View Full Version : Forced Induction
- ssautochrome t70 turbo's
- Anyone need a boost/vac gauge?
- tti street kit help..low volts
- ATI Guys Belt issues?
- special front and rear seals for boosted applications
- Shakedown passes with the turbo setup
- FMU selection help....
- Boost on a 427 darton?
- turbo piping
- Help with Pro-Charger
- Blown Head Gasket
- IM back with a new set up
- Why is this happening? Re: Boost Falling Off
- Turbo Time !
- need help with CAS twin turbo wastegates...
- Boost/Vacuum lines
- Where to get a Procharger D-1SC
- What the STS/GTO air filter relocation kit looks like:
- STS turbo
- Ati or STS?
- ATI Procharger @ 8 lbs.
- 6.0L crank ??'s
- Work to hold 15 psi of boost
- help with Vortech crank pulley
- sts turbo with subframes on driverside
- Turbo or Supercharger on a LT-1?
- Where is Casper?
- STS turbo third gen LS1 question
- Anyone Replaced ATI Rubber Hoses with Aluminum?
- Belt issues???
- boost gauge
- are turbos bad on gas milage?
- Do MAP sensors go bad with turbo?
- Sdce guys with ati damper w/ac
- what part of the turbo makes the wooshing noise...
- all those with the 6.0 manifolds turned around inside
- Intercooler plumbing
- numbers w/ procharger
- Phamspeed turbo blow off valve placement??
- Can you Chrome Plate and Jet Hot a Turbo?
- What are the best turbos?
- anybody else see this 'faster spool' post?
- STS Jewl or Junk???
- Master power or Garrett? Jose?
- New Dyno results T63 single stock motor 7psi
- Anyone heard of the new NEXUS gauges?
- turbo-back exhaust
- Alternative to 2 step?
- 7000 to spend
- AiResearch T04 a/r.60
- MMS Crank Pulley Installed... Snapped Belt on First Drive
- is this twin turbo idea a possibility for an fbody...?
- New Pistons for blown setup for sale
- Quick Question about Wastegate
- thermocouple for incon
- Who makes the best gauges?
- most hp on
- which set up?
- boost gauge placement?
- Pulleys & stuff for sale
- Ground clearance with STS Turbo kits on lowered cars ??
- Shortie headers w Phamspeed kit
- guys that are building there own kits, please read
- Scoobie Doobie Dooo
- How much hp per #'s of boost??
- Any1 know who makes a SINGLE turbo kit for a C5?
- Mounted Intercooler Pics
- Gauge placement
- Guesses on track times?
- Does MTD crash test their lawnmower's???
- Start up problems!
- Blower cam ?
- Intercooler
- Worth it to swap out springs for ADTI D1SC SC on stock LS6 motor?
- GMPP intake require cutting the cowl?
- It's getting hot in here... Please welcome Hi-Flo Turbo as a sponsor!
- Would this be a good product...
- Paging person who sent us turbos to be rebuilt
- what qualities make a "better" wastegate?
- Question about water cooled turbos?
- any of you guys taking out loans?
- incon intercoolers question flow/efficiency
- Anyone using 1LE elbow on s/c setup
- alcohol injection and timing
- Is keying the crank nessasary?
- Newbie questions....
- STS METH INJECTION..once again need help on the install..
- Who has E-BOOST with twin turbos??
- Charger or Turbo?
- Rear mount custom kit
- Any PTK kits installed yet?
- These injectors will work, right?
- vortech vs ati
- Kenne Bell 2.4L twin screw S/C for LS1 *PICS*
- Downpipe cutout?
- hey STS guys
- What is the differance
- Stealth Turbo setups
- Calling PSJ!!!!!!!
- Phamspeed
- Help in the D-1SC ??
- ?'s about lowering compression
- FYI on reversed manifolds...
- Best priced Supercharger kit on the market?
- Boosted gm 847 lt1
- fuel pump help, is it enough.
- Hardcore GTO 7.14@184 ::56k will die::
- lets see your STS rwhp, RWTQ and time slip!
- What is the max size intercooler that will fit upfront?
- OBX for sale
- Turbo torque converter
- touch screen boost controller
- Do you guys think an FMIC is worth it?
- Time for a new motor...need suggestions
- need help i cant figure it out....please read and make suggestions
- Crank Broke
- Few passes from NvsS yesterday
- New to FI. Turbo guys in here.
- #7 Ringlands bad?
- 2002 firehawk
- Rear Mount Guys...Look in here
- Stenod Performance at Norwalk (vids)
- Two new bests for RPM
- I think I have a bad injector, bad track day
- Any STS users out there?
- engine temp with FI
- Any S or SQ trim LT1 guys here?
- Stainless Works Alternator bracket...installed pictures/assembly?
