PDA
View Full Version : Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 [213] 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230
  1. Cam or rockers?
  2. Thanks Might Mouse and Turbo Tech!
  3. Procharged returnless fuel system problems on H2 hummer kit
  4. Where to buy a weld up header kit?
  5. Emissions Legal Turbo
  6. Supercharger on EBay
  7. Paging NBM00WS6
  8. Installing ATI: damper question
  9. ATI Crank Pulley backed out
  10. What size pulley do I need?
  11. gap on plugs?
  12. What to do now?
  13. ??Question about SD Concepts idler tensioner for ATI??
  14. Rear turbo???
  15. incon users
  16. need ideas on supercharger and pics of differant ones installed...
  17. procharger F1 bracket questions .
  18. my turbo set up
  19. 02 ls6 cam-cheap blower cam?
  20. Charged Air 15psi Dyno results....
  21. Calling out Harlan!
  22. 6 Speed Guy's with 500 plus RWHP....
  23. ATI Super Dampener Question
  24. Copper Head Gaskets
  25. Harlan, question on vette fpr
  26. 10.96 video from last weekend
  27. LPE 6 speed 427 TT goes 9.4 at 151.87mph
  28. Pics of my FMIC ATI Procharger Setup
  29. pump gas goal accomplished tonight.
  30. Ws6rufus
  31. FI Motor for sale
  32. FREE ARP head bolts.....
  33. Easy solution for D1's and cruise bucking
  34. What type S/c For almost stock?
  35. D1-SC, 348cid + 6-Rib hits 9's @ 142mph - No juice
  36. Blowed it up last night :(
  37. Boost Change
  38. turbo experiance
  39. My results of 408 stroker ( Thanks for everyones help)
  40. Any turbo guys wish they had gone with a blower, or vice versa?
  41. Which Turbo Headunit would be better???
  42. Twin Turbo Guys Inside please. Need pictures and turbo sizing
  43. ASP Cogs V. Spring Tensioned 8 Rib
  44. Selling my turbo kit
  45. Ati P1Sc Belt Part number
  46. got my car dynoed
  47. Where to spend my money....opinions?
  48. Cam Motion Turbo Cam for Sale
  49. N20 to FI
  50. P1SC Twin intercooler or single FMIC
  51. Pilgrim's Progress (by author)
  52. Automotion Steel Brkt.
  53. Which MAF should I use for FI Tuning??
  54. need vortech v9 gtrim head unit
  55. should I get a supercharger?
  56. Rear Mounted Turbo Setup
  57. TT 427 Projexct
  58. ASP Cogs?
  59. HELP with torque converter for my supercharged vette
  60. z06 with d1sc ran 9.82@ 142
  61. how did this turbo launch happen?
  62. dyno #s
  63. Need help with fuel system
  64. new #'s for p1
  65. I need help picking a cam
  66. PTK has released some pricing and info on the LS1 F-body kit.
  67. Twin Turbo Setup
  68. Paging ATI owners...help with ATI crank bolt ASAP!
  69. Need opinions ASAP please.
  70. Ordered my Steel ATI Bracket
  71. Harmonic balancer pin kit needed.
  72. Forced Induction Cam up for grabs!
  73. I need some help with my ATI belt tensioner...
  74. DFI gen7 questions .
  75. disassembled my engine last week. rings.
  76. Vortech Question
  77. opinions on cam
  78. Which pulleys with no belt slip on ATI?
  79. which plugs/gap with ATI
  80. Finally got in the tens :)
  81. Unleaded Turbo Blue at the pump Cincinnati/Dayton
  82. Help identify this turbo?
  83. New setup what do you think
  84. My new toy
  85. STS Gtech 0-60
  86. Head swap.
  87. How do I figure out which turbos are which?
  88. 10.77 @ 138.86
  89. Newbie,How long to install 7# ATI?
  90. 78mm FAST Intake & ATI Results
  91. Can someone explain compressor maps?
  92. STS 2psi Et's
  93. What is the dyno record on pump gas?
  94. Automotion Steel ATI bracket showed up...
  95. T-76 guys, What size wastegates are you using?
  96. FI head flow
  97. New numbers...
  98. qmp kit
  99. Turbo Kit?
  100. Iron Heads on the QMP Turbo Formula
  101. ??How much is the procharger/magnuson crank pinning kit..??
  102. pics of ATI crank pulley installed?
  103. Procharger guys,ATI+GM Warranty??
  104. How are your cars idling with the Mototron 60's?
  105. 8.7:1 or 9:1 - Help Me Decide
  106. ATI Procharger decals
  107. vortech supercharger repair help needed
  108. ** Do Turbos Care If????
  109. Best oil weight?
  110. over 1 year no CAS TT
  111. Electric Supercharger
  112. Selling the Procharger . FI change
  113. got a leaky head gasket, help with options
  114. Procharger guys (Interesting read)
  115. Another FI Fuel question...
  116. help please
  117. rob raymer
  118. spraying nitrogen on intercooler?
  119. a little different fuel setup
  120. what turbo for a ls6 camaro?
