View Full Version : Forced Induction
- friends are telling me turbo are not the way to go....
- New personal best with MT DR's
- How you guys running PCV?
- ATI twin inter-coolers and rear mount turbo??
- First start up with turbo!
- Will timin change when boost heats up?
- TA w/ FMIC = !Fog Lights?
- Who to get my meth kit from?
- paging "forced inductions"
- Need ARP head bolts
- Picture request of turbo system built by Rob
- Air to Water Intercooler cores
- F/S custom LT1 blower cam
- 408 w/TT or F1?
- Getting pro charger. will current cam work?
- Crankcase pressure = leaky turbo?
- Z Angel, Brian... Any New News on the Turbo Project??
- Any one tried an F1 with stock intercoolers?
- Turbo Fabbing...
- Took "Casper" out again with trans trouble...
- Incon turbos, how many bolts in the turbine outlet.
- Holy SES Codes Batman!
- Everybodys posting pictures, here are some of mine
- estimate on numbers
- Intercooler outlet size?
- Meth on a Stock Bottom End
- Procharger Fan Wiring Diagram?
- Custom LT1 Blower Cam F/S
- Spray the D1SC?
- Question on D1SC blower pullies?
- anyone wanting to sell there Vortech kit????
- 12 rib Procharger belt help...
- Threaded IAT sensor Part # or application??
- M6 guys what clutch do you perfer.
- FMIC tubing pics
- quick question
- TH400 loss over 6spd from PTK 88 car.
- D-1SC Pulley Question
- where do you go to buy intercoolers?
- 1st Gen LS1 twin turbo?
- Goodbye OBX, welcome back H20/Alky
- any huge hp difference between a turboed 402/408 or 347
- Turbo cam from COMP. Does this seem too small??
- PTK pics needed and pricing!
- To the ground with A/C & Power Steering?
- What size downpipe correction.
- The E-boost 2 GP
- ATI damper
- What size downpipes?
- God... what a mess
- Any one done an air to water intercooler with supercharger?
- need help measuring my twin turbos.
- Can't make over 750rwhp - why?
- Phamspeed/ARE intercooler set up w/pics
- Phamspeed dyno results!!!!!
- HELP - trying to Figure out CR of my mish match of parts for MY Tubo Build?
- Gt42?
- Availability of LSx and what upgrades needed for boost?
- TT,T, or SC??
- procharger questions
- sdce 8 rib GP
- changing compression w/LQ4 heads??
- Can this qualify for car pooling?
- Aluminum tensioner pulley for G-trim(homemade)
- Megasquirt for sale
- new to T/C... help me build...
- another sts question: what can i do now and upgrade later?
- Clamps
- Ran the car on new setup. How did I do?
- Oil in the downpipe, turbo freaks I need your help
- A quick question?
- LS1 turbo kit for sale
- 16-gauge tubing
- Dual Spal fan setup and D1SC... need help!!
- what CI for 700+rwhp and what turbo kit?
- PTK Question
- apex avc type r boost controller
- this should put my tt power to the ground
- ATI owners-Catch can and Blow-off Valve?
- Gauging Interest in SDCE 8-Rib Coversion Kit Group Purchase
- Knock retard after shift....help needed!
- Who makes the best proven turbo kits?
- Any information on sequential turbos?
- Main cap walk with aluminum block
- PTK kit came in monday
- F.S. STS with extras
- 6.68 @ 104 1/8 at 3200' DA yesterday
- LS1 Blower question, n00b here
- Cooling fan specs?
- Adventure at the dyno...
- Does this price seem right?
- Procharger-WS6-dual intercoolers cooling air flow???
- Anyone remember the post that showed 2 intank pump Install
- just finished a 2002 ss 810 rwhp trick setup
- Front end support for more room? *PIC*
- Turbo Technology Kit
- Need an aftermarket radiator that works
- SC'd Fuel Systems (650rwhp+)
- What would cause A/F to rise?
- anything wrong with this oil return?
- compression ratio and it's effect
- My PTK PTE88 SS
- CC 918 springs question
- turbo spool vs rpm
- WTB 3.2 Procharger Pulley
- sts and 918's
- Accessories needed with STS turbo kit
- Wastegate?
- it's alive... IT'S ALIVE!!!
- Looking For Turbo PiX
- Calling out Phamspeed owners
- Good BOV?
- pro charger belt/pulley
- 383 Stroker - Cam & Injectors
- progress pics on the small turbo build
- FS. PTK LT1 gen 2 kit
- Bran New CUstom set of ROSS FI pistons For Sale *pics*
- cali leagal FI or shortblock
- Turbo worth the xpense over Procharger?
- how to install guages and wiring
- LQ9 (6.0 Ltr) heads for sale!!!!
