PDA
View Full Version : Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 [226] 227 228 229 230
  1. FMU
  2. blow off valve - bypass valve
  3. Alky Injection
  4. 8 rib ATI question
  5. pulley size for Vortech
  6. Fuel Pressure under boost with a FMU
  7. Need help* New ATI install dosent work
  8. FI head mods?
  9. Custom build turbo kit
  10. Need your opinions about a BOV for a C5
  11. Oil in Procharger intake
  12. Why won't our Knock Sensors save our FI setups??
  13. Can you put a 5 speed automatic into a 01' WS6?
  14. what makes a good blower cam?
  15. why no blow off & turbo timers
  16. What is with the low boost
  17. Pics of the modified Turbotech kit
  18. Supercharge ?
  19. Turbos have lag, do SC's have something like it?
  20. whats the max boost for a 346ci?
  21. supercharger and nitrous?
  22. NGK Iridium Plugs for supercharger motor
  23. Any suggestions on breaking in the motor?
  24. Help a turbo novice: water dripping from a turbo?
  25. Will this make me go fast or blow up my engine?
  26. FI Gear Ratio's?? SC and 3.90 gears?
  27. New Dyno Numbers
  28. IM-147 emmisions test??
  29. Am I misinformed?
  30. What are u guys doing when the mass air gets maxed out.
  31. incon kit on ebay
  32. Turbonetics: Which one on my Z06?
  33. Plastic Plenum box on ATI kit, WTF
  34. ati pulleys and stock motor
  35. 6.0 turbo how much boost
  36. 6.0 How much boost
  37. Theory on FI cars with water/alky
  38. I noticed the SC guys let a lot of threads go unanswered
  39. Vortech owners(or anyone that would know this)?
  40. I suppose I need a puller to change my pulley...
  41. Water/Alky : Who's Got What, And How Well Does It Work?
  42. LT1 Blow off Valve Question, Need help Quick!! ATI System!!
  43. Dyno #'s for new engine at 10psi, pump gas
  44. Move me up on the list
  45. Intercooler for sale
  46. I need a good radiator fan
  47. Hydro-locked with the Procharger
  48. D-1SC Vs. P-1SC!!!!!!!!!!!!!
  49. supercharged cam
  50. IT rained this morning and i had to walk cause my car broke down
  51. how to make an intercooler air/liquid
  52. Turbo motor?
  53. FI question, something I don't quite understand.....
  54. Carrol Supercharging????
  55. Garrett turbos for the LS1....
  56. ? Regulator?
  57. Vortech boost after headers ????
  58. motor is in the car...yippy
  59. Dyno Numbers for Powerdyne
  60. Boost / Fuel Pressure gauge install?
  61. o-ringed block?
  62. what ever happen to the ls1 motorsports test car?
  63. X-pipe Causes A Lean Condition On Supercharged Vehicles ?
  64. Biggest HP on SC?
  65. ATI kits - 4#, 5#, 7# and 8#
  66. Project drive my car is a go! the turbotransam is done
  67. PROCHARGER OR VORTECH? WHICH SHOULD I GO WITH AND WHY??
  68. PICS OF SUPERCHARGERS AND TURBOS?
  69. happy bday Cool28
  70. found a egr leak how much hp did I lose
  71. Stock fans with ATI
  72. who has a SC and then added heads and cam? results?
  73. who has the ATI kit and what do you think of it?
  74. GWP 422 Shipped / Slow Steps
  75. Not LS1 but got T88 3rd gen Camaro ready to start
  76. Emissions
  77. ATI 5PSI Kit and Nitrous?
  78. Heard my engine Run TOday
  79. anyone run a low compresson motor NA for while
  80. $75 Turbo vs. $69 Supercharger.. Which is better?
  81. Idle problems
  82. $69.00 Supercharger
  83. ATTN Harlan - Question About Your Cam
  84. Who makes a Twin Turbo Kit for LS1?
  85. experienced turbo people
  86. Why cant my car be done! leaking heads.
  87. Front Mount Intercooler?
  88. fuel Trims
  89. boost and octane ?
  90. Back To Harlan
  91. intercooled boost
  92. Opinions on the ATI FMU ?
  93. New to FI and have some Qs...
  94. overDrivenpullies
  95. Anyone tried our Timing tuner on a blower / turbo yet?
  96. Spark plugs for ATI stage 2?
  97. New aftercooler stickers--- Which one??
  98. Headers? Head gaskets?
  99. ATI ON STOCK LOWER END
  100. programable fuel control dfi
  101. Anyone ever use Dry Ice?
  102. Check this out!
  103. I just got a new car and I want to go the FI route.
  104. Procharger delivery time
  105. Ported heads???????
  106. powerdyne numbers
  107. Turbo Efficiency at high rpms, Lbs/Min? How to read Comp Maps??
  108. Does anyone use this cam?
  109. Ati procharger 5 lbs
  110. YOU GOT TO SEE THIS!
  111. ATI and Callies.....post some info please.
  112. ATI procharger
  113. PAGING HARLAN
  114. The big detonation issue. Let's talk about all the facts and theories.
  115. Blower with nitrous
  116. Roots-type supercharger now superior
  117. how much boost
  118. Does Vortech fit under SS hood?
  119. Heads/Cam + ATI good idea on stock bottom end??????
  120. Which Headers for Supercharger?
  121. 500 RWHP?
  122. Compression: Lower the better??
  123. Cats or No-Cats for a Turbo?
  124. Turbo Tuning and Wastegate on a Dyno vs. Street?
  125. 83 lb/hr. Injectors and Driver Box Are In!!!
