PDA
View Full Version : Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 [160] 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230
  1. electric super charger or elec-turbo
  2. AEM boost controller
  3. Holy Sh&t check out this F.I. Import
  4. supporting mods just to run sts kit?
  5. ATI 6rib & 8rib differences?
  6. Turbo questions, yes I read the FAQ's!
  7. Did the PN# change on GM 2bar MAP?
  8. tial BOV
  9. Front mount intercooler dimensions on an LT1 Camaro
  10. Turbo-Zone HOLIDAY SPECIALS !!
  11. S91 vs. GT55-91
  12. Procharger rebuild?
  13. Lost my copy of dynojet wideband, help?
  14. Will the LS6 coolant tube conversion hurt cooling system performance?
  15. STS + SFCs?
  16. STS and catbacks?
  17. How can you tell if a turbo is ball bearing or not??
  18. Need pic of front mounted turbos
  19. STS Question! HELP PLZ!
  20. SUPER or NOT
  21. 365 CID, MP122HH project done!
  22. Twin intercooler owners take a gander
  23. Gas Water in my Catch can
  24. How can I build a Low CR block.
  25. turbo kit destoys belts
  26. Hoses
  27. How come so few 1500hp LSx's?
  28. New Setup Update
  29. Turbo Exhaust
  30. noob turbo question
  31. Where are you guys mounting your meth stuff?
  32. pump gas limits?
  33. Rearmount WG question
  34. turbo smoking need some help
  35. C5, APS Twin Turbo, Head/Cam -- Questions
  36. Block to max a T76
  37. Heads/cam for D1SC
  38. Blower size for specific displacement?
  39. need help with new turbo set-up for 98 ls1
  40. Stock coils provide enough spark?
  41. Just for fun YSI
  42. Anyone still with QMP turbo kit?
  43. ATI vehicle guide
  44. Turbocharges off a 1994 3000gt vr4
  45. HP Limit of Magnuson?
  46. Iron 402: Twin 76s or single 96
  47. Going FI want to change my cam.
  48. Well, What did Santa bring?
  49. Hi-flo problems, go figure! (pics)
  50. What should I expect from this turbo?
  51. Head choice, valve sizes and stages LQ9 heads
  52. Tranny and rear diff gear ratio for TT Vette??
  53. I need help
  54. Merry Xmas fellow LS1tech BOOST members! and what did you get FI wise
  55. sts pcv switch working?
  56. Replaced the 2bar with a 3bar today....+ Boost.
  57. Wastegates: dump to atmosphere or route back to DP?
  58. Supercharger DIY?
  59. t-6 turbo flange
  60. Anyone running a LS1 Accufab Throttle body with there blown F-body?
  61. Would i be the fastest STS turbo car if i reached high 9's?
  62. turbo choice help
  63. supercharger??
  64. Turbo exhaust?
  65. Stock block done!!!!!!!!!!!!
  66. Newbie curious ques.
  67. How to tighten Procharger Belt?
  68. Inconel valves necessary for 700whp turbo setup?
  69. PCV setups with forced induction
  70. New member with some boosted 5.3 questionsin a mazda?!?! WTF
  71. d1sc bracket
  72. extremely low oil pressure after sts
  73. STS guys! in here please...
  74. Safe Limit Boost on Stock Engine
  75. what makes a good turbo cam
  76. Post up if you have a 3bar SD EFI/HPT tuned stock pcm FI car.
  77. just got my twin turbo car back together after coating
  78. A fully built turbo charged 3.8L camaro? (video)
  79. hey guys this is a lesson i leared along time ago!!
  80. Building a sequential turbo system
  81. oil drain into oil pan right underneath timing cover
  82. Attn: Paging All Turbo Sponsors!!!
  83. turbo power numbers?
  84. F1r Procharger F/s
  85. STS/ Formula owners ??
  86. help me decide On which on these blower cams
  87. Tr6 gap?
  88. F1-C is here...
  89. STS/A4 owners come in please
  90. 9 psi and stock LT1 ignition?
  91. Vacuum lines and gauge install Help to Newbs
  92. Anyone used a Holset HX40 turbo?
  93. significant increase in boost...why?...how?
  94. not sure on how to ask this ?
  95. Anyone ever regret going with a procharger?
  96. Who can make me an intake elbow?
  97. procharger inlet hat q
  98. Devil's Own Meth Kit?
  99. Turbo Brakestand bog
  100. Cobalt SS MAP sensor?
  101. vortech v9g
  102. PROCHARGER Questions,
  103. Jose Dr Turbo Frcefed98....Turbosmart help!
  104. D1SC owners, how much boost are you getting?
  105. Input on Weiand
  106. Sts kit
  107. Superchargers vs. Turbochargers
  108. Screw the Twins...i want QUADS!!!!!
  109. Will this cam WORK with a turbo car?
  110. finally turned to the darkside
  111. GT42 or TC76
  112. hot side question
  113. WG Flange
  114. Budget turbo kit... Who has em?
  115. Would forced induction systems fit LS2 F-body cars fine?
  116. So who makes complete turbo systems for LS1 F-body cars?
  117. split or single pattern cam?
  118. Which would you think would bettter be suited for long-term use?
  119. just a little ask
  120. Something better than any Turbo
  121. Going FI what do I need to change ?
  122. Twincharging
  123. STS oil pump resistor failed!!!!
  124. Procharger 346ci, +58rwhp/+63rwtq with new Inlet Hat,Exhaust,+1deg timing
  125. Boost gauge stuck?
  126. ls6 intake HOW MUCH......
