View Full Version : Forced Induction
- no FMIC
- Head gasket question
- Why can't I find Turbonetics 7675/7875 dyno results
- Will this CR be safe on boost?
- Flexfuel sensor install on e67 ecms
- Show me your front exit exhaust setups!
- Stock cam turbo spooling ability
- Best shop to take you car for tuning in lousiana ?
- help me decide on a turbo for my build
- Need transmission advice ls3 with F1r pro charger
- Header ?
- About to pull the trigger... What do you think?
- Speed Inc - Procharged '02 F-body results!
- Custom Drive by Wire
- Procharger Intercooler cores?
- anybody using aluminum down pipes
- Just wanted to thank Martin@Tick & Comp
- 4.8 turbo pt88
- Who makes custome air to water heat exchangers?
- Twin Turbo Intercooler?
- vendor t6 crossover
- Twin turbo sizes
- looking for a kit minus headunit
- LSA intercooler
- Will C5 oil pan fit my LQ9? Turbo k member/turbo build info
- 383ci stroked twin turbo'ed ls1'
- Question On Gapping Rings
- How much boost on pump gas?
- Good deal or bad deal for a 5.3l short block
- Turbo, 6."TURBO" hats & other Turbo shirts
- Looking for a turbo
- Cam for LS3/S480?
- 4th Gen Formula and an S475, will it fit with everything?
- PLX Boost Gauge as MAP sensor?
- Can we get our stock bottom end 5.3 in the 4's???
- What size meth injection nozzles?
- Thumpy turbo cam?
- Favorite build threads??
- 88mm Build Slowhawk BUild Coming.. Glad to be back racing
- Procharger build help
- P-1SC tentioner pulley not lining up
- merge pipe ??
- S480, 77/87 T4 or 88/96 T6 on Stock Ls1?
- Turbo 6.0 powered mud truck, weird ticking noise with vid
- Intercooler mounting
- Burning Oil/Oil Resrictor Question
- O2 sensor placement
- these sufficient for twins?
- Info please
- primary, crossover, and downpipe sizing
- need help with oil drain fitting
- need a new compressor wheel pt88
- Twin Intercoolers and boost
- Size and restrictions running S375.
- Cheap chinese superchargers?
- TT fbody question
- Budget, reliability, and power; yes I want it all Chico....
- 4.8 with 317 heads
- GTO P1SC Bracket and Head Unit with C5 accessories
- GT5598/427 LSX 99 Camaro Build
- gt45 turbo
- 72 c-10 6.0 bw s476r
- What wastegates for 427 lsx
- Turbo street cars inside please
- Which size injectors?
- 5.3 with garret 74mm/102ex and 1.32AR
- edelbrock vic jr injectors?
- Curious: Why don't cold sides require v banding (turbo)
- p1sc on stock L59 5.3
- Methonal a/f at idel
- 05 GTO Procharger rotation?
- Pushing water question?
- Ring gap & cam specs for a LS 408
- ZL1 Spark plug
- Looking to buy Treadstone intercooler
- 408 forged LS3 Magnuson FI question
- Gap on my plugs
- Need some LM7 turbo help please
- Need some help
- help me turbo my 370
- Magnuson Heartbeat Dimensions
- Any aftermarket computer guys running a gen4 motor on gen 3 crank sensor?
- Stock ls3 piston ring gap for boost
- Fuel pump in tank and in-line thoughts.
- Best intake/throttle body for a turbo setup??
- turbo build.. 5.3l... head gaskets
- torqstorm on a 4th gen 2002 ws6
- oil + water cooled turbo pumbing
- stainless steel braided teflon hoses. what clamps to use?
- ls3 cam?
- tt 5.3 4l80 e
- The FR8TRAIN new 2014 build (2-16 Update)
- pin install
- Second guessing my part selection. Need advice
- TT Cam Recommendation
- Turbowerx Exa query
- 402 build.. want to go turbo but keep ac
- ProCharger 2014 Stingray C7 Corvette Supercharger System (Now Shipping)
- Boosted LQ4 piston Ring Gap?
- Pulley question.
- LSX Swapped SN95 with a S476R /TH350, time to build a track car
- Intercooler nitrous spray bars.
- forced induction plus nitrous?????
- ? 's on 11/1 compression on turbo 408. need input
- turbo 5.3 s10 build questions
- Can I get guidance on if this is a good deal or not?
- procharger or turbo
- Chargecooler for Holley Hi-ram
- F.A.S.T. 92MM Intake Question
- Question on CR with a D1
- S475 or S480 on my 5.3 317 heads. t56
- Fueling/Tuning Issue Help!
- How much boost with 823 heads?
- Carb Perimeter plate for meth injection ?
- Supercharger Newb
- Please help me decide ....lq4 s475 or s480 street car
- carb setup cam with boost
- Walbro 416
- help choose my turbo
- TVS 2300 cable throttle body and bracket??
- Does anybody have a cam only turbo 5.3 in a super light drag car? Need input.
- 3 255's hot wire?
- Not a build thread yet but just want to show the icing on the roots blower cake!
- What turbo size should i go with?
- whats it take to run 9's nhra lagitamitely
- Rear mount positives and negatives.
- picked up this turbo for $100 anyone know if its worth a crap?
