PDA
View Full Version : Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 [221] 222 223 224 225 226 227 228 229 230
  1. Boost Spike Issues - HELP!!
  2. ? for those with HKS BOV
  3. How Does This Cam Look For a Twin Turbo Setup?
  4. Incon TT cars at N vs. S Shootout
  5. Who to go with????
  6. DOES ANYBODY LIKE MY HEADERS?
  7. 224/228 .567 113 lsa + P-1SC + stock heads=???
  8. Why are Supras still winning?
  9. First Passes on F1 procharger at n/s shootout
  10. PCV issues
  11. What happened to all the TT setups?
  12. help still with ATI
  13. Charged Air TT Dyno #'s
  14. 11 lb. Dyno Numbers
  15. Which cam with an ATI Procharger?
  16. Can the Vortech SQ be Upgraded to S-Trim Gears?
  17. Pulled and Inspected the Motor (!!?!??!!)
  18. Supercharger sale - 1 week only!!!
  19. 01 gt w/ vortech 8 psi???
  20. Any interest in a digital boost gauge?
  21. not sure where else to put this....
  22. Need Heads for that blower car? MMS is the answer!
  23. Cam question for stroker and boost Ap.
  24. Help with a boost related question on LS1 block
  25. cleaning intercooler
  26. what will go if i add a super charger
  27. Vortech power cooler (intercooler) size?
  28. Powerdyne guys - Watch your fan fuse!
  29. $1700 to get started
  30. Incon kit. -BOV, or Waste gate??
  31. Cooling & fuel w/iron block....experts inside...
  32. Does anyone have this timing problem?
  33. Things that frustrate my WOT tuning.
  34. F I question
  35. What Should I Expect From my D1SC
  36. opinions on possible motor/turbo buildup...
  37. help with procharger
  38. Hit 7.5 psi tonight!!!
  39. getting started with turbo???
  40. Graduated High School Look What I Got!!
  41. ! ATI FMU
  42. Pulley change (ATI)
  43. F1 procharger= 21 psi at 5500 rpm ,
  44. LTRIM adjust for new Procharger setup
  45. Procharger Growing pains
  46. ATI D-1SC procharger kit?
  47. P.E tables not working, why?
  48. Vortech YS-trim LS-1 dyno'd (at last)
  49. GWP 422... Back up to 10 PSI!
  50. Which ati kit is best for daily driver
  51. Anyone with supercharger have a question
  52. supercharger with stock rear end ?
  53. where to cut to access pump?
  54. 12lb. pulley killed my trans. Suggestions?
  55. needed for FI project: F-body alternator brackets
  56. Need some advice
  57. Twin Turbo LS1: Wich turbos? What cam?
  58. Anyone wana buy some 50# injectors?
  59. computer program for procharger
  60. LS1Edit: Changes for new ATI fan?
  61. Hotcam with Blower?
  62. Vortech users inside
  63. Help! Setting up fuel system
  64. First Drive of Procharger = Major Problems
  65. single turbo on a4s
  66. Just How Loud is a Supercharger Kit?
  67. 5% off superchargers until 5/27!
  68. Weird problem
  69. ATI FMU
  70. Best way to up Octane?
  71. Drove a MONSTER Blown LT4 this weekend
  72. LT1 turbokit reliability test
  73. Spectacle Solution's Air Lid for Vortech Users
  74. What would be the problems with a SC and Nitrous?
  75. T Rex Pump
  76. Building a magnacharged LS1 from scratch
  77. Boost PSI vs. VE (efficientcy...)
  78. We have a guy with a D1-SC and a 100 dry shot!!!
  79. PCV Hose Routing with ATI
  80. ProCharger
  81. NEW BEST at the track with my D1-SC
  82. high compression + SC?
  83. magnacharger on a f body c5+truck guys help please
  84. Cog pullys for D!SC
  85. FMIC for vortech?
  86. Why does my blower belt keep coming off?
  87. The idea of a blower sounds interesting but...
  88. Where to buy Aluminum pipe for intercooler??
  89. Stock Rods???
  90. Dyno #'s for the new Vortech lid!!!!
  91. Finally got the Procharger to the track...
  92. 475rwhp/495rwtq on 7psi and 91 OCTANE
  93. Very rich idle
  94. Intercooler (inlet, outlet) pics???
  95. Need lower compression
  96. ATI Install Complete
  97. F.I. SYNTHETIC OIL BLOW BY ?
  98. Where can I find some Incon TT help??
  99. What it take to boost my 427 CID motor?
  100. TurboTech 60-1 Kit???
  101. What kind of power will this setup produce???
  102. A few pics of the Procharger install
  103. 2002 Z28 Twin Turbo Question
  104. Supercharger Theory Question
  105. What does the stock computer do...
  106. TurboLS1.net Forums are UP!!
  107. How much PSI and with what head unit...
  108. Updated LT1 Single turbo pics
  109. SLP high-capacity radiator and intercooler
  110. please look over my setup comments/suggestions?
  111. 10psi, water/alky, autolite 103's @ .35, stumbling
  112. Tuning in procharger with 42's.A/F goes below 10-1
  113. Info on forced induction
  114. What checks should I run for the 1st fire?
  115. ATAP Questions: Maxing out injectors?
  116. Best buildup for blown 6.0L
  117. 987 HP 911 torque twin turbo dyno
  118. Recieved my Reichard Racing Blower pulley today...
  119. I got my track #'s!!!!!!! PSJ, check it out!!!
  120. WHAT IS THE BEST HEAD GASKET @8PSI
  121. turbo or pro charger
  122. what supercharger to get?