  127. Cooling system advice (fans?)
  128. 402 PT88 build
  129. anyone have before and after cam swap dyno charts for fi motor?
  130. Vortech self containment?
  131. Which rockers
  132. turbonetics t76 vs gt42
  133. Hypothetical turbo question
  134. 6.0 Boost Capibilities
  135. Superman09's Twin Turbo Build Thread (Turbo-Zone Twin Kit)
  136. Went and did the dyno thing...
  137. HELP! Did I mess up? power adder vs. NA
  138. truck manifold kit... please help
  139. 4" elbow and K&N
  140. sts turbo install
  141. Powerdyne install
  142. Highest CR for low boost?
  143. finally got the F1A on..
  144. Lower Compression= Safer??
  145. intercooler position?
  146. Is a supercharger without headers worth it?
  147. Biggest turbo/turbos for C5
  148. Need the best FI cam I can get
  149. Check out this intercooler. Perfect size for Camaro grill opening
  150. Innovative Mounting
  151. tried the .96 housing on my car, some interesting results
  152. Has anyone ever used this turbo kit?
  153. sts wont boost
  154. Guess HP
  155. LS2 vs L92/LS3(07 Cady Escalade) GM longblock for my turbo project. Expert opinions?
  156. Where to put the turbo...any ideas?
  157. Got car back from LS1SpeedInc...
  158. Thoughts on this combo...
  159. ct26 turbos ??? anyone???
  160. Break in the new motor?
  161. 6.0l heads
  162. fastest stock bottom end turbo or supercharged cars?post your times!
  163. 98 block safe for boost
  164. Exhaust question for the FI guys
  165. NHRA Pro Mod rules regarding turbochargers
  166. PT88 Nossle kit, 408, more pics of the camaro
  167. Mandrel Bent Piping for FMIC...is it really that important???
  168. Mufflers
  169. Anyone thought to extrude hone a 6.0l manifold?
  170. Help with crank pining
  171. Magnacharged F-body track videos inside
  172. Anyone ever tried one of these for a cog setup?
  173. Winter Mods (cam, meth, heads) HELP NEEDED
  174. Turbo guys: Tell me about your timing and CR
  175. Lt1 Sts 383 preliminary dyno numbers
  176. 122 ci Magnacharger ???
  177. Headgaskets
  178. STS Turbo/Daily Driver/Low Boost, is it worth it?
  179. APS GTO Phase 2 twin turbo system - one time deal - $5695 delivered to your door
  180. Spark plug?
  181. P1SC build with stock exhaust
  182. 07 C6 with D1SC Video!
  183. Hardline vs braided stainless pros and cons
  184. oil drain question
  185. How much boost on forged 10:1 compression motor?
  186. How many 1000 hp dreamers have had over 500 rwhp?
  187. Too much compression?
  188. will a Procharger LT1 set up work on a LS1 car?
  189. another is this a good turbo cam thread?
  190. M6=more fun than auto?
  191. mixing turbo parts???
  192. Changing Main Serpentine Belt w/ Procharger Set up
  193. sts installation booklet
  194. Ring gapping questions
  195. twin turbo outboard boat engine
  196. twin turbos + nos pics.
  197. need timing help ASAP!!
  198. STS Owners - What did you do with your IAT Sensor
  199. What is the limit of boost 02 35th LS-1
  200. spark plugs and FI
  201. New Site
  202. turbo questions
  203. OFI single LT1 dyno numbers
  204. exhaust
  205. Looking For Inside Mounted Air To Water Intercooler Pics
  206. sts return oil pump
  207. STS Mufflers III!
  208. Downpipe. to step, or not to step
  209. Info or pics on Turbo Zone Kit.
  210. Best Procharger for Street Setup?
  211. My 402 D1 vs Stock bottom #s
  212. SuperCharged Ls1- Question
  213. will this cam work with a blower?
  214. PTK owners with the NEW alt arrangement
  215. Looking for that T unit for brake booster to hook up turbo stuff...
  216. D1 402 numbers
  217. Ideas for bumper cover support on 98+ TA?
  218. Procharged guys...
  219. So Masterpower sucks right? Now what? I need a turbo.
  220. Guys With 6.0 Iron Blocks Come In
  221. Leak Down Test?
  222. charger vs turbo?
  223. Buying a D-1 from EPP
  224. Oil drain setup.
  225. Has anyone put together a complete DIY turbo guide?
  226. Exhaust temps STS
  227. Back pressure... help an ignorant fool here please.
  228. 2006 C6 Z06 Twin Turbo with Pictures and Dyno Graphs
  229. 88 single on 346, spooling questions
  230. some loose ends for my Hiflo install, need help
  231. Took a Sunday Cruise in my 8 sec IRS C5 Corvette Street Car [VIDEO]
  232. few pics of my system
  233. Top ring to use for forced induction?
  234. Twin Turbo Dyno Video
  235. leaky exhaust for sts
  236. Eboost2
  237. Need help with this SDCE pulley.
  238. TT Viper 7.98@183
  239. New valve springs with Turbo Setup?
  240. oil drain and feed fittings
  241. Got a TSB today (STS owners read)
  242. what size housings for a tt 427?
  243. 2 ques. on turbo
  244. how are you routing all your wires for gauges
  245. TTI car in classifieds
  246. for turbo apps why carb style intakes
  247. d1sc prochargers
  248. you guys that are looking for hoses and NPT fittings
  249. meth
  250. Turbo knowledge
