PDA
View Full Version : Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 [82] 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230
  1. What is the best Aluminum Race Radiators for lumina 2006 like gto
  2. DIY Rear Mount FMIC...Feedback wanted
  3. 260z LQ4 maggie- fuel pressure not holding
  4. DIY piping kits?
  5. 6061 Intake Elbow????
  6. Cleaned up stock manifolds?
  7. i got the turbo now trying to figure out the rest
  8. What #s are stock cars with rear mounts putting down?
  9. Instrument cluster not working?
  10. really considering going FI with procharger..
  11. what exhaust clamp for pt88?
  12. wideband sensor install?
  13. Compressor wheel damage ?
  14. 68 Camaro AES 410" LSX F1R Build
  15. intercooler choices
  16. Vortech vs Procharger
  17. eBoost2 users, step inside.
  18. need advice on lt1 build
  19. Fuel system for TC78 on LSX Mustang
  20. ABody Folks with ProCharger LSX Transplant kit - PS fit?
  21. how are these turbo ? T72 link posted inside what equal to them or better ?
  22. Jgmtday
  23. *Dyno runs*... 454LSX,TFS245, Twin billet wheel 67's
  24. t-bolt clamp vs regular hose clamps, and other questions
  25. bob is this the right filter?
  26. 4500 what can i get?
  27. What hotpipe kit should I get?
  28. What type of tune is best for a turbo build?
  29. Which meth system and why?
  30. They're here! Motovative N383 Billet Alternator Relocation Brackets
  31. 370 CI Twin Turbos with AFR 245's Build Thread
  32. Anybody with stock cubes & T6 78-85mm turbo I have ???s
  33. Intercooler questions
  34. Swapping in the new ERL Powerplant...
  35. new toy
  36. PT88 Oil questions
  37. Will Racetronics in tank pump support 8# boost?
  38. wrapping exhaust pipe wet?
  39. small turbo bad?
  40. Fbodyjunkie's Build Thread PTE76GTS, 4L80E, Moser 12/video/6.61@110!!!
  41. Cam Question for Turbo
  42. TC78 owners come in!
  43. help i need help with boost piston choice
  44. Going For Broke-n.....Twin Turbonetics T76 5.3
  45. Turbo guys....38mm or 44mm wastegate on 5.3 build?
  46. help with vortech supercharger setup
  47. looking at twin turbo ss
  48. after market hypers vs stockers
  49. Precision PT88 & Turbonetics T88 spec questions
  50. MAGGIE VS WHIPPLE on LS3 camaro (want input)
  51. Is there anybody here running this pump, or even heard of this pump before?
  52. anybody running maf with over 650rwh and big cam
  53. EBay Hot side piping?
  54. Do I need a bigger fuel pump?
  55. Do I need a bigger fuel pump?
  56. Thoughts on removing the divider on a tc78 Ex housing?
  57. steam tube adapters
  58. Fuel Slut! AES 390 TT TC-70's AMC Javelin Build.
  59. dual 3.5 vs 3.0 tail pipes - spool difference?
  60. Yes. Another low oil pressure thread. UPDATE 7/28
  61. Is this true about e85 or just bs
  62. Is a forged crankshaft really needed?
  63. Godspeed kits any good?
  64. truck manifolds/turbo in an A body
  65. Oil pressure dropping under load after oil change...
  66. Driver side manifold glowing after an easy 5 mile drive.
  67. vortech supercharger shaft play?
  68. Anyone have any real world experience with the factory style 3.3 BAR MAP?
  69. True cost of running E85
  70. tr6 gap
  71. not building boost
  72. evap?
  73. Rearmount turbo selection help..(NEWBIE)
  74. trying to decide on a turbo...again
  75. rearend mounted turbo
  76. HRM's 1200HP 4.8 LS
  77. The most efficient supercharger ever...???
  78. Loudmouth Turbo v1.0.......
  79. What do I need for a 140+ mph car ?
  80. cam for FI stock bottom end
  81. Seriously unsure about single vs twins
  82. Same cid tall vrs short LSX for boost?
  83. which budget A2W and where to mount
  84. STS turbo need help making boost
  85. Quick question.. What BOV is this?
  86. Champion camaro ttix 848 rwhp
  87. could I run a S/C with my setup?
  88. St-80......:)
  89. Looking for some feedback on my ideas for a TT build.
  90. Anyone have experience with 6-71 blower on LS ??
  91. Precision 76GTS pictures with stock radiator
  92. Moroso Oil Filter Sandwich Adapter Turbo Feed/Return
  93. Custom procharger mounting (fbody)?
  94. KY-Turbo Build
  95. Idler Pulleys
  96. Leaks oil, can't understand where. Need help!
  97. turbo cam size
  98. which fuel injectors
  99. Can i re-use these heads?
  100. Where would I find these parts for my supercharger?
  101. ls6 intake or fast intake?
  102. Jax04--88'rx7---88mm---L33--PowerGlide---8.8"--v1.0
  103. Who is running FTI behind their turbo/blower cars?
  104. Leaking Procharger....
  105. breather?
  106. good read on block machining
  107. Best engine for a blown DD?
  108. to bore or not to bore? Cam choice
  109. Vacuu source for catch can/pcv on a tc78
  110. 600-650 rwhp goal. buy lq4 bottom end or rebuilt spun rod ls1?
  111. If you've had a procharger and turbo car in here!
  112. Carbed turbo guys, I need some advice on a crazy project.
  113. Need turbo ideas
  114. rebuilt pt88 exhaust wheel failure, what possibly happened?
  115. Is this the ebay intercooler that all you guys use?
  116. safe afr?
  117. meth tank
  118. has anyone got the new hotrod magazine?
  119. heater hose questions/mods. answers please.
