View Full Version : Forced Induction
- Which turbo kit?
- Blower belt broke need info on replacement.
- ATI PCV and Surge Valve Setup
- where to get supercharger tuning in cali
- Can a Supercharger produce the mph of a Turbo?
- VORTECH USERS INSIDE!
- LT1 Single Turbo System Pics
- ASP's Phone #????
- ls1speed turbo kit
- Is the 4lb Procharger kit worth the trouble?
- Adding FI to engine w/ 50k miles, bad idea??
- anyone using an oil catch can?
- 8-Rib for Procharger
- Well the singles going in now
- CAMAROGOD98 ?????????
- Experiance With CAS! Buyers Beware! **UPDATE**
- 160 T-stat and Forced Induction
- Dyno Numbers
- Holy mother of crap!!
- FS: Large Front Mount I/C
- When to turn 2nd fuel pump on with hobbs switch
- turbo users with ported oil pump help!
- Any interest in ATI brackets?
- ATI guys with A4 - tranny cooler?
- turbo oil system information
- supercharger and nitrous together
- GWP Stage II kit installed and running...need advice
- turbotech install instructions q.
- Fuel problems. Help
- Need help with ATI Install...PSC unit..
- supercharging and turbocharging
- turbo kits
- Look at this Turbo Civic
- ATI help, tuning problems at shop.
- Replace bolts w/ studs without removing head and changing gasket
- Best blown Tranny's?
- Clutch Help Please
- How do you know if you lifted a head?
- procharger advice
- Thinking of turb0
- Pro Stock John!!
- Check out my website
- Help! New to F.I.
- Can someone email me a timing map for a D1SC?
- Procharger D1SC or F1
- F.I. options
- used supercharger?
- Stock fans?
- 840hp/770tq
- Crank pulley bolt removal?
- Track WEIGHT
- Compare / Contrast these Superchargers
- F.I. seems to get higher dyno#, but Strokers seem to get the better times
- where is the location of the resevior on the vortec kits.
- My D1SC is here. Questions?
- Pics of Vortech YS trim -->
- 15 psi engine build from scratch
- Placed an order today for some parts.......
- Blower Cam, for 6.0L 372c.i. motor.....
- hows a turbo ls1 sound?
- New Vortech and ATI prices for April!
- New big TT kit for the C5
- Gatorback belts anybody try them ?
- CAS Boost Referenced FPR users inside please.
- Belt breaking
- Turbo powerband question
- need help finding turbo
- blower cam ?
- Suggestions needed..
- ATI D1SC Questions
- I need D1SC advice.
- How much is too much for the street?
- Fuel System ?s
- Safe to Supercharge with a 224 224 on a 112.
- timeing and boost
- IGNITION TIMEING " BOOSTED"
- N/A vs Turbocharged
- ARE 404ci and Incon TT...
- CAS Twin Turbo Numbers
- roots blower?
- Fastest M6...
- P1SC question
- turbo issues... any insight?
- Would my current fuel system be enough????
- Easy 10 HP, increase gas mileage
- Where to get Lower Compression Pistons?
- help with misfires
- Got my weldon pump
- How much power ??
- Vortech YS trim is here! (20 psi setup)
- help me build a fi motor
- What a/f ratio is best with Procharger
- Vortech + Heads & Cam Update
- supercharged ???
- Is LS6 cam good turbo cam
- 6.0L BLOCK
- fast boys cold air.. good or bad?
- what can i do to help my motor last longer
- Help! Need Powerdyne Serpentine Belt Part Number
- ati people show me your install photos
- ati crank pulley bolt
- can't wait...have questions
- Need help with GWP install two details not known
- 3 psi of boost on a 7lb pulley...WTF
- Paging Rob Raymer...
- I blew my 4L60E trans.. What do the F.I. guys recommend.
- How much boost will it make?
- What is too big of a cam for a turbo?
- LS1 twin turbo system build a go..
- Vortech V-9 G-Trim with Aftercooler "Programmer question"
- When are we going to start running awesome FI setups?
- Is getting blown better than inhaling the laughing gas?
- 6 liter questions
- LS1 Motorsport kit questions
- Twin Turbo Kit....
- Vortech intercooled
- ATI F1 or CAS Twin Turbo?
- Denso Iridium Plugs
- I want my car in GM High Tech!!!!
- Head gaskets - how thick is too thick?
- Twin Turbo C5 Questions, Please Help !!!
- Help! After larger injectors my car is running lean
- Dynod with F1/T400 and 3.0 pulley
- ls1 motorsports single turbo kit
- Vortech limit?
- any gain ported mass air ???
- turbo tech t-76 kit or procharger
- Powerband changes with supercharger?
- Vortech 9# + heads & cam - WOOHOO!!
- Cometic head gasket lowers compression?
- stock vortech belt with 2.75 inch pulley?
- belt slipping
- spark plug gap for forced induction
- UPS... ARGH!
