- What are pro charger guys using when you get rid of the mass air?
- where to spray meth??
- Procharger w/ 85mm MAF
- Backpressure on single log type systems?
- Boost drop?
- Air/Fuel, Spark Plugs, O2 sensors
- auto guys, do you get a different amount of boost per gear?
- Help!
- Blower cam overlap??
- Volant vs. SLP vs. K&N?
- Maggie's new MP 122HH Q's?
- What heads are you turbo'd guys running?
- Oil ? on turbo setup...
- Will running racegas on a 91 octane tune hurt?
- What kinda power could be made with this?
- What rods for FI? H or I beam
- Installing a Procharger(Degree of difficulty)
- Props to Stenod Performance once again
- BOV open at idle?
- STS - How to???
- saw the boost gauge go to 11psi, should be at 7psi...Jose?
- Would this cam work for the Incon Kit
- 5" thick core intercoolers on ebay for $300
- << Turbo-Zone public release of single kit >>
- Valve size for P&P FI Heads?!?
- New 03-04 Cobra Kit weve been working on
- Building a TT setup with stock manifolds
- Automatic tensioner
- oil in inlet tube?
- Gmr Twin turbo or STS rear mount?
- SDCE Tensioner
- Intake Gasket for the Gmpp intake
- boosted car over heating
- can i use this for my custom oil return lines?
- ProCharger cam recommendations...
- BOV before or after maf?
- Car surges on the dyno
- Ohio Forced Inductions Inc.
- New Twin Turbo system pics
- Opinion On STS??????
- Do i have 2 use braided oil lines?
- How much can I get out of a P1???
- [B]526 RWHP and 510 RWTQ from EPP[/B]
- Just swapped out my 3.50s for 2.75s
- 2nd Press Release of another Ohio Car
- I hate my FMIC setup
- Most Important To A S/C
- Would it be worth it to...
- My twin turbo TA (finally posting the pics)
- Green Thunder on EBAY
- JZ, DrTurbo? Borg Warner S595??
- supercharger problems
- Moving IAT sensor on ATI kit for GTOs
- Forced Induction Bracket Racing?
- Turbo Vs Supercharger
- how much power will i loose with the 317 heads.
- Super to turbo guys...
- Why a 76? Compressor map question...
- stupid question time...
- How I blew up 2 new turbos
- things starting 2 move along-
- Super Charger Oil ?!?!?
- Approximate Timing
- Where do you get a turbo rebuilt?
- Purchasing wastegate need help.
- Finally some video of my turbo camaro project
- the T04E 60-1 trim .81 A/R sts turbo
- Where oh where did my whine go???
- Casper electronics V-plus volt booster
- where to get a Tial WG spring?
- compression ratio
- Do i have 2 use braided oil lines?- and another question.
- It's official, turbo lt1 alive again.
- New cometic gas filled head gaskets.
- Custom radiator
- Whitch Twin Turbo System?
- STS on a Chevelle???
- STS blowing oil out of turbo
- yup...still blowing oil smoke
- Any structural issues with drilling/tapping oil pan?
- Finally got my first 10 :D:D
- Prochager Belt Change?
- Who tuned their own FI setup?
- Think I will see 600rwhp
- Forged 347 Turbo Camshaft Selection
- LS6 Cam?
- STS -- Wrapping exhuast pipes - Will it make a.
- Anyone here running the MSD launch boost controller?
- Install pic of threaded IAT sensor in EGR hole and 4" MAF.
- I think I'm finally going to swap cams..
- p600 Questions
- cars over all performance down?? please evaluate.
- Heads for FI?!?
- New best and a couple vids
- Oil in the charge pipes on STS?
- Who runs boost with the LG5X3 cam?
- What are my options for a head gasket with a 4.04 bore?
- Track Time with my sts
- ported & polised or not
- NGK TR55IX Iridium plugs
- SCE titan copper head gasket choice
- a/f ratio wrong help!!!
- Dyno'd My A&A P1SC kit yesterday 603/482-now have lots of questions!
- worthwhile to change stock 241 heads to 317 (LQ9) heads
- Few questions on installing EPP's FMIC kit
- anyone have pics of their notched k-member
- IAT pulling timing?? Final timing??
- TRTPerformance and FFHP combo for the win!!!
- Went 10.03 @ 120... no gear left at 1000'... HELP!?!?
- Picture of a thread IAT sensor inside.
- ATI ProCharger 4.5" Twin Hi Flow Intercoolers For Sale
- who makes reducing 45deg elbows?
- How many FI guys are running NOS too???
- removing the ecm --- tune???
