PDA
View Full Version : Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 [167] 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230
  1. Optimum Turbo Street 6 speed Setup?
  2. how do you run oil lines?
  3. Talk about a long day at the track..
  4. What do you guys think of my new shortblock?
  5. How to launch with an STS.
  6. sts turbo
  7. Noob question about STS
  8. My PCV Setup PT II
  9. Low CR 402 n/a numbers...
  10. OK to use port on intake manifold for boost/vac reference
  11. are mahle pistons and rods good for 700 rwhp?
  12. Need some advice from Vets!
  13. where to muffle an STS
  14. can i put a performance muffler on a stock cat back?
  15. new intercooler pics
  16. STS problem
  17. getting closer !!
  18. ? about cutting bumper for FMIC, TA
  19. what happend to my proturbo post?
  20. build help
  21. Boosted LQ4
  22. 6L Block Iron/Aluminum
  23. Dumbest question, or Hardest??
  24. Help with my setup
  25. Is Magna Charger worth it??
  26. Universal Intercooler Piping
  27. whos got a turbo lt1
  28. Is there a better fan to use on my ATI kit than what they gave me?
  29. PP Stage 2 or Stage 3 heads for Turbo app?
  30. Instructions on godzilla BOV
  31. 383 stroker,D1SC,14 psi!!!!
  32. power steering delete
  33. sts turbo oil problem, please help
  34. Added another fan, still running hot, now what?
  35. TT LSX 59 Impala nearly complete...finally
  36. what BOV is this
  37. Futral F9
  38. Will race fuel help me on a street tune.
  39. Aftercooled Vortech LS1. You like it? #'s?
  40. Turbos on the way!!!
  41. Ported throttle body, does it help much?
  42. Some STS Help
  43. which would be easier...
  44. LS7 SS build up with a Procharger
  45. Looking for General Remote Turbo information
  46. Turbo Dimensions
  47. Should I buy QTP long tube headers if i get a turbo system?
  48. Whats a good exhaust A/R....
  49. f1 help
  50. Tuner for LT1(stock PCM)??-t-76 10psi pump/14psi race
  51. t4 inlet and exhaust gaskets
  52. T76gts cold side inlet flange question!!!
  53. Where Could I Get Some Check Valves?
  54. Odd question about STS
  55. What about this
  56. T-3 or T-4
  57. what paint for FMIC and IC piping?
  58. mass air question?
  59. another short update
  60. AFR 205 or Ported 6.0
  61. New track videos from Chitown RSD
  62. Track Pictures by 1320Video.com of My SS
  63. New TT Z project.. not what you might be thinking..should be FUN!
  64. Pics of your turbo support.
  65. can you guys take a stock c6 z06
  66. Supercharger for LS4 5.3 v8?
  67. Eaton M112 Supercharger
  68. 98 ls1 edit files for supercharger?? needed
  69. Just bought my Vortech Supercharger kit
  70. Anyone run twin turbo?
  71. Vortech T-trim head unit???
  72. ground clearance with sts
  73. How hard would it be to make a homemade sts style turbo kit?
  74. intake manifold question
  75. head flow velocity
  76. turbo size ?
  77. anyone running 10 pounds with a T76gts on stock bottom end??
  78. what is keeping a Fbody from mounting a procharger to the heads?
  79. Sts Turbo
  80. pics of install roots blowers
  81. Has Anyone Lost His Engine to 8 PSI?
  82. Compression on built block for a D1sc?
  83. What is my rwhp?
  84. Could I be losing boost somewhere?
  85. 304 SS VS Aluminized SS for INtercooler tubing
  86. question on what exhaust to run.
  87. Making my own crossover - questions on WG and flex section
  88. 1000-1200 hp air-air
  89. First time to the track!
  90. So I was looking into getting a turbo.....
  91. First track runs with DIY turbo
  92. F1 Procharger for a 346 F-body?
  93. Wastegate size. Stock o2 location...
  94. New Track Times for my Twin 67's; 9.16 at 146.197
  95. Custom Rear Mounted Turbo Hits The Track
  96. 6.0 manifolds wanted! NO SMOG FITTINGS
  97. Victor Junior fitment issues ?
  98. should i still get a converter?
  99. Stock Ls1 And P1-sc Procharger
  100. 90mm Trottle Body And Elbow
  101. pcv idea
  102. FS:25.2 camaro roller
  103. Twin Turbonetics 60-1 HiFi, on center exhaust housing .96
  104. magna 122
  105. Who has the best price on wiseco pistons?
  106. Procharger people: Do you ever...
  107. Going +1 on STS
  108. Fun at the track. Now I need some help.
  109. T60 freshen up costs
  110. So who has actully done a 3bar tune?
  111. 370 c.i Iron block with vortech ????
  112. I am ordering a KB supercharger kit for a 03 z06/What else might I need?
  113. Differances between Methonal and Denatured Alcohol
  114. Anyone have pics of their 98+ TA with front mount?
  115. Most rwhp on a D1 on pump gas?
  116. Cam selection
  117. Alittle Issue after the dyNo today...need HELP asap!!!!
  118. The lil ole LT1 Dyno #'s
  119. update on my crank reference problem
  120. FMU should raise fuel pressure correct?
  121. Compression ratio???
  122. what do you think about these numbers...