- Racegate Question
- F/S Custom Blower cam LT1
- Stang 4.6 2valve FI question
- Procharger? Twin Turbo? What 2 Do
- F-body STS and Dyno Strapping Ques...
- P-1sc-1 Price ?
- .581 cam with STS Questions.
- Is this a good blower cam???
- fuel pump for vortech v9...
- Corvette Over-Radiator Intake Pipe, how much boost?
- need to order part quick. but where?
- What ever happend with my old kit???????????
- upgrade advice after turbo
- Procharger 3.5 Pulley For Sale
- What Turbo?
- Going to the track soon what will my car run?
- STS with or without cat's and headers?
- What plugs to run?
- Wanted: Sheet metal intake
- Some more progress on Stenod Performance Twin Build-up!
- Block ????
- cooling ?
- Front mount Pro charged issues D1SC
- vortech to stock...
- headers for twin or single LS1 in a 1st gen
- procharger and fuel management
- Solid Roller Specs
- DIY Alky Injection Kit
- Good shop in north east for install of blower
- Procharger HP Problems on a 99 Z28
- nedd help with my next mod
- Any FI cars running in the heat?
- OK, so who has the fastest FI track time on pump gas?
- Link to the "Do it your self meth kit"
- Moving the stock radiator pics.
- EGT question...
- SOME Turbo Kit progress Pics...
- Vortec Superchargers
- Heads:casting #873
- Homemade turbo lt1's on budget
- Turbo tires - just read it!!
- temperature
- Who saw STS on TRUCKS??? anyone anyone?
- Twin or Single turbo,whats the big difference
- Turbo guys,in here.!!
- Timing with 6 PSI
- Who here tunes there own car.
- T72 got full boost at 3000rpms with Phamspeed kit
- maxing out a D-1SC
- Another "what turbo do i want" Thread.
- Where to find an MMS crank pulley?
- Boost brainiacs........got a question
- ? for high horsepower fi cars
- Next project
- Kooks 1 3/4" or 1 7/8"??????
- PTK kit
- what cylinder head specs for a turbo application?
- Best sounding exhaust for Twin Turbo SS
- 409L stainless steel 16 Ga for turbo headers
- what plugs should i run w/ my turbo setup?
- Oil cooling a water cooled turbo. Will it work?
- Intercooler Almost Done...
- Best Check valve for oil drain back line??
- Injector Size for Vortec Supercharger
- looking for pics and pinfo on turbo custom
- How many are using billet main caps?
- What way to control ECU for boost?
- whipple twin screw??
- Got SS back, now have a few turbo questions
- Super Charger Lesson
- which turbo for me???
- good daily setup?
- Anyone tried an INTRACOOLER
- ATI, SDCE guys, changing oil ?
- header flanges
- Oil Pan Drain Plug.......What size?
- tti kit
- Looking for some power
- i need a 2 step!
- A little Video enjoyment
- Who makes the best alternator relocation bracketing?
- What machine work did you have done to your FI Motor?
- LS1 setups, post whatcha got
- Another 11 second STS car
- taking Opinions
- Vaccum questions (bov/wastegate)
- tti oil pan alternative tap location! quick!!!
- Vortech MAF relocation (pictures).
- Advice on a Vortech V9 aftercooled?
- Keep my 918s or grab some Patriot Duals?
- Safe boost level
- 02 2500HD Running now Roadtest time.
- intercooler fan?
- Who makes a good 2-step?
- Getting a New Engine
- CryO²™ - INTERCOOLER SPRAYER
- Random Poll, Post Your Choice!!!
- optimal turbo for 347
- Why is this such a slug without the spray?
- bosch part number for LSU4.2 o2 sensor
- turbine interchange??
- supporting mods???
- Whats the best stroker (cubic inches) to build for boost
- Blown car FS in the classified section
- twin turbo lt1 project
- Speed Inc. 348 Short Block
- Ideal Radix A/F ratio?
- MDMC Twin turbo kit
- Max Boost on Pump Gas
- need 3.75" ID x 6" long, black, silicone hose
- guages
- John Pham
- Where to get pressurized oil?????
- STSHow much boost on a 120,000 mile motor?>?
- Twin Project and other toys..
- LS6 intake questions with Procharger
- vortec supercharger
- Pics of my new 6.0L Heads
- how to lube twins
- Procharger 90 degree temps = over heating
- Vortec Blower Question
- What size piping from rear mount to TB????
- Single Turbo: How are you guys supporting it?
- Pro 5.0 power target
- Need boosted members help,CR question 348vs383
- SMC Alcohol kit.... free progressive controller!
- What RPM should I make full boost?
- 20PSI with 408?
