PDA
View Full Version : Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 [132] 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230
  1. STS kit on a C5
  2. belt question..
  3. SDCE w/ Stock Damper Question
  4. Opinions on my set-up please
  5. Fel-Pro 6-layer MLS gaskets-where to get them?
  6. H/C Change pics
  7. Blower Header Delimma-Educated Input Requested
  8. Whipple kit
  9. My Turbo Project Has Started
  10. Eboost 2 reading low
  11. in trouble
  12. Factory feed line 'T' return size? Pic inside
  13. Procharged GTO -- Oil Leak?
  14. Got the car running and driving
  15. V8 RX7 Sigle turbo build
  16. bolt hole size T76
  17. I need help
  18. 06 GTO with an 402/ATI ProCharger F-1C being built at EPP
  19. Warm start up issue.
  20. wastegate reference issue
  21. ISO - HP Tuners bin for my car
  22. Who eliminated the STS PCV system and used a catch can?
  23. Turbo Question not for a ls1 though
  24. Twin turbo car making high pitch sound...need some help
  25. which block for big turbo power.
  26. Aps Dyno On Stock Bottom End, Trans, Clutch Etc...
  27. supercharge candidate
  28. sts guys come in!!
  29. What Bypass Valve?
  30. Vacuum sources
  31. Turbo Advice?
  32. Twin T-70s
  33. Ohio Boys and Tom Kempf
  34. meth and afr questions
  35. Quick ?'s about LS1's and F/I
  36. Has anyone done the magna charger from LM
  37. Where to get alt. reloc. bracket!
  38. BS3 vs 3 BAR factory computer
  39. FI EZ 94mm BB turbo?
  40. Ac mounting with turbo kit??
  41. Need Help!
  42. Blower Motors & Headers
  43. Short update on my Formula
  44. What do i need?
  45. ST80 problem....poop.
  46. ET LS7 41" or AllPro LSW
  47. Cam Power zo6
  48. How badly will a 3" exhaust choke my setup?
  49. MAF and turbo kits
  50. Manifold ?
  51. Buy FI set up or a C6 ZO6
  52. aps intake duct
  53. APS, little things
  54. Turbo In Battery Location??
  55. Twin 76 build.
  56. D1SC rebuild cost??
  57. Thanks To Shawn!!
  58. TIG welding hotside question.
  59. APS kit: EGT bung in driverside EGR cover?
  60. TVS Pickup (video)
  61. PCV with FI
  62. TRT is no more
  63. STS oil pump and fuel pump question
  64. Forged 347 piston Ring Question
  65. Official: STS Turbo choice thread.
  66. edelbrock intake elbow??????
  67. seeing 9 1/2 #'s with stage 2 snow meth kit 50/50 mix. safe???
  68. Question about getting new setup to the dyno?
  69. wastegate questions
  70. RevXtreme Sheetmetal Intake packages!
  71. To good to be true?
  72. O F I C6 Single Turbo Release!!!
  73. APS charge pipe came off oncesusp loaded
  74. has anyone had problems with spark blowing out with a msd digital 6??
  75. GMC Syclone/Typhoon pistons?
  76. Could I get away with 15psi?
  77. Project Pewter Turbo install
  78. wicked 1 dyno and track video
  79. CheaTR cam and P-1SC?
  80. Car not wanting more timing or boost issues
  81. Vacuum line routing ?'s
  82. spark plugs for high boost
  83. STS kit, Oil all over engine bay!
  84. Another stock bottom end APS Dyno tuned and on the road
  85. Eboost 2 with a twin turbo application
  86. TT/408 GTO Finally fired up
  87. Home made rear mount turbo ?'s
  88. No maggie for now
  89. where to order from?
  90. OFI guys...how did you run plug wires?
  91. 809 rwhp CTS-V we built for Bob Johnson is featured in the Aug issue of GM High-Tech!
  92. 02 Z06 STS 42lb max RWHP?
  93. Looking for some exhaust housings.
  94. who sells procharger pullies?
  95. need some cam help.
  96. Why truck manifolds with EGR ports should be avoided?
  97. Day 1 Build Ebay Kit
  98. Best street setup
  99. Lost ALL oil pressure idealing on rack????
  100. Got the firehawk on the dyno
  101. So i did the LT1 radiator swap.impressions
  102. stock bottom end
  103. Got some new toys today
  104. Supercharger
  105. 370 iron block build....few questions.
  106. Late Model Racecraft 08 Procharged Mustang Pics!!
  107. GT4088R or GT4508R
  108. 700 Rwhp??
  109. budget upgrade?
