- Whats Best Turbo For Street/strip
- Track last Friday night.vid
- Will any UD pully do for a turbo?
- new best track time!!!
- Questions about supercharging
- Who can get me incon turbo's?
- crossover question....
- Cooling turbos?
- Car runs -- TTi street T76 kit
- MP122H Dyno Numbers.
- Turbo Question
- ok the beast runs but..im smoking like a champ..
- tuning sts cars
- t60, t60-1 and t-61
- For those who haven't actually seen a Tial WG spring
- Its Over!
- Front mount intercooler in an F-Body
- Twin or Single?
- What connecting rods/pistons should I go with when running a kb on a ls6(stock cubes)
- F1 Procharger
- Single or Twin?
- F1R Intake pipe??
- What do I need to change on my motor for a turbo setup
- Total weight of a twin turbo setup?
- Were can I find 4.25" t-bolt clamps?
- Need to find forged pistons to get a 346 to 8.5/ Short block because I threw a rod
- Enough cam for SC'd motor?
- Cubes vs SC/TT for RR Q.
- ProCharger dealers?
- Powerdyne Blower
- Some more Alky Control Kit results.
- Up date on my turbo setup
- Anyone know Phillip Bridges? (95 turbo TA)
- t74, 1.00 on stock 346....
- Should i get the hot parts turbo shorty headers coated?
- TT 67mm
- plagued with exhaust leaks on a turbo car
- ATI inlet hat on and off track results
- The Red Rocket Steps it up a notch!
- FI 383 Stroker on the way!
- Turbo runs great only one problem
- where to buy meth kit?
- Ati p1sc1 idler pulley...?
- Paging Jose @ Forced Inductions
- Will an STS off an LT1 work on a LS1
- Just for fun- Guess the mods
- Turbo Question
- Pretty parts!
- It has arrived!!!
- POR-15 on crossover & DP= cool
- First Rear Mounted Turbo in the 7s
- What Electronic Boost Controller???
- head gasket bummer
- Sts High Boost Problem
- I need an intake elbow
- Track Tonight!
- alc/meth kit
- we have ignition!!!! *video*
- Turbo Technology?
- Those that PM'ed me here are the S95 pics
- diesel help
- Accessory Pulley ? Whipple 3.3L 10 Rib
- LS1-LS2 Keene Bell 2.6 2.8
- upgraded injectors are in...but...
- turbo carnage
- sts?s and motor?s
- does anyone know how to work the HKS evc limited edtion black boost controller....
- STS and SFCs will they fit and any sugg.?
- What to look for in used D1SC?
- which block
- alk/meth question
- something to laugh about
- ProCharger sales.....vs. other SC sales. Looking for info
- What size intercooler?
- Procharger question
- Oil Smell on Procharged C6
- dyno results...horrible
- ***Hi-Flo Track Times *** videos to come
- Ohio Forced Inductions Inc GTO Hot Part Pics...
- how fast would a .81 A/R come into bull boost on a 355?
- New ARP headstuds.
- Phamspeed budget kit - Big Mistake?
- One more time before my turbo gets here
- Ok..so how about THIS cam?
- Tc76 Arrived!!!!
- Question about Reichard Racing pullies
- sts in houston
- Intercooler Ice Box question
- New TV81 Turbo Specs & Pics...
- Getting ready for FI
- How do I hook up a manual boost controller...
- innovative street heat turbos
- Pete and Craig raise the bar again 8.39 @ 163.55
- Cast aluminum 180 degree elbow for LT F-Body?
- ~Homemade STS~
- need a procharger intake hat or like
- innovative T-76 with a .81 A/R for 355????
- Stock Head Gaskets/Bolts good to what PSI?
- quick question
- Navy David SS ????
- Whose car is this?
- At what point do GM heads not cut it?
- Search down--anyone use the stock fans as pushers with the ATI fan and shroud?
- Props to Mike Brown...
- Is a solid roller setup beneficial to turbos?
- Homemade Kit
- A few rear mount questions (and PCV pics)
- Procharger people: Has anyone had any experiences with the PRO YANK 3400
- Got the Alky Kit & KB BAP Installed
- my T/A smokin vid.
- Oil Restrictor Where?
- any feedback for the MP t70?
- Help Finding Fittings
- home made turbo headers back from Jet hot
- 10 sec junkyard motor... going 9's soon?
- drag week thrash help...
- Anybody running a carb and turbo?
- TTI street kit clearance-minimum should be what?
- Replacement belts for ATI Procharger
- North Vs South Photo Album! (also need info)
- Mysterious Lack of Boost
- Somebody better jump on this deal on an F1 ProCharger!
- Turbo and Nitrous ??
- ~Twin Rear Mount~
- Congrats to Tom Kempf on his new best...
