PDA
View Full Version : Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 [191] 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230
  1. Heads for Vortech
  2. Turbo Masters: I need you guys to sign off
  3. Dyno numbers for Kenne Bell twin screw supercharger on C5
  4. Intercooler charge pipe size
  5. Where to buy gatorback belt for procharger?
  6. Boost still low
  7. 50trim?
  8. Alky/Water Meth Injection which do you use???
  9. How much did you pay for your Lt1 Turbo set up
  10. Turbo questions..
  11. well i got the head unit off, heres some pics
  12. max boost w/fmic on stock block
  13. IAT retard causing problems on turbo setup
  14. Question
  15. iron or aluminum 408 for F-1r
  16. GT42 Turbo set up almost done.........:)
  17. 9.45 @ 148.89 Video
  18. 3.4 and 3.5 Pulleys For Sale
  19. How do ls1s with turbo kits sound? curious
  20. Turbo LS1 Nova construction pics
  21. Cheep turbo kit.
  22. What hp are my t3/t4's good for ?
  23. Not making full boost!
  24. at what point should you replace your stock valves?
  25. Alternate Mounting
  26. So we went racing saturday
  27. 9.45 @ 148.89- come on PSJ.
  28. 9.61 @ 144.67! Almost caught Mike Brown...
  29. Track Day! New Best.
  30. Radiator Support
  31. Turbo housing vacuum nipple question
  32. Help With Methanol
  33. do i need to get wideband AND EGT gauges?
  34. Finally got my car dyno tuned!!!!
  35. Is Speed Inc still making turbo setups?
  36. Want to spray ontop of the charger.....
  37. Ordered My PTK Yesterday
  38. Log boost cheap, if you dont have AC anyhow :)
  39. meth kit
  40. Just some questions...
  41. C5 Kenne Bell Info...
  42. Turbo rebuild help?
  43. Harlan 2-step + transbrake???
  44. Help Wanted 9sec car.
  45. powerdyne supercharger?
  46. Wiring harness available to run stock gauges/etc with aftermarket engine management
  47. 9.59 @ 146
  48. Thanks Steve (S_J_H) for the nice little vacuum manifold
  49. used procharger Question?
  50. hp calculators
  51. garrett intercoolers
  52. What is your raceweight FI guys
  53. anyone using a D1-R here?
  54. What part # for 2 bar map?
  55. STS boost controller/ misc. questions
  56. Any ATI Guys using SLP Smooth Bellows?
  57. Ford TB electronics with stock pcm?
  58. Tbyrne Motorsports North vs South Aug 6th!
  59. BOV recommendations?
  60. guess my boost....
  61. 231/231, .598"/.598 114 vs. 228/228, .538/.538 114
  62. Blew right through converter..which to get now
  63. noob needs help
  64. Which is the better buy?
  65. StealthWork's phone anyone.??
  66. BOV flange on STS kit (what kind of piping is it?)
  67. looking for a F-1R kit?
  68. Truck 6.0 shorty's...????
  69. 3 ply silicone on cold side of turbo?
  70. TTI turbo Kit power limits?
  71. What are the fastest STS times out there?
  72. phamspeed or just a sham
  73. 408 with a magnacharger?
  74. porting headers
  75. Just A Few Q's
  76. Just some info on testing with Nitromethane injection
  77. Stenod Performance Single Turbo Project Update Pics
  78. 408 With F1
  79. 408 F-1 guys
  80. Vortech question about boost and pulley size
  81. water/meth=what a difference
  82. anyone tried e-brake launch?
  83. Dual channel wideband, and Maximizer 2 Monitoring screens.
  84. Will a D1 reach my goal of 700rwhp on pump gas?
  85. Edelbrock and WAR Manifold guys....
  86. STS for sale
  87. FS:FI heads ,cam,and piston combo
  88. Vortech kit using SLP MAF?
  89. Best turbo cam
  90. whos silver twin turbo camaro.....
  91. Electric Turbocharger
  92. high boost through short tube headers?
  93. Vacuum Source for D1SC Bypass Valve\Boost Gauge
  94. I can not build boost
  95. Finally up and running again!!!
  96. F.I. VS. Compression Ratio Question
  97. Cant seem to hold a blower belt!!
  98. Need Help. What is Required to Make Procharger D1SC Vette Kit work on a F-Body ?????
  99. Help with some electronics to go with my CAS twin turbo
  100. A few questions since i blew my head gasket?
  101. LT1 SS progress pics
  102. How much does a decent single turbo setup cost for everything?
  103. is it just me or are the blower guys making better times with less rwhp
  104. 408 with a F-1r?
  105. fmic painted?
  106. well the procharger just exploded last night!
  107. FMIC guys, have you sealed your IC to the bumper?
  108. Master power turbos any good?
  109. STS silicone coupler
  110. What size stall with a turbo setup?
  111. Help building boosted 408...
  112. How long should meth last?
  113. Where to order Mondo Bypass valve?
  114. at what rpm does the boost build in a sts setup?
  115. where can i buy my turbo's for a good price
  116. Nitrous + Supercharger
  117. Muffler Suggestions
  118. FS: Procharger D1SC Complete Kit
  119. ATI P1SC opinion please
  120. What should I see?
  121. Spectacle Solutions Lids
  122. bypass valve?
