PDA
View Full Version : Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 [207] 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230
  1. Lingenfelter already has TT system for 05' vettes!
  2. Take a look at my heads...
  3. I've got an FI question
  4. FMIC Install Done
  5. Woot!! "overnight parts from Japan".
  6. 700rwhp Lt1?
  7. Anyone got a 3.0 hump hose connector and a 3.0 90 degree bend....
  8. Ls1 Aluminum Block For Turbo
  9. Twin turbo LT1 track results
  10. block is cracked
  11. T3-T04B on a mostly stock 4.8?
  12. I don't like the concept of a Single Turbo for our cars.. IS TWIN AVAILABLE?
  13. Vortech's GTO supercharger is available!
  14. Hey PSJ, why did you change your signature... and
  15. Need a vacuum source for you boost referenced stuff?
  16. tsp 231/237 & sts
  17. Pics of the new GT45.
  18. FS: (2) Dayco Polycog belts, 40.0 8-rib
  19. Anyone running a single fan?
  20. Injector options for a P1sc?
  21. Looking for pics of Turbo Tech Kit on cars
  22. anyone with a F1-R
  23. turbo kit questions
  24. P1SC parts
  25. New Toy and a ???? BOV
  26. What rings?
  27. turbo(s) or supercharger?
  28. I need 2 stock rods
  29. Turbo 403ci with hyd cam= 1329hp flywheel
  30. Wheres a good (cheap) place to get ATI compressors?
  31. Phone # for High Temp Silicone?
  32. Anyone using the newer gtr series turbos
  33. What Is On The Horizon?
  34. Attn: STS owners and supporters
  35. Starting turbo project soon, need opinions
  36. Just ordered my OBX intercooler.
  37. Can anyone help with my EVC 5 boost controller?
  38. For you vette peeps
  39. Heat soak issues with turbos?
  40. Head Suggestions for FI on Pump Gas
  41. Need some help gearing question.....
  42. 01 C5 450hp?
  43. sts replaces drivers side SFC! Are you serious
  44. twin turbo 372 vs tt383
  45. STS Efficiency
  46. LT1 ati procharger manual
  47. 346ci + forged internals + SC = how much power
  48. S-trim belt problem
  49. Where to get ATI Blower Crank pulley?
  50. What Turbos, I aint got no stinkin turbos
  51. Procharger Dyno'd
  52. Who makes the most reliable valve springs?
  53. Thinking of going FI again.
  54. How similar are Procharger kits on C5 and F-Body?
  55. How does the LS1 handle Boost? ***pics***
  56. Newbie need a turbo.
  57. Anyone tell me what parts i would need to build a rear mount setup
  58. TT kit for LS1 T/A???
  59. What psi which manifold?
  60. A quest. for all STS owners..
  61. Massive project to start next Saturday, need advice!
  62. question bout blower mods
  63. FI w/ Stock A4
  64. Going to a 2.75 Pully on my Vortech G-Trim, need tuning suggestions
  65. Intercooler types.
  66. Build or buy a turbo kit.
  67. FMIC going in.... *PIC'S*..
  68. CARTEK's 1016RWHP Twin-Turbo C5
  69. NA$TY-TA...customer of the month at AP!
  70. Soon I hope
  71. SC guys what's your rotating assembly
  72. GOD is not on ls1tech
  73. magnacharger
  74. Turbo Experts Question within
  75. Removing muffler on STS kit will do what?
  76. FMIC install on Z71 w/ STS Turbo
  77. Who all makes turbo kits.
  78. Will this vortech work ??????
  79. Boost retard LED not on under boost in 3rd gear...why?
  80. Mild turbo setup w/ a big shot of nitrous...
  81. Air/Water intercooler leaking internally.
  82. 99 camaro supercharger
  83. sts question
  84. Wanted: Opinion on bearings!
  85. Few pics of new custom kit.
  86. Qmp kit overboosting?
  87. roots style supercharger
  88. Blower on top of Heads/Cam...Feasible?
  89. under WOT check guage light comes on?
  90. Magnacharger
  91. Sts Meets Firebird Evolution Plus Intercooler
  92. Can I use the EVAP connector for bypass valve & boost gauge?
  93. icon turbo set up
  94. Need some advice on ATI.
  95. How far will stock valves take you?
  96. Questions on custom turbo kit fab..
  97. LS1 air consumptiom
  98. 427 block that will respond best to boost?
  99. Help needed ASAP!! Procharger install question
  100. Procharged vette over heating?
  101. Turbo Tech Kit
  102. Wanna be on Two Guys Garage?
  103. Upgrade to Vortech T trim from S trim
  104. would i blow up my car if...
  105. New Wastegate Here Tommorow
  106. Difference between vortec kits 98-00 vs 01-02.. need some help please
  107. Still looking for MMS crank pulley
  108. 372 vs 383
  109. Vortech Install Need Help Please!!
  110. One Last Piece Left 4 Fmic.
  111. OBX intercoolers ?? R they any good ??
  112. Front Mount Pics...
  113. Where can I get a crank pin kit?
  114. Methanol or intercooler
  115. TR-6 Plugs
  116. Front Mount for STS started
  117. intro - newbie incon tt owner
  118. ANyone see Ronnie Dukes new car?
  119. Opinion of Reichard Racing Pulleys?
  120. Blown and forged 347
  121. Incon owners oil system ?
  122. Y do you need Methanol
  123. Car update!
  124. Noise
  125. Downshifting and SC Belts
  126. MAF problem!!! Maybe.
  127. Griffen intercooler results.
  128. PY3400E Dyno
  129. Supercharger problems
  130. how much more can a mostly stock 6.0 take?
