PDA
View Full Version : Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 [39] 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230
  1. Water injection before intercooler? good? bad?
  2. What should I expect going from man pedal to auto
  3. Ls1 style but 3 bar map sensor?
  4. stock bottom end turbo 5.3 turbo timing table with holley hp, advise needed
  5. Make sure im wiring these derale 16925 pushers correct... pics
  6. New to builds and have some questions
  7. ProCharger Hiss
  8. 5.3 swapped notch china 7875, ls1 intake LJMS cam 80e stock pcm
  9. Turbo Silverado 4WD Launch Video
  10. Quietest SC'er these days for 800 RWHP on a 390ci....E85.....
  11. this cam any good for turbo 5.3 build?
  12. Got 2 newb boost questions!?
  13. Different requirements of oil between engine builder, turbo, or camshaft?
  14. 4.8 TTiX iron block build stroke it or no
  15. another turbo 5.3 build...
  16. 2013 Camaro Twin 6266s
  17. 4.5L Whipple LS Drag Week project.
  18. ProCharger F-1A-94 head unit price hike in two days!
  19. Opinions on my Foxbody build?
  20. pushrods
  21. opinions wanted on cam
  22. 1 3/4 vs 1 7/8 turbo headers?
  23. C5 Z06, going to sell the LS6 for LQ4 with boost, Help needed!
  24. Buyers beware
  25. Turbo help
  26. Ram Air turbo intake. . lets see your set up guys,post pics
  27. Vengeance Racing makes 750rwhp on stock bottom end and stock 1.9L CTS-V blower!
  28. 6.0 Turbo Help
  29. What turbo should I buy??
  30. Which 5.3 and why?
  31. What do you think about this cam (turbo 5.3l)
  32. LS 408 Vega 88mm Street tuning with video
  33. Dart LSN (388ci) + YSI w/billet wheel + E85 = 1141HP
  34. Turbo upgrade questions ? Turbonetic units
  35. lets play a game, where do you see full boost with your ebay t72 or t76?
  36. Hinson Motorsports is Installing an A&A Superhcarger Kit on a C5 Z06 This Week
  37. Co2 on the street
  38. 62 c10 turbo 5.3 build
  39. need a new tune if using a 2 step?
  40. 5.3 on3 7665 turbo swapped TType
  41. boost plus spray
  42. slight hesitation around 4k.
  43. Holley EFI remote tunning
  44. What regulator would be best for my set up?
  45. SBE W/Stock48 Baby Cam Over 1000rwhp
  46. Exhaust options for Procharger setup?
  47. Twin 7665s on 2010 camaro makes 806rwhp on 93 and 16psi
  48. 4.8turbo 300zx, needs a clutch 5xx hp
  49. Bullet proof up and forward turbo headers for 4th gen?
  50. turbo recommendation
  51. Looking for A2A intercooler for 1200rwhp, any suggestions?
  52. Best way to remove huron speed turbo?
  53. Emusa Waste Gate Failure - Pics Inside
  54. Sucked headlight harness into my f1c on dyno from broken zip tie
  55. Build me a motor for an f1a
  56. huron speed v1 ac kit users
  57. Sound of echaust leak?
  58. pump gas methanol to race gas 112 dragon fuel. any tuning tips? maxing out pt88
  59. What shifter do you have?
  60. journal bearing to ball bearing switch
  61. Holley EFI rev limiter question.
  62. will an ls9 cam drop right into an l33?
  63. FI or nitrous
  64. 4'' DP needs to quiet down ALOT!!
  65. Need good tune shop
  66. Microsquirt issues, no fuel/spark
  67. the weight difference between lq4/lq9 gen3/gen4
  68. How do you know what waste gate to get?
  69. FI new guy questions
  70. 71 camaro 5.3 swap build thread
  71. Throttlr body prices and quality
  72. 5.3 7575 661whp on 20psi
  73. help with turbo choice for a rear mount
  74. 370/ new f1A-94
  75. Heads, Best bang for the buck
  76. Procharger pulley bolt keeps backing out?
  77. 4.8, 5.3, or 6.0 Motor to build, Single Turbo
  78. Recomended supercharger for my set up
  79. Procharger kit Suggestion and Install
  80. 1000rwhp drift engine setup!
