View Full Version : Forced Induction
- 2006 silverdo supercharged misfire/studder
- Need a little advice for a street/play combo
- 6.0 precision 88m turbo w 2spd glide need advice on motor internals
- Super Smokey
- Questions about timing table
- Video for Spanish Speakers - Going from 7875 .96 to 7875 1.25 - Lessons learned
- LS2 Turbo build - Need input
- Vortech v1
- water/methanol electronic injector
- 2000 TA TURBO BUILD (Psychotic)
- VS Racing S400 vs real BW S400 compatibility
- The Giant slayer Sum-270112R 92mm 103/92 T4 on sale this week.
- Question about this turbo
- Huron Speed 23'-24' Group Purchase ~ BIGGEST SALE OF THE YEAR! ~
- 6.2 whipple accessory drive selection
- 6.2 Turbo Recommendation
- LQ9 6.0 Turbo Build Advice
- Manifold runner size for 1,000+ WHP?
- Cam for a 5.3 L83 with a TVS 2650
- The Turbo TA is BACK!
- Supercharging a 3800 camaro
- Turbo smoke
- Any Holley EFI (HP) Boost Control Experts Out There Willing To Help With An Issue?
- VS Racing turbo upgrade suggestions for 5.3
- JGP Joe Gibbs supercharger 5.3 questions
- Need 2/10ths
- Boosted lm7 build questions and hp limits?
- Haltech Nexus Rebel LS
- Magnuson 2650 SC'er + 250 shot......anyone doing anything like this?
- Summit Giantslayer Prototype doing some work!
- almost done 68 Camaro Turbo LS
- 2015 gmc Yukon can you use ecm to control waste gate and bov
- Best "street" intake manifold for boost
- LSA swap adapters for cathedral port
- Help burning wires
- Newest Summit Turbos for 2024!
- Projected horsepower
- Vsr 80mm T4
- Why so few procharged fbodies?
- TQHD LQ4 Build
- Turbo primaries question??
- JGS wastegate spring
- Dyno Graph and Turbo Sizing Questions
- Turbo headers for G body
- Rotrex 38-81 head unit bracket for LS1
- boosted 5.3 obs blazer 4wd
- What button...?
- PCV for turbo
- Direction on turbo
- Track Catastrophe - What does AFR do during head gasket failure?
- Oil catch can for boost.....is vacuum pull a must....?
- 78 vette torqstorm installation
- Popped head gasket
- 4.8 boosted with 5.7 pistons
- What crank with procharger?
- water7meth pumps and injectors
- 2003 Sierra sycloned
- 1967 Cougar LS3, LSA, Cam Motion PDS Stg2
- Which fuel injectors do I need @800 RWHP
- Turbo LQ4 time!
- Can’t make any boost
- Boost control question from a newbie.
- l20 vs lmg vs ly6
- Procharged P1SC
- Tune is pulling timing. Help
- 02 Ram Air P1SC-1 - 522hp / 475tq - 93 Pump Gas
- 1.32 A/R S475 + LS1 spool up speed?
- LS9 Supercharger - need help identifying what all the ports are
- Turbo Denali - no boost issue
- Which mufflers....
- Evaluate my turbo drain options
- Wedding Season or Racing Season?
- Blow off valve questions!!
- 500 horse power lm7
- Gbody Turbo 5.3 Exhaust Size
- Oil pressure dropping at wot in high gear
- Griffey beats the Push/Pull Race Cars at Wisconsin Outlaw Street
- 1100hp + Radial tire shake + 12 Bolt diff =
- 370ls 88mm turbo numbers don’t seem right
- Boost reference reg in way
- Lazy Twin Turbo 5.3
- Quality turbo blanket vs Cheapo blankets
- Turbo silverado
- On3 turbo leak question
- 72 RivieraTURBO choice
- Different map sensor for tbss im.
- Are all turbo blankets and heat wrap the same?
- Which cam makes more power from 6000 to 7500 RPM in a LS3 head 6.0
- T4 turbo on 408 lq4
- Is your turbo in boost while cruising on the highway?
- Boost control for added back pressure on turbo
- Input on Camshaft--going from turbo build to blower
- *FIXED*Fresh Turbo LQ4 running very hot
- Single vs twin turbos 416 Ls3
- ls turbo problems
- Recommend a cam for my setup
- Boost vs fuel pump volume e85
- Turbo exhaust, downpipe vs 3in to cutback
- How much weight is too much weight on my turbo manifold?
- Trying to back up my Title
- Do AEM widebands suck?
- Term X fuel pump trigger
- 07 Avalanche (aka Frosty)
- Prepping TBSS for Twin Turbos?
- How Much Pump Gas Powa???
- Nitrous cheater plate. Solinoid questions. Super pro shot nos
- Pulley combo thoughts?
- Over boosting 14lbs on 7lb spring.
- Battling high IAT's on a LSA
- 8 rib 10 rib or COG f1-c procharger
- Fuel rails for 1,200 RWHP...............
- in need of cranking fuel values for 6.2 with a whipple on e85
- 500 whp ls2
- Oxygen sensors
- Cams with a large int/ex split
- Oil/filter for aftermarket wngines
- Converter Quandary
- Watercooled Turbos - Anyone
- crankshaft for lm7 with boost
- Billet S480 15psi HP
- I did boost by gear using Eboost2 on a T56
- Procharger lsx transplant vs procharger serpentine setup
- LSA build(no longer going turbo)--critique the build
- Can we talk about turbo DI tuning?
