PDA
View Full Version : Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 [175] 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230
  1. Magnacharger C6 Vette Results!
  2. Help me with this guy
  3. procharged car question.
  4. tranny, and rear?
  5. Harlan 2 step plus TwinTurbo = big difference.
  6. Need help building turbo kit
  7. progressive controled Alky/meth/water inside for help please
  8. Just got my turbo parts
  9. Those with the OBX intercooler...
  10. how to tighten blower belt tensioner...
  11. What block w/forged internals
  12. forged internals
  13. Return oil pump for turbo???
  14. Anyone have the GMR speed single kit?
  15. 6.0 gasket question
  16. The Tune is Done, Dyno results are in!!!
  17. valve cover breather
  18. Question about 6.0 heads
  19. Turbo/SC on 11-1 heads???
  20. turbo kit fab question...Truck mani+pham/TTI?
  21. Cost for turbo setup. And high mileage 98z
  22. Price on getting 8 rib pulleys from ATI???
  23. is this the right part???
  24. and you all thought 2 bar was impossible on a 98
  25. Thoughts on this wastegate?
  26. radix superchargers?
  27. Los Angeles Area Help
  28. What stall for street/strip procharged 347?
  29. Magnacharger on an fbody,
  30. ** 76GTS questions
  31. what size pulley should i use...
  32. Ceramic coatings
  33. OC Corvette - Car is Done!
  34. Procharger or Vortech
  35. what should I do ?????????
  36. Motor build coming along!
  37. Looking for dyno #'s before and after
  38. have plans but need help from the experienced
  39. before and after videos of my turbo Z-28
  40. bov's on prochargers????!!???
  41. Big thanks to Stenod
  42. Thinking of going turbo???
  43. Anyone though about or made a Turbo 302 LS1?
  44. STS turbo kit on a daily driver!!
  45. FMIC for STS questions
  46. Boost on LSX engines
  47. My Hi-Flo SIngle Pics
  48. FMIC Tubing
  49. Having trouble finding a part for my Eboost
  50. Interclooler/methole kit
  51. Biggest turbo available for the incon kit?
  52. Intercooler
  53. STS Happy Customer
  54. Boost gauge oscillation....normal?
  55. which heads?
  56. Need some help here (long)
  57. MSD's ATI ProCharger for their CTS-V has been delivered.
  58. First Startup!!!!yeahhhhhh!!its Alive!!!
  59. Larger throttle body magcharged z06?
  60. CAS twin turbo causing bad vibration???
  61. Is a 60mm Tial Waste gate to big for 700-800hp
  62. Boost Gauge reads 0 Pressure unless under load
  63. my setup ??
  64. Paging Kevin @ W2w
  65. LS1+Boost=Boom?
  66. 05 GT with what under the hood? LOOK!
  67. Bored, so I made a video ;)
  68. boost better at a specific displacement?
  69. People that have installed Victor Jr Intake....
  70. how sluggish is boost motor B4 boost?
  71. ATI ProCharger Price Increase Coming Soon!
  72. Boost control per GEAR
  73. GMR Single Limits
  74. Powerdyne SC questions???
  75. My Custom STS exhaust version 1
  76. Looky what showed up today!!!
  77. Need info to install YS-trim on LT1
  78. GT42 question
  79. Down pipe Delima
  80. need help????
  81. GMR SPEED Ceramic coated turbo manifolds [pics inside]
  82. Procharger
  83. What AFR for FI tune????
  84. Fast LSX Intake Manifold
  85. header fab advice needed
  86. aggressive cam for turbo
  87. Turbo gauges (where to start)
  88. bead rolling for ic piping
  89. ati crank pulley for procharger
  90. Map question
  91. Help Australia - Boost contol
  92. How hard is it to change the pulley?
  93. Want to go FI
  94. FI engine 205 head vs 225 head on 346ci?
  95. Building a 402 for procharger?
  96. a question about wastegate setup(truck manifold)
  97. Anyone tried Eagle 3.9 Crank?
  98. The 'Twins' are home!
  99. STS system sound w/out cats
  100. to heads and cam or not, that is the question
  101. how much boost will a stock ls1 bottom end take?
  102. Need help with ATI Fan...............
  103. which turbo?
  104. n e one ever seen a magna charger on a f-body,.
  105. How much boost is needed?
  106. STS issue or boost issue
  107. AEM dealers
  108. help buid up for FI!
  109. Would this be the equivalent of a T63?
  110. Made airdam for my intercooler, pics/info on my D1SC setup
  111. Vortech not boosting 8-9psi wtf
  112. Blow off valve question
  113. high PSI wastegate springs vs electronic boost controller
  114. STS Boost guage and wideband
  115. not sure if this belongs here, or F.i.
  116. Compression on new shortblock
  117. procharger part needed. please help
  118. "Bling Bling" Hi-Flo Style
  119. Grr Turbo Sts Issue....
  120. Turbo Dyno graph question...
  121. most boost in a ls???
