View Full Version : Forced Induction
- T7875 vs pt76gts
- Huron Speed A/C Turbo Kit
- turbo size ?
- Critique my setup please.
- Procharger 4.5" dual IC Question
- Info on S475
- wastegate flange adapter- any good?
- Looking for a shorter plug than a TR6
- cut out question???
- iat sensor relocation after meth
- WG questions
- Amount of boost or rwhp that requires hellfire rings
- Let's talk exhaust and Prochargers.
- HELP 80mm Magnum T5 housing to T4 flange
- more boost but didn't get the results, e85...
- Rubber adapter for Autometer boost gauge?
- Flex fuel on ls1 f body
- Holly, F body, or Moroso Oil Pan...69 Chevelle
- Some turbo help?
- h/c advanced induction twin turbo setup ls1
- Removing Evap ???
- 370ci pt88 .96ar dyno graphs
- Stock longblock LS1 with F1R= 700whp.
- Refurbishing a d1sc question
- you gotta to check this out. its fucked up
- GM HighTech Writeup on Procharger/Wastegate setups
- cheap lq4 fairytales
- C6 Owners, What Specifics Would You Like To See In A Twin System?
- Noob to turbo. Race Cover? Very minute play in my turbo. (Picture)
- Went to Dyno this week
- Aster bracket on a procharged truck?
- Nice loping Turbo cam?
- 2001 Camaro
- 01 RCSB AWD 5.3l turbo w/ a goal of 600-650 RWHP
- best turbo for money
- lq4 402 pt7675 going to a ?????
- CX Racing LS fuel rails
- 370 turbo build questions
- 1st time out 370 PT88 th400
- Question about 5.3 motor
- Safe and/or possible to drive to the tuner?
- Who offers the bes price for turbo balancing?
- turbo cam ??
- 5.3 turbo build. gt45 or on3 76mm?
- Need a procharger
- IM BACK! (Tondss)
- turbo 347 GTO horsepower estimates.
- help me place blowoff valves/ symetrical twins turbo w/ pics
- Ls flanges for 1 1/2 scheudule 10
- Mechanical injected 5.3 with turbo
- matching compressor and turbine wheels
- 03 chevy 2500 6.0 364 turbocharger help
- More boost in higher gears?
- need a 3.625 dragonslayer crank
- lowering the engine to make room for m122?
- New engine build: need suggestions
- Jet hot 2500 coating
- who is running the ebay gt45 on a 6.0
- 4.8L turbo charger.
- What are realistict RWHP #'s LQ4?
- LS Turbo w/ straight methanol
- Tta
- Porting Cast Iron Exhaust Manifolds
- Procharger LSX transplant guys, need help
- anyone get the huronspeed AC turbo kit?
- Venting a ProCharger to stop oil leak.
- lq9 s10 rear mount turbo
- Dean Goodin's Real Street 275 turbo kit: By Tick Performance
- BMR Releases New Product - Turbo Low Mount K-member for 98-02 F-Body
- turbo newbie
- Procharger Blow off valve question?
- M112 @ 13lbs ?
- Fitting Holley Hi Ram under WS6 Hood
- Running a FAST 102 in a Forced induction car question
- Procharger Allen bolts
- RG-45 Wastegate Boost Creep
- between these two..
- new build , how would u do it
- Compression Question
- ls3 S/C or turbo?
- MP122 compressor map anyone?
- D1sc or mp112?
- 370 vs 390 vs 408
- VZ R8 from Oz
- My 98 Arctic White T/A Huronspeed No AC Build
- How driveable is your front bumper exit exhaust?
- Need Opinions: Is this enough space for my IC to properly Cool?
- JAX04s 00'GT AES347" Twin 66/65 Street Terror
- 370 s475 help
- volvo 242 lsx turbo
- Stumped, ecm resets in boost.
- who is running a cxracing gt45r?
- Can someone id GM a cam for me?
- 50# injectors
- ebay hot side 6.0 76mm and a t56 in 02 SS
- Gt 4294 big enough?
- colder plug recommendation for turbo 5.3 dragboat
- 2000 WS6 5.3 / 7675 turbo 6 speed build thread ~ First startup video page 3!
- Quick Q for PRC .675" spring guys & 20+psi....030" shim??
- Procharger Impeller Bed to Outlet Cover Sealing?
- 4.8 blow thru , zr1 cam ??
- Low or high imped?
- Iron 347 street machine!!
- Procharger Direct Mounted Filter?
- C5 guys with procharger, measurement question!
- 1967 nova turbo build
- 1963 Ford Falcon 5.3 turbo build
- 5.3 rod bolts
- 6.0 s480 1/8 mile
- First track outing pt88 5.3
- OD 8" balancer hits sway bar
- Poor 60' times
- 370 large turbine 88mm back pressure results
- Turbo not boosting Intermittently
- turbo choice for stock lq4?
- lg motosports f-body tvs 2300??
- Best option for plug wires with stainless works turbo headers?
- Looking for the right turbo cam
- how much hp befor pushing water? 1/2" headstuds, 3/4" deck heads.
- LT1 will not Rev past 4500 RPM
- Siliconeintakes V Bands & Clamps??
- turbo 6.0 build newb questions
- MSCB-1 Boost Fluctuation
- Budget/eBay head studs
- FI fuel question'
- D1sc procharger guys
- F1a vs. F1c....Procharger guys help me!
