PDA
View Full Version : Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 [122] 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230
  1. need answers please
  2. What Fuel Pump and Gears
  3. Some build pics from today!
  4. FMIC Guys Come in!!!! ASAP
  5. Recommendations???
  6. Dropped the car off at Dallas Performance
  7. LS3/L76 intake VS L92 truck intake boosted
  8. your opinion on my set u..HELP?
  9. Another D1SC or F1C? Thread
  10. How much boost can stock headbolts handle?
  11. Gas Turbine JET engine Turbo wanted!
  12. GM High Tech Perf Down for the Count?
  13. once turbo seals start to leak is it too late?
  14. Max boost with a LS GM casting head?
  15. Have you ever seen this!!!
  16. STS rear mount turbo
  17. Truck Manifold walk trhough?
  18. Who do you recommend to build my FI short block?
  19. need help with IAT sensor
  20. TURBO CAM for L92 6.0....hows this?
  21. Engine having issues at low boost
  22. Rod bearing clearance
  23. PT88 ok to add oil restrictor?
  24. Powerdyne??
  25. ls3 and boost
  26. Ls9 supercharger
  27. Anyone bearing a steering knuckle for APS?
  28. Stock Bottom & Boost - Reliability List
  29. boost gauge install
  30. Final #s from TTi/402 A6 C6 Inside
  31. MP T76 news...
  32. Centri Superchargers... max psi?
  33. DIY Turbo Gurus Come in and Help Out With a Turbo Build Idea
  34. Some pics on my updated build.
  35. How many of you dowl or pin your mains?
  36. My new c6/6.0 mani a/c setup came in pics!
  37. Aps twin turbo upgrade c5 zo6
  38. Anyone looking for a large A2A?
  39. Running a hotchis front stab bar with APS?
  40. Bumper cover for FMIC??
  41. LS2 GTO procharger on LS1 f-car
  42. 6 bolt head question
  43. 954rwhp c6z!!!
  44. New to FI ??
  45. Which block? How many cubes?
  46. faster spool with same power
  47. 842rwhp @13.5psi Another APS TT C6 ZO6 by Speed Inc.
  48. Truck manifolds and steering?
  49. forged 347
  50. Debating on d1-sc or t72 turbo...
  51. how cheap have you turboed something part 2
  52. what are these procharger parts worth new?
  53. Low budget turbo questions
  54. turbo build
  55. Gonna try something new this year-a Vortech YSi!
  56. Anyone know anything about the T-netic's gtk turbo's
  57. 408/F1-C Vette
  58. Oil Pressure port.
  59. Difference Between D1 and D1SC Prochargers
  60. turbo with TH400
  61. ATI Pin Kit, ATI Dampner Help.
  62. LMR in Doha Qatar!!
  63. 16psi w/ Fast 92mm Intake pics inside
  64. Ideal Procharger Exhaust
  65. FI cam question
  66. check valve behind LS6 manifold
  67. Motor is out: How much $ to convert to low compression for turbo setup?
  68. LTx hangin in there :) New dyno vid and numbers!
  69. where to find 4" + ID silicone connector hoses?
  70. What oil to run??
  71. Timing Set Question
  72. STS guys please chime in!!!
  73. how much boost can a F.A.S.T plastic intake can Handle
  74. 13 psi on a 11:1 engine pump gas or e85????
  75. heads for turbo ls1????
  76. Ayone running AEM tru-boost?
  77. Converter on mild FI
  78. tvs 2300
  79. Cant buy OFi so i made my own !!!
  80. 5.3 pistons
  81. Are LQ9 heads any good?
  82. h/c for supercharger set up
  83. STS - separate turbo oil system Qs
  84. Few quick q's about meth
  85. surge valve too loud
  86. EPP's Cog Drive Assembly for F Body ProCharger now available!
  87. TVS 2300.....out with the old, in with the new!
  88. Carburated supercharged LS1?
  89. Long COG Belt?
  90. Which gate?
  91. Rear mount turbo setup, oil return pump suggestions?
  92. Just Completed 2000 TA Maggie Install!! Dyno numbers!!
  93. Hey what are you TT guys running for exhaust
  94. curiousity question..............
  95. Spray meth before the intercooler?
  96. Belt Needed?
  97. Gen-ttr turboI got a qu
  98. NEW FORGED MOTOR ..... TWIN TURBO Experts COme in!!
  99. Procharger Question!
  100. ls1 with sts turbo
  101. Another blower belt question
  102. Wideband not working
  103. PolyTech cog belts
  104. sts questions and concerns
  105. What headers can be fipped/modded for twin turbo use?
  106. tell me what you guys think about my new "blower" cam???
  107. 5.3 turbo build????
  108. Best 16 injector intake.
  109. Where to position methanol nozzlel, maf, and IAT sensor
  110. So am I the first one to blow up an LS6 manifold?
  111. How come there are so little F.I. bin files?
  112. New intake going on
  113. Wanting a rearmount, help me get it started.
  114. STS Problems
  115. Hey guys, Twin screw questions
  116. cruise control question
  117. Wastegate spring... maxxing out at 13psi!?!?
  118. my LQ4/4L80E tc78 build
  119. New Dyno Numbers: 700rwhp+ LS1 Stock Bottom A&A Vortech V2 S-Trim System
  120. Procharged C6Z?
  121. 8 sec Nitrous guy going FI??