  120. Could not ask for better people
  121. 370 PT88 only making 3psi on dyno
  122. Turbo Questions.......
  123. TC78 W/ 1.15 ON 4.8 or 6.0???
  124. Are there any notable differences in these 2 PCV Catch Cans?
  125. Catch can or no catch can
  126. whipple on a f-body?
  127. need a good a/w intercooler
  128. return line question
  129. what should I change about my turbo system
  130. Aeromotive 13105 regulator enrichment, lol
  131. camaro ls1 turbo at dyno
  132. MAP Sensor advice needed.
  133. Supercharged 408 intake manifold
  134. 383 Lt1 F1-r Blower build
  135. forced induction doubt
  136. power steering question for ptk users
  137. turbo seals question
  138. Boost #'s changing?
  139. Need help with 408ci turbo build...
  140. My rear mount standalone oiling system, have a question
  141. Ohio Boys Racing Updates
  142. Thoughts of Holset HX40 paired with a 4.8?
  143. need help with pushing water
  144. Help out a newbie.
  145. AES 410c.i. LSX & KY-Turbo
  146. Pro flow Xt turbo LS2
  147. supercharger pulley
  148. Short intro video
  149. Dyno...what do you think?
  150. Question re: PCV system and forced induction
  151. Turbos to fit the following criteria
  152. Extra Thick MLS Head Gaskets
  153. Overheating with AC on with P1 now...
  154. Billet T76GTS Dyno Results on 19lbs and E85!
  155. vette 50mm cog drive used in F-body
  156. L76/LS3/L99 vented catch can setup?
  157. Stripped coolant sensor
  158. 1966 velle twin turbo 454 or LS ?
  159. opinions on piping?
  160. .68 or .81 a/r exhaust for rear mount
  161. Spool and power difference w/twins pt6765 vs tc76
  162. Gt4202r
  163. RPM, boost, and engine life
  164. 30" tires now working on my LSX Drag Radial Vette
  165. I better upgrade my fuel pumps asap lol.
  166. Boosting lsx376
  167. Copper Head Gasket O-rings
  168. 2-bar MAP sensor not reading above 105kpa
  169. Turbonetics T76
  170. those running 5.3's
  171. 408 Twin Precision 6765 V&P Racing LSX Pinto
  172. FAST and 2 step.
  173. ProCharger Video Challenge 1st place $5,000!
  174. 427 F1C build
  175. AN fitting question
  176. Signs of a bad Procharger?
  177. rear gear- boost- t56 ?
  178. your timing and A/F increments from 1lb-20lb of boost?
  179. ls2 rails on lq4 intake?
  180. Thinking about going FI
  181. What plugs for ls3 twin gt35s
  182. 6.0 lq4 turbo?
  183. Turbo Guys! Exhaust question
  184. which oil pump?
  185. i need mild steel colector flanges for ac mani build
  186. turbo ls2 in a 245" top dragster
  187. Which large frame turbo for a 5.3?
  188. Procharger Help!
  189. rear mount guys
  190. How'd you bend your PS lines to clear turbo plumbing
  191. Suggestions on build....
  192. Diesel vs gas engine?
  193. My Forged LS1 KYTP TC 78 Header build
  194. Best exhaust manifold bolts/gasket combo?
  195. 16" Zirgo pusher / griffen /160 therm keep me cool ?
  196. 150/160/220 natural gas injectors?
  197. LQ4 Tuning/Timing opinions wanted
  198. FAST LSXr vs LSXrt
  199. Got started on the 20psi tune last friday, dyno and video inside
  200. Wiring woes
  201. 02's stoped reading in HP tuners
  202. lets take a vote on turbo selection.
  203. building ls1 for boost.help
  204. need help bad
  205. gear ratio? for my 5.3boost camaro build.
  206. ran friday!
  207. help choosing a turbo
  208. Well car is running with the D1.
  209. I need clarification please
  210. Single or Twins and what size?
  211. Finally dyno'd my turbo LT1
  212. Holden WH Statesman, 390ci + S400 build
  213. Eboost2 setup help
  214. new record: stock longblock 4.8
  215. STS turbo
  216. Meth Troubleshooting Help Please...
  217. Brute Speed Blower Cam
  218. Just my luck, D1 installed and now the alternator isn't working.
  219. The latest technology Turbo Charging!
  220. S91 Turbo Problems Again. Or I'm Wrong? I don't Even Know Anymore.
  221. help what springs should I get?
  222. Same WG,differant ci,turbo,cam,lower boost??
  223. Most power with a 5.3
  224. anyone here ever hurt an e85 engine?
  225. arp head bolts.
  226. Turbo ls1 Horsepower estimate?
  227. 99 Procharged ls1 with part throttle knock
  228. Rear mount turbo- Should I run a pre-turbo flex pipe? Do you run a flex pipe?
  229. methanol injection
  230. .120'' Head gasket for boost??
  231. Heading to Milan this weekend...
  232. O-ringed block for use with MLS gaskets
  233. sts turbo problem need advice:/
  234. 89 octane with meth
  235. truck manifold questions...
  236. Safe octane level/timing for 20 psi?
  237. Procharger with Wastegate
  238. Turbo craped out, so what size should I get now?
  239. My TT Vette 930/870
  240. best streetable twin turbo kit for C6 corvette
  241. coated intake?????
  242. 9.2 compression and ? Boost
  243. rearmount help
  244. yes the question again, what turbo to use??
  245. Magnacharger tvs 2300 or go with kenne bell???
  246. Turbo oil leak problem
  247. Twin Turbo's
  248. RHS 427-F2 Cog-Stock Susp C5 PICS...
  249. couldnt find the anser to this
  250. intercooler size question
