PDA
View Full Version : Forced Induction
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 [62] 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230
  1. Cast turbo manifolds
  2. What's 1 7/8 headers worth over 1 3/4 on a procharged car making 15psi?
  3. boost & nitrous timing?
  4. Smartfire injectors
  5. Header/log manifold build
  6. Best spot for the O2 sensors in my crossover?
  7. Turbo LS engine builders in the Southeast?
  8. Ls1 with aviaid 3 stage pump lower left
  9. Slow Ride's twin turbo vette build
  10. Which turbo would be better for my 390?
  11. high hp stock short block guys... question
  12. Trans Am 88mm Turbo Build
  13. Motor mounts
  14. 39x ish with twin turbos
  15. My Procharged truck made it in Truckin' Magazine this month
  16. Need help picking a motor for my TVS1900
  17. Pros and cons on TT vs ST?
  18. Truck manifold gaskets
  19. Need help with Cam selection
  20. the Mighty LS6 cam.post your combos
  21. 2012 ProCharger Rebate 3 Days Left
  22. plugs after 2000 miles tell me what you think.
  23. Fuel feed line size
  24. Paint, powdercoat or anodize my IC
  25. Anyone run the K1 Billet Rods?
  26. 2k turbo project
  27. 1025rwhp f1r tbss!!!
  28. 5.3l turbo build
  29. WG not hooked to boost reference?
  30. 1118 RWHP Twin Turbo CTS-V
  31. Who makes baller drag spoilers?
  32. Best block for forced induction ?
  33. Ebay Turbo build?????
  34. How many of you guys run your oil feed off the oil pressure sender?
  35. project 1951 chevy fleetline ls1 (aka BOOSTLINE)
  36. Need some rear mount help.
  37. Turbo cam gurus please answer
  38. Sleeper......or Custom?
  39. Who all is running a carb setup?
  40. Heard the vic jr does not like rectangle ports....?
  41. Maggie Cog Drive Video
  42. Keeping A/C in new turbo build.
  43. What size Ebay intercooler and piping to get???
  44. DIRT CHEAP: LQ4 Turbo carb yadda yadda Need advice!!!!
  45. ls1 magnacharger to fit l99
  46. FrozenBoost??
  47. Ebay Turbo Kits???
  48. increase power but not boost?
  49. Lq4 +F1r
  50. 6spd FI guys and no lift shifting (lingenfelter lnc-003)
  51. HS turbo kit with alternator relocation???
  52. Merry christmas fi people
  53. Anybody have procharger pullies?
  54. Boosted 5.3
  55. Head/Intake question w/boost
  56. no intercooler
  57. 69 Firebird LS2 Twin Turbo HELP!!
  58. Which is better turbo build, LQ4 or 5.3. Need pros and cons.
  59. Guys I need some help
  60. Perfect gears for turbo M6 setup
  61. Who Is Running a GT91?
  62. Crank Question
  63. NYC Tri State area
  64. turbo sizing definition!!
  65. Pro Flo XT...install help needed.
  66. Need help identifying a turbo kit???
  67. stock truck cam?
  68. Second cable attached to throttle?
  69. Looking for wrapped truck manifold pics
  70. Opinion on "refresh" of a stock 5.3
  71. 11.5 compression and boost-why not!
  72. Help! Will my current cam work with a supercharger?
  73. s475 on untouch ls1, what to expect with 9psi
  74. STS turbo build soon!!
  75. STS Kit Build????
  76. TT + 390ci..........which turbos....Modular Turbo CBR F2....
  77. Procharged LSX mustang
  78. Turbo cooling question.
  79. Wishing You a Supercharged Holiday Season
  80. Boost and rwhp
  81. Crazy turbo setup idea need help
  82. 02 Ws6 trans am with a junkyard diesel turbo? sure why not
  83. My new sleeper!
  84. Undersizing or Oversizing Your Turbo: An "Honest" Discussion.
  85. tech question
  86. is it to big
  87. FI guys at or near the 1000rwhp mark, what flexplate are you using?
  88. 400+ ci LS9 blower speed?