  131. Have a Whipple problem on my Silverado
  132. F.I guys with wideband
  133. intake tube connection question
  134. would this be a good cam for a vortech superchager with 14-16 psi
  135. ATI Inlet Hat Bigger Filter ???
  136. Need help with Procharger Bypass !
  137. Sts turbo
  138. STS Turbo Kit Q's...
  139. Dark Dragon Motorsports 1998 C5 1200RWHP
  140. If the MAF sensor is put in larger sample tube, will it read more (1000hp etc)??
  141. APE Shop Car Getting Closer
  142. Vortech Vs. Procharger
  143. Is a higher cfm head really better for turbo?
  144. How to set a bov?
  145. ??What's the torque spec for the pulley bolt on the D1SC??
  146. Need two measurements if anyone can check...
  147. New record....
  148. BOV question
  149. supercharger necessities?
  150. Turbo FAQ
  151. just add me to the tti owners list :)
  152. LS1 Turbo Kit
  153. Turbo guys, where should I mount a cutout?
  154. Livernois Motorsports Turbo Escalade Video
  155. ? on Incon Fuel Pressure Regulator
  156. For Sale: 42# SVO Greens, only used in Dyno Testing
  157. Belt Slip difference in the Rain?
  158. follow up
  159. FI heads and cam MUCH lower price
  160. Angled Turbo Hose?
  161. what a/f do you get max power?
  162. Where to get Procharger oil?
  163. Hobbs? switch?
  164. Slight Oil Pressure drop with Vortech Oil System normal?
  165. Is some SC Belt Dust normal?
  166. Intercooler who??
  167. alky tuning
  168. Can I safely run a ProCharger on my setup?
  169. OBX TBX3000 intercooler
  170. has anyone used......
  171. Drawing through MAF instead of blowing through
  172. 2300ax whipple for a c5 corvette?
  173. Boost Help!!!!!!!!!!!!!
  174. Updade on the Car.
  175. heads and injectors FS
  176. Thinking of getting a ProCharger
  177. Maxing the MAF
  178. Please post your radiator info!
  179. Questions on Snow Methanol Inj. Kit
  180. new use for my alky kit--not tech related
  181. Turbo (T76) question for the experts :)
  182. where to get turbo head unit ?
  183. Land and Sea Dyno Question
  184. Incon TT Car for sale
  185. Has anyone experienced this code?
  186. Alky Injection question
  187. S/C vs. NA
  188. ATI Procharger or leave stock?
  189. how much timing and timing at diferent rpm's?
  190. I regret getting this FMIC...
  191. Gears with turbos...
  192. Belt size selection for ATI?
  193. Right bank LTRIMS acting weird on startup...
  194. WTB: P1SC or V-2 SQ or other supercharger Head Unit
  195. Fuel Pressure Drop at WOT
  196. What do you guys think of the STS Turbo KIt
  197. Anyone use Stainless Works?
  198. This can't be for real!!!
  199. haha it's the little things that keep me from racing
  200. ? for CA supercharger install
  201. STS Tailpipe Question
  202. An easy way to prevent a lean condition??
  203. ATI Twin Intercooler Talk
  204. Tranny is in
  205. Intercooler has arrived......
  206. Eviltwins.... YSi?
  207. Anybody Looking for Dave Inall / INCON ???
  208. Turbo Oil Question
  209. Turbo? SC?
  210. where to buy whipple supercharger
  211. 1.23 a/r exhaust housing
  212. Muahaha...sure lets race for money, you can look under my hood...
  213. Intercooling A Turbo truck
  214. 688RWHP - Stock PCM - Speed Inc NEW ATI Front Mount Upgrade
  215. Got my car all torn apart...
  216. So whats the symptoms of belt slip on a 4th gear wot punch
  217. One way check valve? Where?
  218. MAF acting weird....
  219. Belt and pulley problems? Need Help!
  220. STS fins????
  221. turbo setup/custom
  222. down pipe doesnt fit???
  223. turbo on a v6 3.8L
  224. Rumor has it.........
  225. AutoTap Dyno Numbers...
  226. What brand belts are you SC peepz running?
  227. which cam for turbo?
  228. Any Good FI Tuners in the NJ area??
  229. Tuning changes for more boost
  230. Need some RWHP numbers
  231. Has anyone thought of remote oil tank for a rear mounted turbo?
  232. any one seen this 900+ rwhp turbo camaro??
  233. turbo manifold
  234. can anyone identify these turbos?
  235. Who is using the stock maf?
  236. Which ATI damper ?
  237. logs vs. headers
  238. Which is better single or twins?
  239. How do I get ahold of Rob Raymer?
  240. Wastegate Is Off......
  241. TBI Whipple HELP!!!
  242. Noisy steering pump after Vortech install
  243. PCV w/ turbo?
  244. Where the Intake pipe runs on an STS
  245. My alky system
  246. SC Belt Wear, normal vs. abnormal + pics, Cogged Serpentine?
  247. STS oil return pump?
  248. STS users! You running cats or no cats?
  249. I'm gonna intercool my STS
  250. How much boost on pump gas?