  122. Spark Plug Gap
  123. Q: Deleting turbo anti-surge?
  124. Wideband guage or Fuel pressure guage?
  125. Anyone have their spring tensioned pulley go bad on LT1 P1-SC
  126. G5X3 and boost, Answers within....
  127. Sts Bov Help
  128. What compression to run in a forged 346??
  129. Post your pics--FM turbo location
  130. Garrett GT60
  131. question
  132. Wideband o2 location for remote mount??
  133. anyone seen or heard....
  134. Superchargers and Headers...
  135. Worrying rattling noise from blower bearing
  136. Lq9 HEADS
  137. Making progress with the new thumper (Pic)
  138. dissapointed with H/C should have gone procharger...
  139. whos got good prices on turbos?
  140. KB for LS1?
  141. whats your GAS MILLAGE under boost and not under!!??
  142. BOV needed
  143. groundzero turbos
  144. what do i need for boost?
  145. Help identify turbo
  146. Size of the vaccum line off the back of the intake?
  147. Check valve needed for rear mount
  148. boots lt1 or ls1
  149. Pinning kit for stock balancer??
  150. Hi-flo single turbo kit
  151. how to make a low cost turbo blanket/cover
  152. Any info on sts rear mount turbo?
  153. Vortech V27 YSi ??
  154. turbo exhaust housing
  155. Who makes a good 1 way check valve ??
  156. how will a t70 react on a Stock SB LS1?
  157. Converting from D1 to F1
  158. FI gurus, please help!
  159. FI-Experts: Please check this setup.
  160. superchargers
  161. Heads for boost?? LQ9
  162. 36000 miles stock springs
  163. Question about pressure leak
  164. Another truck manifold question.
  165. My Turn--So Close Yet So Far Away!
  166. Supercharger Sounds
  167. rad packaging?
  168. Any Quick Fixes?
  169. How far can you get with 16k?
  170. how do you guys get it passed?
  171. Any use DEVILSOWN alcohol injection kit? Looking for feedback.
  172. DIY Turbo help
  173. FADMIC Front Air Dam Mounted Intercooler "Save the Bird"
  174. Fmic ?
  175. Bypass Valve and boost gauge off same vacuum source?
  176. manual boost controller?..opinions?
  177. T-88 + built 346 Hp #'s??
  178. Swapping turbine wheel
  179. F/I Crew, Who has knowledge of broken comp 918 spring with less than .590 lift?
  180. Pros/Con on throttle by wire vs. manual throttle body in FI setup?
  181. Who has dyno testing comparisons of the Victor Jr intake vs LS6 style intake?
  182. Going F.I. This summer!
  183. supercharger? how much
  184. Any particular supercharger cam I should look for?
  185. What to do?
  186. Procharger noise
  187. Catch Can Pic?
  188. BOV placement
  189. Air Filter Size???
  190. Heads showed up...
  191. Need help - stroked turbo build
  192. Wastegate springs
  193. hey guys
  194. sts kit-electrical question
  195. New 408" dyno queen - 950HP @12psi
  196. Oil suppy/drain ?'s for Precision t76
  197. Air to Water/Liquid Intercoolers from ebay...
  198. what gears you guys running?
  199. h/c super vs turbo pricing?
  200. What turbo for single setup on 85 350 engine
  201. Question Lots Of Questions
  202. Hi-Flo Street Killer Update (includes pictures)
  203. Good deal!! Let me know
  204. Worth it or NOT?
  205. Supercharging performance
  206. Electronic Boost Controllers...
  207. post some 88+mm turbo install pics ...
  208. Comp 918s vs. Patriot Dual Golds for BLown stock LS6 motor?
  209. Supercharger question for experts
  210. spark plugs?
  211. A4 D1SC Done !!
  212. Desktop Dyno
  213. Question about ATI inlet hat and small filter
  214. Cam selection for my setup...
  215. where did you get your truck manifolds?
  216. FI Fuel Economy
  217. Another Vortech Question
  218. Fast 90 and NW TB on forced induction
  219. Top speed challenge vid
  220. For best reliabilty, should i swap out LS6 springs for Pat. dual golds on Blown Z06?
  221. Which coilpacks to run for boost?
  222. Procharger help needed
  223. lq9 patriot heads..compession drop..
  224. any one use this for eliminating belt slip?
  225. Magnacharger kit on LS1
  226. Crankcase Evacuation Kit
  227. MAFless Procharger question
  228. Stenod Performance "Red Rocket" Update
  229. When is water or meth injection used??
  230. how far can i push the tr6's?
  231. Which will make more power 8.5.1 or 10.1 on pump gas and boost
  232. Super Chevy show TT 69'
  233. TURBINE housing swap?
  234. In need of procharger ls1 Advice
  235. turdblow
  236. turbo people....what muffler???
  237. Max Boost On Stock LS1 Bottom end?
  238. Looking for a supercharger
  239. D1sc
  240. Opinion on what to do
  241. 6.0 gmpp single plane and PCV
  242. Vortech Supercharger Problems
  243. silicone 90* from tb to maf housing?
  244. header wrap
  245. Air filter for Procharged F-Body?
  246. Sorry, question on roots/screw in an FBody
  247. Procharger pulley help
  248. NEED an Oil pump for Turbo set-up?
  249. Procharger
  250. magnacharging
