PDA
View Full Version : Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 [73] 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230
  1. need advice on runnin hvy springs and solids
  2. Speed Inc 1579 HP Vid added
  3. cam suggestions
  4. how screwed am I? crank pin fail
  5. Big turbo build advice
  6. 67 Nova TT build
  7. 5.3 lqx Iron blocks Strenth question
  8. D1SC procharger got quiet not sure why
  9. Burkhart Chassis Tax Sale
  10. LSA swirl wing. Effects?
  11. Another cam question
  12. what size and where to buy a turbo?
  13. gt500 supercharger on a 5.3L
  14. two step with auto?
  15. who makes Up and forward turbo headers for 4th gen camaro?
  16. boosted vaccum sources
  17. Manual vs Electronic Boost controllers...
  18. Need help???
  19. Local turbo for sale, need quick advice if good for my build
  20. These should make some power!!!!
  21. Engine Gridle
  22. Need Help With Head Selection
  23. Spoolin performance altenator bracket
  24. How much HP difference 317's vs. L92's on a turbo 6L?
  25. anyone recognize this car?
  26. Water/Meth kit trunk mount. Will this be track legal?
  27. Cylinder charge temp bias with meth injection
  28. Where are you mounting your A/W Tanks?
  29. **LMR Drag Radial Car runs 4.66 in testing**
  30. 9.52 @ 144 Stock bottom end LS6
  31. Lt1 p1-sc?
  32. New dyno numbers with AFR225, XSPower catback on my single turbo ZO6
  33. Cam question. F13 and lm7
  34. Fairmont 2.0 (forged lq4, s480, 800whp, under new management)
  35. tsp 231/237 112 lsa with vortech?
  36. torn on turbo selection for my 408 build
  37. Confirm 98 OEM Fbody stamped steel manifold material.
  38. PCV/ Catch Can help please.
  39. Turbonetics turbo identification
  40. Boosted break in question
  41. Ls6 vs Tu1 cam in a 5.3 how much am i leaving on the table...
  42. crossover / merge pipe
  43. Mounting turbo to frame
  44. AI/trex to procharger? what cam should I get
  45. E85.... Thinking of trying it out.
  46. Boost referenced regulator question
  47. Truck Manifold Flanges
  48. Turbo LS6 Cap Walk?
  49. Street car, pump gas, what fuel pumps?
  50. budget junkyard 02 lq4 TT for roadrace build
  51. Critique my Twin Turbo Plans Please!
  52. Ls9 vs ls2 turbo head gasket?
  53. Who has used LSA exhaust manifolds?
  54. Air to water plumbing
  55. Question about tuning before startup
  56. Want to build a turbo header
  57. Got my procharged camaro tuned!
  58. Supercharger = Insurance Dropped?
  59. Using PE Adder vs. IAT as safe guard for meth failure?
  60. Truck manifold placement question
  61. Would like to know about this Precision turbo.
  62. How much power will ID1000 injectors support in FI.
  63. lt1 style trans am intercooler size & location?
  64. air to water cooling question
  65. heat transfer
  66. LT1 Blower sizing
  67. procharger f1r
  68. s475 choking out?
  69. Website feature on my single turbo C6 !
  70. Help building custom rear mount system
  71. Build 347 or 370 for pt7675
  72. Catch Can setup with single plane manifold
  73. What gears??
  74. Comp Oil-less CHRA upgrade for APS kit.....who is interested?
  75. Wow...talk about a sleeper!
  76. Explain Meth is it safe + dependable
  77. Anti surge compressor housings yea or nay?
  78. Nasty BOV for D1SC video inside...
  79. Which Borla XR-1 muffler? F-1A/408 setup...
  80. D1SC issues just after install
  81. Exhuast is way too damn loud.... power loss?
  82. pics of my twin turbo hot pipes for a lt1 camaro
  83. gt91 408 cnc ls3 heads hows this cam look
  84. Plug gap
  85. Anyone build a turbo kit with stock fbody manifolds???
  86. Built LQ4-Will it handle 20#+?
  87. best coating for mild steel tube headers?
