PDA
View Full Version : Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 [63] 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230
  1. Whats the difference between the 76gts and the 76/75?
  2. Hot side options shorter length vs equal length?
  3. Name that Turbo
  4. quickest/fastest stock 6.0L?
  5. Twin Turbo 92 C10 ????
  6. just a thought
  7. Need info for Turbo build
  8. Need cam suggestions!!
  9. Would these manifolds work flipped up?
  10. best cam ratio for supercharger
  11. stock 5.3 twin turbo build
  12. which valvetrain for turbo motor??
  13. Which cam should I use for turbo?(dyno # update)
  14. Decided how to blow my money. Forged 347 w/ AFR heads, D1SC
  15. 5.3 Twin build
  16. Twin turbo street 67 camaro,60-1's?
  17. Camaro 68 jy5.3 guestions
  18. Looking for a compressor map
  19. Help with cam spec's
  20. lq4 turbo build
  21. PLEASE HELP!!! looking for a low mount passenger side alternator bracket
  22. Anyone run one of these elbows?
  23. 243 vs 241 heads, does it make a difference with a MP112?
  24. G body 5.3 turbo single turbo, which manifolds
  25. any manifold out there that will clear the a/c compressor on the passenger side?
  26. what intake/tb setup for a l92 404?
  27. Need advice on a GT-45 LQ4 setup
  28. Crossover flex joint
  29. EFI Live injector tuning with turbo question.
  30. stock 5.3 turbo...how much boost?
  31. eBay gt45, stock 4.8, goes 9.18@146
  32. Cam for Nos
  33. What's the fastest stock bottom end LSx?
  34. Marcella Intake for boost!!!
  35. Found a cheap bracket for forward manifolds
  36. whipple 4.0 Camaro ZL1 teaser
  37. ring end gap discussion
  38. All Out Bonneville Junkyard Effort
  39. turbo kit parts ?s
  40. camshaft opinions please
  41. 5.3 turbo
  42. 1998 Camaro LSx Real Street Build Thread
  43. Chevelle turbo sizing
  44. Ls6 vs fast intake
  45. Cutout Gains For FI vs. NA
  46. Big Cam and Boost
  47. Barrel style water to air intercooler
  48. Time to give up the 98 PCM?
  49. price help
  50. 5.3 with scat I beams gen lV pistons
  51. Forged Mahle flat tops with boost.
  52. 383 twin turbo t-66?
  53. which turbo would you run.
  54. Stock lq4 how big turbo size?
  55. Supercharger kit?
  56. Forced Induction Options for C5r Block and AFR Heads
  57. some progress on the MuffStang
  58. S488 turbo
  59. Got my KUP water vapor system hooked up, no retune time!!
  60. Can anyone tell me what blow off valve this sounds like?
  61. spooling a 110mm turbine wheel, will it work?
  62. Turbo SS
  63. Huron Speed HOTSIDE 25% off SALE!
  64. White smoke blowing out of oil cap. Compression test looks good.. Help
  65. Ati damper question!
  66. 1995 Silverado TT.. Redsled
  67. Piston dish?
  68. Welding to Stock F-Body Manifolds
  69. Gearing for a high HP boosted engine
  70. Critique turbo my setup
  71. Vacuum manifold & Catch can (Help)
  72. My pics of my TC78 and PT7675
  73. ProCharger Retail Rebate Extended - Save Up To $500!
  74. PA Racing NOW through Cyber Monday SALE! TURBO K-MEMBERS!
  75. 402 stroker and F1A estimated power
  76. Turbo oiling questions
  77. New build: 2010 Camaro | X275 88 | TH400 | street car UPDATE: 03/03/13
  78. Lq4 turbo coldside and waste gate help
  79. Ls1 S366 buggy build
  80. help with twin turbo chevelle
  81. v7 ysi not making boost
  82. alternator mount
  83. bulleye 94mm batmowheel or pt98?
  84. Horsepower guesses...
  85. Boost Falling off at High RPM & Dyno Graph looks Weird?!
  86. post pics of your LS turbo mustangs/Notch engine bay setup
  87. Turbo hot side questions
  88. turbo advice (trying to learn)
  89. 347 turbo batmowheel
  90. Where are you guys getting your LS9 head gaskets?
  91. Jax04's 1991 Rx7- 5.3-PG-8.8- S475- Street Machine
  92. converter help
  93. Manifolds VS Headers?
  94. 402ci pt88 build video...
