View Full Version : Forced Induction
- 98 Camaro On3 No A/C Build. 11/18/2013 It Runs.
- getting closer.
- zl1 intercooler pump pigtail
- Milled 317's pushing water?
- PCM FOR TURBO?? need to change or not
- supercharged 5.3?
- VR C6Z - Stage II heads/cam, Whipple, 5 psi...
- compressor, turbine match
- Am I going in the right direction????
- turbo cams
- advice on injectors and fuel system for E85
- Do I need to go to a bigger exhaust wheel?
- 6.2 truck 740hp+
- AMS Hearse and 80mm ETR-HO
- Intercooler or not
- twin PTE5862's goal of 650 on Corn.
- -8 or -10 return fuel line?
- Lightweight DIY vertical FMIC mount for 4th gen F-Body (No welding required)
- made it to the track today finally..
- Low compression 383 turbo selection
- turbo .. what do you guys run for motor mounts
- 01 ls1 camaro turbo kit
- +Awesome deal on AEM Meth Injection kits!+
- 8.76@156mph with stock nissan IRS and JY 5.3L...
- Pre and post filter recommendations for Holley 1800 ?
- Recommendations for 1968 c10 5.3 turbo build
- Our Gangsta 76mm, LS in Fox body....
- 2000 RCSB silverado, now with Iron 370 and FI 76/92 billet
- 1500HP E85 Fuel System Daily Driver
- 2009 CTS-V 427lsx TT 6266's
- Rear gear for 12 bokt on Turbo setup.
- Interesting F1 pics of new Turbocharged engines
- What ever happened to KP?
- S475 users come in
- **LMR Drag Radial Firehawk in Denton**
- Stock 5.3/6.0 truck heads turbo 700hp
- ly6 s10 thinking about twin turbos
- Need a little input...
- buying valve train stuff
- Maggie Magnuson tvs2300 FAIL!
- What pumps are you E85 guys running?
- **lmr in bahrain tuning race car**
- Slowhawk tune
- flex-piping for Charge pipe?
- First turbo build
- LS7 magnacharger
- 63 Nova single turbo questions
- intake cooling methods
- How far will a 7675 go on a 6.0?
- Need info on "6 bolt/4 bolt" motor. General nooB info.
- little different- TT LQ4 + M6 + not drag racing
- Hot side tubing crossover behind and underneath?
- boost/compression question
- Vic jr intake
- Oil drains in a 5.3 twin turbo build. How do I weld in AN fittings
- New 5.3 owner getting geared up for boost.
- S475(or recommend me something) on 5.7 vs 6.0 and truck/c6 mani questions
- Those with Huron turbo kits on a 5.3, Couple Q's
- Merge pipe question
- Laying over on the top end
- my 87' T Turbo LS swap...
- Procharged F1a Camaro
- 408 with t4. Need advice/help
- is boost all the same?
- Header Wrap & Tune
- Holley Hi Ram with standard LS1 Injectors
- 317 or L92
- Twin 6262 69 Camaro update
- Turbo onto advanced induction N/A build?
- will some guys experienced with turbos an engine combo help me out
- LM7 in 98 short box build..
- What hobb switch fitting is this
- Hot side piping parts list?
- Any body have turbo piping kit for lq9 into foxbody
- C5 Custom FMIC and Vertical Radiator Results and Pics
- ** BAD ASS VIDEO: UGR Lambos, 1600hp GTRs, my TT Camaro Airstrip Race
- Meth injection on my Daily?
- Help with truck intake
- Lsx Shootout true street ride along
- looking to build a reliable 1500whp motor block?heads?turbo?
- S400SX-80 ET-R HO Billet or S400-HP88 on 5.3?
- 370 or 347 for TT BW S300's?
- Half size radiator enough?
- Latest State of Art BW EFR-9180 Turbo
- Intercooler clearance?
- Need input on gears for a 9" turbo car with auto
- Huron Speed Custom Single T6 Kit *Martins*
- cam for twin gt45s
- Huron Speed A/C Retain Turbo Kit Blow-Out COMPLETE PACKAGE
- Oil Dipstick for Truck Manifolds?
- turbo setup?
- 01 z06, p1sc, 6-rib. Pulley for 6psi?
- A Safer Way to Wire Meth (Using EBC)
- **LMR Twin Turbo Firebird runs 4.45 @174mph**
- sloppy mechanics wiki
- fast rail brackets for maggie??? help
- P1SC Procharger and Intercooler for my 06 Silverado?
- Is it possible to design a cam for boost and mpg?
- Dialing in timing on a boosted stock bottom end 5.3
- stock 5.3 cam intake 13lbs 633whp borg s475
- 88mm,High ram, all black turbo build.
- SN95 5.3 TH400 3.27 build thread - 10.88/134.86 - NOW LQ9
- Noob turbo help
- BW Matchbot accurate
- F1 or Front mount single on a forged 347?
- 2 bar map sensor
- Help me pick at turbo!!!
- LSX willys is going forced induction !!
- Procharging this LQ9
- cold side piping
- timing and water/meth on gas
- Had little fun this weekend in the firehawk at Cecil
- to strightline performance
- 408, 91mm, E85, Head Lifting Issues.. HELP!
- D1SC or?
- Which turbine for max effort 4.8
- How much Pump with e85 and turbo?
- Tips for preventing engine destruction
- My SBE ls1 build
- LY6 return fuel rails for boost.
- New here, have some turbo LS questions...
- 7.22 @ 200 mph ,, Season's over, time for a new combo
- Stupid question:Welding Almn piping
- turbo list of parts????