  126. I must ahve power now
  127. best compresion ratio?
  128. Getting closer - new times
  129. Who has had ProCharger problems??
  130. turbo A4 question and head gasket question
  131. Went to NOPI Today..
  132. Would a 216/224 114 be bad for a Turbo?
  133. 11.83 on street tire :)
  134. what is best & difference?
  135. Ati cooling question?
  136. F-car Magnuson/Magnacharger kit??
  137. Gary, how goes the quest for completing your kit?
  138. So would the G5 cam be a good choice for a turbo setup?
  139. Looking for more HP!!!!
  140. What injectors do ya'll use???
  141. et's with an ATI ProCharger
  142. A question for those who have installed Vortech's Ice Box?
  143. Who had Cartek tune there car?
  144. Paging Harlan
  145. 42-Pound SVO Injectors For Sale
  146. anybody add a ls6 intake after you put on your FI
  147. cleaning induction part of turbo kit
  148. PAGING HARLAN
  149. Engine durability questions
  150. post pics of your procharger intake~!
  151. who cut the inner fender area for the intercoolers
  152. Paging Harlan
  153. Vortech and ATI superchargers - deep discounts
  154. Biggest SC'er for an F-Body LS1.......
  155. What version of Autotap?
  156. I wanted to know why there is oil on the procharger. I was looking under my car
  157. Will Vortech fit if I have a Hotchkis STB?
  158. ? for Black LS1 T/A
  159. who wants to get rid of their stock fans?
  160. Anyone want to buy Incon -10 Actuators?
  161. Anyone with a rebuild 346CID LS1 here
  162. o2s were the problem
  163. HELP!
  164. Anyone here that used to use Nitrous???
  165. How hard is it to pull a motor out once you got the turbo in?
  166. who thinks OD isn't for racing?
  167. Noisy Procharger Tensioner Pulley
  168. BOV flutters when I let off the gas
  169. Cablebandit, do you have your pics yet?
  170. Aleindroid, got your PM - rebuild it.
  171. WHIPPLE LIGHT FLASHING WOT
  172. Finding the cheapest supercharger unit (without kit)
  173. Lets talk blower cams
  174. Attn: y2khawk
  175. "safety" of a turbo"...
  176. ok someone fill me in....
  177. Incon TT with P/A K-member
  178. Need opinions on my convertor please
  179. Rebirth of a turbo car
  180. ATI Squealing Tensioer
  181. spark plugs for FI set up
  182. Vaccum Pumps
  183. Powerdyne fan install help needed please!
  184. ATI d1sc idle clip (link inside)....
  185. changes that affect spool time
  186. smokinHawk, I have some info about the smoke problem
  187. Help me find power ratings on all the turbos we can use.
  188. cheapest forced induction kit?
  189. Blower.....Should I???
  190. CARB Legal Turbo Setup????
  191. Chevy Silverado 1500 Turbocharger ???
  192. Incon BOV Question
  193. Would this S/C fit on SS???
  194. Looking for low compression heads?
  195. ???? about Harlans 2-step
  196. Help me spend some money
  197. tuning GWP stage 2
  198. Stage 2 it is
  199. rotate the compresor
  200. Paging person trying to sell ATI kit to me.
  201. Need help with boost guage
  202. Why head gaskets pop?
  203. Head gaskets blowing out
  204. Bigger Cube Twin Turbo
  205. Greddy Profec B Boost Controller For Sale
  206. GWP 422 Stroker - 693 RWHP / 611 RWTQ
  207. vortech s/c with 100 shot?
  208. B & M New Volt
  209. Magnacharger boost ?
  210. street super/turbo charging not realistic?????
  211. Ed Wright tuning with Procharger?
  212. Specs on Lingenfelter cams???
  213. what a wonderful day
  214. Are there ANY reliable, unbroken, no excuse FI setups out there?
  215. ATI F1 blower is up and running
  216. Vortech boost loss
  217. stock fans with ATI kit?
  218. Question about Turbos
  219. turbo&supercharging give wut ya got
  220. Help me setup gauges and acurate sensors for FI tuning
  221. Question on LS1Motorsport's Turbo Tuner Kit
  222. Spark plugs.
  223. Anybody running denso plugs with there F.I.
  224. The real cause of my old engine woes
  225. Single Turbonetics Turbo Sizing? T64/62-1 ??
  226. who uses o2 simmulators
  227. Anybody selling a D-1SC?
  228. The nightmare is over, almost 1.5K later....
  229. What does a m6 with a stage I ati kit run in the 1/4?
  230. MAT Sensor Location
  231. Paging Blackls1T/A
  232. Calling all M6 cars with ATI
  233. Got my impedance converter today!
  234. thinking of building a motor for boost..need help
  235. People who have there incon kits please read
  236. I am so pissed at ATI
  237. Twin Turbo kit almost avail!
  238. Injectors?- QUICK RESPONCE PLEASE...
  239. ls1 motorsports build up
  240. help with 2 step install....????
  241. Advice/Opinion on Turbo Build-up
  242. LS1 Motorsports Single Turbo Update:
  243. Best gears to run with a blower?
  244. Whats the highest psi you can run on a stock bottom end with ati procharger?
  245. What gears are you turbo guys running?
  246. fuel pressure
  247. Any updates Harlan?
  248. FTRA... 1/4 Times
  249. ATI Fuel Questions
  250. ATI Procharger on my LS1
