PDA
View Full Version : Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 [225] 226 227 228 229 230
  1. Procharger Question ??
  2. Now I am really confused!!!
  3. Compressor maps for Prochargers
  4. PROS/CONS
  5. Anyone have a Vortech SQ sound clip??
  6. Throttle Body with SC?
  7. please help in finding turbo kits.......
  8. I have a t-60
  9. Head Flexing under boost? > Get them "Pinned"
  10. Paging Mike from MMS
  11. LS1 Motorsports Single Turbo
  12. Waiting for my new mota in my Z, took the 1LE out for some action
  13. P1SC-1 or D1SC and why
  14. D1-SC Noise Levels... anyone request a quiet blower?
  15. New turbo tech owner needs advice... (long)
  16. How does she sound?
  17. T4 garret
  18. Horsepower store... amazing!
  19. Removing Cats on a Supercharged C5
  20. Need Quality Hose & Clamp Sources for Custom D1-SC and Single Intercooler
  21. What head gasket and bolts to use?
  22. is high humidity faster or slower? also how much does IAT effect power?
  23. Ls1motorsports Singe Turbo Kit.....
  24. 9th injector? Harlen, anyone...
  25. Which is more efficient? More Water/Alky less Fuel or More Fuel Less Water/Alky
  26. Max boost on a D1SC
  27. Where can I buy forged low comp pistons?
  28. Cheapest Ford SVO 42lb Injectors?
  29. Finally an easy alternative to get more boost out of your Procharger!
  30. TURBO GUYS
  31. Speed Inc Procharger Cog Kit
  32. Finally got the ati kit runnin decent.
  33. NOS and INTERCOOLERS
  34. Better cold plugs than TR6?
  35. 6psi of boost and NOS on a stock bottom end (LT1)
  36. TT are done!!!!!!!!!
  37. Scared chitless!
  38. Technical Literature for LS1 engine ?
  39. Anybody need a 7psi pulley?
  40. Cold weather = broken 10 bolt.......
  41. What do I have to do to get an ATI D1 supercharer?
  42. Fuel supply
  43. Help w/ cam for stock heads and ATI Tuner kit.
  44. Stock 6.0L bottom end?
  45. In-line Booster Fuel Pump
  46. whats the diference between the gss340 and the gss307
  47. Where to start with LS1 edit?
  48. CFM:HorsePower
  49. blew up my motor last night!
  50. loosing boost
  51. Big Bro got his 396 in, Need engine build up advice...
  52. Powerdyne 6#
  53. Will these Delphi 50# injectors work?
  54. Twin Sequential turbo??
  55. Bought FAST today
  56. Paging SJH
  57. AQUAMIST
  58. ATI Idler Fix
  59. Paging Ed Potter from LPE!
  60. Getting 7 psi pulley kit > whos best.....
  61. First kill story!!!
  62. ported TB with blower?
  63. Turbo mounting cause oiling problems??
  64. 8rib ati worth the cash?
  65. what turbos
  66. blowing the spark out
  67. GWP422 idle .mp3 - AWESOME!
  68. What would the symptoms be if my oil scavenge pump is going out?
  69. Big deal!!!
  70. Big deal!!!
  71. First time at the track with my ATI kit
  72. *** Paging Harlan ***
  73. Roots Blower
  74. Replacing Stock Regulator !/MightyMouse
  75. WANT NEW OR USED SUPERCHARGER....
  76. colder dense air question
  77. Has anyone fabed a front mount for new ATI system
  78. Got the loan Car getting redone
  79. Picked up my new D1SC
  80. Turbo size for twin setup???
  81. New to ls1 tech an the turbo world!!!!
  82. Which MAF?
  83. big injector questions, fuel pump question
  84. My CARTEK blower motor is running
  85. Carputing's (Ls1-Edit) Customer Service
  86. pulley size & PSI ratings???
  87. people with more than 9psi boost
  88. LS1 BUDGET TURBO
  89. Tapping into the oil line for a vortech
  90. Power output of a 427 TT
  91. PAGING BLACK LS1 T/A
  92. ATI Question
  93. idle pulley exploded....
  94. LS1-Edit -> Carputing
  95. ati install questions***
  96. Cheat Sheet for High Octane
  97. ATI D-1SC Question
  98. Newbie with Boost looking for info
  99. TWO FUEL TANKS???
  100. Used turbo kit, any problems???
  101. Racking my brain - ATI vs Vortech S/C
  102. how much boost?
  103. Rebuild question???
  104. 1:1.8 investment rockers.
  105. Cam for LS1 Motorsport's Turbo kit?
  106. Fuel pressure dropping??
  107. Installed Propane Injection
  108. Most boost with stock timing and fuel system?
  109. Small Oil leak on D1...
  110. ATI Procharger Installed + a question
  111. fuel system differences between FI and NA?
  112. stock bottom end + 10.8:1 CR + boost
  113. Vortec T-Trim on a 98LS1 Boost???
  114. Where to buy used charger??
  115. Got the money, but needs some advice
  116. What to expect from addition of Stage 2 heads to blower car?
  117. vortech guys using a canton oil pan
  118. What is the highest Boost I can run?
  119. ati pulley belt size?
  120. Vortech S/C Question
  121. ati d1 users, got a ?
  122. 8.5 compression- help a limey!
