View Full Version : Forced Induction
- zr1 cam compared to patg 218-238
- 60lb injectors
- S475 vs. S480 "T6" LQ4
- Twin suggestions
- Blew my LS9 Headgaskets mid pull?! **5 MORE PICTURES PAGE 3**
- Texas speed and performance 408 or 421 turbo
- 347-stock 243 heads-Stage 3 cam-YSi-976 rwhp
- GT45x vs S483
- Pullied , Boltons , Cammed , 200shot C6 ZR1 Dyno vid
- cam question cant find the answer im looking for
- My 2010 Camaro ss Turbo Build
- AEM truboost?
- 4.8 turbo questions
- 5.3l single turbo parts help
- Speed Inc working magic!!! Turbo fab work
- Anyone know the exact size T-Bolt clamp for Fbody procharger kit?
- Good single turbo?
- Crank pining questions
- Lets Talk Under Hood Temps
- ? best prices on tial wg, blow off valve
- Are you sick of cam threads yet? (I'm narrowed down to two)
- ON3Performance No A/C Ls1 Camaro REVIEW PICS VIDEO GREAT KIT!
- Twin truck kit.
- Msd 6010 or stock PCM
- Fuel pump for 1000rwhp???
- 377 ci, TR6060, Twin 67s Build Updates **Start up vid**
- Who makes a nice front mount turbo kit for a 2000 camaro?
- Radiator hoses for dual pass?
- Oil Adapter (For cooler/turbo) Is Thermostatic Option Important?
- Props to ForcedInductions.com (Dr. Turbo)
- Engine temps...good or bad
- Custom Turbo Build
- Fuel system for a dd
- 2000 Firebird LS1 turbo
- predictions
- Turbo decision help: single, twins, bb, journal, oil-less?
- Looking for a intake elbow
- Stock Bottom End LS3 makes 763rwhp/651rwtq
- 4.8 with a 75mm t6 ..
- Synergy 2 step instructions
- lingenfelter gt9 cam question!
- Turbo Cam??
- What do I need fuel system for 1000HP s480 Turbo
- sdce pulley
- L33 5.3, S475 turbo build!
- how much radiator is needed?
- How much power are you making with twin procharger intercoolers?
- Relocating A/C hoses. Receiver/Drier
- Please Help Anyone Im new need help
- Where to put a GT45 in a 1998 camaro with A/C?
- L33 stock cam and boost
- Anyone knife edged a divided turbo housing?
- LS engine with th400 oil pan install
- How many of you running ls2 knock sensors on your 4th gen.
- 76mm turbo question
- Procharger kit elec fan?
- Is this a gas or diesel based turbo?
- need help on supercharger setup on my 68 camaro ls swap
- Need 5.3 turbo advice
- Necking down a down pipe
- Seen Matt (Denmah) at work the other day..vid
- pipe dreams... grudge car
- ~Procharger Build Write up~
- Device to store a tune
- what valves to use on a supercharged motor
- Buy Turbo hot side parts, T6 flange, brands etc...?
- Ls376/480 TT what would you do?
- head stud install poll?
- What valve springs should I run???
- Track advice
- Neep your IDEAS!!!!
- Aps tt short block predicament
- Boost or lack there of.
- Building a turbo LS advice..........
- Small turbo 4.8
- Best oil for Turbo LQ4?
- FI head assembly parts
- Procharger 3.5" intercoolers?
- Carb or efi on my ls3 turbo race project????
- Best rotating assembly for a procharged LS2?
- High horsepower turbo differential options and opinions
- Anyone running boost on a iron headed 6.0
- pre turbo intake pipe size?
- Cracked Oil Pan
- Iron block verses alum block
- Aussie VS SS Ute Ls1 twin Garrett 35/40,T56
- New 76mm wheel for Real Street from FI
- 3" tail pipes support power? (fox)
- Looking for 120lbs/hr injectors
- ST80 turbo 346LS1 good combo?
- Billy Briggs 365/LSA heads ECS YSi Build
- 2006 Z06 + 2 GT35's + 4L80 = 8.69 in 1/4
- My LS1 Truck Turbo Build
- need help deciding what sparkplug i need with 4.8L turbo
- Gear ratio?
- best location for meth nozzle and IAT sensor?
- input needed: 5.3 turbo fuel system.
- fuel pressure problems.
- How much power out of a Vortech Si-Trim? How about 744 rwhp!
- Forced inductions.. Oil Coolers???
- LQ4 bottom end for boost question.
- high compression plus boost
- max efford 5.3.. twin turbo selection
- Anyone make a Plug and Play dual fuel pump + hobbs switch wiring harness
- What serp belt for NON p/s f body
- Looking for EPP FMIC Brackets
- Anyone here use the summit racing 90mm TB?
- Build questions
- corvette F1A kit on an fbody
- Show me where you mounted ur turbos on ur 98-02 camaros
- New engine, different set up, is this safe?
- what inline fuel filter do you use with dual wallys?
- Any gains from upgrading to a 101 mm TB/Maf, and a FTP 104 Lid on a Maggy 112
- 01 Transam Intercooler Question
- Valve Springs
- 404-GT91 3 Years later and 3500+ miles.....
- Are catch cans necessary???
- YSI + Arun cam=The Jam
- Help!!! downpipe cutout and wideband o2 issue
- By show of hands. Who has
- OBX 2.25" Mild Steel V-Band, with pics.
- L33 or LQ4
- Huron Speed Custom T6 or Mid-Frame T4 Turbo Kits!
- which turbo is better bang for buck!