- Boost controller Hookup
- pacesetters no emmisions hookup installed
- powerdyne?
- cam
- So I want to turbocharge...I got a problem
- turbo question
- Turbo guys...how are you using your boost controller?
- Wastegate
- AFR & Boost
- Timing & Boost
- f'ing bs map sensor problems
- Stenod Performance Twin Turbo new best 9.14 @ 150, but then bad luck....
- MAP question
- help, ati guys with fmic
- Air-2-Water Intercooler Locations...
- Boosted Guys: How would you do against someone who sprays?
- if both cars have same peak horse power...
- Is this someone on here?
- single turbo ???
- Anyone had their tune done at 21st century muscle cars in Dallas?
- Update on Turbo Project!
- Do STS's really et/mph lower?
- Considering buying a ATI SC, I have a question or 2?
- F4 cam and boost?
- Alternatives to Crappy ATI Aluminum Idler Pulleys?
- Could be a stupid question
- Turbo/Supercharger Noise
- removing belt...came across a problem (pics inside)
- Stenod Performance Single Turbo Project Update Pics Round III
- Guaging intrest turbo kit
- Gauge and lighting PROBLEM????
- Guaging interest
- HELP! About to buy a P-1SC How to visually inspect it?
- Guaging interest in PHAMSPEED kit
- eboost controller?
- ~2003, 2004, and brand new 2005 Boosted Lists~
- the first time u started it...
- A/F and Timing vs Turbo Boost
- HELP!!! Throwing "Mass Air Flow Circuit High Input" code when i get up in rpms &boost
- Boost Controller controlled by vehicle speed?
- 9.90 video from last Saturday
- Need turbo advice from the pro's here. Turbo spike during shift.????
- i would have expected more
- Turbo Exhaust
- I'd like better cooling
- turbo kit??
- What supercharger will make the most power out of a low compression 408?
- 1000hp, here I come
- Will 38# be enough for P-1SC @ 7-8psi?
- what is a good set of rings
- RWHP on stock crank?
- I think I'm gonna buy a mustang...
- Where can I find instructions on how to change a belt?
- STS Turbos will be 50 state legal!
- help i'm an addict, is there a support group?
- anybody know
- turbo size? P-trim T-76
- Are LT1's the only ones who can get 12 rib
- Safe boost on stock LS1? How much POWER can an LS1 handle?
- Cry02
- What do you all think about a forged 346 + STS?
- TTi users or relocated alternator peeps
- sd tuned blown ls1
- Procharger Psi HELP ORDERED WRONG PULLEY
- Procharger
- What size do I need to get for pusher fans?
- my 2 step wasteful thoughts
- Ordered my blower today
- 02 zo6 cam or stock ls1 cam for turbo setup
- Is this a good blower cam?
- 2 step wiring
- Best cam for magnacharger?
- Newbie questions
- STS possible with Borla ??
- v6 S/C question
- How much do hi-flowing heads/Intake matter w/ FI?
- Phamspeed kit & tune Los Angeles area
- new to FI, but tell me if this is.....right
- Any 2 Bar Map options for 98 cars with HP tuners?
- STS turbo kit with Procharger intercoolers
- ProCharger Question
- 9.36 @ 149.72
- turbo question
- Is my cam selection pointless?
- custom radiator for turbo
- FS: STS Turbo set up Getting a Vette
- Casper Is ready to test
- Need info on Holset turbos...
- Baught a D1SC
- How long would my projected FI setup last.
- NA$TY-TA's STENOD Project Page
- boost gauge installation??????????
- Best shortblock for boost?
- Building a custom supercharger kit
- Where can you buy OBX FMIC's????
- Motor blew at 8,000 miles, what do i do next??
- questions about high mileage superchargers
- What psi is the wastegate spring that comes with the phamspeed budget kit?
- 11,000mi on the stock shortblock and boom.
- is this calculation accurate?
- WideBand O2 Sensor?
- Header Upgrade, What power gain to expect??
- what turbo do i need to hit 500 rwhp
- LC-1 and wide band sensor placement
- spec stage V is dead. Turbo camaro = 0 clutches = 4
- Hit 9s today at BG.
- may add a blower,have some ?????
- Need help from people w/2 step
- I have my factory ECU working as a 2 step
- More new pics of twin turbo buildup, getting close!!
- Main girdle???
- 27"x7"x3" IC core support 800hp?
- I need a bigger turbo! Help me pick!
- List of my current mods
- Which Block?
- Anyone Interested in my Meth Kit?
- H/C or Turbo
- 600-850rwhp guys... Trap speed vs. rwhp vs. total weight
- P-1SC 7psi procharger
- My turbo project
- gas problem in my city tuning and octane question
- Max bore LS2 with short stroke