  123. Thinking of a power adder.
  124. Aluminum vs Iron Block for Forced Induction?
  125. ATI stage II blower w/custom fuel system???
  126. Brand new D1 head unit for sale
  127. Why T-trim?
  128. BIG TrOUBLE
  129. Vortech LS1 Head Units Failing
  130. FI Cars using Low Timing Table?
  131. Turbo headers are finially on
  132. Venom Nitrous
  133. real men get blown...
  134. Just bought a 72 Nova!!
  135. REALY NEED HELP
  136. What do I need??
  137. Supercharger & NOS??
  138. How to tell which pulley I have?
  139. Black ls1 T/A or anyone questions about blower
  140. Is this ture?
  141. Harlan can you assist me please.
  142. What next?
  143. Ok I have totally lost it
  144. What Injectors To Support 650fwhp?
  145. Is it possible to have a supercharger and NOT reduce engine life? How?
  146. H/C Suggestion for S/C
  147. Currently Running Incon Stage II Racelogic Box? HELP!!!
  148. GWP422 sends tranny to an early grave...
  149. oops,Sorry about multiple posts
  150. Only 5# P1SC, still too lean!!!
  151. Pics of tt setups
  152. Harlans low 10's vids.
  153. Is this possible...?
  154. November is supercharger month!
  155. Harlan's Car!!!!
  156. power loss after I sprayed with blower
  157. ati guys
  158. Centrifugal Blower flow rates, Vortech, ATI?
  159. Best MAF Electronics for FI?
  160. 3.0 pulley.... would it be to much boost?
  161. Exhaust gone boost controller dont work, lot of psi!
  162. Scerw blower max HP output
  163. Kenne-Bell Boost-a-pump, Others?
  164. thinking about adding heads and cam set up to a whipple 6.0, will the blower keep up?
  165. Gapping TR6?
  166. 98 twin turbo z28 on EBay
  167. vacuum hose to BOV
  168. Steel Idler Orders *Please Reply*
  169. help, got a couple questions,thinking about a budget heads and cam with my whipple
  170. ATI belt slip
  171. Supercharger & Wastegate??
  172. WOOHOO! Procharger is on...
  173. Vortech V-9 with aftercooler For sale
  174. Anyone boosting a 11:1 motor (come on in guys, help me out here)
  175. 7# ATI guys know if I should keep my ATI inline pump?
  176. Exceeding Max Impeller Speed?(Vortech)
  177. Denso plugs for FI ?
  178. Can someone Please Predict my Time with a ATI Procharger??
  179. Lingenfelter crashed in drag race
  180. Help Me Control My Boost Spike!!
  181. vortech guys
  182. Trouble Codes
  183. How much for a stock crankshaft pulley....
  184. people that wanted Steel Idlers
  185. 8 rib setup is done!
  186. spark plug reading question
  187. Ditch FMU w/7#lbs
  188. What wheel/Tire combo you guys running?
  189. Building FI motor, NEED Help
  190. Mounting a Paxton Novi 2000 to an LS1, Can i use ATI crank pulley?
  191. Should i get rid of my Cats?
  192. 410 98 TT in classifieds
  193. truck turbo kit
  194. Can I be added to the boosted list too?
  195. plug gap Q
  196. Stock Fans and ATI Kit?
  197. 4.10's W/fi m6 HC car?
  198. f1 price over d1sc
  199. S1 heads stock cam & procharger
  200. Got a '98 With False Knock? Step In!!
  201. Suggestions for 5lb to 7lb ATI upgrade?
  202. Will a single T-66 Turbo support 600 rwhp?
  203. I need some help with my 98 camaro!!!
  204. powerdyne supercharger
  205. Why not a whipple?
  206. Started to polish my ATI system, new plumbing mod, maybe, pics>>
  207. Dave Inall info from ls1.com
  208. rain in Procharger
  209. LS1 TURBO/BLOWER PISTONS FROM DIAMOND
  210. Supercharger or Turbo
  211. Can someone update the Boosted list?
  212. Alky Injection
  213. forced induction forum SUCKS!!!!
  214. Cheapest place to buy a turbo by its self???
  215. does ati supercharger kit come with damper?????
  216. boost guage
  217. FMU or LS1 edit
  218. Who's in the first group...?
  219. ATI steel idlers for sale
  220. Which would be a better blower cam?
  221. piston rings
  222. fule pressure problem?
  223. ATI pulleys for CHEAP!
  224. Boost prob
  225. MAF Rate -> Horsepower
  226. Approximate price for ATI ?
  227. 2 weeks, 2 ten bolts, BOTH BROKE!!!!
  228. Pics of the Golden West Performance 422 CID Blower Motor
  229. new z28 supercharger
  230. Turbo Options?
  231. Turbo or S/C
  232. update kit for P-1SC
  233. what happened to the guy with the custom turbo mounted under the pass.. seat?
  234. Turbo kits for 5.3 trucks
  235. T/A totaled
  236. 36.5" belt for ATI?
  237. Who sells .030" thicker head gaskets?
  238. Next step when the T/A dies
  239. Race gas + more boost = HOLD THE F#$% ON!!!
  240. anyone lifting heads?
  241. electric superchargers
  242. Custom ARP Head Studs will be ready on Friday!
  243. New pics of the motor...but
  244. Just bought the 12psi pulley from ATI
  245. Which BOV to use?
  246. Benefits of a cam??
  247. Who Else Has A '98 Red Incon TT SS??
  248. Help me build my turbo motor!
  249. I dont sell shift lights
  250. Selling the camaro