- Lq4?
- 370 LQ9 Build - Need some guidance
- Pulley configuration for 20psi on an F1A
- Id this turbo
- How much power can I make?
- engine harness problems
- Aftermarket radiator for stock location and F1 procharger ?
- looking for super or procharger for lt1
- 99 SS D1SC e85 stock short block
- Exhaust manifold flange
- Another failed exhaust flex pipe
- 370 gt91 turbo cam options
- 700 rwhp on stock motor?
- AES 408 with PT91.5
- how much hp gain can be expected
- Turbo Choice
- Cog setup or direct drive Procharger
- 5.3 turbo help
- Boost on l33 silverado
- GT45 GOOD for rear mount?
- Just bought a turbo kit:
- IATs at the track
- 5th Gen Twin turbo kit
- Intake any better for a street turbo motor??
- back into build mode winter is coming.
- ReAr moUnT vs FroNt MOunT???
- bosch 044 and 3/8 lines.
- VR 707-rwhp Centennial Edition ZR1...
- on3 turbo Kit new for ls1 cars
- 5.3 /4l80e GT45 rear mount S10
- 6.69@217 new world records, lsx shout win and videos!
- Heads/Cam/Valvetrain recommendations for D1SC/370/T56
- New DD, 2009 G8 Twin Turbo, Dyno results
- Procharger noob question
- Got my car out to the track this weekend 10.700 @131 1/4
- G Body Malibu first passes
- Couple of new in-Boost videos of my Junkyard GT45 5.3 Mustang GT
- Wastegate Size & Placement for LQ4/S475 Setup??
- Battery relocation tray
- 2500# car - 4l60e - Boost
- Turbonetics T3/T4 Hybrid
- A supercharger for a 2000 Camaro V6
- On 3 performance turbo kits?
- Educate me
- Turbo Trans Am ws6 pictures
- GT55-88 ETR-HO with a little flavor
- What is Tick Performance working on?
- WhiteLTone/Legend Racing 4 day Turbo Build testing at Indy.
- so, NMCA has cancelled MEAN STREET
- Trust MAP or boost gauge when looking for pressure?
- Gt45 turbo how much power can it make?
- Injectors and fuel system for E85
- EEK 22PSI Back Pressure on Rear Mount
- 5.3 goes a little faster 8.55@159
- Need some advice...
- Good heads canx out with FI?
- Gauging interest: H11 head studs for FI applications
- Turbo leak by air filter
- Fabrication experts
- Thanks to Matt at RedLine and Robert and Robert at Chiseled
- 6-bolt Head comparison those with good & bad experience please share
- LS6 vs. LS2 intake on turbo LQ4
- 4.8 + precision 7675 + 75shot = 144mph
- junk yard 5.3 turbo records?
- Wastegate advice needed (pics inside)
- Power Gain
- Got a intecooler related qustion....opinions needed....
- another boost plug gap question
- can you adjust boost on supercharger?
- Semi-budget build Forged LS3
- MSD Slim Starter
- What is "peak power" & "power under the curve"?
- Dave Adkins 63 Impala 4.19@183, 6.36@219
- BW turbo???
- first time at track with new realstreet setup
- Need help on lt1 P600b Install in 96 WS6
- Would you or would you not?
- BOV noise
- comp ct43 6767 vs bw s366 for twin turbo 390ci
- Microsquirt vs MS3-Pro on Boost
- stock bottom end limitation?
- GT4788 Vband help.
- Twin 70's on 5.3 good or bad?
- p600b Purcahse for my 96 ws6 lt1 Should I do it? Need help
- 224/230 115lsa .59x-.59x lift idle issues
- Quench on turbo engines
- Is this a no-no? turbo mount pics inside
- Highway mpg turbo on e85?
- C5z06 5.3/Rearmount turbo.
- cheapest place to buy v bands and cupplers
- Ati double key damper, what does that mean?
- Stock Connecting rod ????
- Boosted 79 Malibu
- turbo forged 370 build. what to get and where
- Holley dominator efi or bs3
- ZL1 Front accessory drive for LSA 1900 on F-body
- IAT sensor- which one to use
- Turbo kit q:
- FIC2000 and E85 issues.
- *** Ninetres 194mph crash pics/video ***
- Catch Can Routing (Yes, I know it's been covered)
- 5.3's making big power step in. WHATS YOUR SETUP??
- My mustang street car I built this year...
- Magnuson TVS 1900 folks....
- 5.3 turbo project
- tc-78 3.5 v band? stock?
- Turbo Auto guys with Lingenfelter 2step LNC-2000 come on in
- Anyone pieced together a water/meth kit?
- 1205 RWHP on pump gas - F1X C6 Z06 by CBI/DSX
- limits on3 7681 turbo
- blow through carb non ic but water meth thinking of going e85
- What to do,... what to do?
- Front mount turbo, PS cooler???
- 6 speed turbo guys
- Twins or big single? Exhaust constraints
- Official C5 Build Thread: Front mount PT7675 LS2 E85 6 SPEED : )
- Ls1 with vortech V9 g trim supercharger
- Curious about size comparision of a S480 & GT4788 Turbo
- Rear Mount 2013 LS3 Powered VT Commodore
- LS6 w/ 65 vs LS2 ported w/ 90
- VR SinisTTer - 195mph half, 1586-rwhp, Twin Turbo STREET C6!
- Running truck coils with your FI setup? Ditch that unsightly bracket and go billet!
- How much rwhp on premium gas, turbo, lq4?
- Tick Performance Customer Appreciation Day Highlights (photos and video)
- Afco radiators