  122. ??? P1SC to D1SC ???
  123. LS1 to LS6 need help please with supercharger!
  124. Simple question
  125. to much power
  126. Procharger+ nitrous?
  127. Need some help, GT42 turbo
  128. Looking to go turbo with stock motor. few ?'s
  129. APS turbo questions
  130. cutting out front grill
  131. l76 intake 2bar map part number
  132. whats the biggest cam i can go with on a turbo setup?
  133. How much power is too much for dd...
  134. Can a stock LS1 be built to handle more boost?
  135. Pullying Down... guesstimate on boost/power?
  136. Port or not.
  137. D1sc impeller damage.
  138. 38mm wastegate to small for 80mm
  139. STS Rear Mount or..
  140. too much meth?
  141. Autometer electrical boost gauge wiring
  142. Put forged rods/pistons in my stock LS2 or buy a shortblock?
  143. cobra s/c on ls1??
  144. 347ci 900-1000hp turbo build questions
  145. 403 Kene Bell
  146. I wanna go turbo
  147. DeModding STS WS6????
  148. 5.3L Turbo Build
  149. Wide Band With Warning
  150. engine runs for a second and dies out
  151. small turbo small engine?
  152. Need quick help mounting meth nozzle
  153. Finally! Higher boost levels with reliability from your current SC Setup.
  154. Will Procharger D1SC for LT1 work on LS1?
  155. ceramic coatings on hot parts?
  156. What Nitrous should I use?
  157. Question for turbo tuners
  158. truck manifold build
  159. YSi Pulley Combo
  160. Intercooler questions A2w vs A2A etc
  161. compression ratio question
  162. Paging peter@aps
  163. 14point7 wideband question
  164. Pics of turbo set ups
  165. turbo piping question
  166. roots blower on T/A
  167. Few recent pics of my turbo LSx 240sx
  168. pro charged lt1 stock bottom end
  169. My New KTP turbo kit .
  170. Reliable Daily Driver
  171. ATI inlet hat question
  172. What cam for boosted Ls1??? Help
  173. 88mm Turbo or smaller and F1R or smaller guys that want to race....
  174. Calling C5/C6 with procharger kits
  175. Incon twin kit question!!
  176. Forged 347 break in
  177. Interest in a 275 class for LSX Shootout????
  178. How to change Procharger pulley
  179. What engine config. will it take to get 1000+ rwhp under 22 PSI out of 62mm twins?
  180. motor builder !
  181. Top mount GTO turbo pics inside
  182. Anyone using E-85 instead of Meth
  183. TR Blower Cam
  184. Where do the head gaskets blow/leak/push water most of the time high hp builds
  185. 2009 Hummer H2 Twin Turbo Build - Pretty Sweet
  186. Turbosmart wastegates
  187. boost a pump
  188. 3inch or 3.5 inch down pipes
  189. Single turbo vs Twin
  190. radiator mod
  191. T-bolt Q.
  192. can i run a procharger with stock heads?
  193. Oil return fitting placement??
  194. big bore STS questions
  195. Low oil psi.
  196. Multiple Tees into manifold boost line, need some insight
  197. Intercooler Question
  198. PT88 Rearmount 408 (Longrange4u's LMR Build)
  199. Boost-a-pump
  200. Boost and valve springs?
  201. Procharger Plenum Fast 90/90
  202. what bearings
  203. Diamond Blower piston rings???
  204. Pic's of shaved turbine housing
  205. how do these cam specs look for a 427iron block d1sc?
  206. looking at a setup
  207. Am I alone in hidden charge from APSshippment
  208. How much will those pipes hurt my performance??
  209. turbo v6 camaro
  210. 3" downpipe HP limits
  211. ?'s for you blown ls1 guys
  212. Complete ATI ProCharger F Body D-1SC/F1A-C kits from EPP
  213. Finally started fabricating the turbo kit for my C5 yesterday
  214. rod bolts???
  215. some questions about turbocharging...
  216. a few turbo build pics
  217. STS turbo elbow diameter?
  218. magnacharger
  219. Car won't stay running after turbo install
  220. DIY TURBO sheild
  221. who tunes there own turbo car
  222. Turbo support pics..
  223. CLSD - Would enabling STFT be of any use ?
  224. another timing question
  225. Proud new Daddy teaching son the ways of Forced Induction
  226. 367 + 15psi + pump gas = which compressionratio?
  227. To anyone building a downpipe for their Borg
  228. Steam vent hook up options
  229. Magnuson / EATON TVS 1900/2300 Performance Maps
  230. My Truck Manifold Build
  231. Turbo/Supercharger C5 Question
  232. 76mm ideal size turbo for an LS2?
  233. Prochgr Enclosed or Open---Bypass vlv pro and cons
  234. turbo KR* question
  235. meth kits
  236. Some Upgrades Have been made, not sure on some other things!
  237. Joining the FI club
  238. just got it done
  239. FS: Methanol tank caps covers
  240. 85 MM LS2 or larger MAF?
  241. trade turbos..
  242. hot side suggestions
  243. What is needed to rework my nitrous motor for FI?
  244. Coated Intake?
  245. Who makes or can spec out a good blower cam?
  246. hp tuners 2 bar
  247. Boost gauge
  248. Our race track just banned forced induction cars from street nights
  249. Tuning Shops near the Deep South
  250. Best electronic boost controller
