PDA
View Full Version : Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 [157] 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230
  1. GT40-88 Rear Mount Z06 - Build pics!!
  2. GMPP ASA cam OK for blower?
  3. D1SC procharger cali emissions legal?
  4. KBs and Whipples
  5. TSP long block any good
  6. Replacing my oil pump and had a pulley question
  7. water cooled?
  8. Sts Vids
  9. Vortech V9-kit
  10. D1SC or OFI? What would you go with?
  11. anyone else make a sumped tank?
  12. slp smooth below strong enough?
  13. Front mount set up needs ideas
  14. what kinda track/dyno numers should i expect
  15. why can't turbo th400 cars be dyno'd?
  16. Tool need to cut front end for FMIC
  17. What size spring
  18. STS dyno results from TRT.
  19. New Dyno Numbers for the STS
  20. 408 / S85 turbo project halfway there
  21. Fuel System Limits
  22. Speed Inc's TT kit
  23. Sts Boost Controller Reference
  24. New Turbo kit!!!
  25. How much torque on ARP 12pt studs?
  26. which blower with my brackets - hybrid 69 Camaro?
  27. fuel pump part# comes with procharger
  28. Confused? Bypass Valve / BOV
  29. Cog Pulley - way noisier or not?
  30. Who wants to upgrade away from their new forged LS6 346/7 blower motor?
  31. 2 38mm wastegates f/s in classified's
  32. Procharger P/S Pump Re-location Kit
  33. sts & sub frame connectors?
  34. LS6 Valley Cover (PCV)
  35. Supercharger drive belt needed
  36. compression
  37. Where to find MS 1/2" header flanges
  38. F/I Compression Experts-How much will comp drop on stock LS6 by going to 72 cc heads
  39. twin turbo kit... need some help
  40. Think I blew a head gasket?
  41. Any reason not to use an aluminum AN fitting on a chra?
  42. 6.0 turning rpms
  43. LQ9 317 Head Guys, are you using stock LS1/6 head gaskets or 4.0 gaskets on 346 LS1/6
  44. STS guys What have you replaced
  45. 2007 Boosted List
  46. Procharger heads?
  47. STS oil pump????
  48. Question on boost at the line???
  49. Cam/Power Question
  50. F/I experts, for D1SC blown 346 LS6, go with 225 or 205 LQ9 72cc Patriot Blower heads
  51. Upright radiator mod pics.
  52. New best with the trusty old D1SC today..
  53. Who has any experience of the Patriot LQ9 72cc F/I heads!
  54. Progress pics of my CDNPERF 347 F1R combo
  55. 2 Wastegates...
  56. OFI 4" downpipe with stock accessories!!!
  57. Can u run a lumpy cam w/a blower?
  58. Do both LQ4 and LQ9 heads offer 317 castings with 72 cc chambers?
  59. When is 3" Needed
  60. Lets Try This Again...
  61. Pump Gas Drags
  62. what are good heads for FI?
  63. ? about forged SB and convert to FI from n2o
  64. STS Dyno!
  65. PCV on STS HELP!!!
  66. Best setup for the money?
  67. Inspector12...part 1
  68. custom blower pulleys?
  69. anyone interested?
  70. 8.1L whipple supercharger
  71. Size WG and BOV
  72. Q trim vs P trim
  73. juist got my wideband in, where do I put the bung?
  74. lower CR on stock internals
  75. Pics of my new custom front mount what ya think
  76. Any Good Steps On How To Install Fmic??
  77. Re: TTi Fox Body: 8 second street car [vid]
  78. I love cleveland weather...
  79. IC pipe w/ no bead will the silicone hose blow off?
  80. Supercharger/OilPump Question
  81. Any 1 every used this kit?
  82. High boost T-76gts results please......
  83. GT4294/gt42 who has run this......
  84. GM MLS gaskets good enough for YSi?
  85. Anyone running turbo with higher compression?
  86. How do these sound?
  87. Anybody done with their manual? 98 F-body
  88. What does 199 MPH look like??? **Video**
  89. procharger vs turbo sound thread!!
  90. HP potential calculator......turbo engine
  91. Twin Setups?
  92. pistons for s/c 383
  93. too much milage for a blower
  94. Not a LSX BUT I think you'll all approve.. [vid]
  95. 383 stroker or Intercooler...
  96. Reading Compressor Maps For TT setup
  97. no response from ptk
  98. Dynatech split flow muffler
  99. possible sts turbo oil sources (pic)
  100. What Electric Source For Sts Oil Pump?
  101. turbo on pre 87 motor
  102. Peeps w/ TURBOS & STOCK eninge!
  103. Exhaust leak at Flange for turbo...what to do??
  104. Will D1SC be adequate?
  105. plug on block
  106. Getting ready to spend alot more $ and need some advice.
  107. boost and f/p guages
  108. 2001 Z06 Preliminary Results, 403ci, Novi 2000 Blower
  109. ebay aluminum intercooler tubing kits?
  110. How much power on stock botom end+rod bolts
  111. fabricated turbo!!!