  88. pressurizing a carb
  89. Meth vs Nitrous
  90. Question re: STS Turbo and Muffler Setup
  91. Procharger guys with truck hat come in
  92. SPA turbo gasket eliminator?
  93. Magnuson MP112 on ls 4th gen fbody?
  94. turbo lq4 electric water pump question
  95. H/C/I/E to FI
  96. NEED HELP!! Twin turbo 70 chevelle build
  97. should i turbo a 210,000 motor
  98. which turbo should i get
  99. Tips on getting spool time down?
  100. What will it make? 370 - F1C - E85 - lots of other stuff!
  101. CBR alternator bracket
  102. Dagger GT?
  103. Zirgo electric fans
  104. MP112 Cam?
  105. Is this turbo to small
  106. twin turbo ls1 question
  107. Project "Ricky Bobby"
  108. **LSX Drag Radial Racers get READY, LMR IS winning championship this Year**
  109. Turbo in a high hp manual car an issue??
  110. Cam for T6 88mm on 346
  111. what cam for boost?
  112. What heads are you running on your procharged setup? 12+ psi
  113. 1995 Steeda Q car gone to the dark side
  114. Cam Specs with complete I bought. Advice
  115. Question about catch can?????
  116. Vortech V1 kit no mounts or crank pulley....
  117. Help me identify my new turbo
  118. Stock LQ4 76mm turbo questions
  119. Turbo build cost?
  120. Carb Hat or Carb Box ? Blow thru set up
  121. 317 heads help
  122. Piston ring gaps for 76mm Turbo LS6 - Need Clarification & Opinions!
  123. speed inc tu2 cam
  124. p1sc 5.3 blazer
  125. Ebay Turbo, any turbo set-p for sale
  126. Another E85 thread
  127. removing starter with APS kit
  128. Super chiller
  129. **LMR ZR1 Corvette 9.47 Vid**
  130. How low is your filter?
  131. front mount install help
  132. Turbo header
  133. any way to test seals on a d1sc?
  134. LSX 434ci | TFS 245cc | Viper T-56 | SP Tubular Headers ***WHAT GARRETT TURBO*** ??
  135. How much timing are you guys running 93 with Meth able to run?
  136. HELP will this boost controller work?
  137. st80 turbo on a 5.3 motor
  138. Procharged 408
  139. fuel pressure regulator and boost
  140. Headers or manifolds for turbo?
  141. how is boost limited on a whipple?
  142. Anybody have a 9/16 Rotabroach?
  143. proflo vs ls6 turbo
  144. Holset HX40 for Rear Mount LS1 RX-7. Good size? Compressor Map Inside...
  145. remote mount and intercooler
  146. No 9 sec FI M6 car out there ???
  147. TBSS TT,PTE 6766, 385ci, AFR 225cc
  148. HOlley Hp Efi and Boost with Stock Coils... Problems?
  149. TT TBSS Vs Turbo Foxbody
  150. V7 YSI rebuild
  151. truck intake/FPR question
  152. Need help! What A/R to go with?
  153. LT1 style Trans am Forged LQ9/ S475 front mount
  154. ported ls3 intake or fast 102 ported
  155. breather
  156. first time supercharger owner
  157. Root Charger
  158. Vortech Oil supply line options
  159. Help me choose a cam 5.3 with a s480
  160. turbo stock ls1 z28 ?s
  161. Please help me find this video/thread!
  162. fbody supercharger on a gto
  163. Turbo 5.3
  164. A/C system
  165. 91' Notch 383/PT88 in time for TX2K12
  166. A few 5.3 questions
  167. how hard can i launch her?.
  168. obx vband clamps any good?
