PDA
View Full Version : Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 [184] 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230
  1. stock pump
  2. What would it take to build your own meth Inj. Kit??
  3. All you Accufab and Wilson Tb users...
  4. Turbo cam comparison and dyno results
  5. huh, ever see a 4" obx type (xspower) intercooler like this?
  6. Finally, PRELIM numbers, home T76 kit.
  7. Where to find S/C belt
  8. Help needed...
  9. Vortech S Trim vs. ATI Procharger P-1SC
  10. 8 rib pulley for SDCE tensioner??
  11. Intake hat for the D1-SC
  12. Supercharger or Turbo for me???? Totally stumped
  13. HKS boost controller
  14. F1 pulley torque specs?
  15. Plastic Plenum
  16. Hi Flo's "Street Force" twin turbo system for C5 is up and running
  17. Who holds the record for highest 6 speed FI on pump gas?
  18. (THE OFFICAL)help noobies choose the right cam for application!!!
  19. Turbo guys - do you use a full dish or partial dish piston??
  20. Finally started my own LS1 camaro TTi race kit turbo project
  21. D1SC pulley swap! Glad I did it.
  22. Turbo for road race?
  23. best turbo kit
  24. single or twin turbo?
  25. Running A/F < 10 . . . Build Boost Or Not?
  26. Where to get a bypass valve
  27. turbooost
  28. Any reason NOT to use a BOV w/ my turbo?
  29. If you are looking for YSi stuff....
  30. Did BigTTPaul run a 8.5?
  31. MasterPower GT45 results
  32. Finally!! Got the tranny, motor, and twins installed!
  33. Any suggestions on a possible problem
  34. Blow off valve
  35. ls2 402 twin turbo VIDEO
  36. IAT relocate to EGR location. How?
  37. Turbo or Supercharger!!!
  38. GMR SPEED twin turbo ......
  39. Extreme FI Heads....
  40. Need help! Which turbo system to buy for emissions compatability?
  41. Turbo Stuff at SEMA 05
  42. Multi Level Boost controller
  43. Internal Wastegate - Downfalls?
  44. Need Sts Tuning Help In Il
  45. cam
  46. Weiand 144 Blower
  47. STS turbo size?
  48. Street Killer Dyno Numbers
  49. Cam for Powerdyne kit????
  50. Any pics of LS1SPEEDs "Eliminator" turbo kits?
  51. Turbos "Look Inside"
  52. Is it possible to buy everything but the head unit?
  53. Procharger needed
  54. CARTEK C6 Stage 1 Twin Turbo First Track Runs, 10.62 @ 130
  55. New to the Turbo... NEED HELP
  56. STS Doubters....
  57. LT1 Procharger 12 rib D1SC/P1SC 7.65 and 3.40 people inside!!!
  58. crank pulley problem
  59. SC's with ported & polished TB?
  60. Should I be OK with my 918s for the time being? *9psi and 6.0L heads*
  61. Need assistance on FI gauge selection
  62. ***Make Your Own Sale - Save Up To $400.00!***
  63. Roots type blower?
  64. Turbo guys inside (STS)
  65. boost gauge?
  66. Made a few 'street trim' passes this afternoon
  67. PTK is finally here!
  68. need advice on tt sbc project
  69. ATI Procharger 5-7 psi
  70. Design on FMIC... HELP!
  71. Post Pics of your Meth Setups
  72. Whipple Superchargers?
  73. Pic of turbo headers
  74. Anyway to stop the STS oiling of the engine?
  75. New STS Times
  76. Want to upgrade to an 8-rib
  77. 67 Camaro's 104MM Update
  78. Deeper in the 8's with CE
  79. ID of Precision turbos
  80. A/R ratio for 427ci twin turbo....
  81. Magnacharged LS1
  82. W2w
  83. advanced turbo tech
  84. TTi Stage X - Stock Bottom End - Corvette Dyno Numbers
  85. cam with super or turbo,good idea?
  86. D1sc kit on Ebay? Is this the old style D1?
  87. Rough Idle problem solved!
  88. Lrry93 finally good results from the STS
  89. Where to spray meth at?
  90. Where to spray meth at?
  91. DIY 6.0L truck manifold TT?
  92. part # for 8 rib belt from a/c to ati damper
  93. Precison released there own line of ball bearing turbos
  94. Did you know.........
  95. Newer Numbers
  96. Hi-Flo Horsepower Numbers
  97. procharger/LS1/1970 Camaro - has anyone done this?
  98. lQ9 heads??well im ordering a turbo and new heads and cam
  99. Bandwidth at EPP
  100. ?'s about stock ATI bypass valve...
  101. pt88 questions
  102. A2W intercooler fill.
  103. drive 3000 miles with an STS?
  104. twin 67's....or.....
  105. I need experienced opinions on the STS turbo setups
  106. Difference in meth/water/washer fluid ??
  107. Wtf Is Wrong!?!?!?!?!
  108. Rumor Has it 3 Hot chicks are working on my Turbo TA
  109. MY friend IS nuTS! 10 PSI ON A STOCK MOTOR!!
  110. low-end torque loss on turbo cam
  111. Can I drive without tune?
  112. Help me finish my SC setup.
  113. Any SLP shortblocks with FI
  114. Turbo Horsepower Numbers
  115. T56 w/ twin setup
  116. 10/27 Turbo Upgrades
  117. single gt35 on stock ls1?
  118. which way to go
  119. Futral Does FI Too! New Shortblock!
  120. Why do supercharged cars seem slow???
  121. LS1 pumping out 837 hp @ rear wheels!
  122. oil drain to oil level sensor hole?
