View Full Version : Forced Induction
- procharger LSx fitment in LT1 b-body
- Turbo 5.3 Blow Through Boat
- pics of freshly detailed 85 gn with turbo ls swap...
- Precision Turbo THIEVES!
- Congrats to Eric G (Wins a Wally!!!)
- LSA exhaust manifolds vs. Truck exhaust manifolds
- First turbo build with goals... (LQ4)
- Dissapointing Dyno Numbers. Any Ideas?
- When do they push water?
- will i meet my goal
- oil cooler with turbo motor
- Engine sits high after BMR turbo k-member Install
- Which heads for turbo ls1?
- PCV system with roots/twin screw
- 5.3 PT88 Z28 vs 1000rwhp Viper,700hp 911 turbo, 900rwhp Grand national, ect.
- Ls1freak33- 370/D1
- Boost Reference Reg
- Meth failure?
- need advice on CID on lsx turbo motor
- Pinning Main Caps - necessary? Pics of what happens if you dont?
- meth or intercooler with e85
- C6/Truck manifold Turbo build (With A/C)
- Anyone have a 4L80E installed in your Turbo LT1 Fbody?
- Question about oil return on rear mount turbos
- How much power with F1A and twins
- zero to huron speed in a day!
- How do I use nitrous to help build boost?
- Best place to find 2010+ Camaro exhaust manifolds?
- Looking to make 15lbs on e85.. What compression should i shoot for?
- turbo 5.3 60lb injectors
- will a paxton 1200 work on a ls1?
- **Supercharged Grand Sport By Late Model Racecraft**
- Forged 6.0L, S480 Combo - Feedback
- forged iron 5.3 bored to 348cid
- My LS Willys Jeep has twin T4s on the way + Bonus VID lol
- Frame Mounted Procharger ??
- interchanging vortech v2 parts
- Borg Warner K31?
- New to the turbo world, having fuel problems...
- LS3/L92 FI cam...GT11?
- LS1 or LQ4 accessories
- Anyone running dual fuel tanks? (pump gas/race gas)
- Shredded my serp belt!
- Boost creep problem
- What crankshaft...22psi....single 94mm....iron 408ci...????
- LTX 383 with E85.
- 5.3/4.8 jy build help
- Vortech v2 sq to v2 t trim
- Rear Mount On A 05 GTO
- f-1a procharger off a ls2. would it be compatable with my ls1??? please help.
- Procharged lq9 question
- whats the best valued rods and pistons for a 6.0 looking to make 800-850rwhp
- SFI 25.3 Outlaw Street '70 Buick GS Build with 1800hp Twin Turbo 455 LSx
- Turbo Conversion manifold help
- What v band flange will work?
- Methanol Kit On TT Z06?? Snow Performance.
- Lets talk electronic boost controllers!
- D1SC Fan Shroud question
- 378 LSx TT Trans Am build ='s Modular/CBR twin kit DYNO results /VIDEO inside
- 94 Quasar Blue 370 GT-88 Powerglide Build Thread
- Looking for a good fi tuner!
- Ati bullet bypass vs. Ati butterfly bypass
- Pro's/Cons of building an iron 408 vs my 347 for D1SC
- How much power on 92lb injectors on E85 with meth injection?
- Will my cam be ok for boost
- what tq spec for a 600+rwhp turbo 5.3
- KR and running e85
- RMCR 50mm Cog Belt Issue
- LQ4 into GTO
- Derale 16925 guys?
- turbo 5.3 or 5.7 question
- Gbody mounts?
- PT88 vs Magnum 76 vs PT66
- Another 5.3 turbo dyno results
- At what vehicle speed do push/pull fans not help?
- I got a kick out of this video
- Should i sell my tt t/a?
- Tc 78 vs. Pt7675
- GMC Syclone build up
- Help needed for choosing trans for new build
- some basic FI q's
- 2005 LQ4 boost ?
- What fuel pump for stock LS1 with D1SC?
- Need Advice on E-85 and Pump Gas setup
- Ran the car need help sorting torque converter,gear ratio & tire dia.
- Guess whats bigger than a can of coke ??
- need pro charger for ls1
- Good cheap reliable heads for boost.
- My 5.3 build is almost completed, want your opinions!
- Quick vid of a buddies 88mm T/A!!!
- Can I buy just one head stud?
- car wont go passed 5lbs!
- "limit" of boost on Pump gas
- quick heads question
- Front mount turbo guys post pics of downpipe/exhaust.
- 1999 2000 Camaro Exhaust Maniflods needed!
- Head gasket failure - opinion?
- I am tired of seeing all these damn 5.3s going so fast..
- Catch Can Setup
- Spraying Meth before or After the IAT sensor?
- Ethanol levels changing in winter? really.....
- Weighed some blocks this morning
- E85 and back pressure
- Filtered or un-filtered oil source?
- Procharger P1200 parts
- Help Please
- Question about BOV
- Twin Wastegates
- Woke up and found this in my driveway...
- Master power T3/T4 super 60 twin 6.0 lq4 ??
- E85 poll...should i or should i not? Closest station 17.4 miles.
- Vacuum Line
- Turbo leaking oil on turbine side.
- truck manis vs some stainless shorties
- Boost reference location for waste gate.. what is the final answer?
- Turbo cam help!
- Blower cam advice
- How long should ls1 engine last on 8lbs of boost?
- Race Proven Motorsports New Shop!!!