- Mustang/lsx turbo kit
- Turbo parts placement
- Tick Stage 2 Turbo Cam (Video)
- Forced induction panel inserts
- ON3 76mm A/C Kit............
- High Compression Turbo Motor E85 or 93+ 100% Meth?
- ***Late Model Racecraft's 750/1000/1250/1500hp C7 Twin Turbo packages***
- Fender exit exhaust for street car. Fumes?
- Turbo foxbody
- HELP WITH HP POWER ISSUE over 15psi
- Red Race valve installation help?
- d1sc + 408lsx powered TBSS i tuned
- Intercooler?
- Stand alone
- Got my Huron Speed t6 kit in the mail!
- Wastegate options
- Kentucky turbo and peformance still in business?
- Project turbo s10
- Total timing over 20psi, whats everyone running?
- 92 GMC Typhoon T76, 4L80E, AWD, Forged 370
- timing for 12 lbs of boost
- LR4 with 799 heads and ls9 gaskets with boost
- Can I use heater hose inlet/ return for water cooled turbo?
- What body modifications need to be done for a d1sc?
- tnetics midframe 78 DP size help.
- plug and play Micro2 for LS engines going up for sale tomorrow
- why does power curve get bumpy after 5,200 (centri blower)
- Maintenance/Oil changes on turbo car.
- new project..need help on a turbo size
- 57 chevy truck turbo ls1 build
- anyone been successful in geting a 10-12 rib belt on an F body?
- Opinions on cross flow/dual pass or conventional down flow radiators?
- Procharger bracket
- Suggest a turbo for my setup??
- Spare Parts Sleeper (99 GMC Turbo Build)
- How to seal the block off plate m12 threads for turbo oil feed line.
- Quick piston Question?
- S475/83/T4 Nova 5.7/127 first time out...
- Anyone Have Champion 3-Core aluminum radiator in f-body???
- Turbo making horrible noise under boost
- Rear mount oil system question
- Big power six speed guys??
- Best intake for boosted 402
- What would cause oil to come out of exhaust (STS turbo)
- Budget build questions
- Huron Speed A/C retaining turbo kits IN STOCK ready to SHIP!
- a2w intercooler question about water pump
- Driveshaft builder?
- which turbo for 408/L92 heads M6
- You guys happy with your jgs 60mm wastegates?
- Fuel System Questions
- need help asap tt lt1 breaking up in boost
- Comp turbo 100 turbine wheel vs BW turbine graphs inside
- Smallest T4 Turbos for LS2 Twin Build
- Need help with HP tune for turbo ls1
- New LS world record!
- 69 Camaro 6.2L Twin Turbo - Out Playing
- Will the Corvette PTK Twin Turbo kit fit an fbody?
- Ebay A2W
- Issues with RX Catch Can & PVC System......
- 5.3L set up for turbo good?
- Need ideas on a flexible fuel system
- Procharger F1X on an 09 CTS V - idle video
- megasquirt
- supercharger pulley to add more boost?
- Power gains from A methanol injection kit?
- Opinion on this cam for dd turbo 5.3
- E85 + Turbo + Plug Gap?
- HELP!! Procharger Parts Procurement (PPP)
- Need a little help picking a turbo for my build ebay gt 45, s400??
- vortech supercharger question
- turbo 5.3 transmission that will probably never see track
- cam question
- Head Stud Question
- PT88 + 255 tire + 4L60e = 9s!
- Rear mount exhaust / manifold question
- M122 build on 00 f body need help
- Is 190K miles on a L59 5.3L to many for a JY Turbo Build?
- Heat shield for fender exit exhaust
- What sz are the clamps needed for procharger twin intercooler kit
- Bearing Clearance Iron Block 383 Turbo
- Top Notch Customer Service Tick and FI
- T bolt clamps for twin intercooler procharger 98-02
- part number on 62mm procharger bearing
- Anyone with an F1C or F1R running less then a 4.00" pulley?
- procharger pully upgrade question
- looking for pictures of AN fitting on valve covers
- Another wastegate question
- More boost needed - Edelbrock 1567 e-force
- Every engine builder should have one of these
- 383 Twin Turbo overheating, which fans?
- Twin Turbo LSX T/A first dyno video
- Stainless Procharger J Bracket
- Race gas?
- high or low imp. injectors with holley efi... does it matter?
- Carwash Issues?
- WANTED: ls1 twin turbo kit
- Retune after turbo change
- 3.2 pulley/P1SC-1?
- boosting doubt?
- Holley Dominator EFI question
- custom ECS NOVI 2500
- 81ar turbine housing
- junkyard t76 5.3 ring gap?
- Any GTO owners with ProChargers optional 1300 HP intercooler system?
- 1957 Chevy all Fiberglass turbo ls Build
- small cubes and twins
- s 10 w 5.3 p1sc procharger
- 408 with a f-1a setup! gurus critique it please!
- Steves Procharged Silverado
- Chevelle FI fueling question
- What muffler for a turbo??
- P1sc record?
- 5.3 block machined to a.....????
- what pistons/rods for l76(ls2)?
- ls9 in 5.3?
- Procharger boost loss question
- what size precision turbo 5.3 silverado on 37s
- Updated Turbo Build Pics (Lots of Pics)
- A Cautionary Tale about Precision Turbo
- 1979 Malibu Wagon (denmah edition)
- Need some help with My 5.3 idea
- ls6 pcv setup with turbo?