- How's this cam for FI?
- 31 psi Video
- sts cam selection
- Oil evac setup vs: catch can / pvc setup
- Those who run scavenge pumps
- Is there some super secret trick to V band clamps?
- Someone please lend a hand here.....
- Long tubes and Rear mount turbo
- Whining noise in my bird
- alot of smoke
- results on the stocker
- Untuned STS 60mm... Xylene an option???
- Heat wrapping crossover gained 3 psi
- New Maggie MP122H
- Roofer Dave's car 7.69 last night
- Serpentine Belt siz for a Pro Charged 01 Z06!
- would you put a blower on this LS1?
- coating the hot side of the turbo
- The butt blower is here!!!
- not starting right and a P0343 code, what's up?
- n/a or turbo or supercharged please help
- Oil line restrictor poll - guys chime in
- Paint Vs Coating Intercooler tubing
- New pulley?
- GM Vented Oil Cap
- Boost Motor Help
- Sts?
- Turbo Suggestions Please
- Tee'ing off the brake booster line?
- North vs South Shootout - Extra $100.00 of ATI ProChargers from Exotic Performance Pl
- Downpipe size T70
- Who is running a 8.9 or below CR??
- WTF! Car wont make boost on dyno..
- turbo tuning opinions
- Spool time
- AN size drain line with scavange pump
- Worth It or Wait???
- what converter
- look at this cam.....give input
- What do you think about this LT1 turbo cam.
- How to remove EVAP system - does it hurt anything?
- Safe boost??
- Will a small cam increase your IAT on a turbo setup?
- AllPro FI head guys... what plugs are you running?
- Truck manifold peepz q's within...
- PCV Z06 Catch Vent $10!
- how much of a restriction would a 90* angle coming of the turbo be?!?
- Well I think it popped. You tell me....
- new t-70 but no v-band
- ~Custom Turbo Kit~
- Guys, I need some input
- sts dyno graph?
- TurboLS1SS, I'm almost ready for ya...
- Opinions???
- How much power can you be robbing by running dirty air filters?
- What does a dying turbo sound like?
- what pistons is everyone using
- What compression for sts
- what intercooler is everyone using
- Gathering correct parts for my build... few questions
- guys check out this cam
- new to the s/c world and need help
- The Real Price of Forced Induction
- ~Help me build something FAST~
- Cant stop the smoking
- Having great results with Procharger on C6 Corvettes
- My two best friends.....
- Twin gt40's or single GT55 (91mm)
- Need help with O2 sensors
- The "Some Hi-Flo shiznit came in today" POST IS NOW A STICKY
- Pics of Camaro front end w/ FMIC
- Can you guys post some pics of your fmic/airdam setups please?
- Mustang S.c.
- HELP NEEDED!!!! Oil remote pump
- Can a/c condensor be used as cooler for A2W setup?
- What would make more power and throttle response?
- ls1 missing at high rpms help?
- silicone elbow blew with only 10lb.
- sts rear mount #'s on a stock car
- Source for Garrett parts
- Turbo question (please dont laugh)
- Procharger Bracket flex
- Header recommendation
- Made a new inlet hat for my Procharger (Warning!! alot of pics)
- Dream car with a nightmare!
- What does a turbo rebuild cost?
- Porting the throttle body.
- New Filter?
- Questions about turbos
- Vortech users come in
- is there a way ti keep the AC
- Looking for an Incon turbo or compressor housing.
- Power differences between truck manifolds and headers
- Duke goes 7.51 @ 186MPH!
- wire diogram for sts setup
- What kind of difference in 1/4 mile times do you see from summer to cooler weather?
- STS Z06 PCV Vent!
- Vic Jr. Intake = hp??
- oil catch can questions
- Paxton for an LT1 ????
- Are there still any issues with the Procharger SC units?
- getting there w GT47-88, #'s inside...
- Ohio Forced Inductions Inc. F-body hot parts pics
- what r the day 2 day problems running FI
- What does this mean?
- What exhaust housing choices do I have with this turbo?
- Where to find this turbo?
- garrett or turbonetics???
- Supercharger or Turbo
- Need A TURBO or S/C ????
- Lt1 CAmaro front mount
- TTi log and spark plug wire clearance?
- Any tricks to drop the pan?
- 1000rwhp single turbo formula 'street car'
- 90° Intake Rubber Elbow
- New to FI-need help
- mondo blow off question
- Anyone using the Griffin radiator with the ATI shroud and A/C?
- V1 S-trim dual meth nozzle track results
- Any problems with a MBC?
- Optimum turbo for a 6 speed LT1 355(with 10's in mind)
- my question ???????
- Well... 9.90 @ 139 and still problems... help!