- anybody running 5.3L FI motor?
- LQ9 Heads
- questions about CAS TT setup
- PULLEY PROBLEM
- Thinking about boost
- need some supercharger info
- LT1 BLOWER ON A 99 Z
- Blow-Off Valve For Incon Setup
- Update on Dragula's Vortech YS Trim conversion
- Quick compression question
- ATI -D1 or Vortech ? Which one is better?
- Blower info needed, esp. from D-1 owners
- D1SC PROCHARGER NOISE
- ASP pulley iwith ATI-D1
- Vortech 6lbs kit (no intercooler) fir on 2000 SS?
- Keeping Cool
- TR230 CAM and a Vortech Supercharger
- Check out my car!!!!!
- wastegates internal or ex?
- Questions about the Vortech 4GK218-028SQ.
- Much better Recording of my Blower Issue
- ?? What are the 2 lines (boost,??)that run into a wastegate??
- Chance At Stock Short FI Record???
- solid roller fi
- Question about turbotech intercooler
- Check out this clip of the whine from my supercharger.
- Beyond 550rwhp - Help With Fuel System
- PAGING Y2KHAWK
- How much boost can a good...
- MIGHTYMOUSE
- What Cam for my setup
- At what power level or rpm do folks max out the MAF?
- Anyone pinned their crankshaft?
- ATI Plenum??
- Mustang Blower on an LS1???
- Rob's old turbo finally in..
- Thinking about FI...
- Radiator, Fans or Both
- ATI Install have a few questions
- High altitude 1/4mi run(video)
- what to do b4 turbos? plz help
- Why do superchargers whine?
- Guys with water/alky injection
- Building the best FI motor?
- merge collectors??
- best cam slection
- I need help from ALL the members!! Kenny did not deliver!
- NOS or Water/ALKY?
- TByrne Motorsports - AOK!!
- Supercharger prices that will blow you away!
- ATI F1 and T400 are in, now Im just waiting for my..
- wonder what a vortec minus the intercool can do?
- Pistons/rod?
- 6.0 iron short block limit?
- ??What are the test FP's for OEM injectors and aftermarket ones??
- ??Some questions about wastegates and using one in a SC'd application??
- Oil for turbo car?
- 404ci Agostino Racing Engine For Sale
- Why are most turbo cars slower than some H/C??
- LS1 Motorsports Turbo Kit Update - Please Read
- Alchy Kit
- Engine Build, have questions
- Calling all past and present ATI people I need parts
- why water/alcohol injection?
- Alcohol / Water Injection - Optimal Mixture Ratio??
- are these parts necessary for turbos
- single turbo lag
- LS1 Twin Turbo Z28. Almost done!!!!
- what do you use for coolant in your intercoolers??
- How much was your Vortech T-trim Bracket?
- Polished Vortech Kit on Ebay
- LAST CALL ! ATI STEEL IDLERS
- Need To Get Work Done :) Please Help
- holly smokes, got 9/10ths with a 35shot!
- To all that installed a weldon 9200 oil pump
- What Rear End Gear Ratio.
- Turbo sizing
- To ALL members!! Need help concerning GWP
- YS-Trim 9.49 @ 144mph, 14psi
- CAS TT,done this week!
- Anyone have a ATI/Vortech Blower bracket I can use to copy for novi kit??
- Custom bent tubing
- What airfilter works best with superchargers?
- What oil weight are you supercharged Folk Using?
- experienced turbo guys....i have a few questions - kinda long
- Sound Clips of Super Chargers and Turbos.
- looks like the new dodge neons are moving up in the world!
- Here's my dyno Run. Is this too Lean?
- FS: Tech edge ver 1.5 wideband controller/NTK sensor
- P-1SC with a Vette better than P-1SC with an F-body!!!
- 600+ rwhp on average??????
- ATI guys come in!
- QuickSilver 2002 Boost Control
- ATI F1/ 4 inch pulley only 7 psi/ need help/
- Boost/Fuel Gauge Install....
- Thanks for the Advice, New Family Member Coming
- FI Heads?
- PCV and FI cars...
- Which internal belt is better for the Powerdyne's Kevlar or fiberglass?
- PCV Delete?
- NEW - Paxton Novi 2000 LS1 Kit to be released!
- Seeking info regarding ATI 8" dampener?
- 91 unoxygenated or 93 oxygenated?
- How do you guys do it.....
- Lingenfelter Supercharger or Internal Mods, Help!!!!!!!!
- Anyone have pics of a T-trim bracket or links/info?
- Advantages and Disadvantages of a Cogged Drive Blower
- ASP pulleys with superchargers
- 73cc and 77cc FI CNC chambers
- How loud is the T-trim?
- Blower choice regrets??
- vortech guys, need lots of parts.
- People with Powerdyne what is your best 1/4
- ATI F1 blower guys?
- can I run 10psi on my stock engine
