PDA
View Full Version : Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 [119] 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230
  1. procharger inspection
  2. Procharger installion??
  3. ls9 cam in ls1?
  4. Heads for Turbo car-- is ported worth it??
  5. alternator relcation brackets
  6. alternator not charging after relocation?
  7. first turbo start up
  8. G-Force ProCharged Z06 761RWHP
  9. turbo ls s14 progress
  10. Twin Turbo
  11. What is the diff blow off/ waste gate
  12. Valve question
  13. Opinions- what options are important to you in a turbo kit ?
  14. Procharger "Tuner" Kit
  15. wanting turbo set up
  16. OFI Install cost
  17. has anyone converted an STS.....
  18. Turbo 106mm vs Procharger F3?
  19. Megasquirt Setup
  20. twin turbo kit
  21. Exhaust with a blower ?
  22. Any proven turbo cams out there and who designed it for you?
  23. compression
  24. holset H2C turbo
  25. FI and tires ,if you are over 600rwhp come on in!
  26. Where can I find some honeycomb mesh??
  27. Road race & Overheating
  28. 317 heads on ls1 what push rod?
  29. What lifters and what rockers for TT 900+rwhp?
  30. STS VS Procharger Poll?!!!!!
  31. A2W intercooler STS question
  32. sts instuction manual needed
  33. gm castings vs aftermarket castings with big numbers
  34. Got a ? concerning WG spring pressure and boost pressure
  35. Overheating - turbo question
  36. Cracked block: what could have caused this?
  37. Boost control
  38. water vs air
  39. Old Style PC Bracket???
  40. blow thru tuning
  41. pro comp heads???
  42. Getting dynoed today
  43. spool difference between turbonetics t76 with p trim vs s trim turbine
  44. Part number for Cobalt 2bar MAP
  45. Where are you getting the bar across the front when standing radiator straight up
  46. Making meth??
  47. When do you start building boost?
  48. Best Fitting Aluminum Radiator with A/C and D1SC
  49. external wastegate leaking by at an idle!?!
  50. Twin turbo suggestions
  51. Compression Ratio Calculation
  52. valvesprings breaking!
  53. STS new numbers
  54. Anyone try silver paint on head gaskets?
  55. LSXTV Article about 8 Sec Z06
  56. Stuck trapping 154-155mph...
  57. AIS meth kit question
  58. p1sc c5 epp blower cam and kooks installed clip
  59. Fastest Rear Mount F-body??
  60. turbo setup(so far) andy suggestions
  61. Nice 447 with a 101 turbo video
  62. looking for the best mbc..
  63. Track results are in!!!!!
  64. Ls6 427
  65. Typical gains with Methanol injection??
  66. blow up my motor, pics inside
  67. Need help on this camshaft for my turbo
  68. kenne bell
  69. Start Up Audio and Pics of V8 Miata
  70. STS dropping boost
  71. Am i safe or pushing it?
  72. Boost Guys Opinion
  73. Forced induction lq4
  74. Installing custom FMIC. Have some questions
  75. 09 corvette supercharged numbers
  76. In Car Pics of my 427LSX motor
  77. Miata First Start Up - More Videos to come
  78. How much boost?
  79. Stock LS1 turbo questions?
  80. APS 346 dyno 599/543
  81. boost controller on s/c
  82. Complete ProCharger D-1SC kits with tune from EPP
  83. Best Chemical cooling agent
  84. Frcefed98 Signing off.......
  85. how much boost will i have
  86. exhaust manifold gaskets
  87. side dumps
  88. Best place to get a 76mm turbo??
  89. Just how much power??
  90. Coating Turbo Headers - which one recommended
  91. Synergy 2step wiring on 98 F body
  92. Turbo setup for 4th Gen camaro
  93. turbo fittings
  94. WhereToBuy - Procharger J-bracket?
  95. restrictor plate guys come in !
  96. Boost Pressure Gauge
  97. AFR dual valve springs good for boost?
  98. Playing with the trans brake and 2-step....
  99. Who all has disabled Burst Knock?
  100. FINALLY Taking the Rear-mount 88 SS out!!
  101. compression?
  102. Where to get a z06 cam
  103. Lunati Pro Billet rods
  104. ls6
  105. stock MAP with MAF tune?
  106. Intake Elbow?
  107. Need Big Boost Big Bore Head Gaskets
  108. light weight fly wheel?
  109. APS Twin Turbo Questions
  110. procharger fan setup
  111. any problems with wrapping exaust pipes??
  112. LMR Procharged 08 C6Z Dyno Vid and Pics!!!
  113. turbo selection help
  114. Dyno Question
  115. supercharger wanted
  116. supercharger
  117. anyone have a 2/3bar timing map i can copy
  118. what does a evap solenoid do and why do i need it?
  119. twin turbo lq4 or ls1
  120. Alkycontrol Kit: Denatured Alcohol vs. Methyl Hydrate
  121. turbo or procharger?
  122. Turbo bikes?
  123. Downpipe w/ Truck Manifolds
  124. lt1 intercooler piping ???
  125. sts exaust question
  126. would i need a retune?
