PDA
View Full Version : Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 [115] 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230
  1. Sooo frigging pissed!!
  2. KYTP kits
  3. loosing boost and power at 4200rps.. any ideas??
  4. custom serpentine belts
  5. "Need help" what turbo is this, have many pics..
  6. help me pick pistions
  7. 96 Vette LS 402 88mm finished engine pics
  8. What do you guys think about the new LS1 Kenne Bell?
  9. Need a good Top-End for LS1 + D1SC
  10. 5.3 twin turbo?
  11. air to water intercooler
  12. Where to buy an STS kit?
  13. Non LS. 08 Challenger TT. Gettin er dialed in
  14. Keep your fingers crossed...
  15. TT LS2 typhoon track results
  16. Well Just ordered Trickflow 245 6 bolts from 99blancoSS. Any one running these heads
  17. Loud pop ,backfire mabye when going wot low rpm though low boost.
  18. 21 psi w/ 16* timing on 93
  19. Finally getting my tune!
  20. sts style oiling question
  21. 8.3L Whipple on a C5R, 427
  22. Two Questions!
  23. New D1SC with Forged 347, How much HP on 91'?
  24. Who has used a MP70 for a rear mount? Results?
  25. most horse power made on T4
  26. What headgaskets? (408ci/AFR225)
  27. Discussion about turbo cams, overlap, boost and reversion
  28. forged bottom end question
  29. need some advice
  30. My p1sc setup. What else do i need
  31. Where to ger convuluted tubing?
  32. Is a TSP Torquer V2 Cam Like boost? What gears to run?
  33. some new bests tonight (added videos)
  34. this cam good for boost???
  35. ROCKER help!
  36. Cam for my Butt mount TT ZO6
  37. S91 Build FeedBack. Is this Reality?
  38. Paxton 1500
  39. Spark plug & gap for fi ????
  40. CAD Drawing for truck manifold exhaust flanges?
  41. ls1 turbo friendly?
  42. Vic Jr vac line connections
  43. 08 Vette, TVS 1900, auto
  44. I've restarted the 2009 FI fastest list
  45. Who can tell me about this Vortech SC?
  46. Super Victor vs Vic Jr for 370ci twin turbo GTO
  47. please help cant hold boost
  48. What radiator are you running with 700rwhp?
  49. 427 LSX build, heads?
  50. turbo project, looking for tips!
  51. What should I do next?
  52. A intercooler is a intercooler....right???
  53. Turbo m6 cars ?? launch?
  54. Getting a D1SC soon, Help please?
  55. what AFR to shoot for with 16 psi boost? FAST system
  56. Gravity Drain or Scavenge Pump?
  57. What turbo?
  58. Made up mind...going for boost
  59. callie dragon slayer crank
  60. HELP! - 6 psi Blowing off Silicone Connector
  61. Why truck monifold for DIY?
  62. alternator relocation=what do i do about oil cap?!?
  63. MasterPower T70 hp capability?
  64. Where to find Mo-cal Pump?
  65. Car just doesnt seem to be as fast as it should be V2
  66. How much boost to expect on a d1sc
  67. conflicting head gasket apps and search blows, what gaskets for 1999 block and 317's
  68. 370 or 408 ProCharger Motor ???
  69. Redone EPP frontmount
  70. BOOSTMASTER's TTix goes SD and pulls 925RWHP on 91 Octane and Meth
  71. few questions please help real quick
  72. Aftermarket defogger for windshield?????
  73. Va Speed's new FI machine processes/parts
  74. Which ATI pulley for my procharge setup?
  75. Cheap Scavenge Pump~!
  76. Meth Kit
  77. 1500hp Boosted fuel system: Will this work? (New Idea)
  78. LSX Cog Kits Fit Tri-Fives...
  79. Turbo kits that keep A/C???
  80. New best... 5.26 @ 141.86 (1/8 mile)
  81. Boost and FPR???
  82. ATI balencer
  83. I need some Advice please.
  84. Has anyone...
  85. Loss of power Brake and No Boost
  86. need help for BIG BOOST !!!!!!!
  87. Boost and the LS3...
  88. What makes the trim? Superchagers
  89. Maggie 122 - 90mm TB gains
  90. F1R 427 C6...numbers
  91. Blow through with ls1?
  92. f1r 6.0
  93. did some plumming today
  94. Timing and boost
  95. found oil in throttle body
  96. Dynoed the car today, ???
  97. Turbo rebuild
  98. Going custom 61mm twins in the GTO
  99. Head gaskets for 4.005 LQ9+317's+15psi?
  100. magnum xl vs magnum for forced inductoon
  101. Where is my boost going?
  102. Vortech V1
  103. need advice/pointers on 6.0 turbo build
  104. I need some help!!!
  105. Procharger belt problems!!! Please help..
  106. is this a good set-up for a carbed 305?
  107. Sierra turbo build up.
  108. Boost gauge install
  109. Waste gate vacuum lines?
  110. help choosing turbo size
  111. DISC FMIC / 408ci Iron Block - Running Hot
  112. Twin turbo build up in 67 LS1 Camaro
  113. Fan on intercooler??
  114. rear-mount track times?