  110. STS Meth kit a progressive sprayer?
  111. Couplings for 30psi?
  112. Main belt drive idler w/ Procharger
  113. the white chicken is back
  114. What Size piping for custom Y for rear mount
  115. stock 4.8l with turbo est. hp
  116. What are high HP guys doing for traction?
  117. Header Wrap Question?
  118. Procharger clocking
  119. Need some sts Turbo help!
  120. Turonetics 66mm rebuild or t76
  121. 1dirtyZ V3.2 build (F2 procharger , 427, etc. )
  122. Can I get a TTi street kit review?
  123. a2w intercooler
  124. Puller fans on Intercooler
  125. Eaton TVS R2300
  126. Boost Project..... Anything Else I Need To Add to The List?
  127. IAT readings
  128. questions on an unknown cheap turbo kit please give advice
  129. How thick is too thick?
  130. APS install: Steering linkage too short with BMR K-member??
  131. BOV and BPV the same thing...
  132. 76mm Chevelle hit the rollers
  133. Which plugs for e-85
  134. Heads for my boosted 408 Darts or different?
  135. Rear Mount double wrapping, Bad Idea
  136. Anyone Here running Master Power Turbo?
  137. What happened to"Stops making power after 4800rpm on dyno!! " by VINCE
  138. Whats up with the APS turbo upgrade?????
  139. FI on a old pontiac BB selecting a turbo?
  140. Which turbo? Forged 347
  141. Moroso and APS
  142. cost of APS Extreme Performance Intercooled Twin Turbo Kit
  143. What all do you have to do when putting a F1 on?
  144. What FMIC should I get with F1A?
  145. New Pics of my STS kit
  146. STS turbo kits
  147. LSA Supercharger ?
  148. T76 60# mototrons at fault?
  149. Cometic phuzion gaskets
  150. TTi street kit goes 10.74@127!!!
  151. Turboshaft?
  152. turbo oil return line
  153. EBOOST 2 questions
  154. Do people here actually search?
  155. reverse rotation prochargers?
  156. Max boost on regular 4-bolt heads?
  157. speed incs sc1 cam
  158. procharger FMIC
  159. Need some help with a decision.
  160. drill front of oil pan??oil return turbo..
  161. LSX supercharged swap into a mustang. Anyone have any pics or info?
  162. MPT-70 on vortec 350?????
  163. Weird O2 sensor behavior (and they're new!)
  164. too much boost!!!!!!!!!
  165. Up the boost?
  166. Intercooler Piping?
  167. It's Official.. out with N2o Injection.. In with F/I
  168. LT1 2 bar MAP sensor part number?
  169. Gagin interest on OFI base kit
  170. EGT's
  171. Does Altitude affect boost pressure?
  172. preping 317 heads for blowthru
  173. Inital Turbo LSx numbers from Tempest Racing 1100hp/13#
  174. do any sponsors sell a tt kit but
  175. Is my IAT too high? Do in need a better intercooler?
  176. The Poor Mans ls1
  177. o2's and maf replacement recomendations?
  178. STS AND What muffler are you running?
  179. Twin Turbo Oil recomendations
  180. difference in turbo size
  181. What will max out a D1-SC?
  182. Simple question...
  183. Akerly & Childs rings
  184. To Boost PVC Or Not To?
  185. Got the car (Finally!) Now diagnosis-Advice?
  186. Pics of OFI radiator and fan setup?
  187. somewhat of my supporting parts list for SC
  188. having trouble keeping filter hat on procharger after fmic and bringing rad forward
  189. Newbie + Boost
  190. 3" Aluminum doughnuts...where?
  191. what boost levels for 408
  192. Thinking about going FI (STS Turbo)
  193. APS car overheating
  194. Cooling Fan Questions
  195. Round Stock for Bracing
  196. Where to find tr8s???
  197. APS. litte things.
  198. 347 or 383 for FI and stock block
  199. Here is a new type of stock engine failure! 749whp and this!
  200. best block and cid to turbo
  201. lt1 running 10 lbs boost?
  202. piecing together a turbo setup
  203. Wanting to go Turbo but I have some ???
  204. lt1 ?about front mount Air2Air
  205. D1 with stock (241) heads?
  206. relocating alt.?
  207. epp fa1 fmic kit question?
  208. Where did you put your injector driver?
  209. Fighting Knock 1 to 2 degrees
  210. Had to lower my sway bar
  211. 408 Rotating Assy
  212. turbo 6.0
  213. what size wastegates to go w/my twin 70's? are 60mm too big?
  214. Turbo Guru's inside please...
  215. turbo lt1, rev limiter at 4,800 when hot
  216. Is it ok to have IAT sensor before BOV?
  217. turbo 96 firebird progress
  218. blown 383
  219. 3.4 Whipple Build
  220. APS 35th BUILD has to all!!be redone!!
  221. H/C LS1: Procharge-able?
  222. Just curious...What kind of times are the APS TT cars running?
  223. 317 heads vs aftermarket
  224. vortech question
  225. Need some idea's
  226. 1,000 RWHP Twin Turbo LSx
  227. Guys with 6.0 liter Iron blocks and Prochargers
  228. Need question answered about a LT1 rad???
  229. t4 gasket questions?
  230. Crank pinning?
  231. Turbo Sizing Question
  232. Thinking of Changing my setup
  233. can a regular mortal change one turbo seal?
  234. SDCE Tension
  235. Need Help S.o.s(( Aps)) Guys !!
  236. Need help with what setup to run
  237. Accufab throttle cable is now loose!!
  238. Looking for a little help w/OFI cold piping
  239. F1A or F1C for 427 LS7 F Body
  240. Just fired up my APS 35th LE today
  241. BOV swapped but getting more boost
  242. What boost can I run with a 98 pcm using HP tuners?
  243. LSXtreme Trans Am jumps into the 8's
  244. valve springs
  245. Prime New motor
  246. Turbo Fbody = worst investment ever!!
  247. Add Nitrous or go with bigger Snails?
  248. OFI hot parts group buy
  249. What Cars/Trucks use pusher fans?
  250. APS inlet drivers side hose rubbing issue???