  121. Anyone have a ATI(s/c company) crank pinning kit I can rent?
  122. Holy Crap!! LS1 STS Is Installed
  123. Cam Choice, Twins ... Poll
  124. Cog Pulley Update 3/30/04
  125. Turbo Pics Please
  126. Ford newbie has questions
  127. MAF location with multiple turbos
  128. Progress on my car...
  129. Worth swapping out stock cam for 216/220?
  130. Just ordered the new D-1SC 8-rib setup
  131. 6-Rib D1-SC and 10 Sec Times
  132. TurboTech wastegate question
  133. 1/4 mile times w/ turbo
  134. Aftermarket MAF or MAF Ends with SC?
  135. dyno vid from sunday
  136. Front mount intercooler for Vortech?
  137. Sat in PSJ'S car today.
  138. FI Survey - What size injectors and power level
  139. DIY water to air intercooler
  140. Advice for a 600rwhp turbo setup?
  141. HP inline pump vs. intank hp pump
  142. QMP Turbo Formula....LOT's of Interesting Stuff...
  143. Anyone running a FAST intake with their blower?
  144. Stuttering at part throttle...
  145. External Fuel system help ??
  146. read and heed
  147. fi vs big ci
  148. F'ing ATI
  149. what's a good head and cam package for ls1 turbo
  150. How much boost
  151. How are these numbers for stock motor, 6 psi?
  152. Any turbo technology knowledge?
  153. need pro charger information.
  154. Supercharged Throttle Body.
  155. Supercharged Throttle Body
  156. Waiting Part II
  157. cam selection
  158. run this by the FI guys..
  159. NGK-TR6 or TR-6 Iridium
  160. 2.75 pully
  161. Need vortech 2.5 pulley belt #
  162. unleaded race gas vs xylene mix?
  163. Hey trtturbo
  164. wtb: ATI procharger kit for 98 ls1
  165. Saw "Big Stuff" yesterday
  166. Master Power Turbochargers
  167. Problems!
  168. If my compression is 8.5 will...
  169. how much boost
  170. QMP Formula Update....780rwhp/850rwtq
  171. Got My STS Turbo Kit Today
  172. 99t66ls1's finished t76 system
  173. On a turbo'd car which is better ? Automatic or Manual?
  174. gasp, heres a turbo for you guys...
  175. Headers and supercharger installation specials
  176. New 5# ATI supercharger
  177. Octane Question
  178. Radiator Choice For 404ci Incon Car
  179. help please
  180. Need IAT Sensor
  181. should i super or turbo?
  182. Separate Oiling System For Turbos
  183. Turbo Guys!, I need help! What Kind of Turbo is this!!
  184. y2khawk...where are you?
  185. Procharger Cam
  186. GP on 60# mototrons
  187. Newbie, Supercharging help!
  188. Need pics of TTi setup
  189. Need some Ideas/Help
  190. Cogs... to be or not to be?
  191. time for new heads
  192. mike black ls1 t/a
  193. Ordered the Steel Automotion Bracket today
  194. Rumor on cometic gaskets.
  195. How much should this make?
  196. LS1 Twin Turbo's
  197. Turbo Size Question??
  198. nbm00ws6 - PM Box full
  199. pics of installed FMIC
  200. Boost Question
  201. TX2K4 dyno competition results
  202. Oil returns on turbo setups.
  203. Been Busy
  204. D1-SC with Stock Internals???
  205. Switched from T-56 to TH400
  206. ATI made 575 rwhp but problems - need help
  207. only a tenth away from my goal :)
  208. Need good supplier for aluminum tubing!
  209. Input on turbo kits
  210. how much power and boost???
  211. What size belt?
  212. What gauges???????
  213. Big Stuff 3 ECU+ boost= awsome
  214. Votech question
  215. Question on headers and pulley size?
  216. hi i want to know some thing
  217. noone is ordering Mototron 60#???
  218. vortech pulleys f/s
  219. Single turbo ls1
  220. Slowly, but surely!!! Thanks, ATI, Automotion and LS1 Speed!
  221. Turbo on my 422
  222. Incon TT...
  223. You like stealthy installs?
  224. What kind of gains from manifold?
  225. Where to get a high quality BOV for 1200 HP?
  226. can a cam cause a loss of hp?
  227. Car's off to MTI for forged longblock any helpful tips?
  228. Guys Running Big Boost ( 12+ ) What Is Your A/F?
  229. What rods you FI guys using?
  230. turbo need for my 383ci .
  231. Help! Overheating after ATI install
  232. My new Iron Block from APE...Pic's
  233. where to find 3.5 and 4inch exaust mandrel bends?
  234. the highest RWHP on a LS1????
  235. 77cc LS6 Heads from WCCH
  236. Pinning the ATI pulley
  237. TT setup and cam???
  238. And now a little extra umph for the competition
  239. Those of you with stalls
  240. A lil shop fun
  241. need parts for vortech V9 kit, f-body
  242. Rich or Lean??
  243. Cylinder Head recommendation for TT
  244. need 2.5 vortech pulley
  245. just got my new cam :)
  246. What size turbo???
  247. Paging black ls1 t/a::::
  248. slow spools and lag on each shift
  249. Special moment I had with my ATI SS...Class Winner At Seattle Roadster Show...
  250. Options with going to an 8-rib setup/how to get more boost?
