PDA
View Full Version : Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 [168] 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230
  1. What could the problem be, if any...?
  2. intake elbow problem
  3. ECS put an STS in the 9"s
  4. Stall too high for blower?
  5. More Boost?
  6. How do I eliminate boost creep on TTi kit?
  7. turbo
  8. magnacharger
  9. Turbo guys, how much do u think I am leaving on the table with my small housing?
  10. custom front mount turbo build..
  11. Borg Warner Supercharger??
  12. i need some quick help with my turbo cam for hiflo kit
  13. What year is this truck manifold?
  14. Initial start up Question's
  15. Can you have too much intercooler?
  16. First pic - APS C5 twin intercooled twin turbo system
  17. Supercharged camaro intake help
  18. how to read compressor map???
  19. Well if its not one thing its another...
  20. forged internals for a D1SC procharger?
  21. Nw bracket for procharger install finished..ahhhh..
  22. turbo question
  23. Anybody have a TTi street kit intercooler?
  24. AFR's or LS7 heads for high hp boost motors
  25. Help me with my cam
  26. My PCV / Breather Setup **PIC'S**
  27. leaking boost?
  28. Calling all of you HIGH HP guys
  29. LT1 TA question
  30. General turbo oil question
  31. turbo on/off
  32. Injector opening time with 160lb injectors
  33. Turbo Choice Help
  34. oil In The Intake pipe
  35. Magnuson MP112 Baseline test/results
  36. Used OBX intercooler value?
  37. Both Incon Turbos Need To Be Rebuilt. Who should I Send Them To?
  38. D1SC with stock air filter location and lid?
  39. Vortech bypass...help please
  40. Upgraded to D-1SC
  41. is a 90/90 set up good for FI - 90/90 leakage
  42. At what point would vertically mounted ATI intercoolers be done?
  43. this is what an aluminum inlet hat on procharger looks like
  44. Trailblazer SS turbocharged...
  45. V-Band leak
  46. think my MAF crapped out
  47. FI over 15psi boost, how much hp gain are you seeing (or ET) + 15 degrees of timing?
  48. Is my wastegate too small??
  49. If you cannot find a Sponsor Feedback thread look here-->
  50. Procharger inlet hat...
  51. Vertical flow vs horizontal flow intercoolers..
  52. How many have lifted ported 6.0L heads?
  53. Who can fab a 4" elbow ?
  54. HorsePower TV STS C6 TT
  55. Turbo LT1...maybe.
  56. Forced induction cam,,,,,,
  57. just purchased blown z06- what do you think of this setup?
  58. Accessory belt jumping
  59. roots vs centrifugal
  60. My CAR HATES ME!
  61. Will my new cam work for turbo???
  62. Sts High Boost Problem -- Need Help
  63. car dying after it gets warmed up.
  64. Car harder to start since relocating the MAF after intercooler?
  65. Compression ?
  66. Car runs for 10 sec and then dies--troubleshoot please!!
  67. Head Gasket leaks
  68. Head gasket help...sbc
  69. Paging Bob from EPP, D1SC inlet question...
  70. ahem.....IM 21 today!!!!!!!
  71. Out of the loop question, any TT kits yet?
  72. Got on full boost finally
  73. You guys say you like turbos?
  74. external wastegate???
  75. I've got a *noob* question i need answered!
  76. Procharger question
  77. What hp will i be looking at on my homemade kit
  78. Soooo close......
  79. What will the 6.0l truck heads drop a stock ls1 compression to?
  80. Interesting pictures....PT-67 next to a GT47-88
  81. D1 belt alignment?
  82. turbine housing question....
  83. turbo below oil pan... imm gonna need a pump so i got some questions
  84. what signs tell you to upgrade your stock ATI bypass valve?
  85. how often do you guys have to change your plugs?
  86. LT1 single turbo project beginning soon
  87. underhood turbo kits
  88. Newby 6.0L with Garrett TV81
  89. Cutout on a restrictive exhaust on a high-hp turbo car
  90. Finally got it started again
  91. Victor Jnr related queries
  92. Best Wastegate?
  93. new turbos for the 402...thanks Jose
  94. Which Cam
  95. how size is the mondo bypass flange and mondo inlet?
  96. Went to Hi Flo today...
  97. Need Crank Pinned...
  98. Anyone Have A Magnacharger?????
  99. Crank pin drill bit
  100. NEW Lingenfelter MAF for FI...
  101. Help me find a shop please
  102. Alky Control Methanol Injection install pics and results.
  103. needing a turbo for my car gt 70 went bad
  104. Where should i put my o2 sensors?
  105. highest hp on stock LQ9 heads?
  106. quick question on mechanical boost gauge
  107. Another Procharger Belt Problem 8 Rib
  108. Going to Procharge my '04 Tahoe
  109. PCV question
  110. what does it take to change a gtrim to an s trim
  111. Which By-pass valves are the SC guys using?
  112. Blower Time
  113. STS Turbo System
  114. turbo setup....
  115. Comp Cams' SC2 custom grind results :D
  116. Twin turbo on stock LS1 in 67 Camaro
  117. final draft, twins vs single, real world opinions..
  118. breaks up High boost headlights on, runs smooth same boost with them off???
  119. Dyno tune #'s
  120. Rotrex C38-81 Supercharger??
  121. Some Hi-Flo shiznit came in today.... (pics)
  122. problem with supercharger crank pulley
  123. Charlotte/ Raleigh area custom piping (mandrel/pieced together welded)
  124. should i stick with my turbo or what?
