PDA
View Full Version : Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 [90] 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230
  1. Spark Plugs?
  2. Gt-91 budget turbo backorder
  3. procharger hitting alternator pulley
  4. What turbo do I need?
  5. PCV Setups?
  6. Victor Jr. intake IAT placement idea good or bad?
  7. forged 346 ls1 or iron 370?
  8. Anybody have a f1r setup for a LS for sale ?
  9. Turbo Oil Feed Line Pressure Question / Sanity Check
  10. Variable vain turbo V. spool valves
  11. Can I use ls9 head gaskets on stock head LS1?
  12. ST80 pics Compare to t76
  13. Help deciding for a street monster
  14. 2011 FASTEST FI LSx 1/4 MILE LIST
  15. Would this car hold the stock bottom end LS record?
  16. Project 4 letter word...
  17. Turbo cam/pushrod help!
  18. Boost+LS6 intake
  19. Which Turbine housing should I run?
  20. Oil in Exhaust on STS Z06
  21. E85 Who has done it?
  22. procharger
  23. Help me identify this turbo
  24. Camaro LS1 turbo >> question
  25. LS9 SC, Edelbrock SC or F1-C Procharger?
  26. prochrger help
  27. Stick with the 241s or go 243 heads?
  28. convince me...SC or Turbo
  29. Monitoring EGTs on a turbo car
  30. Motovative Insta-Boost Quick Spool valve
  31. Twin MP61s vs PT76gts on 370
  32. ls6 intake boost source
  33. ati balancer help
  34. Suggestion on possible cylinder head swap
  35. FI question
  36. LS2/LS6 Cam Vs. Turbo Cam? How much diffrence?
  37. Are RCI injectors any good?
  38. Who has the best deal on 160lb injectors?
  39. Anyone need some SERIOUS exhaust/intake bends? (new product)
  40. Re-building an older FI motor
  41. Might be a dumb question...but do all Turbonetics turbos have the brand on them?
  42. Master power gt45?
  43. procharger inlet hat?
  44. LS1 SDCE Spring Tensioner
  45. What gasket
  46. What precision turbo/s do you use?
  47. Will my car spool up lanuching?
  48. 232/236 with a maggie 112?
  49. Power to push a c5 to 200 in the mile?
  50. Another Procharger truck inlet thread
  51. Square port vs Catherdral for boost?
  52. procharger inlet hat
  53. Thought this was kinda cool. LSX TV article
  54. turbo smoke @ Idle
  55. anyone running 15+lbs on a fast 92?
  56. Is it possible?
  57. NA Car to Supercharged Questions
  58. Looking for DIY turbo build parts? We have them all!
  59. Update on group buy of larger exhaust housing for tc78
  60. s480 for my 408 questions
  61. GM 12626958-LSA heads
  62. Twin Turbo CTS-V Build
  63. whats your idea of the ultimate street FI motor..
  64. Ati pro pulley
  65. STS turbo LT1 vs LS1 differences
  66. two things : spark plugs - red race bypass procharger
  67. procharger to j-bracket bolts....loctite?
  68. Buying a Procharger
  69. Opinions needed
  70. injector size ?....please help
  71. stock crank pulley at 1000hp?
  72. Anyone running a BOV instead of a surge valve on there SC
  73. LS1 Supercharged Threaded IAT?
  74. 2002 ta 408 f1a
  75. sdce
  76. true tech bracket v. Procharger j bracket
  77. F1a inlet
  78. Good article on the new Garrett gtx billet wheels
  79. Need advice for a turbo build
  80. Possible procharged 370, help needed
  81. which bearings and head gaskets for a 370 with 16# boost?