  89. Twin Turbo cam
  90. The power (Literally) of ignition timing
  91. Worth the build?
  92. crankcase vent for cam /D1sc
  93. 5.3 twin turbo
  94. LS1 243 heads and pro charger build?
  95. keep blowing headgaskets/ cam too small ?
  96. 67 Nova SS. Pro Touring. LS + Twin 72's. 1000rwhp plz.
  97. how much boost are you pushing your stock bottom end iron block?
  98. discussion about overlap in a turbo cam
  99. T56 Rearmount GTO Cam
  100. Anyone run a big cam with turbo?
  101. need help with ls1 turbo combo!
  102. Heintz Racing resets IRS GTO Record @ 8.74! Plus a few other great runs.
  103. NXS Spring Loaded Manual Boost Controller Question
  104. Need some opinions
  105. V2
  106. AES Announces Our First Year End Sale!!!!
  107. 02 Turbo Camaro Exhaust Question
  108. Wanted: Twin intercooler and Procharger
  109. How many still have A/C?
  110. Does unequal exhaust pipes matter?
  111. Catch can with return style BOV Question.
  112. Procharged G8
  113. Thinking about completely changing the direction of my car, advise?
  114. 370 BW s480 e85 non intercooled build
  115. How much boost and hp will a stock bock, forged internals LS2 handle?
  116. Boosted 5.3 guys drop in.
  117. making LSX happen everywhere
  118. TC78 + 390ci..........will it make 900 RWHP....?
  119. New best 78 Turbo Trans Am, cam only 5.3 rear mount Turbo 10.22@140.98
  120. good idea or bad- twin turbo oiling
  121. TC78 BMW build
  122. ebay hot parts kit
  123. I did some LSA head testing!
  124. Where can you find official rules on the stock shortblock record?
  125. Changes for 2013
  126. How much HP can a stock ls2 handle?
  127. Where to place wideband sensor on twin turbo
  128. do I need to run a thermostat?
  129. What size intercooler on 71 chevelle Single t76 turbo??
  130. Head studs ?
  131. 68 camaro 5.3 single turbo swap, what manifolds?
  132. 408, S488 turbo build feedback
  133. 69 Camaro twin turbo build - Loads of pics
  134. T78 + 4L80e + e85 + stock cooling system and AC round 2 **dyno vid pg 3**
  135. Road Racing twin turbo 5.3 cam and turbo selection...
  136. New Project... need advice, opinions and help
  137. Flipped C6 Manifold for Driver Side???
  138. Huron Speed *Special Edition* Truck Manifold Turbo Kit end of 2012 Special!
  139. bv57 and ysi settings
  140. building turbo headers /log
  141. Using meth to compensate for more boost on current tune?
  142. First Gen Manifolds
  143. New BAD ASS Turbo kmember ( DKT/BMR )
  144. LT1 Turbo Tuner in / near NC ???
  145. best short block?
  146. 408, GT55-94, E85, Glide, Truck manifold build thread -- UPDATE 06-29
  147. burkhart chassis-Thanks
  148. LS9 cam ?s
  149. LS6 intake how much boost
  150. First turbo build
  151. Edelbrock Vic Jr VS. Edelbrock Pro Flo XT
  152. Boost creep issues please help!!
  153. AMS-1000 Boost Controller
  154. 626hp 800+Tq!!
