View Full Version : Forced Induction
- What about this cam?
- What about mild steel headers and downpipe?
- Video thread! LT cars with Forced Induction?
- Please Guess RWHP & RWTQ
- Power steering problems with an old QMP turbo kit.
- max boost on bone stock motor???
- S88 Compared to a Large Frame GT47 88MM turbo
- ATTN: PA k member with out manual rack and 4' dwnpipe
- need piping
- 642hp/ 577tq :)
- Unpressurized cooling system for high hp race cars?
- GMHTP Mag 35th Aniversary SS Vert - questions
- tranny help!!!!
- Stock LS2 2005 GTO with ATI ProCharger D-1SC and Kooks Headers runs 11.58@122.24.
- Hey Guys!!!
- which heads
- Sleeper Project
- Nitrous or Methanol
- Idler pulley question?
- OIL restrictor// How small is too small???
- Guys with synergy motorsports AST 2-Step... Questions...
- exactly what height to tap for oil return
- Broke into the 9's with my partners Z06
- Got my STS in
- 408 or 427 LSX block questions.
- Clutch question for FI only.
- questions....
- Supercharger Compression Question
- fueling problem please help
- Correct FI cam for 366ci LS2 with LS3 heads?
- Old phamspeed power potential?
- ice box install
- Exoticperformanceplus phishing emails? Anyone else get one?
- New motor is in and running..Dialup beware
- sts/cat delete
- Which is better for my 355, D1SC OR F1A
- SDCE LS1 Tensioner Tool
- Anybody know where to get incon WG actuators?
- Snow Performance Methanol Injection Help
- 408 with GTS-76 rear mount turbo video
- t-4 for sale
- Eboost-2 questions
- What Turbo?
- Financing For STS kits!!!!! Through GE Money!
- 800HP Project
- STS Turbo and Severe BUCKING under boost!
- Whipple & F-Bodies
- APS TT Forged Numbers.
- Procharger ?
- s/c dress up
- Truck Manifolds on a GBODY
- Hobbs switch psi settings
- New best 1/8 mile MPH last night - at 5000' DA
- To boost, or not, on my AFR 402?
- So what's the difference if I switch to YSI from T-Trim?
- MAF and BOV placement
- Question about LS7 gasket on a Ls1 block?
- New driveline for my ProCharged C5
- gen tt and a 4l80e
- Gains from timing with boost?
- werid question...(meth kit related)
- Big Procharger??
- MPG gain with a Blower or Turbo kit?
- I need your opinions on a turbo setup...
- 408ci Twin Master Power T70 turbo's
- Intake set up for big single turbo?
- APS TT Setup in F-Body, All input is welcome!
- Anyone have some old QMP turbo kit instructions or pictures?
- Compression Experts-What's comp with stock LS6 heads and -2cc Diamond Pistons 347 LS6
- Dumb ?
- Gen-TT on a cam only car??
- Magnuson dyno question
- best head studs?
- What kind of TB???
- Official STS Thread
- Turbo help needed
- STS ?'s
- Well the motor is here.
- which supercharger for my lt1
- Procharger guys what radiator are you using?
- can head studs be used over and over again?
- Belt Slipping......
- F1 is on!
- Need knowledge on Rapid Motorsports ability to build quality 346 forged LS6 motor!
- How are Diamond Piston Rings and Scat Rods for 700rwhp blown D1SC LS6?
- Damaged oem crank nose from blower drive?
- dissapointed with 2.8 kenne belle on 408
- Which single Turbo for 6.0L iron. S88 or smaller?
- Need opinion for D1SC cam for 402ci
- how fast has a STOCK lsx been FI
- turbo/procharger with a carb ?
- turbo auto vs 6 speed DAILY DRIVER guys
- Best price for Wilson cast elbow
- No, No, No, No, NO!
- Ordered my first turbo today! GT-K 850 What you think?
- how well would an sts turbo work in a single front mount
- PCV Hardware and Routing for Supercharged C5 - Will This Setup Be Effective?
- F/I Cam experts-Stick with LS6 cam or 224/230, 114 lsa for 346 forged LS6 D1Sc motor
- Supercharged Lt1
- Mti Clear Lid W/ Powerdyne
- Blower Belt PN
- 8s with a 347??
- 14-15psi...D1SC or F1A??
- what piston would you guys recomend for <18 >8 psi
- need fmic for sts firebird
- and now for somethimg completely different..... OFI install!
- Anyone making Novi 2000 brackets yet?
- Oil Issues HELP!
- should i coat the pistons or not?
- vortec supercharger
- Just a bought a 2.8L Kenne Bell
- Need ProCharged LSX Help (cam and boost)
- Not everyday you see one of these!
- How do you increase boost on a turbo???
- Procharger Bypass Valve Question
- Can some of you procharger guys help me out...?
- New Updates at KY Turbo and Performance.
- Which balancer are the big turbo guys using?
- stock motor need help
- Procharger Problems...STILL!