  82. P1SC Procharger & stroked 408 question.
  83. TC76 .96 on 347 ls1 and backpressure
  84. DD turbo car
  85. DIY Fmic
  86. better numbers with smaller turbo! 404ci + 76mm
  87. HTV2300 onto LS1? [HELP PLEASE]
  88. Turbo I.D. help CCH78
  89. S400 Choices
  90. What rear end gears for 9 sec 4l65e car?
  91. Carb ready for more boost and better MPG's
  92. Vortech with low boost
  93. Multiple wastegates vs Large wastegate?
  94. Best intake for Forced Induction
  95. 6speed Turbo cars with 4.11's question
  96. Turbo guys with mass air flow sensors
  97. eboost 2/ lnc-002 Forsale
  98. eBoost2.2 or 4 port solenoid?
  99. best intake
  100. Anyone running the throttle body facing the cockpit?
  101. most compression that you can run with a YSI blower kit and
  102. 317 head 5.3 turbo question
  103. FPR for my setup?
  104. vortech 355 how much is too much oil
  105. Passenger Side Procharger
  106. Tial with a 2.5bar spring??
  107. air-to-air or air-water?????
  108. Who has a pic of a PT88 next to a TC76/78?
  109. blowing oil from oil cap breather
  110. Too much boost
  111. am i sizing my turbo and piping correctly?
  112. Vortech confuzzled.
  113. APS Shortened End Links
  114. Which turbo?
  115. Crankcase Pressure?
  116. Downpipe size for mpt76q
  117. What map sensor is this?????
  118. Will vette accessories and blower brackets fit on on a 99 F-body
  119. ***LMR Rear Mount Camaro makes 1050rwhp through 4L80E***
  120. New PTE 66mm gate
  121. Trying to Bump comp up a little what heads?
  122. LQ4 vs LY6 stock vs stock
  123. Tial 50mm Vs. Tial "Q" 50mm bov?
  124. How am I doing on HP?
  125. 5.3 bored and stroked to 383 and boosted 1000hp
  126. pt88- 25x12x3" intercooler too restrictive?
  127. 1972 Nova Turbo Lsx Build
  128. ***LMR Twin turbo Corvette in car Vid***
  129. 317's, L92's or Aftermarket w/Procharger
  130. Twin 6765 408 88 GTA build
  131. Buy turbonetics or not?
  132. anybody do verticle rad mods in amarillo tx area?
  133. Need ls2 turbo advice
  134. new numbers
  135. TT TBSS idea..
  136. Looking for someone to tune a procharged car
  137. Billet wheel Discussion: Point milling vs Flank Milling
  138. What Kinda power will i make with a d-1 ls2?
  139. NEED FMIC pics and instructions
  140. Backpressure - Can big wastegates help?
  141. how much boost on a studded stock allum block 5.3?
  142. TT kit's other than Incon or APS?
  143. Selling my Procharger D1SC
  144. Tc78 with 1.15 ar vs pt88?
  145. 4.8 combo, looking for a little help.
  146. What makes a CCW crank so much better then a reg crank?
  147. how much boost will these pulleys make
  148. stock ls1 turbo
  149. Looking for feedback on Incon TT system on LS1
  150. ***LMR Reality Show Clip #10***
  151. badass 97 lt1 forced ind built motor daily driver help!!!!!!!!
  152. Ls9 Head Gasket on 4.8L
  153. Have some questions, new to boosting LS1s
  154. the bigger,the better
  155. More boost?
  156. Couple Qs about my 383 turbo build
  157. Forced Induction and #7 Faliure...
  158. TVS 1900 Jackshaft Question.
  159. procharger oil slinger
  160. New to the Turbo world, need opinions on my combo
  161. Are the smaller K&N filters trouble?
  162. coating hot-pipes
  163. l92 heads and boost???