  155. AES 390 users, how do you like it?
  156. Twin turbo LS1 heads question
  157. Oil for fi
  158. flywheel choice
  159. What fans for procharger?
  160. need help to make my part list
  161. S475 Billet wheel
  162. Will it make 1000 RWHP??
  163. GN TB0348 Turbos?
  164. Check out my sweet new turbo merge
  165. FREE Installation & Tuning of Prochargers
  166. VNT turbos?
  167. Help!!!Info needed...TURBO LS1 CHEVELLE BUILD
  168. Sell me your turbo Camaro or Trans Am
  169. Something went wrong, ticking and smoke...
  170. what size turbo /injectors/tb/regulator
  171. Homemade Turbo Build fuel problem :( (video up)
  172. Any 4th Gen Maggies still out there?
  173. APS parts?
  174. LSX 427...is this power a little low?
  175. quick question: procharger pulley jack screw
  176. Lifters for stock turbo?
  177. Stock 4.8 & t76 What cam???
  178. FAST 78mm Throttle Body Question
  179. Arp head stud question
  180. Going to a new setup! 408, and 91mm
  181. ~Procharged ls1 f-body 1/4 mile times~
  182. stock 6.0L 8.81@161
  183. stainless turbo tubing and bends etc.
  184. Turbonetics 6665 Twin Turbo build, Fab process started Post #71! finally!
  185. MSD Timing Twister users. Please come in!
  186. MS1 and Micro2 tune, downloads.
  187. Need help on some steel cable ties please.
  188. Help on used motor?
  189. need your advices please
  190. What muffler(s) maintains TURBINE whistle?
  191. Quick help! ATI SuperDamper removal.
  192. 5th gen twin turbo build
  193. Head selection advice
  194. Recommended gear ratio? (FI related)
  195. TC78 9.05 at 150
  196. what size turbo?
  197. Dyno numbers stock bottom end, D1 procharger
  198. Truck manifold hot side
  199. stock manifold pictures?
  200. Procharger pulley for 6-8 lbs of boost?
  201. Howards Turbo cams?
  202. inlet pipe size?
  203. EMSpro testing for EFI source (even more MS stuff)
  204. big boost with wiseco pistons
  205. Christmas special on Whipple Superchargers
  206. Made it into new GMHTP
  207. Procharger Rebuild
  208. Our Shop Car 427/88mm setup
  209. On 3 Performance Introduction, New Turbo System Details, And Photos
  210. Turbo Support/Braces
  211. 91 S-10 Front Mount 5.3 L33/GT45/TH350/ Holley HP EFI update 3/10/13
  212. 5.3L Big Single vs. Twin 76mm
  213. spraying a boosted lt1
  214. Wastegate dump into exhaust or air
  215. Bearings for Turbo 383 Motor
  216. anyone running power steering with a front motor plate
  217. First Turbo LS
  218. turbo question
  219. Guys with transbrake's and lingenfelter 2 step got some ???
  220. My car on dragzine!!
  221. Who makes the part?
  222. 4.8+ GT45 on notchback
  223. BW s366 oil feed
  224. How bad will the tourqer v 3 be with a turbo?
  225. have the casting issues been fixed on the rectangle port hi rams?
  226. ~Procharger budget build~
  227. GT45 vs 6CTAA
  228. Critique my Turbo Setup
  229. Slipage, belt wrap vs tension???
  230. Gauging Interest: Custom Build per Order Kits
  231. can i boost an lq motor with 11:1 compression
  232. Attention all KY-Turbo Customers, Supporters, and Friends:
  233. Twin turbo system supports 1200 hp
  234. Proper BOV spring?
  235. ?? water intercooler pump switch ??
  236. Lets see some s/c pics
  237. Holley Intake question
  238. Procharger questions
  239. 85 c10 5.3 turbo build
  240. new to FI
  241. c6 manifold turbo set up
  242. T70 (on3) questions
  243. finally hit the dyno
  244. 12an fitting on timing cover
  245. How do you build boost off the line with an m6?
  246. stock 5.3 goes 8.89 @ 157
  247. 383 S488 Build
  248. Input needed for torque converter
  249. 65 Mustang build thread- 404,Twins,Caged,Tubbed,ETC. UPDATE 10/9
  250. C6 manifold turbo build pics
