View Full Version : Forced Induction
- turbo? school me??
- New Electric Supercharger for Camaro/ TA!!!
- need a turbo
- Larger crank pulley
- Powerdyne?
- New Dyno #'s what do you think....
- can you break a piston if you don't detonate?
- Oil scavenge pump??
- what stall in twin turbo truck
- LS1M Production Kit #1 arrived today.
- ATI Procharger Decisions
- Pop Off (not Blow Off) valve question
- Heads/cam car + 4psi turbo = how much horsepower gained?
- Turbo gurus.... questions inside....
- 97 30th anniversery SS TURBO FS:
- Smoking out the breather valve....
- Question about Supercharger and H/C
- Wich cam for a TT 382?
- small shot with blower?
- Why does Vortech make comparable power to ATI ?
- See if you can figure out whats wrong
- new fuel pump
- stock compression and boost?
- Boost gauge not working anymore??
- Think I found a decent turbo cam...
- Will SVO30#'s on TurboTech T-60 work.
- Project Dragula, Supercharger or Turbo
- ET/MPH: Vortech vs. ATI
- Injector Question for blower??
- Hot cam and turbo
- need help asap
- injector selection
- F1 supercharger for sale
- Can you put any turbo on a car???
- Where can i find headers for turbo LS1/LT1
- LS6 Heads/cam with blower
- Stroke and S/C????
- Should I change cams for blower?
- walbro 340 questions
- turbo kit for camaro
- How safe is this?
- F-body twin turbo options??
- big cam with sc?
- fuel injector question
- Decided on the ATI D1SC
- FI vs Head/ Cam/ Nitrous
- Whats better Twin or single turbo????
- power steering question for Vortech owners..
- Custom H-11 Head Stud Kits F/S
- Compression check came back - burning oil
- I'm Back....Turbo Update Info Within....
- Lets talk MPH between SC'd and Turbo setups..
- water injection or nitrous to complement boost?
- Magna Charger or simular?
- Engine/head Removal W/ Incon Kit
- How much PSI on ATI Pullies?????
- Vortech YS-trim
- Plugs other then TR6 ???
- adding enough fuel for boost
- what is the largest procharger anyone has used on a street car?
- For you that have been following my buildup.. updatest within
- How do you adjust boost on a turbo, and other FI?
- New company to the LS1/LT1 scene wants to do a turbo kit w/in
- Difference between P1SC and D1SC???
- Centerforce twinplate clutch, is it strong or weak?
- Question for Mr. Raymer
- How to acheive a desired CR with 6.0 heads?
- boosted top 100
- More turbo questions
- looking for a 2.85 inch pulley for vortech
- FI Cam Discussion
- ls1 motorsports turbo kit
- What all is needed for complete fi fuel system?
- ATI Supercharger Info
- Aluminium flywheel & twin plate clutch?
- Need help on H/C ?????????????
- got some baseline numbers today!!!
- turbo question????
- stainless 304 vs 321 for turbo
- 42 LB Lightening injectors?
- speed inc twin turbo??
- LS1 T Trim Kit and Z28 HOOD Options
- Took the car for a little Ride..OMG
- Stock headers for turbo setup?
- LS1edit and turbos
- Turbo trailblazer?
- Are heads a waste with a blower?
- Rob's Dad...
- ATI D-1SC with an Aeromotive A1000 fuel pump
- oops
- Looking for best option
- So What's the Best????
- Vortech SC is here!
- Burning oil
- vacuum/boost referenced fuel pressure regulator
- FMU --DO I STILL NEED IT??
- How's the 5# ATI setup?
- h/c 346 v.s. supercharged. same hp, who wins on the street?
- Clutch Slipping, Price for installation?
- Ported Throttle Body effect after dyno tuning...
- V9-SQ ls1 question
- TURBOCHARGE
- How are these H/C cars pushing so much air in?
- Free boost gauge with Vortech or ATI purchase!
- Boost gauge hookup
- Question For Formulation...
- Can somebody help me out? ATI ducting size?
- ATI Steel Idler People.
- E-bay has 42lb injectors!!!
- post up your sc/turbo vids, I can't find the old thread. Please. :)
- What exhaust are you FI guys running?
- Marks on the pistons from the valves hitting....
- Harlan/Rob or anyone with a turbo Ls1
- Turbo cam article in MM&FF
- PTE-63 Installed
- turbo vs supercharger
- Very happy with dyno #'s!!!!!!
- Possibly building a turbo motor....need some feedback
- Can I replace ATI bypass with BOV?
- pics of Vortech setup please.
- Here's an FI car for you !!!
- what to use for alky injection
- paging dave aka formulation
- Overall sheet metal FI intake design
- Is there a Benefit to LT headers with blower???
- Questions about 6.0L heads....
- eliminator fuel pump
- Paging LPE
- Best plugs and MAF for the ATI?
