- Any suggestions on why my car mississ and stutters???!!
- APS twin turbo
- More progress on my turbo kit...56k get some dinner
- Instructions for ATI Balancer Pinning Kit
- Exile MSBC-1ET01 from Turbo Technology
- OFI--need my a/c stuff
- New parts
- balancer spin on crank?
- Experts chim in please
- I NEED F1SC for camaro
- Is this normal
- Cutting the honeycomb for an intercooler...
- SDCE Tensioner problem (tensioner cocked)
- ideas please, Kp, and other FI gods
- I officially have twin turbo's "thank god theyre on"
- Need New Plugs: Which Ones (D1SC Procharger)
- boost calculations.
- Is this all i need??
- What turbo?
- Temp Sending Unit Placement!
- ST-series T4 turbo
- All-pros arrived!
- Complete Incon Kit ... how much?
- Guys running large injectors (83 or bigger) on stock computer...
- A FEW TURBO ?'s
- Blower cam: LS6 vs. 224/228 114lsa
- APS C6 ZO6 intercooled twin turbo dyno vid - 620 rwhp @ 6 PSI
- Cooling problem update: "F" you, EWP....
- Air/water intercooling
- high sided idler pulley
- What shortblock would you pick for boost? 7k max?
- those who cut the license plate filler on T/A
- How to test for boost leaks.
- Best heat shielding metal material?
- 3 bar sensor & electric boost gauge sensor the same?
- heres a video for FI guys
- scavenger pump low mount turbo ?
- *** Pics of new C5 Vette Rear-Mount 88mm Turbo ***
- Going FI need to lower Comp ratio
- What a real muffler for a turbo car looks like
- Procharger Rebuild?
- Any way to tell if knock is false or real?
- big cam?
- Turbo kit???
- Turbo Oiling issues. NEED HELP!
- New MT91-98 turbo
- Nitrous and Boost....
- What size injectors with new APS turbo kit. Plus other ?
- HKS dealers?
- bad bypass valve
- Compressor A/R
- Cooling success with A/C on Procharged street duty combos
- Just a quick preview of my first numbers.
- If your on the fence about APS....
- The Mighty S95
- spark plugs update
- procharger hat
- How close is your FMIC to your airdam or radiator core support?
- F1C is SICK!
- What stat you runnin'?
- Procharged D1 Install
- Home built D1-SC part 2:fuel & grill (pics)
- Twin STS's?
- F--- this car. Still running hot.
- STS Help
- Vortech blower pullies
- On average what kind of timing are the turbo guys running?
- Final Dyno #'s For Now!!!!!!!!!!
- Is this set-up going to crack?? (pics)
- Converting to a YSI or T-trim
- turbonetics' turbine wheel
- TFS 225'S or AFR 225's
- My Magnacharged SS almost done
- Ran my TT 01 SS at the track tonight
- L92 w/ intake and boosted 6.0-408
- Mahle -16cc users...
- blow off valve
- Nitrous or D1SC....
- How to mount fogs on a TA with a fmic
- Custom Turbo X-over pipe
- Help! Supercharger ??'s 2000 gmc 5.3
- Anyone who knows about supercharging a 5.3?
- What size turbo do I have? GT45
- LT1 Ram Air box w/ vortech supercharger... possible???
- Pics of my EB2 dual solenoid to dual Tial gates install.
- My poor stock replacement head gaskets
- Downpipe of Epic Proportions Mockup..
- how much boost for LT1???
- Vacume Manifold
- Can I make it work?
- twin turbos
- Forged motor already
- How to tell A/r on a T76??????
- Syngery 2 step wiring
- 2 step help
- Cats with Corsas vs Cats Only vs Corsas NO Cats
- Any experience with bored out high Imp injectors for FI? Link inside.
- Melling 10296..which spring should I use for Oil Cooler and Turbos
- Got Custom Hi-Flo dyno numbers with a little problem
- O-ring block leak water??
- FS: RC Eng. 75# high imp flow matched injectors
- sts turbo system-good or bad
- Another FI Cam Suggestion Thread
- Questions B4 dyno.
- 01 ws6 - d1sc
- sdce 8 RIB & ATI Damper install?
- A.I.R. pump as a power adder?
- Where to mount Hobbs switch?
- Racetronix pump and FI D1SC
- I have a theory....
- Wastegate flange
- Little present showed up today for a few Stenod Cars.....
- getting close to getting her dialed in.. just lack some money :(
- Old School Blowers
- at what point is CO2 needed for the WG?
- How long it take you to finish building blower/turbo motor
- Average MPG
- Best plugs for a turbo setup
- Few passes from yesterday
- lifting heads
- rwhp t74GTS ?
- Ported LS6 manifols
- FMIC trans ams. psot front bumper pics
- AtoW Intercooler Help
- finished 4" intercooler piping on this obx style
- Quench and gasket seal for a low compression super charged build???