- Spal Rad fans
- Dyno vid of my ttvette
- GTOlarry
- Suggestions for the turck manifold DIY
- 98 Supercharged 2 Bar Tune
- Intercooler options for twin turbos
- Pending disaster! What to do?
- solid roller cam for turbo
- Is this turbo a good choice?
- Quick question about power with FI during summer/winter...
- advantage of short stroke for FI?
- NGK R5671A-8...stocking number 4554 vs TR6 ?
- Best place to put MAF on a boosted application?
- Guages for FI
- Poll: What is the best Meth kit and why?
- Bypass valve on automatic?
- Hi-Flo pixxx ...56k, naga-naga-nagunnahappin
- Can anyone tell me how to hook up the belt with the TTI street kit???
- STS kit with Edelbrock shorties
- Ps1c Belt
- Has anyone had a crank snout ever snap off with a blower application on a LSX?
- tech Q
- What's A Good Methonal Kit?
- Belt Is Impossible To Get On????
- Warranteed Maggy on GTO??
- Sts W/ Fmic
- My DIY dyno numbers
- Which eBoost2 fits my AC vent again...?
- dumb ?
- Twin turbo GTO's?
- professional products intake manifolds?
- Jesel timing belt kit VS slp double roller timing chain or one similiar?
- LQ9 heads?
- Driveability
- cheap fi
- Installing Incon Kit... Should I Shoot Myself?
- Any new people doing a Kenne Bell?
- Need a 9 sec turbo recipe
- which will make more power front vs rear
- EPP just finished my FI setup and called to give me my dyno #'s.
- Max boost on procharger?
- 90 Suction elbow
- tt408 vette in az
- vortech dealers
- ProChargers???
- Front Mount or Meth. Injec.
- which setup is faster?
- Price on fixing a D-1sc impeller.
- ATI Procharger question...
- Guys who ran the griffin radiator...
- I guess I need to get started on my junk
- Downpipe placement with truck manifolds
- TTI turbo kit question
- Where can I pickup one of these? *link*
- Truck Manifold Kit?
- Whipple
- mustang throttle body cable
- 408 spooling up dual Q-trim turbos?
- Silicone connectors?
- New numbers from my T trim kit
- Decent turbo cam?
- Taking S/C off
- New updates with the setup...
- Good Idea or bad
- 800RWHP? Motorheads Enter!
- Supercharger and BARO
- STS with CATS
- L19 bolts a good idea?
- Will these rods work?
- ati procharger belt question
- Need Help with MSD... FI related.
- Best prices on Precision turbos
- Wrapping the headers improved spoolup.
- Those with pusher fans....
- !A/C guys, condenser/shroud question...
- need a tee to hook up boost gauge
- Turbo Tuning on an automatic....FI related so :P
- Procharger P1sc Vs. D1sc
- head stud TQ specs?
- trtturbo stage 5
- Procharger leaks from dipstick
- F1 Procharger Kit
- What does hi-fi mean and will this turbo work?
- Sts What Stall?
- Pic of a 100mm maf I'm trying with the Incons turbos.
- Can you have a tune for two boost levels?
- 5in reducer cones, adapters....
- Alternate method of routing coolant through Incons?
- First drive 408 "TWINS"
- Headers-crossover-turbo-radiator **pics**
- 346 life???
- Slowly but Surely...
- Need help with turbo lag
- STS make the same WHP as FMturbo @ same psi?
- H/C+nitrous or FI
- does this look like its out of turbo?
- oil in sc box
- Found the problem in the Transmission...
- New Sticky? What Tools/Supplies to carry with a new FI setup?
- Lets talk some about the affects of compression..
- low coolant dillema
- Very Important question-all SC owners who drag race step inside.
- LS1 tuning fuel system vortech
- Turbo car update!
- Boosted questions????
- STS And 408
- how well will 5.3 head gaskets hold up under boost?
- Would a turbo cause a ringing sound?
- Braided lines for BOV/wastegate vaccum circuit
- prefabed cross over
- need help
- what do you have and what timing you run?
- How are 4.10s with a supercharger?
- Procharger question
- T6 flange question..
- 93 Octane #'s Twin GT 40/88's
- Where is the best place to buy piping?
- Bored/raining so time for a new exhaust
- What is a good IAT?
- whats your custom plate?
- Anyone use these for BOV mounting?
- Post turbo oil reservoir questions
- Finally............
- Any 6-Rib pulleys laying around
- STS No boost on dyno!!!!!!!!!!! HELP
- Turbo Or 383?
- Best Bang for the buck progressive Meth Kit?
- Need Help! Budget Rebuild!!!
- 2 step doesnt build much boost..
- Help
- STS Questions ??
- some smoke?
- Spinning
- Best budget forged 347 shortblock?
- what else do I need for the sts kit...