  95. Turbo 6.0....will XER273=14 cam work ok?
  96. Mayhem Motorsports goes 5.44@129 stock 5.3/s400
  97. Twin 67 5.3?'s
  98. new to LS1 tech
  99. f1 start up
  100. th400 or PG/3.23's or 3.42's/28" or 29" tire? high 8 second car at 3600lbs
  101. 370 ls1 or 6.0 truck crank or 5.3 for boost
  102. The wait is over...TTI twin turbo F-body kit finally available
  103. maggie/magnacharger 122 for sale anywhere???
  104. Spend my money
  105. kits that keep radiator in place???
  106. Diesel vs pump gas and boost
  107. Turbo Technology Turbo Kit?
  108. TC78 Oil screen.. oil restrictor needed?
  109. trapped 150 tc78
  110. 5.3 turbo questions?!?
  111. quick question about turbo mock up and K member.
  112. LSx turbo mustang 8.93@157!!!
  113. help me figure out my turbo setup
  114. Precision Turbo Problems?
  115. How much to gain from S475 to S480?
  116. Heat shields
  117. Boosted stroker motors, yes or no?
  118. Adding a catch can to my procharged ls1
  119. Procharger F1-A Head Unit For Sale
  120. 2006 GTO Almost done
  121. TC78 on a 4.8/5.3- Horsepower/Backpressure
  122. Turbo lq4 fuel questions
  123. 100% stock motor + boost TIME SLIPS!!!
  124. 706 heads on a stock 5.3L ported or not?
  125. Building a manifold flip kit for a 2008 4.8 silverado questions.
  126. Building a manifold flip kit for a 2008 4.8 silverado questions.
  127. Got the hot side to the turbo started today.
  128. Turbo 5.3 valve marks on pistons...LS6 springs not enough??
  129. Copper coating ls9 head gaskets
  130. oil feed and return line size
  131. Is there a 6 bolt head for big boost/power that works with only a 4.070 bore?
  132. Im going bonkers (5.3 Sonoma T70 build)
  133. LQ 6.0 built for boost but NA for a while..
  134. Oil Priming Problem
  135. APS twinturbo question
  136. Procharger mpg effects?
  137. Cost for power
  138. need your help of Turbonetics
  139. Thinking of switching blowers
  140. My budget Twin Turbo 383 build
  141. fast 102 intake
  142. JY 4.8 builds
  143. Confused on which block for boost?
  144. Those with Griffin 1-25241-x
  145. twin turbo opel, lots of questions
  146. How do boost contollers work without tunning?
  147. ls6 cam
  148. New turbo not spinning at idle
  149. Turbo Cam Discussion
  150. Stock short +63cc heads + D1SC =?
  151. Noob turbo question, Rear vs Front
  152. Detailed Info on twin turbo setups, especially pictures!
  153. Lets Play "Name That Cam!" And the Winner Gets A Free Camshaft!!
  154. 5.3 Junkyard Build - Cam suggestions?
  155. Huron Speed Turbo guys, what are your plans?
  156. Does the truck hat on prochargers rob horsepower??
  157. It's Alive.......
  158. T4 divided flange
  159. turbo Tahoe pics
  160. Poor mans LSX Real Street.......Car is sold- New car/Wifes car= new updates
  161. First time at the track with my turbo C6(forced inductions gt91)
  162. vortech v9
  163. use my 226/234 113+3 cam for my turbo motor???
  164. f1a blower with custom cog belt set up
  165. Determining the correct blowoff pressure?
  166. Eric Lancaster's bolt on ZR1... 9.679@146.23... Video inside
  167. Incon TTi and 5.3 build
  168. New PB with the JY 4.8L GTO
  169. How fast people been w/ D1SC? Customers stock longblock 9.77@141 so far...
  170. What do I need to put 3700lbs in the 10.50's? 5.3 or 6.0
  171. RPM TBSS Goes 10.47 @ 132
  172. TN550 on 5.3?
  173. Lower static compression???
  174. Looking for pics of s475s in 4th gens
  175. 99 Camaro SS build Thread with Dyno video
  176. Another successful track outting
  177. 3" coldside + 88mm?