  123. Cool Air plus Boost=mucho fun!
  124. Belt tension on a D1SC
  125. HOw many of you have saved your crank after spinning the balancer
  126. Boost on a D1SC
  127. 01 SS Supercharged complete
  128. coughing back thru intake, popping pipes loose
  129. Boost w/ F1 impeller RPM maxed out????
  130. A Different Boost Gauge Question
  131. Blew out my Jet-Hot Cats
  132. Ain't No Quitting at Hardcore!
  133. different crank pulley with procharger???
  134. What RPM should I see full boost at from a P-1SC?
  135. Has anyone attempted this?
  136. Need help choosing a cam
  137. sts abd AMW PCV catch can how to install it
  138. ATI Back Bracket
  139. Help w/ boost and some N20
  140. Fuel injector question
  141. Boost gauge question
  142. just got my STS Turbo
  143. Transgo kit for STS and 4000 stall
  144. twin turbo "kit" for fbod?
  145. some recomandations on wastegates and BOV
  146. Intercooling your turbo???
  147. Coming Soon... The Magnuson Experience!
  148. LS1 knock sensor vs LQ4 knock sensor
  149. Will this work on a sts set-up
  150. A few newbie FI question
  151. Budget Turbo Kit/Pre-fab Kit???
  152. DFI help please
  153. Preliminary Dyno numbers on "The Beast" Dyno graph inside
  154. Need help analysing this cam for my application
  155. Vac/Boost gague, where do you hook it up?
  156. Best combo for 5.3 heads
  157. what plugs for Vortech SC IC with H&C
  158. valve job for FI setup?
  159. Eastern Forced Induction meet.
  160. Magnuson's LS2 Dyno Numbers!
  161. Blow through carb turbo systems?
  162. 6.0 truck manifolds.
  163. How come turbos always have that rusted look?
  164. Cooling issues
  165. Twin 63 Turbos, how much power??
  166. CARTEK C6 Stage 1 Twin Turbo dyno results.
  167. whats this guy using to build boost?
  168. Recommended Stall for F/I setup?
  169. alt bracket
  170. Can I run a turbo or SC with a CC306 cam in a stroker LT1?
  171. big blower cams, do I need one ?
  172. Extending MAF wires
  173. Need Some Feedback on Setup (TT 04 GTO)
  174. does a gt47(88mm) really spool faster than a pt88?
  175. Some pictures of the Harlan's TT project and Derty's Outlaw 10.5 project are up....
  176. Metco breathers 1 or 2?
  177. MS3 cam D1SC, and Spray!
  178. Quick update on my 408 turbo setup...
  179. intercooler operation
  180. Replace pusher or add puller fan for ATI setup?
  181. most rwhp/rwtq with p1sc?
  182. supercharged
  183. F-1R placement?
  184. Budget turbo kit questions
  185. Good place to have a turbo freshened up?
  186. Questions by a Turbo Newbie!
  187. turbo kits for gto?
  188. Reworked STS intake piping
  189. 4500 lb sts truck in the 11s
  190. Bah, more issues!
  191. new best for me (street tires)
  192. The beginning of something...
  193. 370" turbo motor, what theoretical compression?
  194. What size reverse split cam 2 run for SC and Stock motor?
  195. 8-9 sec turbo cars what....
  196. Turbo Kits
  197. F-250 intercooler
  198. Pvc-pcv....
  199. New 1/8 Mile Times with STS
  200. My dyno numbers with P-1SC @ 6#
  201. What AFR's do you run?
  202. 99 Magnacharged Z28
  203. ***Garrett GT42 V-band clamp needed****
  204. How to choose P1 or D1?
  205. STS instructions
  206. TBYRNE Motorsports Is Now Taking C6 Magnuson Orders!
  207. Notice: Hi-Flo's Phone System may be unreachable today, 10/21
  208. New Best last night
  209. STS Turbo LS2 GTO...the details and graphs
  210. 2005 GTO Owners - Time To Order Your ATI Supercharger!!!
  211. T76 kit on ebay?
  212. How much out of a Forged 347 and a T-67?
  213. Orlando speedworld world street nationals.... ;)
  214. Turbocharger limitations
  215. procharger 6-rib d1sc???
  216. E-Boost 2 Guys
  217. stock 6.0 horsepower and compression
  218. '05 GTO ProCharger to be released November 15th
  219. 617rwhp on a Mustang Chassis Dyno with an STS!
  220. Magnacharger on a camaro/firebird?
  221. Say good night to the bad guy.....
  222. Million dollar question: manifolds -vs- headers
  223. Need help with cam choice.......Thanks
  224. Hi-Flo Turbo Systems - The final pic thread
  225. cutting hood for powerdyne???? WTF!?
  226. What RPM do you reach full boost at?
  227. whose turbo kit to buy?
  228. Twin Garret T03Bs?
  229. Need help with a procharged Z06
  230. flanges for 2003 silverado truck manifolds
  231. Turbo size for a 632 cubes
  232. New kind of Hybrid
  233. Twin Turbo- Single Wastgate
  234. Homemade ls1 turbo?
  235. turbo 6.0
  236. Stenod Performance Does it again......
  237. My LPE TT Hawk is in the new HPP...pics inside.
  238. 402/408 Plenum Volume for FI
  239. GM 6.5 Diesel Turbos on LS1
  240. 6.0 piston info needed.........
  241. Best FI piston's
  242. sts Turbo
  243. Turbo setup, LS6 cam, what springs??
  244. Wish me luck
  245. Ideas as to what happened?
  246. Phamspeed/Groundzero Turbo Kit
  247. Gauging Interest - Custom ARP L19 Head Stud Kit
  248. You all out FI guys may be interested in this...
  249. Dyno boost?
  250. Learn me something...tubular manifolds vs ??????
