problems running LS6 intake and PP throttle body with boost?
- What pulley size do I need to max out a D1?
- pt88-47 build, retains a.c power steer. etc pics
- Vortech Twin Screw?
- Should this oil be there?
- APS TT Kit Questions
- LQ-4 Motor
- FMIC with front plate?
- Your Thoughts On My Plan
- air intake temp, what is too high
- What are you Camaro guys doing for airflow to your frontmount?
- Guidance
- Procharger bypass and boost gauage hookup?
- Procharger install: Help me finalize BOV location and Air Filter tract ...
- Thinking of use a turbo set up but need help ?
- FMIC with my new D1SC kit, Mounting?
- Valvetrain Question
- .68 ar or .96 ar??
- Retrofit procharger cog bracket
- Aps for c6?
- Help me out here guys.
- Oh...SNAP!!!
- How much does temperature change HP on FI with meth?
- Where to go in OKC (OK) for FI information?
- How much of a pain?
- daily driving procharger... best FI for f-bod, opinions?
- Rule 3700 IC pump flow test.
- Sooo frigging pissed!!
- KYTP kits
- loosing boost and power at 4200rps.. any ideas??
- custom serpentine belts
- "Need help" what turbo is this, have many pics..
- help me pick pistions
- 96 Vette LS 402 88mm finished engine pics
- What do you guys think about the new LS1 Kenne Bell?
- Need a good Top-End for LS1 + D1SC
- 5.3 twin turbo?
- air to water intercooler
- Where to buy an STS kit?
- Non LS. 08 Challenger TT. Gettin er dialed in
- Keep your fingers crossed...