  123. getting down there, D1SC 2600' DA, 10.25 @ 135.5
  124. good a/f ratio with FI
  125. Z06 Supercharger
  126. waistegate q's
  127. Threaded fan spacer
  128. Need pics of Phamspeed kit...
  129. D-1SC users in here.
  130. Well its official I have joined the Darkside.
  131. silicone hose
  132. Intake Choice for future FI car.
  133. Got an issue that I can't figure out...
  134. Sts Problem.
  135. Bucking hard
  136. Noise Level
  137. WTF??? CAR 1 SEC Slower tonight at Track!
  138. Twin turbo update...Cas kit is a B*tch to install!!!
  139. my twin turbo project car is for sale
  140. Phamspeed Kit, here are the pictures of mine
  141. Best Forged piston for Forced Induction
  142. Adding a P-1SC
  143. 414 7500rpm solid roller vs D1SC stock motor dyno.
  144. fuel system with supercharger
  145. Understanding FI
  146. Need a 2 step
  147. Has anyone pressure tested their turbo set-up?
  148. Where to buy a supercharger?????????
  149. My car is alive!
  150. Where do I find 7.25" 8 rib crank pulley?
  151. tuning my procharger
  152. What do you guys do for air filters???
  153. Phamspeed Bov
  154. Thinking Question.?
  155. Dynoed Today.....
  156. Slight smoking?
  157. Anyone know a sponsor w/an F1?
  158. will my head and cam setup work on a supercharger
  159. CoolCharger
  160. how should i go??
  161. which blower should i get
  162. Incon wishlist....Previous owners come in
  163. ATI 5psi numbers wanted
  164. Need FI Tuner ASAP, Trenton NJ.
  165. C5 single turbo???
  166. Help W/ Phamspeed Build*
  167. compression ratio advantages/disadvantages with turbo...
  168. Our big move at PTK
  169. 408 with tubonetics 94mm inducer
  170. turbonator
  171. tti kit T-76 for sale
  172. "Spy pics" of the upcoming C5 STS Twin Turbo!
  173. BOOST and 4l60e
  174. supercharger or turbo
  175. Need help deciding which turbo kit to go with; would love your opinions!
  176. Vortech Kit on 2004 GTO ... dynoed 424/408
  177. Guaging interest in single turbo kit demand for F body...
  178. phamspeed single turbo kit?
  179. Silicone Hose
  180. Would this 90* work on the suck side " blower"
  181. rocker arms and emissions
  182. Want to laugh?
  183. For you LT1 turbo guys
  184. any turbos hitting 5.50 and lower in the 8th?
  185. Dry Sump + Turbo
  186. someone tell me why the "Budget turbo kit" thread is locked so i cant read it...
  187. What's the proper way to drill/tap into oil pan?
  188. help with phantom kit
  189. Anything new on twinscrews/roots
  190. Kit Complete Oil problems
  191. What do people think of this catch can
  192. Updated intercooler pics, more parts also
  193. Stock LS1 with T-76 ?
  194. exhaust temps
  195. Wow!
  196. 8.3'S Secound time out with turbo setup!
  197. 101mm thumper kit FORSALE
  198. Turbo experience?
  199. Forced Induction Stuff 4 Sale
  200. Smoking at odd times!!
  201. Vortech questions
  202. Any TX guys want to barter for S/C install?
  203. Nice Carb intake for sale on ebay
  204. Trying to wire up boost controller...help!!!!
  205. what to use
  206. Help With Turbo Build
  207. part fitment issues on tti kit, anyone?
  208. 4L6?E or 4L80E on turbo setup??
  209. I am still learning about turbos
  210. adding ATI or Vortech to my N/A setup...thoughts!
  211. Plug wires...what Truck wires are the longest?
  212. Passing the sniffer with a turbo
  213. pic from blower uninstall
  214. Does one cylinder go before the rest?
  215. Twin turbo build from scratch, LT1 or LS1?
  216. Methanol or Not to methanol?
  217. My CAS kit is sold to 30th T/A time for ptk? phamspeed?
  218. Which FI sponsor can get TiAL BOV springs I need to buy..
  219. need novi1000 mounting bracket for lt1
  220. cam and valve suggestions for forged 383 DD
  221. procharger pulley
  222. Where to get flanges
  223. Wanting to go blown with C5 and looking
  224. Who can build TT for me?
  225. Supra vs. Camaro?
  226. Wanted:ATI 6-rib 4.10 or 4.20 pulley
  227. which is a better street cam for blower?
  228. have a question about air fuel ratio...
  229. Sucking water
  230. Notice anything different? Pic inside...
  231. Running Meth injection NEED HELP!!!
  232. PTK kit bought.
  233. Need turbo size help...
  234. STS owners want TT for Centerline exit
  235. SDCE Where are they? Number is disconnected
  236. clearance issues on tti street kit?
  237. check out my buildup
  238. Anyone got any pics of Harlans TT setup?
  239. New Superchargers for Gen III V8s by Joe Gibbs Performance
  240. Stenod Performance Twin Build-up...SOOO CLOSE!!!
  241. GM MLS or Cometic
  242. how important is heat in a turbo setup? (hot side, not compressor side)
  243. Procharger
  244. Procharger done...GTO
  245. Some new Pics Of ProCharger
  246. Mustang 5.0 shorty headers work on ls1's
  247. Need Advice on Turbo Kit and Procharger
  248. Monitoring Radix I/C and H/E temps
  249. OBX intercooler for sale, cheap
  250. LS1 turbo header idea?