  178. tapping moroso oil pan
  179. need help from procharger guys (inlet hat b4 procharger)
  180. borg warner/garrett hybrid t6 85mm 1.32 a/r on a 402
  181. How does this cam look for FI?
  182. Will an AES 410 be able to get a full weight street car in the 7 sec zone?
  183. who has the most affordable sheet metal intake?
  184. F1 procharger trouble
  185. Ported vs Non-Ported Compressor Covers & LS Engines
  186. LSx 6.0 stroker 408 pro charged
  187. Lavoy goes 8.85 @ 153 on stock 4.8 shortblock
  188. Intercooler tubing size?
  189. Compressor wheel Question
  190. Exhaust fumes, cats ?
  191. fan setup
  192. Video of my 6.89@221 pass in eliminations...
  193. Keep a/c with truck/c6 mani's. (come in if you run a down-pipe under stock k-member)
  194. Sloppy Mechanics guide (wire and fire ms1 and MSD6010 LSX)
  195. Intercooled vs straight pipe???
  196. Cranks? And rods? Boosted!
  197. 4.8 turbo
  198. Noob turbo help
  199. 2.9L Whipple Build
  200. Upgrading to a PT7675, what AR should I get
  201. Junkyard 5.3l turbo build, will this cam suffice?
  202. LS in 1st gen with screw blower..advise
  203. procharger questions
  204. ABS Module Delete Guys, Normal Lights on Dash and Does Your Cruise Control Work?
  205. supercharged with a wastegate
  206. POOR man's low slip converter?
  207. 5.3 running Microsquirt 2, waste spark and fuel *1-8-13 updates*
  208. research beyond search -TT 5.3
  209. Opinions on gt4202 for 370
  210. 5.3+76mm
  211. Vengeance built 2009 C6 Z06 TTix Twin Turbo System makes 847/776 on 12 lbs of boost
  212. 2004 5.3 engine ?'s
  213. Mayhem Motorsports / Lucado Racing X275 C6 Corvette at WCF - 7.72@180 - VIDEO INSIDE
  214. Any one use Holley 522-128 Universal Fuel Injectors (8) low impedance 120 lb hr flow
  215. FMIC and pipping question
  216. what do you think about a powerglide on a 1000hp street car
  217. Any 2nd Gen Camaro's with a single s475 post pics please
  218. 408 turbo cam recommendations
  219. best 88mm for under $2k?
  220. My buddy says....."Not possible!"
  221. Procharger help!
  222. Turbonetics NEW 7675 and 7875 Turbos AVAILABLE through Huron Speed!
  223. New self contined turbo system. You gotta check this out!!
  224. Damber and fuelpump for procharger kit
  225. Procharger rebate - save up to $500
  226. plugs gap change+same timming table=pushing water???
  227. What do you guys think?
  228. I have a VORTECH SUPERCHARGER FOR MY 02 TRANS AM I AM THINKING OF SELLING!!! HELP
  229. Has anyone tried a 70mm turbo n a LS engine?
  230. 7.44@192 with an 88m turbo**new videos added***
  231. Procharger HO kit, P-1SC-1?
  232. Preliminary #s, 402/F1R
  233. Pictures of where you guys mounted your air to water intercoolers
  234. What is the optimal rear gear ratio?
  235. Ls9 valve springs on 317 heads
  236. New to lq4 turbo jy questions
  237. New Maggie?
  238. help all procharged fbodys !! belt slip n low power
  239. CalSpeed C5 427"/TT rear mount best ET 8.9 & 161, 91 octane pump gas, fastest 4l60e ?
  240. Making "log" turbo manifolds
  241. Short deck 427 or Tall deck twin turbo?
  242. GT45 on an LQ4?
  243. Proper tuning sequence
  244. Lets see your exhaust setup Turbo guys!
  245. jy 4.8/5.3 guys come in
  246. We just Sprayed 200shot on C6 ZR1.....
  247. Quick spark plug question
  248. Procharger bypass?
  249. which spark plugs for e85 and mp122 maggie
  250. A&A Corvette Vortech users - post your combo plz.