- seeing knock, poping head gaskets, tried many things, need help, 1000+rwhp
- STS guys running straight spring
- Opinions on these spark plugs please
- What will make a big cam work?
- Whats happend to gen tt f body guys?
- Finally hit >10# of boost on my T-trim from S-trim Upgrade
- Custom 76mm Turbo GTO setup
- Anyone Have Any Experience with a GT4202?
- Where are you making full boost?
- 797 RWHP APS Twin Turbo GTO Hits the Rollers
- New toy
- 4.38" to 3.9" pulley?
- Is S the designation
- Can I get away with an internal WG?
- best alternator relocation bracket for turbo setup
- Piston question?
- Did Synergy go under?
- Does anyone know if the Procharger F1A fits on the F Body with the Be Cool Radiator?
- Synergy twin kit, 717 hp...
- Supercharger for my '01 Z28 Camaro
- Anyone have any idea how much to fix turbo?
- help with magnacharger
- Knock under boost when ECT higher than 215F
- need .81 turbo housing! i have .96
- meth or intercooler or both
- Motor Build! With Pics!
- WTB 80MM to 96MM Turbo
- Changed wastegate springs, need some advice
- Sts
- COS 2bar, IAT & ECT multipliers
- Another OHIO BOYS Win!
- APS C6 ZO6 twin turbo system pics and install instructions
- im curious about some of your FI tunning rituals
- MAF-Keep it or ditch it! Explain why=>
- what do u guys mean by "spools by 3500rpm"?
- My APS TT Install Thread
- Pics of oil return off turbo into pan or timing cover??
- APS TT blow off valve
- Can i run my oil return for turbo to a valve cover?
- 402 twin turbo mistake ?HELP!!!!
- turbo tech worth??
- HCI vs. APS Twins
- Building the ultimate turbo LSX---head Q's
- For the love of god...can we make a turbo cam sticky?
- Turbo Cam
- d1sc on a torquer v3 cam car?
- Cat issue with STS?
- Using airconditioning as an air cooler?
- TT Truck Manifold Kit! (18psi)!
- Is bigger better?
- which cam to go with???
- Turbo guys suggestions please
- Forced Induction
- ofi radiator and overflow for sale
- HELP!! Cant rev my engine more than 5300rpm
- ati pinning kit
- Electronic boost controller recommendations
- APS TT Kit, Setup
- Turbo'd the wifes truck
- SX88 Dual Ball Bearing
- ditched my darts for l92
- Whats really needed in the FI world?
- any one using a ported fast 90 with a procharger?
- 350 whp from sts!?! thats all!?!?
- LS1 Magnasun Supercharger!
- Install Of Aps Twin Turbo!!! Kwikss
- lost low end
- Teaser video of Whipple 3.3L in C5 Z06
- oil return idea
- Who has 4" TB cast elbows? And some meth questions...
- performance products intake
- What size TB for carb intake w/elbow?
- YSi compressor map.
- Professional produvts intake and throttlebody
- New Best ET/MPH Worst 60 ft!!! 9.670/145.83
- meth vs nitrous
- S80 versus S88 on 408
- lt1 turbo ,can it be done
- New PB with F1A Procharger
- Need opinion on used D1SC Procharger
- IC for STS kit..mounting by air dam
- HPM TTiX 347 Dyno Results
- Superman09 track results
- APS f body install thread, tips,tricks,pics,etc.
- MAF problem!!!
- Reliable DD: P1SC vs. STS Help me decide
- Who has gone with a Custom Turbo??
- OIL + SMOKE out of DOWNPIPE= not cool
- How is everyone printing out the APS turbo Guide?
- Can I reuse intake and valve cover gaskets?
- Pro's and con's of running COgs on the street
- Saturation Intercooling
- F.i.???????
- Heads up on Hardcore....
- 50mm tial BOV what spring?
- Time to tune and boost my 98. What MAP? Still using MAF
- 3-bar map sensor
- STS Help...
- different prochargers???
- Which BOVs and WGs are preferred???
- Procharger Install Help
- Aps manifolds
- Why Am I Losing Boost - Incon Setup
- Finished! C5 vette single T4 turbo setup
- Those with the 8-Rib SDCE setup
- A2W intercooler help...
- Anyone using Trick Flow heads
- Going Turbo :D
- Pics of boost gauges/controller in dash vents,T/A
- Turbo Spooling #'s!!
- Now is the time!!! It wont be any cheaper!!
- Piston Rings Boosted?
- after catchcan runs like sh@$%
- Turbo specific engine build ?
- gt45 on stock motor...any comment!!
- Turbo Needed
- low oil pressure, is my ls1 on the way out
- sp motorsports west coast killer
- Pick my cam for me
- crank pulley
- Prosport Gauges - Any experience or info
- Tt 04 Gto
- PT98/88 on a 347?
- what do you guys think
- Lq9 and Lq4 heads
- Stock Cube LS1, Which Turbo?
- ??? For you OFI owners
- Incon tt Stage 1turbos HC408 or LC364
- confirm my fear.....
- Looking for 2nd opinions.... Forced Induction camshaft selection...