  169. LT1 to LS1 swap. Whats a decent turbo ls set-up worth.
  170. Powerdyne brackets
  171. Whos made the most power/gone fastest with the EPP FI cam???
  172. LS9 Head gaskets. Dry install?
  173. Switching up the combo....F1R time!
  174. Help choosing compression ratio???
  175. Pcv and breather Junk
  176. my ls2 cobra is almost done...
  177. Help With my Twin Turbo 5.3 Build/Swap
  178. LS3 Turbo Head Gasket Advice
  179. LQ9 twin turbed!
  180. can you over blower a motor?
  181. What breather are you using?
  182. Zturds Stock 09 ZR1 goes 10.42@134mph first time out on drag radials
  183. SCREAMIN SEMEN GMC 5.3 Turbo Swap
  184. new build ideas
  185. Help me with my procharger setup
  186. spark plug gap
  187. Meth injection..Pre Turbo or Post turbo??
  188. What Seats for Drags/Daily Driving?
  189. Taking out oil level sensor?
  190. 1957 Cadillac. Twin 3076R 390ci
  191. D1SC Procharger for 02 WS6
  192. BOV Placement...Who's Right?
  193. cant get manual boost controller to work
  194. HX55 Too large for rear/mid mount setup?
  195. 5.3 w/ z06 cam and BW S400?
  196. best turbo setup?
  197. oil restrictor
  198. stock 5.3 TT build: THE GRENADE
  199. How long will it last Stock LS2 pt7675???
  200. Back on the road.
  201. procharger finally on!
  202. air inlet temp sensor
  203. LQ4 S480 Build
  204. Stock Long/Short block record contender
  205. v1 to v7 ysi
  206. gearing for S/C SBC
  207. Drivers side head alternator bracket?
  208. 4.8 stock block build
  209. Failure analysis leads to rebuild along with a cleanup.
  210. Restarting the build thread... forged 76mm front mount
  211. quick spool valve,,,, anyone used this
  212. Will This Be a Good Cam For a Turbo 5.3?
  213. looking for big power, you thoughts needed
  214. Updated first post, Pick apart my turbo 5.3L build
  215. DKT Precision 6766 turbo's for my APS kit.
  216. heads for a 383 turbo motor?
  217. 370 GT91.... 8's or bust build
  218. How much Boost can a D1SC make?
  219. turbo drain hose angle
  220. Fast 102mm Intake Vs Holley Hi-Ram Modular
  221. D1 Install Help?
  222. Ls6 intake vs Vic jr intake with arrons elbow
  223. Bad MAP?
  224. Belt slip on Maggie
  225. Mechanical or Electrical boost gauge?
  226. intercooler basics..I promise I did search first
  227. 1000RWHP capable blower kit for C5 Corvettes
  228. Who has filled their blocks? Come on in....
  229. STS Universal Turbo Install Cost Please Help!
  230. ls3 block or lq9/4 block
  231. 68 turbo nova build update 11/10/12 10.56 @128mph
  232. help me pick a cam
  233. Aluminum block...to...iron block.........who has done it? Need opinions.
  234. Procharger, and combustion chamber size determination?
  235. Yes, another "what turbo thread"
  236. 370+F1 Video
  237. What turbo??????
  238. MPGs with FI
  239. Car Craft Ls Series Power
  240. Which turbo for a 5.3- GT42-76 or Precision GTSHP PT-76 CNC Ported or PT88
  241. E85 plugs for 15psi boost
  242. more stroke vs more bore with a turbo
  243. Critique and help my build
  244. Need advise on my L92 block. Twin turbo build
  245. Need wiring diagram for 2 step and trans brake wiring
  246. Turbo build list, looking for help/opinions.
  247. Anyone with a Lt1 vortec bracket.....
  248. 317 heads on stock bottom end?
  249. Lean spike as I enter PE (and knock retard) any way to combat this?
  250. Procharger Hex Standoff Question