- Better lsx rear cover setup
- Boost loss with new Holley Terminator X Max swap
- Car leans out and won't take throttle, puzzled
- IC options
- PCM Tuning a mild N/A set up, but using 1,000+ RWHP capable fuel injectors.......
- BTR LS9 Multi-Layer head gasket...........ok for 241 heads / LY6 GEN 4 block
- From all motor to Turbo, need opinions!
- No boost
- New project
- Flexfuel sensor location
- New PB Mph in the Nova
- New build need suggestions
- D1SC what engine should I build?
- Griffey captures ASAG at Michigan Mayhem
- Which compression for full time E85.....
- 5.3 turbo build questions
- LC9 leaking coolant past the head stud
- Fuel injectors for 1000+ RWHP set ups ----- Ok to use for a mild N/A set up?
- GT45 OIL FEED question
- Question about going banjo fittings to push lock
- Suggestions and advice for turbo 5.3 build
- Turbo sizing for 402
- TT 5.3 with post-turbo x-pipe
- Oil pressure lines
- E-turbo data proves pre turbo meth inj. makes turbo more efficient.
- Procharger guys - Help
- 4L60E questions
- IATs and Recoating Headers
- It’s been about 10 years…
- Weird turbo question.
- Short block price difference. ATK, Thomson, Borowski
- Wideband 02 Reading off at idle - is something wrong with my build
- Speed Engineering down/forward
- hooker ls turbo manifolds O2 location
- first Procharger build question??????
- Crankcase /PCV System / Boosted application. Ls3
- Finally caved, and got a Terminator X Max, and a boost question already, lol
- Griffey goes to the Dyno
- Holley Dominator boost control
- What is the perfect turbo size for a 5.3 ls?
- What V-Bands work with the V-Band flanges on VS Racing turbos?
- First start after turbo install
- Belt issues (Gates green belt)
- sparkplug dillema
- Just gnna kick. s480 sxe on 6.0 L76
- Turbo durability AGP vs BW
- Interesting problem with twin-turbo 98 Camaro.......
- 5.3 LS and 5.3 LT
- Weird injector problem
- Running a trubo without exhaust?
- Built engine - turbo suggestion
- Shared attributes of Twin Screw (e.g. Lysholm) vs Roots (e.g. TVS)?
- 1993 FD RX-7 Turbo 5.3 Build
- Hawks third gen blower help needed
- Procharger Mounting Brackets.
- Procharger belt sizing
- Twin 50mm turbos
- Junkyard turbo build donor engine?
- What crank for 408/2650
- 408 twin tuebo cam help
- C5 Procharger kit fit on F body firebird?
- 402/1500sl power #s.
- Aeromotive a1000 question
- O2 sensor location for turbo
- Injectors
- 383 LS1 D1X Build Plan
- Purge valve-boost?
- Fuel system compatibility
- Curious about possible numbers
- Oil Cooler for Stroker with YSI
- Throttle body for Holley high ram (Fitech?)
- Looking for advice on first turbo build
- LsSimple Procharger Bracket
- I wanna add more boost
- 4303 Fuel Pump Troubles
- JW Ultra Bell TH400 Yes or No?
- S480 or 2.9 Whipple
- LT1 383 Procharged build
- F-body TURBO guys: Huge imminent decision to make re: k-member/downpipe clearancing
- Turbo sizing recommendations?
- Will whipple 2.9 clear 68 camaro yenko hood?
- 3 bar map for tbss/nnbs running holley
- External oil cooler for turbo LS3
- Two Step for Boost Check?
- eBay ecotec3 turbo install on L83 2016 Silverado 1500
- Summit Ghost Cam. Power limit on boost? Kind of a what will it make thread??
- Procharger Race Intercooler
- Wastegate size for twin 66s
- CX Racing turbo kit???
- Procharger vs turbo
- Blow Through Carb
- Ignition Coils D581 or Similar
- Switching up setup and need a cam.
- Cam specification for high back pressure, rear mount turbo
- Wastegate Size and Location
- Texas speed 408
- Condensation. Need advice
- Xotic head studs
- Dome sensor placement.
- Dead horse beating! S475 vs s480 vs 7875 vs 7883
- Looking for advice on first boosted build.
- Cam Recommendations: 4.8L, 6speed manual
- Turbosmart Hyper 45's, Precision PW46's, or other gates?
- On3 kit upgraded flange
- Terminator X
- Ruthenium Spark Plugs for boost??
- Boost Control - Compressed Air or Turbo?
- Turbo drain location
- Whipple supercharger pulley options
- Talk me into/out of an S480
- What kind of valve cover set up should I run?
- 4th Gen Centrifugal Supercharger questions
- CTS-v LSA Heat Exchanger Brick Reinforcement
- Block choice
- How much exhaust weight can a turbo support?
- what valves do I need??
- Could you add a 12VDC AC compressor to help an Interchiller?
- Preload/ pushrod length
- Higher or lower compression? Have two piston choices...
- What size turbos
- Intercooler upgrade - 4 inch core A2A or Air to Water - Pump Gas
- Opinions
- Size differences
- Any BOOST LEASH users here?
- Dart LS Next Gear Drive Procharger build
- Electric boost controller reference point vs wastegate.