  123. People who have FMIC IN!!
  124. First steps towards BOOSTED
  125. corvette boosted tune and 3 bar map sensor ???
  126. tuning..........turbos
  127. List of truck manifold part numbers?
  128. I did my homework and want your opinion
  129. shop forgot bov on sts turbon help
  130. Looking for a 3.5 x 3.5 elbow. 90
  131. 2004 C5 346 ci with D-1SC at 14 psi - 700+ rwhp on our Mustang Chassis Dyno
  132. two stage fuel systems
  133. need help
  134. Turbo oiling idea
  135. I like 'em THICK!!!!!!
  136. Sts Owners Help
  137. Best twin/single set up?
  138. WTF??? Need crossover help
  139. how much boost?
  140. ls1 1000 hp
  141. cam?
  142. Thats it, I am worried.....
  143. Boost my car?
  144. So what is "the" solution to the ATI overheating issue?
  145. Bill/Hiflo tracking #
  146. what catch can do you have???
  147. Why is the ATI fan shroud like this?
  148. Innovative turbos
  149. GT47-88 Build pictures (1998 Formula) ---->
  150. another 1000rwhp tt burnout
  151. North vs. South Shootout
  152. What is the preferred brand of piston
  153. T76 rear mount track results from tonight
  154. Flex pipe??11?!?!??/?11??
  155. turbo
  156. 1000 hp burnout!
  157. What are the best heads to use with a kenne bell on a 346?
  158. 6.0 manifold question, flanges?
  159. What do you think
  160. people with custom radiator setups
  161. Iron block and procharged Fbody guys
  162. Blower Cam
  163. need help
  164. superturbo?
  165. lifted a 6.0 head need info
  166. Vortech Users help please
  167. Boost+Nitrous=????
  168. Oh that zach, hes at it again...
  169. The beginning of something (TTi install)
  170. TTi question
  171. Cam Change,"boost change?"
  172. SDCE 6 Rib Spring Tesnioner
  173. Video of my D1SC Procharger First Run Against anyone..
  174. Fan settings for boosted engine?
  175. wide band
  176. STENOD help
  177. Block selection
  178. Need to send some stuff back to procharger...
  179. has anyone ever tried a stock GN turbo on a 346
  180. BOV vaccum/spring question
  181. guys with iron block and procharger in Fbody
  182. FOD Damage
  183. Non-intercooled ok for lower boost?
  184. turbo cam? is this too much
  185. little video of my car vs a 450hp 240sx
  186. This is what happens when you go big HP!!!
  187. What do you single digit cars think??
  188. Odd question, but what size turbo?
  189. Help with H/C package
  190. Help Please!
  191. what plugs?
  192. Spal fan wiring questions
  193. Heads up for FI guys looking for Track TnT at Norwalk
  194. Duke Goes New Best 7.71
  195. IFR Table
  196. lq4 heads, porting worth the $?
  197. hi
  198. Why ROTREX ? any others ?
  199. TURBO LOUD-ness...
  200. BOV location
  201. How much RWHP would you say the STS is good up to?
  202. Bob emailed me !!!!
  203. Is a breather required on drivers side valve cover
  204. How many Run with Manifolds
  205. Race gas???!!! Which one?
  206. fast 90 or victor jr
  207. Short Vid of the T TA
  208. OVER 825rwtq at 2300rpms
  209. info on this car
  210. bigger radiator
  211. Heads came back from machine shop
  212. Went to the track today, one of those days lol..
  213. old man cam or cheatr cam for STS?
  214. eboost2 hose routing to wg
  215. Stock SS or WS6 + Rear Turbo = ?
  216. Anyone here read Car Craft?
  217. Cylinders lean on 7 and 8?
  218. custom rear mount FINALLY on BOOST, now what??? (car is slow lol)
  219. catch can needed please help
  220. What size stall should i get or need?
  221. What do you 370ci turbo guys put down on pump gas?
  222. FLP DID NOT give me what I paid for!!!!
  223. Sts Kit On A All Stroke 395?
  224. no pics but a short update.
  225. First day out to the track with new combo-close but not close enough!
  226. what kind of hp can I make with stock heads, and maxing out d1sc?
  227. whats all need for a turbo set up?
  228. What should my Fuel pressure be at under boost?
  229. Stock 6.0L + XER281HR + TV81 W/12PSI Boost = ?HP
  230. sts turbo...what else is needed.
  231. GT47 VS GT42....size comparo pics needed..
  232. Is the Victor jr intake a good idea for my STS setup?
  233. Congrats KP for the win in his "turbocharged" T/A...
  234. Dropped my 0-60 time by .4 Sec on the street just from tuning
  235. oil problem
  236. What is the inlet and outlet OD of my stock MAF?
  237. turbo kit options for 98-02 ls1.
  238. Want to Procharge my SS
  239. Rotating Assembly For Turbo car
  240. best cam for my SC trans am
  241. Turbo-Zone
  242. Just a general Turbo question with 93 octane
  243. Went to the dyno..
  244. What Turbo Kit?
  245. Help
  246. 78mm Y2K turbo or
  247. t70 turbo max power
  248. oil catch can and pcv ventilation
  249. Which engine block to use for Procharged buildup??
  250. New #'s with the twins