  81. holley mid ram vs vic jr with aaron elbow
  82. Melo Yelo GTO is alive. 347 78mm 4l80e
  83. regulator question
  84. Whipple 2.9 Guys. Have you upgraded your fuel system???
  85. lq9 budget build procharged help
  86. ~~~~~~~ RatCityRex's Turbo LQ4 66 Chevy II NOVA~~~~~~~
  87. 408ci/F1-A, reccomended intakes
  88. Give me some ways to clean up my engine bay (turbo build)
  89. How many turbo combo's to get it right.
  90. help picking gear for turbo car
  91. Ls1 fbody screw/roots style supercharger install?
  92. TC78 what can i expect?
  93. 4.39 @ 181 Speed Inc. Twin 76mm, Drag Radial , Midwest Chassis 25.3 build. Pics.
  94. 2012 cts-v noisey supercharger what the fix??
  95. not another boosted 5.3...
  96. Trying to figure out my boost issues?
  97. new 4.8 stock bottom record? 5.57 at 127
  98. on3 t88 turbo anybody Know anything about it??
  99. post your times aster bracket with t56
  100. TT 408 Stroker
  101. wastegate on only one bank?
  102. Another SNL Performance TT CTSV Build!
  103. What to be done to the factory LS1 for boost?
  104. Issue with Racetronix 160lb injectors- wrong ones!
  105. Stainless Works Turbo Headers
  106. Turbonetics Price Hike coming 1/1/15 *Order now at Huron Speed to Save!*
  107. Anyone want to go propane turbo?
  108. A few newbie boost questions
  109. LSX forced induction options for '95 body
  110. Ecs novi 1500 or 2200sl ?
  111. Turbo selection for 88mm, what is the best?
  112. Replace the k member or notch it?
  113. first time to track with my camaro. the "9" second one please read.
  114. eboost 2 controller. Where to put it in a Camaro?
  115. don't be scared of pro comp/ebay head studs
  116. lingenfelter GT9 cam ??
  117. LQ9 bent rods at 16psi/12*/11.5AFR
  118. Help me out! What heads?
  119. 98 firebird concider turboing over winter?
  120. What injector and fuel pump for 1,000 RWHP (LT1)?
  121. Lasershop - Got the Vette' featured!!
  122. Quick answer/opinion needed on my fuel system..
  123. picked up another turbo motor today
  124. Can this be done on pump gas?
  125. Pre build advice (turbo LT1)...
  126. Exhaust for Blown Street Cars ?
  127. Custom Turbo Build help please
  128. new guy ls build, looking for input
  129. 408/f1a
  130. carb style intake elbows
  131. Turbo and cam for 383 ls stroker
  132. 65 Buick Spec. build
  133. vertical radiator?
  134. Whats your opinion on this PRC 260 LS3 head
  135. turbo LS nova shakedowns (6.0 7665 th350)
  136. 3.890 5.3 tt
  137. 5.3 Turbo Build
  138. Any comparisons with s475 t4 vs t6?
  139. Vengeance Racing | What can methanol do for you?
  140. Making a Ported M90 Work?
  141. Retarded timing when trying to build boost, hptuners...
  142. supercharger for 99 ls1 c5
  143. turbo bracing
  144. LSX Subaru WRX S476r/Stock48 Cam/Dominator/E85 Build
  145. which head gasket with d1sc??
  146. advice on 4.8 turbo builds
  147. ARP head studs for L33. 234-4317 or 234-4110
  148. Wideband bung location on downpipe?
  149. Flipped exhaust manifold dimensions for Mustang II front end (help)...
  150. pt 88 turbo shaft play already
  151. Cam and Torque Converter for Procharger Setup
  152. Anthony Manna wins LSX Drag Radial and sets new class record 2014 LSX Shootout!
  153. Pro Charged 2000 SS Camaro
  154. LS1 D1SC Torque, Stalled Auto
  155. 1982 Fairmont Futura
  156. F1 cog belt questions
  157. need help
  158. help with borg warner turbos
  159. LJMS equipped cars Dominate NMCA LSX True Street in Indy.
  160. 76mm with 5.3 straight e85 no intercooler?