  115. What Gears
  116. Can i make only 5psi with a 8.702psi wastegat spring?
  117. Black smoke?
  118. what stall for boosted car
  119. STS PVC switch valve question....
  120. track times with p1sc
  121. Rear Mount Turbo Compatibility Question
  122. Boost
  123. Not happy with autometer triple pillar pod anyone make full pillar replacement?
  124. Well, selling my new SDCE/FMIC/D1SC setup, ordered F2 setup :)
  125. More boost?
  126. Procharger belt problem
  127. Turbo 347 LS1- S475 turbo- Tubular Turbo kit
  128. Unrealistic?
  129. Compressions Ratio's and boost, 93 VS e85
  130. Newbie to FI looking to make the switch.
  131. turbo size
  132. Eboost f body install faq in center vent?
  133. Nitrous and boost
  134. alky meth kit install instruction
  135. P1sc fuel system help
  136. Just bought turbowerks scavenger for my aps tt car.
  137. Where to SC?
  138. Turbo oil pressure
  139. ngk plugs
  140. Help with a pillar?
  141. What is the disadvantage of a tight cam LSA?
  142. anyone have a p trim 96 or 100 divided housing layng around?
  143. How long did your stock ls1 last with boost????
  144. Twin turbo 427ci corvette / 4L80e conversion forsale MINT
  145. truck manifolds - where do i buy?
  146. my car RESULTS corvette 2006 F1-C
  147. Twin Scroll turbos?
  148. cam too big for boost?
  149. New car twin turbo size & brand ?????
  150. Misfire issue only in 4th gear.
  151. Can I run just mesh screens for filters on turbos??
  152. 10 psi stock long block fuel pump
  153. Running 9's vid within..60ft sucks though
  154. bmw twin scroll twin turbo
  155. Forged Short Block + ProCharger Install Cost?
  156. Couple of questions... (long)
  157. Engine build for SC
  158. boost creep? will Eboost 2 stop it?
  159. 2-step vid
  160. front mount turbo
  161. Pictures of my new turbos for my APS car.
  162. 370 OR 408 for boost?
  163. Help! it cranks but won't start.
  164. $100 = 3 more #'s of boost
  165. Made a couple hits Friday, new best 9.52@148.95
  166. Meth Injection, GTO, Maggie
  167. o-rings/gaskets for boost?
  168. turbo oil return
  169. New dyno numbers!!!
  170. fast 90/90 or vic jr intake? how much increase will i see?
  171. What to put in Warhawk block rear vallys sensor holes ? few other questions
  172. STS Mechanical Boost Controller Questions
  173. Questions about the Kentucky Turbo setup
  174. Got the pipes back from coating....
  175. Getting Closer 9.25@150!!!!!
  176. Trying to find highest Hp/boost on stock heads and where weld 5 bolt on stock heads
  177. Procharger Mounting Bracket
  178. twin setup
  179. T-bolt Clamps.
  180. Can the stock map sensor leak under boost?
  181. Stock 07 ls2 with 7k miles.
  182. To those looking for an alky kit....
  183. HP Performance Turbo Kits?
  184. FMIC cooling
  185. <<blown stock l92>>
  186. Using a rear-mount turbo setup on a V6 fbody....
  187. fastest on a stock pcm?
  188. WG Temps
  189. Which electric fans?
  190. running boost on a stock ls1 intake.
  191. Anyone running an EBoost2?
  192. URGENT URGENT APS Turbo help
  193. Question on turbo blanket thickness
  194. FI Noob questions.
  195. CAN I BOOST MY 11.5 to 1
  196. Big thnx to EPP!
  197. meth with race set up?
  198. Got car dynoed today but concerned about tune
  199. Any 78mm or 80mm turbo owners want to upgrade to an 88mm?
  200. jus a little corvette build up.
  201. Max Cylinder Pressure / Boost on a Stock LT1?
  202. Quick Q: can I clock TC78 hot-side?
  203. patriot heads on turbo lq4?
  204. Looking for a used complete turbo kit
  205. Need some eboost2 help
  206. procharger install problem
  207. Scavenger pump install on front mount?
  208. Turbosmart BOV's Question for how hard to set them??
  209. BOV's
  210. 2-step/APS track times
  211. Need advice on rockers for my built 35th APS
  212. APS GTO help please
  213. 402 LSX with custom F2 set-up(Dyno vid & Graph)
  214. Air pump on a procharged car
  215. Harmonic balancer bolt for procharger
  216. Replaced the Injectors & Alternator = A/F is RICH! Turn up the boost?
  217. what muffler turbo guys?
  218. Kytp
  219. STS Install finally done!
  220. Who's running 25+psi?
  221. best 16" fan ???
  222. Thinking of a 383 forged stroker.
  223. BS3 guys, where'd you mount your ECU? Pics?
  224. turbo cam idle clips Wanted
  225. Where do you drain oil on front-mounts? Pics please
  226. What spark plugs and fuel to run in 14 psi ls2
  227. How did i make these numbers?
  228. Big sigh of relief!
  229. Car just doesnt seem to be as fast as it should be...
  230. Turbo Oil feed question
  231. Who has had to rebuilt turbo when it leaked oil?
  232. Headers for 454 lsx w/f2 procharger
  233. What parts am i missing? Will be installing a used STS GT70....
  234. How much exhaust wrap will i need?
  235. does anyone here have a throttle stop cause you cant control the power??
  236. Pistons and connection rods kit
  237. Which valve springs for boost? Playing it safe
  238. First Day at the track with the YSi!
  239. APS Problem need help
  240. Info on my 1000+ Rwhp TT build running on E100
  241. single turbo kit?
  242. If its not one thing, its another!!! HELP!
  243. Airesearch turbo's.
  244. APS Problem need help
  245. My BOV was leaking a little would i lose any hp form this ?
  246. ls6,vic jr. with sheet metal 90?
  247. crank case pressure, and your down pipe.
  248. Turbo Cam Help Please!!!
  249. Oil leak on 9+ psi
  250. Dumb question
