PDA
View Full Version : Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 [178] 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230
  1. Any blower guys using a speed density tune?
  2. Heat Issues??
  3. Routing intake pipe for STS between radiator/ power steering. What's the best way?
  4. Not LS1 but is Steve Kamis's Twin Blower Merlin still around
  5. my new t76 gts ans heads and fuel ectt....cool video inside!
  6. newbie fi question
  7. My Turbo Truck is slow... help!
  8. <1/2oz a big deal on P1SC
  9. Guys with Iron blocks, turbo, and qa1's...
  10. Gauge help for turbos
  11. Can we see the WS6 front ends with FMIC??
  12. remote turbo question
  13. STS turbo is pushing oil into intake piping. Gasket? Input appreciated!
  14. turbo cam theory.
  15. Greddy boost controller problem-sts kit
  16. FAL Fans
  17. Crank pinning, 2nd time around. Forged crank
  18. Turbo cam question
  19. 76mm or 80/88mm..
  20. Ideas on next round of mods. What you think?
  21. Valve cover oil in Procharger
  22. Getting textralia clutch for planned turbo which flywheel?
  23. Boost Spikes?
  24. controllers
  25. Procharger question
  26. Vortech cooling alternatives
  27. 671 BLOWN LT1 INSIDE, one question though.
  28. New dyno numbers: 638rwhp/588rwtq
  29. cylinder heads, velocity, cross sectional area, and forced induction.
  30. CAS Twin Turbo pics!!
  31. Sucked a chassis washer into my Z06!
  32. what spark plugs to run with turbo?
  33. ati procharger p1sc for gm truck
  34. Good Twin Turbos
  35. Vortech or ATI Procharger?
  36. Cooling concerns with new combo?
  37. Powerdyne Superchargers
  38. Z06 cam or Futral F7? Which one would you use?
  39. Where is Lasershop?
  40. Anyone checked this company out???
  41. Custom homemade air to water intercooler...
  42. Help finding weldon 9200 fluid pump for incons
  43. STS Help!!
  44. Slowhawks at it again...victor intake on purevl
  45. How much valvespring pressure?
  46. PSC1 for 5.3 Silervado will it fit Fbody?
  47. Finished!!!! Pics
  48. 408 truck with D1SC, good idea?
  49. Turbo Help!
  50. Best of all FI kits
  51. Best Intake for Forced Induction? (Supercharger)
  52. What spring for tial BOV
  53. 2 small gates vs. 1 big gate
  54. P1SC Boost VS D1SC boost
  55. True Duals
  56. 6.0 Crank boost - HP ???
  57. 6 days to decide on what turbo...one last thread.
  58. Header studs??
  59. Which gaskets and bolts for heads for boost ??
  60. Car misfires and sputters really really bad when under boost
  61. Turbo heads
  62. Looking for possibly a cheaper 76millimeter turbo replacement
  63. 80mm turbo
  64. 688 rwhp and 697.9 ft lbs of torque with a D-1SC at 14 psi
  65. How to adjust BOV
  66. D1SC Dyno Sheets??
  67. Need Help!!
  68. twin turbo collectors?
  69. what the difference between(flow wise): stock ls1 exhaust manifold & 6.0 exhaust mani
  70. best plugs, wires, and gap to run with boost?
  71. Anyone have success using toulene
  72. New Pics of Setup!
  73. LQ9 heads are done
  74. Question about turbo
  75. Speed Inc. Turbo?
  76. A couple questions for the gen III experienced...
  77. You won't believe this sh@&!!!!!
  78. Turbo kit for Trailblazer
  79. Crank/SC support
  80. BBK 80 mm throttle body ?
  81. Rotrex superchargers?
  82. Blow-through 750 carb?
  83. ATI Harmonic Dampener Pics (For Procharger)
  84. more STS numbers
  85. How much boost with these pulleys?
  86. What Kind of Power Can I Expect
  87. Spark plugs with boost???
  88. Plug gap for FI
  89. twin turbo gto?
  90. Why are turbos and Centrifugal superchargers so different?
  91. Almost ready to go again
  92. 427 turbos
  93. pics of my homemade turbo system
  94. Which B.O.V. for high power
  95. Help me out...
  96. how much are S/C benefitted by a small blower cam?
  97. Twin Screw's and Root's Blowers
  98. WTB: f-body lt1 supercharger
  99. Why I had been losing boost (pics)
  100. Installing Magnacharger on ls1
  101. Evap question on 2002 Turbo Z
  102. Do you guys fuse your gauges?
  103. s/c and cam ?
  104. looking for a good place to buy a T76, T67, or T61.
  105. 2001 clucth master mod ?
  106. some turbo help please!!!
  107. Turbo Oil Pump Noise?
  108. What needs to be done to the suspension on a blower car?
  109. Blue silicon couplings for piping?
  110. Turbo-acceptable shaft play (side to side)
  111. Heads???
  112. What Compression should I run
  113. Superchargers and Turbos Available At TBYRNE Motorsports!
  114. Engine Management, which PCM.
  115. Got My Stuff.....well Most Of It
  116. BOV. Does this sound right?
  117. Boost gauge question?
  118. Installed STS kit...AC running 24/7. Any ideas?
  119. GMR single turbo question-GMR Single Turbo???
  120. can this piece be purchased?
  121. CAS twin turbo car FINALLY running...
  122. what is lame about kyle's setup is that...