  123. Intercooler/grille
  124. Dyno place refuses to dyno my truck-Procharger
  125. Wet shot, where to spray?
  126. Procharger guys who've replaced the bypass valve
  127. Motor went south - Rebuild in Progress
  128. Auto Meter gauge install.
  129. Correct Belt for Vortech 2.85" Pulley
  130. new motor today and need help with fuel?
  131. MAF 11250 Hz limit
  132. Need a set of LQ9 heads, where is the best place?
  133. Fuel pressure problem
  134. Hypothetical tuning questions... (700rwhp)
  135. ULTIMATE PROCHARGER SETUP 4 SALE
  136. Question about Xylene
  137. New Best
  138. Boost Tuning ?'s
  139. who is using dual 11" spal fans?
  140. My numbers are getting better!
  141. Extrude Honing Cast Incon Manifolds
  142. Pop off valve for procharger?
  143. BOV in ls1motorsports kit?
  144. Started re-tuning at Drag Strip with GWP 422
  145. problem with procharger
  146. Formulas with Prochargers please read.
  147. Any other turbotech users have had belt problems?
  148. Now It's time to get serious
  149. Any pros/con to running larger plug gap with F/I??
  150. Supercharger special
  151. Pics of my Dual Intank mod.
  152. How bad does D1SC lag?
  153. draw through vs. blow through maf
  154. Magnacharger Supercharger
  155. Stupid Tuning Question
  156. to everyone who has a procharger or has owned one
  157. Spin the engine how high?
  158. Using ls1 edit to tune supercharger
  159. Stupid question: 12# pulley safe?
  160. Best way to control fuel/timing
  161. What cam is everyone using?
  162. what is the proper way to increase my maf tables
  163. What is BLOW BY?
  164. Vortech @ 7lbs - 520 rwhp
  165. Single Turbo and cats
  166. Compression and boost questions
  167. Serious Fuel Pressure Problems - Please help
  168. HKS Bov users inside
  169. What to do about Vortech Sucking OIL?
  170. Just installed a D1SC Procharger!
  171. Dyno numbers
  172. MMS Procharger Kit
  173. Rattling noise at idle from my new procharger?
  174. TEST forum 7
  175. Should have my motor next week (Vortech YS Trim)
  176. Suggestions On Tuners in So Cal
  177. Air flow at Idle Incon Kit
  178. High flow MAF / 80MM TB's ?s
  179. Vortech 6# kit ?>>
  180. procharger and belts breaking question
  181. Nitrous with blower?
  182. newbie, hows my setup?
  183. Is there a difference between a wastegate and a BOV?
  184. EGT gauge users inside>
  185. Heat wrap
  186. which turbo is on that WS6 on ls1motorsports
  187. I want more midrange boost, how?
  188. True cost of an ATI blower
  189. setup questions
  190. Proper way to break in a new F.I. motor...
  191. a future alternative for F.I. heads
  192. A parts list for Turbo Tech kit.
  193. blower/piston questions
  194. question about boost?
  195. Part number for Gm MLS head gasket?
  196. whats wrong with us?
  197. best turbo piston
  198. borla plus procharger
  199. Plausible
  200. Max boost for 9.5 compression..
  201. Incon Turbo website?
  202. Does anyone here have the Mike Morgan Motorsports pulley?
  203. Air filters for incon kit
  204. Two more bite the dust!!!!!!!!
  205. whats the cost of a turbo setup for a ls1 T/A
  206. Max bore on 6.0L for FI
  207. Turbo Problem ?
  208. Anybody Got Any 6 Rib ATI Pulleys for Sale or Trade?
  209. ATI Pulley Change any tips ?
  210. Need some advice with LS1 Supercharger
  211. Twin Turbos
  212. Please Help???
  213. Which FI peeps are going to the N vs S Shootout in BG?
  214. Best Way To Tune With SMC Injection Kit?
  215. Twin Turbo setup on a 01 T/A?
  216. ice water intercooler
  217. Harlen (Please Help with 2-Step Problem)
  218. 1300hp twin turbo LT1 94 z28
  219. Turbo's Vs. Prochargers Help plz
  220. Nitrous vs. FI
  221. Superchargers hate heat!?
  222. Got to the Track, Not bad first runs!!
  223. Tuning for ATI
  224. Where to spray NOS?????
  225. MAF location
  226. Wait Time for ATI Procharger???
  227. Blow off Valve for ATI procharger
  228. PULLEY not pully not pullie not poulet
  229. Considering switching from H/C to S/C, any suggestions?
  230. how much boost
  231. Initial results With F1 and 8 rib Reichard Racing set up,.
  232. intake system
  233. Turbo Cam specs ?
  234. PLEASE READ!!! No Belt Slip with TEST Pulleys.
  235. Two serious questions, need help.
  236. I got turbos in my pants
  237. !Boost
  238. Stock LS1 with D1SC and 3.7" pulley. Boost?
  239. supercharge OR turbo my commodore
  240. LS6 intake & Turbo
  241. Just got an SS so now do i >>>
  242. Upgrading my P1SC?
  243. Twin Turbo + TNT = Crazy????
  244. which blower for a stock automatic T/A?
  245. Ok fixed one problem now I have two huge problems.
  246. Installing EGT question?
  247. turbo plus whipple?
  248. GWP after problems.
  249. Blower pulley questions....
  250. How much boost can this setup take?