- Turbo help!
- Ordered a cam for the PD - Lingenfelter GT2-3
- How long did it take to get your ATI kit from GWP.
- Second shot at the dyno and here are the results.
- How Are 2003 Cobra's getting so much hp out of simple mods
- ARE 409
- Anyone get their LS1 Motorsports turbo kit yet?
- FI and stock short block ????
- Which head for blower motor?
- LS6 head VS LS1 stage 2
- Anyone running the Thunder Racing supercharger cam?
- Check it out->Will this help with our MAF issues....
- MMS crank pulley users
- AMS crank pulley for ATI kits?
- When do u know u need a larger SC?
- New ATI dyno #'s despite some problems....
- New ATI Dyno numbers :)
- Iron block VS Alum
- ATI Steel Idlers
- How's this for a blower cam?
- D1SC with stock manifold ?'s
- Another 42# injector question.....
- Whats the deal about a bleeder valve for turbos....?
- Those of you with Fuel Pressure Gauges.
- Misconceptions / ATI-D1SC
- Any F1-SC or T-Trim guys out there?
- intake for turbo
- Head Gasket Suggestions
- McCoy LS1 Turbo Kit???
- How to install A/F Ratio and Fuel Pressure gauges?
- Well bought the F1
- new turbosmart e boost controller
- Need help asap ATI 7# kit
- 4" diameter ATI pulley ?
- Vortech superchargers are 50 state legal!
- ATI D1SC Install results, dyno and track times! Help with choosing gears please!
- Anything better then the stock oil pump for the turbos
- Underdrive pulley w/ATI question.
- pte-63 need coverter
- double maf g/sec how to?
- Paging all Water/Alky injection guys
- FI or NA with $3500
- Need help installing 42#ers
- What is all involved with supercharging a LS1
- UPS man dropped off new project now what to put inside it?
- Stock LC2 motor = 8:1 or 8.5:1?
- New turbo kit...who's interested?
- Underdrive pulley w/ ATI P1SC??
- For those of you thinking of running water injection...
- Who here runs 11s on a 40k mile 10 bolt?
- curious about ATI oil
- anyones ARP studs loosen up under normal street driving?!
- H&C to complement FI, NEED HELP
- ATI 8# D1SC kit owners
- LS1 Motorsports Single Turbo Update: DYNO GRAPHS!
- LS1 Motorsports Turbo Z28 Update
- newbie question. simple and straight forward.
- Does anybody have any info on the fbody turbotech kits
- Here's what I'm thinking...
- o-rings ?
- Driving to the track under boost....Got a ???
- Who is using Water Injection ?
- LS1 Crank signal to 90 deg signal adaptor is available.
- Belt squeal with Procharger
- your opinion on this cam
- What do you think of my new gauges?
- ideal a/f ratio
- Buying Tensionometer & Belt Tension
- Tossing belts with Incon TT?
- detonation and preignition?
- C5 Twin Turbo System
- Mr. Harlan...
- what A/R should i get
- 218 cam?
- rebuilding turbos
- Incon TT RaceLogic Controller
- Larger Procharger IC for D1SC?
- need help what wastegates and bov??????
- Is 500rwhp streetable?
- F/p dropping
- Belt Dressing.. Always use it?
- How long will the stock bottom end hold up?
- Help with pistons
- belt part # for 7lb ATI??
- detonation and boost question
- What should I expect?
- looks like the magnacharger should fit f-body
- where to buy header to head flange, custom headers
- Granatelli maf on an ATI D1SC Setup?
- Converter box to run 83 lb injectors?
- Stock TB, or home-ported TB for Incon TT?
- BBK 80mm Throttle Body for Forced Induction?
- AFR or EGTgauge
- How well does the dual walbro in tank setup work?
- Any links to turbo setups on other late model cars?
- Ported Throttle Body on F.I. setup....
- How to build a good FI foundation?
- Sump 98 tank or buy Speed Inc. tank?
- interesting new product
- ATI Harmonic Balancer
- turbos cost hp like superchargers? IMHO no.
- D1sc for sale and FMU
- Cog System for Procharger?
- Advice from Turbo Mustang guys...
- Any New Info On LPE or Magnacharger SC???
- Dieing out after WOT
- The engine in my next project is going to be...
- Scavenge pump veterans inside please (again)
- New dyno numbers---I need more fuel
- ? about Procharger belt...
- Decided to pull TR224 cam/ Help please.
- Cartek Breakthrough for FAST
- Wanted: Details on CAS Twin Turbo Kits
- Paging SJH or JAS
- Help! Review Vortech Checklist Please!!
- Where to buy SPAL fan
- Turbo lag whats that lol
- How much overlap on a 216/224 114 110 Cam?
- Will ABS/TCS still work with a TT/FAST system ?
- High hp turbo people, help! stressing a little