- alternator booster vs Boost a pump
- exhaust wrap and stainless exhaust (fatigue and fail)
- What dish pistons for 8.5 on a stock LQ4?
- Precision T76GTS vs. Turbonetics GT-K1000
- ProCharger guys...blow-off valve pics and specs please...
- D1SC + E85 Results
- INCON Experts inside.
- 402 D1 track times
- OFI results
- DIY Turbo Kit Finished
- Air filter or screen for turbo
- my 02 camaro sts project buildup progress--(pic)-
- New Gaskets.....front and rear seals don't look as good as they used to.
- Correct gauges to use when supercharging
- turbo questions ...look inside
- Magna Charger for Fbod lsx
- hp/boost/drag times????
- How much boost would you run on SCAT rods (w/ARP bolts)???
- vortech
- belt length
- clutch?
- front bumper cut out pics?
- Getting a STS car off the line.
- Iron 370 or Aluminum 347????
- Air Filter Restriction vs Boost On FI
- Need Some Help.....
- Testing Results
- 346ci FI vs 408ci FI
- Melling High Volume Oil pump w/Rollmaster Double Roller
- boost on a 3 bar fast unit ?
- vortech help
- making more room for turbo setup
- Trouble with my motor head gasket?
- Cam & stall recomendation, 6.0, Blower, and bolt ons
- my PT88 car *vids*
- APS TT GTO Dyno Video 16PSI
- Slick turbo plug wire pic
- The real story behind Phamspeed's Budget kits... (Read Me)
- Am I leaving streetable power on the table with my current cam?
- D1SC on 383LT1
- Procharger on stock ls1
- Anyone using FJO Racing's Water/Methanol Injection Setup?
- STS Dyno Number Low
- Not a F body but a cool FI project!
- Will these turbo spec work with an ls1 or lQ9
- When are the IATs to high for FI??
- FAST 3bar MAP install
- is this bs or reliable?
- Shall i do a pic by pic write up on LS1 vortech install
- Check Out Andy's "Secret Cam": Looks Like He Is On To Something
- how much more money do i have to spend!
- turbocharged problem with brakes!
- Will this pcv system work?? PICS!!
- who does work like this...
- Dyno #'s @ 5500 RPM
- 2 or 3 BAR MAP for hpt & interceptor gauge
- forged motor
- Anybody using an EBoost2 with two external gates and one solenoid?
- Updated Pictures of my SS
- What thermostat for 346 twin turbo?
- Synergy Twin dyno results....two dynos
- An STS Trailblazer SS is Born
- Boost piping.
- Carb# California
- school me for boosting on transbrake
- Any boost numbers for 403/F1A with this pulley combo?
- low CR fuel economy...
- TT vs Big Single Turbo
- dumb question - pt76 turbine v-band flange, what size?
- Turbo cam recommendation
- Fluttering past 6K rpms?
- Possibly purchasing s-trim/ need advice from vortech guys!
- Meth options
- Hi-Flo "Street Killer" Install pics
- Sputtering in boost...HELP!!
- pics of a/c compatible turbo setups ?
- what is a safe afr for low boost?
- tonight 1265 hp and lost a tire...
- How to remove the blower pulley on maggie?
- 347 F1R dyno video
- LT1 Manifolds
- LS1 sts on a Lt1?
- 3 bar wiring
- Forged Motor Build In Progress
- DCR's turbo engines?
- ms3 with fi??
- Anyone use a powerglide in thier turbo setup?
- 7" Velocity Stack
- Anybody used LS2 plugwires on a LS1 for turbo pipe clearance?
- STS and driving in rain
- 408 with single Turbo T76??
- Alky Control Kit Install ?'s
- 946 hp street tune
- Anyone Got one!
- 796 Rwhp 720 Rwtq 347cid C5 Auto F1r
- is it ok to spray lube in wastegate to prevent it sticking open?
- MSBC-1. where to buy?
- IS this turbo capable of 800whp?
- Who has/uses a Bead Form?
- new 403 in and running
- only 5ps1 help1
- ProCharger belt length rule of thumb?
- New Car New Build PART 2
- more boost with restricted exhaust?
- Supercharger Surging @ Idle
- Fireball FI98x Turbo Build
- My STS turbo 383 build **PICS**
- Twin Turbo Vette. Anyone know this guy?
- cam shaft for 6L with f1 procharger
- my first new car pass little video
- intercooler inlet
- Ls6 Intake Gain?? Worth the cost??
- Twin Turbo Manifold Kit(Coated Hot Parts)
- Final Twin Tirbo Kit Pic's
- Intake suggestions for my street Twin Turbo set-up
- basic FI questions
- Progress pics of twin turbo Firehawk
- procharger & exhaust
- Any one using greddy catch can for pcv system?
- need help, chance to buy headunit
- Physical Dimensions of the Procharger Red Race BOV?
- coolant recovery
- More power with higher octane same tune?