  123. Which supercharger cam? GT 2-3 or Speed inc SC1
  124. Twin Turbo Z06 Dyno Results
  125. twin T04E sizing question
  126. Building a Block thats turbo friendly, help
  127. Looking for a little guidance
  128. maf with supercharger problems
  129. Dyno again :( again
  130. Best deal on short block (assembled)
  131. Ok.. I give up.. where is it?
  132. How much boost?
  133. Any pics of Magnuson blowers on F-bodies?
  134. What else to buy
  135. Paging JZ 97 SS 1500
  136. Sts Intercooler
  137. Fox LS1, Single or Twin Turbo Setup?
  138. Tuning my turbo car
  139. is this a good turbo cam
  140. Need input....I want a SC. Waaaaaah!!
  141. Magnacharger camshaft suggestions?
  142. How does lower CR help with boost?
  143. Pictures of the Limit engineer 91 turbo for "Fear"
  144. low gear for turbo?
  145. Speed density tune with turbo?
  146. Mthanol Injection, IAT Sensor, and MAF Sensor
  147. Turbo Or Supercharger?
  148. LS1 S-10 Turbo
  149. Sneak pictures of my custom turbo fuel tank.
  150. STS+8psi+Meth Inj.=Boom on stock block?
  151. F13 and PP 59cc heads with turbo
  152. 1st day track results
  153. FI - Timing Chain
  154. What parts do you need for a turbo install?
  155. The Turbonetics Super T76
  156. Building new engine!! Need Advice
  157. vortech dampaner
  158. how much boost
  159. Power Outlook
  160. Adjusting Boost level need Tune?????
  161. Engine compartment paint on turbo setup?
  162. which fuel pump should i get???
  163. wastegate spring problem
  164. Correct oil for my turbo setup...
  165. Anybody know whats going on with the HI FLO kit?
  166. meth injection help.... few ?'s
  167. Quiet or loud S/C?
  168. When is O-ringing the block called for?
  169. Whats the best way to cool off a turbo?
  170. Advice: Looking to maybe purchase a STS kit and need info with my set-up.
  171. Spark Plug FI Question
  172. Installed the ATI D1SC? Come inside...
  173. FI guy's have a question on my build motor
  174. Dropping stock comp.
  175. What compression ratio and boost level are you running?
  176. STS kits, how much did you guys pay?
  177. congrats to red91Z for chevy high performance magazine
  178. Going to be one mean STS Car!!
  179. Supercharging a High-compression Motor.
  180. New Best Today! Details/Video inside!
  181. Boost Control Diagram
  182. STS turbos?
  183. update on slow progress
  184. Evaluate my FI setup!!!!
  185. new setup quistions
  186. Cam question
  187. Best Compression Ratio for Turbo
  188. Gauges Necessary for FI
  189. You saw the graph, here's the video...
  190. Turbo size for a 402???
  191. Turbo Mounting Angle
  192. What do you think about this set-up???
  193. Flex-a-lite fans
  194. using the SD-concepts tentioner with the Procharger 8 rib crank pulley?
  195. Farewell supercharger, hello turbo setup (coated manifold pics)
  196. ebay turbo crap
  197. Stainless or Mild Steel
  198. pulley sizes
  199. Procharger D1SC video/sound clips
  200. boost limitations 30+psi?
  201. S88 Questions???
  202. innovative twin turbo manifolds?
  203. 402 + P-1SC @ 6 psi Dyno results
  204. Need help planning my setup
  205. Turbo Mounting
  206. turbo cam
  207. Is the only difference between a TT and a T set-up.....
  208. Jose, Where Are Ya?
  209. what timeing chain? ls2 or double roller for FI
  210. almost there!
  211. PICS!!! Turbo headers,clutch,Fuel Rail Covers
  212. My Stenod Performance Single Turbo Build-up Almost there..
  213. QMP setup opinions?
  214. Not enough fuel?
  215. Incon TT for sale...$6500
  216. What are cars like ours worth?
  217. ANyone have a Q trim on center housing for sale/trade?
  218. D1-SC and 91 octane?
  219. SDCE 8 rib setup pics?
  220. Dyno Results :(
  221. Simple turbo cam question
  222. S95 turbo vs GT55-91mm
  223. Best Setup for Reliable 600hp Near Stock LS1?
  224. Turbo Exhaust Questions
  225. Stenod Performance...new for '06!!
  226. Single "STREET" turbo guys post up
  227. tuning a supercharged car?????
  228. which headgaskets ?
  229. 90mm MAGNACHARGER !!!
  230. boost gauge problems
  231. t60 TO A t67
  232. Heads/Cam for ATI ProCharger D-1SC
  233. Supercharged Ls1 Help
  234. METH Users Inside..........
  235. 2006 C6 Twin Turbo Project In Progress
  236. Fan ?
  237. t70 or t76 on a built 346
  238. Ls1 intake and stock throttle body restriction??
  239. 597 rwhp on Mustang Chassis Dyno with 11 psi of boost with stock LS6 heads and cam
  240. Blowing Dip Stick Out
  241. Custom turbo build
  242. incon trouble, need pics!
  243. Squires Turbo?
  244. Vortech Horespower
  245. Future procharger build any suggestions ?
  246. supercharger cam
  247. Procharger Balancer Confusion????
  248. 3.73 gears OK for FI?
  249. AllPro Head Question
  250. Twin GT3076R Turbos - .63 or .82 A/R?