  164. Sale or build turbo kit?
  165. Help With High Idle/ BOV staying open.
  166. Need some front mount IC ideas?????
  167. Need help with what t6 turbo for 346?
  168. Thanks to BECK, HKE and LMR, 937 rwhp 800 rwtq pump gas!!!
  169. custom exhaust for aps twin turbo camaro
  170. A few more changes and finally ready for action this season...
  171. Basic Turbo 5.3
  172. Heads for 6.0L truck manifolds turbo kit??
  173. Threaded IAT and 3-Bar MAP Sensors
  174. Is this an OK turbo cam? XR269 216/220 525/532 114 lobe
  175. skool me on f-body turbo setups
  176. Garrett GTX billet wheels?
  177. Best K member for clearance?
  178. 427 twin turbo choices
  179. Gains from a pt88 to a garret t4 91
  180. FI Questions
  181. head selection for FI big block
  182. Looking for a nice C5 turbo kit.
  183. intercooler piping A/W
  184. clutch for FI
  185. 10.5 compression with forged pistons=good or bad? 15#
  186. Some final ?'s on !PCV, vented valve covers, and puke tank
  187. can i get the compression down to 10.0?
  188. 80lb injectors = what max WHP range?
  189. Pulley combo/blower RPM
  190. How strong is the LS1 BLOCK itself (not internals)
  191. turbo?
  192. Check out our SSR Magnacharger on E-Bay. Can be used on LS in late model with afterm
  193. t3 turbine to small for twins?
  194. Anyone have experience with the 860 performance intake elbow?
  195. KY-Turbo Inc. Updates. New Setups.
  196. Stock crank, forged engine--bearings, oil pump, and ring gap for boost?
  197. Who is using the TSP 228R cam in a turbo set up?
  198. ***LMR 09 Z06 Twisted Package Vid***
  199. 5.3 or 6.0 turbo?
  200. Meth questions??????
  201. ls1 or ls2 throttle body
  202. Who has experience with a boosted lq9?
  203. Core support mods?
  204. Boost cam?
  205. What size dish for an lq9 and 317 heads
  206. What internals to use for a big boost lq9 setup
  207. Lq9 stock stroke or larger stroke?
  208. Bought an lq9 and wanna go big with forced induction
  209. How much boost and still hydraulic?
  210. engine is cutting out at 430hp help plz!!
  211. LS2 Nissan 350z Turbo Stage 3 =)
  212. pt88 on 20ish lbs. + stock crank = fail???
  213. 317 and 5.3 CR
  214. why a turbo 5.3 when there is a 6.0?
  215. Rear Mount Questions
  216. need some help taking a turbo apart from the experts
  217. Help with clutch for turbo engine
  218. help with picking a turbo for my Z06
  219. anyone with 370 with 317 heads
  220. House of Boost LSR Cog Procharger Drive System
  221. GMPP LS9 S/C Package
  222. twin turbo oil lines
  223. GT47 80, Can I use this turbo & what ci is it good for?
  224. 64mm turbine vs 79mm turbine?
  225. Should I switch from OL-SD to CL-SD?
  226. LTX Guys, what shorty headers are you using for turbo builds?
  227. 402 Turbo help
  228. AIS instructions
  229. for those of you who have done turbo 5.3 swaps into your fbody
  230. Best Head and Cam Setup for '03 LM7
  231. Where can I find a FAST 92mm for my setup?
  232. Procharged 427
  233. 10% Off water/meth Systems!
  234. Anybody want to sell me a 02-04 Z06 cam?
  235. any other manifolds as good as the truck ones?
  236. Power adder opinion help?
  237. Ebay Turbo Headers, any good???
  238. LSXtv.com boosted car article
  239. Any offer fromThe forceinductions.com for Christmas??
  240. Pump or e85?
  241. GT88, Need DP starter pipe, drain flange, t4 flange, merge, ETC..where?
  242. dimensions (maggie vs kb)
  243. mail order tune?
  244. How many 347's out there
  245. Anyone with turbo set up & no muffler?
  246. **LMR Episode #9**
  247. ? about venting wastgate to atmosphere.
  248. Square port heads any good for a turbo?
  249. Another turbo LM7 noob question session.
  250. 4.8L & 5.3L Wow