- vac line help please
- stock 5.3 with turbo help
- ping at wot?!?!
- Turbo Mounted to Frame from Comp Housing?
- Time to Upgrade!!!!
- 1000whp LS3 piston to wall and ring end gap recommendations
- TT selection and vender plz!
- walbro 400lph fuel pump.
- Build Thread: Lsx, 4L80, GT55-94: Street car WS6
- 85 turdbird going 4l80 4.8 turbo
- Looking For the BEST BLOW DRYER for 800-1000hp.
- Which T4 turbo blanket?
- 6.0L build/ Stroke,charged,or turbo?
- Sold the GT91-What twins for my STREET driven 404
- Need advice on my setup!
- Equal length merge ?'ss
- Weird IAT sensor problem
- G8 D1s/c 4.5 pulley pump gas
- Those running a remote water pump
- (Maggy 112)What kind of numbers should i expect to see?
- LS3 - ECS Novi 2200 utilizing a wastegate
- 6 speed
- 70 Nova 402LS what turbo parts ?
- Bout to pull the trigger ..... EZ94x **opinions**
- Magnafuel Pump in Tank ?
- GM Truck on Kill -- 919HP/880TQ 4.8L
- Converting T6 GT4788 to T4 questions.
- Truck accessories and pullies for LQ4 or swap over my LS1 accessories?
- Twin Walbro 255 question
- Setup thoughts..
- 98 Camaro SS 441 LSX,twin PT6766 CEA BB turbos street car.1190rwhp 1016rwtq on 15lbs
- Lets see pics of your duel fed rails
- Billet S480 track results.... 144mph.
- what solid motor mounts with Pa k member
- 408 turbo cam ??'s
- Weak Point on Stock LS1 with FI?
- divided vs open
- Which turbos for my LSX427?
- What are these procharger parts worth ?
- Forced induction cam ? Thompson engines ,Huron speed,tick performance come in!
- Got some free stuff and LSX block warrantied
- 91 camaro 6.0 LS3 heads turbo build
- New Turbonetics Turbos
- so i took the caddy to mexico...
- injectors for 700rwhp
- E85-E70 How much will it effect my tune
- on3 turbos
- C16 or pump gas w/meth injection?
- Ls1 vs. ls6 intake
- anyone tried this
- my 5.3 parts list help with turbo
- Thank you Huron speed
- Turbonetics??????
- External oil pump for turbo system
- FMIC or Meth Injection?
- Fast 92mm intake and boost?
- 1930 Model A Twin Turbo 5.3 Build
- How much hp can dual bosch 044's handle with -08 feed.
- Valvespring question
- Opinions Needed!
- Oil pan question
- Procharger F1-A on 97 SS
- Measuring boost before & after intercooler--What is an acceptable loss?
- List your cheap-azz combo
- can my 5.3 spool this?
- Anyone use a stock shortblock l92 for boost?
- Best Meth Injection Kit?
- Fuel system
- Huron Speed Truck Manifold Turbo Kit TAX RETURN SPECIAL!
- Low Compression + Pump Gas... How Much Boost?
- Any front mount turbo guys using this?
- good budget glasspack/strait muffler for turbo lsx cars?
- Catch Can has some smoke/vapor
- anyone using a bmr alt. relocation bracket
- Turbo flange braces, what size round bar?
- 9.0h at 150 tc78
- z28 vert*370*twin 76mm*budget/barter build
- Starting over/Help Needed
- Educate me on Prochargers
- oil feed question
- Some Video from the CTS-V Rental 2/23/13
- Root/Twin Screw - Supercharge Options
- LT1 Guys Come On In Please
- Newb question????
- power adder advice
- is this manifold broke???
- ProCharger guys...anyone ever have issues w/ stock crank?
- The new WOOOOO ls/sb radial tire record!
- FI.com lists tc78 (1000hp) why?
- 402 10.8:1 pump gas boost possible?
- My Build 96 Impala SS
- Spark blow out, my experience & what I learned
- 408CI boost question
- stock vs aftermarket heads
- A/W intercooler question????
- Procharger Kit/tune?
- What does your turbo car weigh?
- Stall on a Turbo T/A
- turbo k member
- Whats going on at Race Proven Motorsports (Video)
- Heintz Racing does it again!!
- Version 2.0 / Z28 / Procharged / 383ci / Build /Dyno Results
- Huron Speed A/C Turbo Kit GROUP PURCHASE!
- 2011 6speed camaro ss turbo build
- Turbo s10 build thread
- THANKS! Huron Speed
- My attempt at TQing boosted LS head bolts. (Inspired by Denmah)
- 1998-2002 F body Pro Charger mounting...
- Huron speed guys? oil return hose ??
- Low RPM / high torque
- FI + m6 + 27.3" = ?:?? gears
- Lock the converter for less RPM at traps, or leave unlocked??
- New turbo manifold for trucks. :)
- Dual Fuel on the fly(87 and e85) on stock pcm's!
- Turbo 4.8 Dyno Mule
- LQ4 - Single or Twins
- Unique Turbo Recommendation, Please
- how well do you think this turbo will work?
- Wrapped headers to help with under hood temps (d1sc car) what u guys think?
- C6 Corvette build - ProCharger F-1A / 365ci / LSA / E85 [*UPDATE* 915whp/815wtq]
- Changing pistons, need 370 pistons .. What to get
- If I wanted to build a LQ4/LY6 for a turbo, what should I do???
- Bosch 044
- 6.0 + S480 = 1289 rear wheel horsepower.
- Belt for ATI harmonic balancer?
- Filter Selection