  127. Oil fittings in/out S480
  128. pics or advice
  129. Boost Controller 'duty cycle'. What does that mean?
  130. Keep forged 347 or build iron 6.0
  131. Boost reference FPR base pressure
  132. To hell with n/a!!!!!!!!!!
  133. 233/239 cam for turbo
  134. 317's on LS1 For Boost!?!?!??
  135. Lookint for boost gauge
  136. 3.08 or 3.50's?
  137. HX52 turbo
  138. Ways to keep AC?
  139. Belt size for ECS bracket, D1SC with 3.2 pulley?
  140. installed meth inj.? some opinions needed
  141. Questions on a DD turbo truck project.
  142. 11.0 to 1 compression on 10lbs.
  143. turbo piping
  144. pusher fans
  145. LT1 FI tuner?
  146. turbo headers
  147. where do i get a quad guage pillar pod
  148. Crushed bent pipe ok for turbo piping
  149. Oil Pump For a 370?
  150. Belt PN for smokinhawk alternator bracket
  151. Pieced together a complete Procharger kit, 8-rib, FMIC, 4" Inlet for $2k :)
  152. best intake for my setup
  153. Boosted 6.0L guys inside please
  154. My Harlan 2-step not deactivating
  155. best comp ratio/build for a procharger 900+rwhp ???????
  156. Looking for a serpentine belt
  157. turbo/nitrous
  158. What injector whould you run??
  159. Retorque heads
  160. Pix please of your custom overflow coolant set up?
  161. 72 chevy project
  162. 317 head swap
  163. Where's the best Magnacharger kit?
  164. intake idea for my 5.3
  165. 60 lb injectors ?? Boost??
  166. oil cooler? who runs one
  167. Best place to get 1 3/4" stainless bends
  168. restrictor plates
  169. .82 or 1.06 A/R ... that is the question
  170. air to water IC ?s
  171. Up the compression and lower the boost or keep what I got??
  172. Those with a third gen and a turbo LSX
  173. speed inc twin turbo f-body kits
  174. Cam opinion on Procharger setup
  175. Magnacharger or STS?
  176. v bands leaking like a sift!!
  177. New Build for a novice
  178. Oil restrictor on a T67?
  179. Msd 6010
  180. Ebay turbo manifold
  181. Quick rundown on the Setup
  182. broke the clips that hold the MAP sensor
  183. IAC block
  184. fuel injectors
  185. PCV questions... car stinks like oil
  186. would this be enough fuel?
  187. f-body manifolds vs truck manifolds?
  188. procharged 346
  189. Please help!!! ASAP
  190. Boost spiking between gears.
  191. T76 feeding a TVS1900 blower
  192. Question on APS power output in 2 different cars
  193. vortech kit on LT1??
  194. warhawk vs afr or other !!!!!!!!!
  195. Any idea why this thread got closed?
  196. turbo from a supra in a...
  197. LMR 09 Challenger with Techo Supercharger!!
  198. Any C5's with exposed Front mounts???
  199. SC with cam
  200. getting no boost!!!
  201. AEM UEGO Wideband acting funky...
  202. thinking of going 4'' dump
  203. boosted 6.0 cam selection help
  204. Any APS owners running the Burkhart front bumper support?
  205. need some advice for a turbo setup
  206. Is this cam good for a turbo 5.3?
  207. Getting fuel to the turbo LT1
  208. which fuel pump?
  209. Good FI tunners in MD, VA, DE
  210. Where to mount eboost 2 in a camaro?
  211. Lets pick out some heads!! 408 iron motor
  212. Highest Boost a LS6 Manifold Can Handle??
  213. Turbonetics TC-76 Downpipe
  214. decisions, decisions...... need some suggestions
  215. anyone have a maggied car New Haven CT area
  216. It finally shipped!!!!!!!
  217. i know they are pieces of junk... but..
  218. Msd 6010 ?
  219. Billet tensioner with a centri?
  220. Mike Brown's best ET?
  221. Whats the quietest SC system?
  222. [PICS] Katech Performance Air Attack LS7 D1SC. 865hp/735tq
  223. harlan 2 step for sale
  224. Oil Pump Up Grade with rear mount?
  225. Help! Whats this Turbo for!?!?
  226. help with sts turbo needed
  227. Our NEW Set up from ....
  228. Help me pick some components to my turbo motor build
  229. Need opinions on this cam
  230. Intercooler Size?
  231. Turbo Info
  232. How would you do this
  233. Thrust bearing worn? what causes it.
  234. Kenne Bell on a Camaro? fab'd K member?
  235. Why an Iron Block
  236. boost control
  237. sts turbo
  238. lt1 procharger help
  239. Opinions Needed, 10.1 CR & Turbo
  240. changing Procharger F1 oil...
  241. 978 hp 1300 tq 496bbc with ebay T70's
  242. Forced Inductions Is The REAL Deal !!!
  243. heads for boost
  244. LS2 Turbo build - Opinions/suggestions
  245. turbo hose
  246. s400 to big for 5.3?
  247. DITCHING the fmu with my LT1 vortech set up?
  248. **TPE Kenne Bell Blown 434 LSX and Hannibal Lector Cam**
  249. Lmr cts-v!!!
  250. LF 6.1L FI info :)