  112. Need help with Cam selection...
  113. tt "re-build" pics
  114. BS3 Help.
  115. ~Budget Engine Build...Turbo Set Up~
  116. Boost bleeding/staying constant
  117. NEED HELP! Welding exhaust while turbo is on the car??
  118. F.A.S.T Intake
  119. Finally an In-Car Vid
  120. Selling my gauges
  121. Large Twin Selection
  122. Procharger Guys Inside Please!
  123. STS Guys Help Plz!!!!
  124. Turbo Oil Pressure Gauge??
  125. New TC T-76 is in and tuned.
  126. Effects of varying turbo AR
  127. SLP cold air intake?
  128. Dynoing the car soon-question about fuel
  129. Got my STS SS running last night!!
  130. OFI twin turbo mustang kit
  131. OFI downpipes are ready
  132. manual control over bypass valve possible?
  133. Powder coating a procharger? Can it take it?
  134. when buying a used procharger kit....
  135. 99LS1 a good platform to build turbo?
  136. o2 sensor location
  137. EBoost electronic boost controller wiring
  138. Damn STS Buzzer
  139. OFI progress pics
  140. Oil return from turbo
  141. Thinking about Kenny bell
  142. 3" pipe into T4 flange tricks
  143. head gasket for 408
  144. MAF Help
  145. PSI Loss over twin IC
  146. Anyone know the Dayco part # for a vortech tensioner?
  147. Best blower for F-body?
  148. how about supercharger pcv venting? what do I need to do?
  149. VIDEO: 5.97@118 3900+ lbs
  150. I put our newly released ATI ProCharger CTS-V kit on Ebay
  151. ideal set up for an F1A
  152. Quickest spool possible...
  153. vortech ls1 edit tune
  154. TSP Twin Turbo C6
  155. who has the fastest stock bottom end turbo or any for of supercharger here???
  156. Will spraying Alky (on a Maggie) change the AFR???
  157. thinking of Fast 90/90
  158. True 3" Dual Side Exit Twin Turbo!
  159. Where to buy air werks turbochargers?
  160. New Turbo kits on E-bay 690.00?
  161. Blower Manifold
  162. a quick question about prochargers
  163. Which size headers for my combo ?
  164. how far do the pistons come over the deck on ls1/ls6
  165. How much boost is lost over the FMIC??
  166. Keeping them down....
  167. hey guys got one last question
  168. Z28 project help
  169. Do I just need to change heads to go FI?
  170. working on a custom sts turbo setup
  171. Emissions Legal Supercharger Cam
  172. Plz Help !!!!!!!!
  173. SD tune
  174. Procharger ID without a Tag?
  175. Turbo Manifold/Header Question/Help
  176. asp underdrive pulley VS stock VS ATI superdampner 4 FI
  177. My Turbo project Finally done.
  178. putting kit on a vert
  179. do good flowing bolt ons really matter?
  180. compressed thickness for stock mls gm head gasket
  181. 3 Bar Connector Help
  182. Probe pistons
  183. 64cc AFR 210 with a 5cc Piston?
  184. 317 heads
  185. looking for procharger...
  186. Source for aluminum tubing
  187. Twin rear mount turbo sizes
  188. 92 LS1 FM T76 Build
  189. 8 rib balancer' available
  190. Maggie owners - what other mods?
  191. Boost compression chart
  192. Building FI manifolds which collector to use?
  193. Turbo guys, what plugs and gaps are you running?
  194. 402 and Maggie
  195. Cheatr Cam w/D1SC?
  196. CTS-V ATI ProCharger kit from EPP!
  197. Setting up my PCV. Will this work?
  198. Pistons for 408ci F/I
  199. how long did your stock 10 bolt last?
  200. help me call BS on this...
  201. Compression ratio on a Procharger car
  202. question on the Speed Inc TT kit for ls1s....
  203. t bolt sizes for sts
  204. twin turbo 05 mustang LSX.......
  205. looking for some 408/402 idle and cold start tables
  206. How often do you drive your FI car?
  207. Would like some motor advice and input please for an incon setup.
  208. Does DCR matter as much.....
  209. And so it begins...............
  210. T3-T4 Turbos
  211. sts dyno!!
  212. ? for STS guys
  213. CTS-V Twin Turbo Options
  214. TSP 370ci iron block BEST F.I. shortblock for the MONEY???
  215. 370ci rotating assembly
  216. Tuning a Turbo car on a non load dyno?
  217. LS1 Supercharge intake roots style 6-71/8-71
  218. PCV Confusion
  219. F1C/F1R on 6 Litre Iron Block?
  220. E.t?
  221. boost and lt1
  222. Oil lines for turbo
  223. At what power level do you need to change cylinder heads?
  224. Chosing between Forced Induction, and Natural Aspirated motor
  225. How fast on pump gas?
  226. FMIC fab work!!??
  227. Need help!!!
  228. intake tubing for forced induction?
  229. need help installin meth kit.
  230. Turbo To Supercharger
  231. ati plastic plentum, how much boost can it handle?
  232. Dart heads with FI
  233. Lingenfelter cam ques?
  234. need help on what turbo cam to get and where??
  235. Quick and easy question.. cooling fan connector.Please identify this connector.(pic)
  236. The 500 RWHP mark has finally been hit with the V6 Fbodies!!!
  237. Custom Forward Facing headers done
  238. Attn: New trick for FI FMIC?
  239. please post your turbo or procharged or supercharged track video here!!
  240. Help Wanted! Best blower for ZO6?
  241. How does a wastegate work?
  242. What Sponsers....
  243. what size pump/tank for TT air/water IC
  244. Have a new Project now.
  245. What clutch with a turbo?
  246. does anyone make one ????????????
  247. STS Turbo Pics on SS Camaro...
  248. Twin T-70 camaro dyno results
  249. Price on a setup
  250. thearded iat?