  161. Ring gap?
  162. mast ls7 heads 285cc
  163. Big thanx to Doug@ East Coast Supercharging(ECS) 914rwhp novi2000
  164. Need help, why didnt i hook off the line?
  165. Help me diagnose this :)
  166. Twin Turbo fender exit exhaust
  167. dyno numbers
  168. Tu2 hurt more than help?
  169. Lets see those On3 Turbo Ls builds!
  170. Re-gapping rings, what are you guys doing about rod bolts/bearings?
  171. Progress on the shop turbo street car.
  172. Anyone with Huron Speed V2 Single T4 Turbo Kit oil drain question
  173. two turbo LS cars just under 700whp? just another sunday lol
  174. getting rid of vortech and going twin turbo
  175. to big of turbo?
  176. How to option my Holley Dominator???
  177. 1971 Chevy C10 Stock bottom End LQ4 10.1@133
  178. 2002 Camaro SS AC Retaining Turbo Build
  179. Turbo gears can it work ????
  180. need help which turbo for project c10 opinions welcome
  181. M90 on an LS1
  182. procharger pulley size
  183. Good IVO\IVC\EVO\EVC for 383CI blower cam??? Would this Tick Performance cam work ???
  184. Help Choose Cam for my Turbo Build BTR Specs listed
  185. 58-64 Impala/BelAir/Biscayne turbo build help
  186. Noob building Turbo LS1 Nissan Sand Truck
  187. Exhaust sound help
  188. will the car start with 60lb inj without a tune?
  189. What is the best product to "glue" heads on??
  190. ATI ProCharger Supercharger kits for the 2014-15 Chevy SS Sedan
  191. Open flange on a divided turbo?
  192. My turbo project "1FastSS" getting ready to ship
  193. Vengeance Racing | 2015 Tahoe Lays Down 423/424 with Whipple Supercharger!
  194. what turbo for a 370 street car? opinions welcome
  195. winter turbo setup
  196. 5.3 with ls7 heads and 70mm turbo work?
  197. What V band is on the FI s480 standard Compressor cover?
  198. WG Placement
  199. Problem with 2012 GMC Sierra turbo
  200. Proven HP numbers with single Walbro 450 w/E85
  201. cnc 317 heads ?
  202. L33 s475 BW Fuel pump question
  203. Meth Kit or 2 step : What should I buy first?
  204. Alternator Brackets these days?
  205. Compression for my ls E85 motor
  206. knock sensor and oil on head questions
  207. prepping ls1 for boost. what else should i do?
  208. SC Dedicated belt vs 8-rib All on one
  209. dedicated turbo oil system, Ideas and inputs welcome
  210. Any reason I shouldn't run this cam and springs in my budget turbo build?
  211. Any point in custom cam?
  212. Quickest and Fastest with an 88mm turbo
  213. Blow-off valve location
  214. 5.3 questions
  215. Keep nipping the #7 plug.....
  216. 2014 Tick Performance Customer Appreciation Day Pictures and Videos
  217. how slow will it be
  218. Vortech V2 Question
  219. how to properly set up a horizontal mounted intercooler. What do you guys think.
  220. Shorty headers on mid mount twins LSX 5th gen
  221. twin turbo kit from ebay
  222. Help Me build my first turbo Car, Huron Speed kit ???
  223. looking to buy a supercharger kit or turbo kit
  224. K1 billet H-beam rods???
  225. Horsepower numbers for vs Denmah kit?
  226. Gen 4 YL6 6.0 block
  227. Turbo 383 idle hangs after WOT pull.
  228. LS1 with GT4294 blowing blue smoke after coming off boost
  229. Help choosing intake
  230. LS1/t56 s14 here - Turbo build coming soon
  231. Almost tossed a belt
  232. Magnafuel regulator & boost control
  233. ***biggest numbers out of twin s366's***
  234. Lsa head on a lq4
  235. Which brand throttle body?
  236. Supercharger or Turbo?
  237. Porting heads after valve job has been done?
  238. 370ci turbo build questions
  239. heads for boosted 408
  240. LQ4 or L99 for boost
  241. about to order a new clutch. which weight flywheel?
  242. New PB, 5.6 at 123mph 1.28 60' ...317s
  243. First Turbo Build
  244. Need help with twin turbo set up.
  245. Supercharger CI motor
  246. Turbo Review; On3 Billet BB 67mm
  247. Planning my turbo set up, input/ideas welcome.
  248. Best 3 bar MAP for 411 pcm
  249. 2010+ Camaro turbo kit
  250. Procharger price increse coming 11/03