- Keeping Cool
- VNT Turbo rear mount questions
- Which turbo with my build ?
- stummped on routing
- LS1 boost build/reliability?
- Trade BUILT for BIG BOOST !TURBO 350 and BUILT CONVERTER FOR SIMILAR T56
- D1SC build spending spree - Opinions?
- 2001 Camaro ls3-s480 turbo-4l80e
- Forced induction question???
- water pump question
- The Gap Thread - Spark plugs
- Fbody turbos in CO ?
- How far do you drive it....
- Best place for oil return?
- High comp low bost 408 questions
- Are 60 lb Siemens deka injectors good enough for turbo ls1?
- STL Tuning???????
- Maggie press on pulley quick change option
- L33/GT45. Questions before next purchases.
- PT7675 CEA turbo
- OLSD - Hptuners guys, iat fueling fix?
- How much power will Callie's ultra billet h beam rods hold?
- Best Plugs For My App?
- WS6 Build #3 2 1/4" hot side twin scroll S480
- Compressor Map Airflow
- Looking for the best tq. converter for a turboed big HP 4L80E car
- What is the required TB CFM for a partricular application?
- Speed Inc. Stock M6 C5 picks up big power with A&A kit!
- Precision GT-4788
- best victor jr. elbow for boost?
- Turbo four door 55 chevy build
- How much HP am I giving up?
- NEED maggie 8 rib pullies mp112/122
- Did a auto swap do I need a retune
- Can I make 500-550RWHP with this setup?
- Tb???
- How much fan is needed for boosted+ac car?
- 05 S2000 (turbo LS1 swap)
- Non-ac turbo guys. Ways to keep cool? Little car fans any good?
- Twin turbo upgrades
- PRC 247cc heads for boost?
- Magnacharger parts needed
- CBM 2014 Performance Products Catalog
- External pump for "street car". Need help
- Question ab big injectors but stock fuel rail
- stock Iron headed LQ4 limitations
- LQ4 pistons for boost?
- spintech oval exhaust sound?
- 86 Mazda RX7 FC - 5.3 - TC78 build
- Looking to stand up my radiator
- Want to buy precision 8891
- New pulley availble for ProCharger users
- ~NEW Huron Speed V2 Single T4 Turbo Kit *GROUP PURCHASE*
- Thinking about upgrading my turbo....
- Speed Inc LSX alternator relocation kits!!
- Gauges for turbo build
- 370/91mm/4l80 bird
- LS7 Exh manifolds anybody using ?
- F1R intercooler piping size
- Should I loose the FAST?
- ***Big changes for 2014***
- Pure Evil - VR CTS-V Coupe, Heads/Cam, Nitrous, pulleys, Weld RTS & ADV1s...
- Who has the best price on s475
- First day above freezing, so what else to do but test the new TiAL blowoff.
- gt45 with 76mm compressor
- Part Number for NGK BR8EF spark plugs
- 1100hp with an f1r
- Need opinions on cam
- LQ4 Turbo S300 Or TC78?
- Corret part numbers
- ***LMR Twin Turbo C7 Corvette makes 836rwhp and 737rwtq***
- 1972 Chevy C10 5.3 turbo
- spark plugs
- how much boost on stock lq9
- 370 or 408?
- Twin Turbo oil feed lines??
- water/meth injection
- Methanol Injection questions....
- Slo-poc, Futral Motorsports Build
- Junk Yard LS...Cracking the Code!
- Am i the only one with this engine combo?
- Porting a holley hi ram for boost ?
- Buying a USED Procharger?? LQ4
- 02 TA Procharged
- Huron Speed stepped up to the plate to fix an issue that was not their fault!
- Thinking of going turbo
- Sick 650-rwhp CTS-V Wagon content inside!
- LS2 or LS6 intake for boost?
- Stock LS2 and a TC78, is the turbine too small?
- budget turbo setups
- Who is running a bumper exit with a bullet muffler?
- Need some help picking my wastegate size
- super oil system for rear mount turbo setups
- how fast or how much power out of a bw475
- Purchasing an on3 turbo setup...couple questions
- Best single turbo for high hp LS1?
- Turbonetics .96 vs PT .81 vs PT vband pic comparison
- pt94 is it too big for the street?
- What AR to use on twin turbo 5.3?
- Turbo Motor with No Turbo
- Budget Turbo LQ4 Cam selection
- Ysi
- Whats a good inexpensive twin turbo kit?
- Need some guidance
- My 80/20 meth/water experiment
- John Deer Hy gard Trans Fluid?
- Novi 1200 s/c on ls3
- Truck manifolds with egr, ok for turbo build?
- Planning P1SC
- Benefits of E85 + meth?
- Tial Q 50mm BOV spring rate test
- Frontmount LT1 Question
- help with piston/rod selection
- Truck manifold guys, how close are the flanges to the frame rail??
- Twin Turbo TA Upgrades
- Who to buy a turbo cam from....
- Twin 4.5" Intercooler question
- Which cylinders do I pair for Twin Scroll ??
- lsx intake
- Twin screw or centrifugal?
- Procharged and boost???
- head and fuel input requested for new build - supercharged 2003 Z06
- What to do with O2 sensors on stock computer/HPT?