- How far can you "safely" push pump gas + meth? (20psi/800+rw/9:1 forged 370ci)?
- High mileage 317's for FI?
- What % of methanol gives the best protection of KR?
- Is a meth/water injection kit worth it?
- Racetronix pump hp numbers come in
- Max seat and open pressure w/ stock lifters
- lt1 turbo questions
- lt1 turbo questions\
- 69 LS2 Firebird twin turbo question
- Trying header evac PCV... what to do with stock PCV (LT1)
- Filling D1SC Head Unit
- New Motor Dyno 974hp Vortech YSI 23lbs
- turbo suggestions
- Out with the D1SC in goes the F1A
- Simplest catch can setup
- Procharger blowing oil on less than 3,000 mile rebuild
- Dropping compression from 10:1 to 9:1 require a larger turbo?
- Turbocharge of procharge?
- Good stock crank boosted bearings? Clevite "P" work good?
- catch can setup question?
- Camshaft help with 112 Maggie LS2
- 99 Trans am build thread
- Turbo Set up
- dual turbo size question
- cracked piston some advise needed
- What # wastegate spring?
- what size is the sts oil pump fittings?
- anyone with eboost2 setup for gear based mapping?
- Atomicfusion 7.85@185 video
- turbo routing
- Is a t4 76mm .96 too small for a street driven 6.0
- STS Z06 dropping boost
- 240sx crate LS1 ebay GT45 build thread... I'm probably going to kill myself.
- Is -16an big enough for rad lines?
- Crank pulley without a/c pulley??
- Looking for 90* silicone bend
- Cam's Gt91 2002 T/A Keeping the Ac budget build **Fire up 7/21**
- 8 rib no dampener Procharger
- Kenny Bell supercharger 01 ws6
- 1969 Chevelle 5.3 Twin Turbo TNT Results
- PT 7675 guys lets see your numbers
- Rear Mounted, Oil-less, Comp Turbo Fbody?
- Best external fuel pump for high hp E-85 cars?
- how much more boost can you run befor you have to retune?
- xer281hr cam in my 4.8 Camaro
- Norris catch can or moroso with dual inlets & breather...or both?? OR RX Perf can?
- please estimate my hp
- Pulley Size Question
- Where to look for a quality low cost supercharger
- FI LS3 cam help
- trubo heads
- Turbo header build question
- Newb to boost build few ?s
- Manley Forged 2618 with boost
- A2A or A2W intercooler, my situation
- ls2 intake good for boost? searched didnt find much
- Rear mount turbo
- can someone ID this turbo?
- Intake runner size
- stock cube cam help
- building a boosted motor, few questions
- 1981 Turbo T/A vs New 5.0
- Camaro lean at idle
- Need some advice on my junk
- Your thoughts/Criticism -and a question on engine build with D-1SC
- LUNATI cams advice
- F-1X camshaft advise
- Modular Turbo kit and ON3 turbo #s stock motor
- 408 turbo guys in here
- help please!!
- big boost on stock LY6 pistons?
- is a 30 micron inline oil filter good for a Ball bearing turbo ?
- Any LS Turbo Tuners in PA or MD?
- Procharger D1SC 34000 rpm impeller speed to low?
- Madre di Dio! whose stock crank turbo car is this?
- how much will a stock crank hold procharged.??
- piping question
- twin turbo ls1 question
- Made it to dyno today! D1 on 10lbs 416 CID
- Boost in action... maiden voyage... 140mph.
- Congrats Mike Brown on the Atlanta win!
- 317 heads on 5.3?
- what does valve float feel like?
- BOV and wastegate
- 317 heads
- what do you guys think of this noise
- Has anyone tried this LOW MOUNT PASSENGER side ALT Bracket made for truck mani kits?
- rear turbo chatge pipe routes
- Would this cam work in a 5.3L 72mm turbo?
- Best "reasonably priced" ring set for boosted 4.020 build?
- -12an oil drain flange...where to buy???
- 05 GTO DIY Turbo, Cage, Mini Tub build
- Timing gear/chain?
- Help with gear selection
- Wastegate Mounting Position
- '98 Camaro S475 build just started.
- Keep 317s or Not?
- how much rwd power you think i have
- Need to plug a -10 AN oil return
- water to air intercooler????
- Holset HX55
- procharged and exhaust i want more what next
- lt1 guys what throttle body you using
- Single intercooler set up
- 5.3 700hp build advice needed!
- how much boost should i expect to make?
- adding e85 to pump anybody doing it?
- 600 RWHP LQ4 Turbo
- one nasty sounding mid 8 second dragster!
- What turbos to use
- Race Proven Motorsports 25.3 C6Z06
- supercharging high mileage
- LS-6 valley cover/catch can how to route lines
- tips and tricks for lighting a turbo 4.8 car
- twin turbo post
- Procharger install manual
- Heating issues with front mount setup.
- ugh 8.1l problems
- Pt76gts, run an oil restrictor?
- How much power can this iron short block hold?
- 4.070 lq9 block will be ok on boost?
- J/y 5.3 - tc76 vs pte 7675
- Anyone make a plug and play pusher fan set-up?
- which intake for my boosted application?
- Piping Kit
- ARH Monthly Newsletter
- Lingenfelter 2 Step Installed and Bent Rods
- How much area for a air to air intercooler for a vortech ysi?
- Smallest Radiator/Fan combo that will cool
- **LMR TTV Dyno Vid Inside**