  125. Anyone run a bigger single turbo?
  126. jose (forced-inductions), do you take credit card?
  127. T4 vs T6..size?
  128. Benefits of Meth. vs. FMIC
  129. D1-sc on a stock LS1 , pulley size to make 9 PS1
  130. Turbo LT1 ??? guys
  131. lq4/ lq9
  132. New best for my junk *video*
  133. ? about cool down and RACE car with Turbos.
  134. max boost for stock block
  135. What catback are you running with FI?
  136. Methanol Tune ???? --Help Plz
  137. disapointing day on the dyno :(
  138. Need a 7-8 psi wastegate spring for T-netics deltagate
  139. Another dyno update.
  140. Oil from my turbo?
  141. Victor Jr. and PCV
  142. Something old, something new...turbo swap..
  143. Silicone Couplers!?
  144. 90 degree coupler from throttle body to maf
  145. A few pics of a friend's Z06 FMIC-->
  146. Found a few boost leaks...
  147. help needed on my dyno run
  148. Sts Please Help Asap!!!
  149. this turbo stuff can suck at times 13.4@87
  150. SC Vette Guys
  151. How much would CNC LS6 heads benefit a D1SC setup?
  152. STS drill any?
  153. E-boost 2 question
  154. ls1 heads?
  155. Would I benefit from a 2-step?
  156. TB for turbo car?
  157. Intercooler???
  158. i need help with 02 ss camaro
  159. What kind of numbers should I expect? 408 & 76mm
  160. launching on boost -STS need help
  161. Largest turbo possible w/TTi kit without relocating radiator?
  162. Centered inlet/outlet 4" OBX
  163. Red Rocket Update
  164. who makes the best a2w intercooler
  165. got an EPP FMIC for my procharged ws6....
  166. who has the lt1 twin turbo car?
  167. Sts Oil In Exhaust And Intake ?????
  168. Diesel Turbo Question???
  169. Forward facing headers from 5.0L?
  170. Controlling boost question
  171. What Are My Choices For Roots Type Blowers For My 2000 Ss???
  172. Blower cam
  173. autometer gauge pod - can't see gauges
  174. STS Car needs heads
  175. exhaust manifolds
  176. How many of you are running a turbo blanket??
  177. Anyone have an instruction manual for a HKS GTII wastegate?
  178. are the STS turbo systems good?
  179. HIFLO manifolds and cross-over are in!
  180. Its all coming together now
  181. How loud is an STS setup???
  182. Blower clutch
  183. Turbo Vacum
  184. yet another turbo build commencing
  185. thinking about procharger after iraq
  186. Whipple S/C
  187. Good news!
  188. Best afr heads for a 346 D1SC
  189. is it okay 2 use the blue oil lines for my feed/return
  190. 1st track outing for the turbo vette.. humorous times.. :)
  191. procharger leak!
  192. Crank bolt problem with Vortech
  193. Is a 3500 stall too much for 6.0/4l60e 12psi 3.08 gears???
  194. My new toy S95
  195. Im goign to see BOB @ EPP
  196. good valvesprings for sts
  197. Installing a BOV Greddy type s
  198. Boost guage: Mechanical or Electical
  199. Question about Turbo Kits
  200. what head for my s/c
  201. Static Compression Vs. Boost?
  202. 226/220 cam for TTi setup?
  203. Help me build my Turbo shortblock.
  204. Need some help identifying some metal I found in my oil.
  205. d1sc numbers
  206. Where to find 1/2" header flanges?
  207. STS Help
  208. sdce guys?
  209. D1SC people, need some advice.
  210. do all turbo cars run hot or is it just the design of mine?
  211. Re-locate the STS oil line
  212. does your alternator slip?
  213. valvetrain noise, in my procharged coupe
  214. Cog belt system for procharger ?
  215. need heads and cam
  216. Temps of water cooled turbos?
  217. 4L60e behind a turbo motor???
  218. Ohio forced induction turbo kits intro...
  219. truck manifolds/ ac ??? take a look please
  220. What options for Birds front ends with FMIC...
  221. Clearance problem with TTI Street Kit?
  222. Forced induction compression ratio
  223. what heads are you using for your boosted application
  224. Who's looking for a refund from Hi Flo?
  225. A/C delete questions
  226. How much boost/hp on SI motor?
  227. Heads and Cam or Fuel system???
  228. Limitations of pump gas - highest HP on pump gas
  229. Remotemount wastegate vacuum line placement
  230. Another CTS-V with an ATI ProCharger D-1SC
  231. Where are the O2 Bungs on the TTI Street Kit?
  232. Turbo TBSS
  233. Vaccum Leak?
  234. blower + turbo
  235. ford cobra ?????
  236. power steering pump as scavenge pump?
  237. Ever tried blower + turbo?
  238. Made a few hot weather passes yesterday..
  239. oil psi at turbo
  240. TTI turbo kit for LS1
  241. Putting togethor my kit
  242. ATTN: Kyle Farley.....
  243. Waste of money? opinions or experiences wanted
  244. will this work??
  245. paging stoleit
  246. Just installed SN-2000 (GEN ??)
  247. Help me find a shop...
  248. TTI and/or GMR Turbo Kit with 2 CATs, is it possible?
  249. Sighting...near Jeffersonville
  250. Catch can question
